--- 产品详情 ---
Output options | Adjustable Output, Negative Output |
Iout (Max) (A) | 0.2 |
Vin (Max) (V) | -3 |
Vin (Min) (V) | -20 |
Vout (Max) (V) | -1.2 |
Vout (Min) (V) | -18 |
Noise (uVrms) | 80 |
Iq (Typ) (mA) | 0.05 |
Thermal resistance θJA (°C/W) | 63 |
Rating | Catalog |
Load capacitance (Min) (μF) | 2.2 |
Regulated outputs (#) | 1 |
Features | Enable |
Accuracy (%) | 2.5 |
PSRR @ 100 KHz (dB) | 31 |
Dropout voltage (Vdo) (Typ) (mV) | 216 |
Operating temperature range (C) | -40 to 125 |
- Input Voltage Range: –3 V to –20 V
- Noise:
- 80 μVRMS (10 Hz to 100 kHz)
- Power-Supply Ripple Rejection:
- 50 dB (1 kHz)
- ≥ 27 dB (10 Hz to 1 MHz)
- Adjustable Output:
Approximately –1.18 V to –18 V - Maximum Output Current: 200 mA
- Dropout Voltage: 500 mV at 100 mA
- Stable With Ceramic Capacitors ≥ 2.2 μF
- CMOS Logic-Level-Compatible Enable Pin
- Built-In, Fixed, Current Limit, and Thermal
Shutdown Protection - Available in High Thermal Performance MSOP-8
PowerPAD? Package - Operating Temperature Range: –40°C to 125°C
The TPS7A3401 device is a negative, high-voltage (?20-V), low-noise linear regulator capable of sourcing a maximum load of 200 mA.
These linear regulators include a CMOS logic-level-compatible enable pin. Other features available include built-in current limit and thermal shutdown protection to safeguard the device and system during fault conditions.
The TPS7A3401 is designed using bipolar technology, and is ideal for instrumentation applications where clean voltage rails are critical for improving system performance. This design makes it a cost-effective choice to power operational amplifiers, analog-to-digital converters (ADCs), digital-to-analog converters (DACs), and other analog circuitry.
In addition, the TPS7A3401 linear regulator is suitable for cost-effective, post DC-DC converter regulation. By filtering out the output voltage ripple inherent to DC-DC switching conversion, increased system performance is provided in instrumentation applications.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
