--- 产品详情 ---
1.5A、低 IQ、负电压可调节线性稳压器
Output options | Adjustable Output, Negative Output |
Iout (Max) (A) | 1.5 |
Vin (Max) (V) | -3 |
Vin (Min) (V) | -40 |
Vout (Max) (V) | -1.2 |
Vout (Min) (V) | -37 |
Noise (uVrms) | 1110 |
Iq (Typ) (mA) | 0.065 |
Thermal resistance θJA (°C/W) | 23 |
Rating | Catalog |
Load capacitance (Min) (μF) | 1 |
Regulated outputs (#) | 1 |
Accuracy (%) | 4 |
PSRR @ 100 KHz (dB) | 19 |
Dropout voltage (Vdo) (Typ) (mV) | 2000 |
Operating temperature range (C) | -25 to 150 |
- Output Voltage Range Adjustable
From –1.2Vto–37V - Output Current Capability of 1.5AMax
- Input Regulation Typically 0.01% Per Input-
Voltage Change - Output Regulation Typically 0.3%
- Peak Output Current Constant Over Temperature
Range of Regulator - Ripple Rejection Typically 77 dB
- Direct Replacement for Industry-Standard LM237
and LM337
The LM237 and LM337 are adjustable 3-terminal negative-voltage regulators capable of supplying in excess of –1.5 A over an output voltage range of –1.2 V to –37 V. They require only two external resistors to set the output voltage and one output capacitor for frequency compensation.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
