--- 产品详情 ---
Output options | Dual Output, Fixed Output |
Vin (Max) (V) | 36 |
Vin (Min) (V) | 5 |
Vout (Max) (V) | 35 |
Vout (Min) (V) | 2 |
Fixed output options (V) | -2, 1.5 |
Iq (Typ) (mA) | 5.5 |
Thermal resistance θJA (°C/W) | 65 |
Rating | Catalog |
Regulated outputs (#) | 2 |
Accuracy (%) | 2 |
Dropout voltage (Vdo) (Typ) (mV) | 500 |
Operating temperature range (C) | 0 to 70 |
- Minimum VIN - VOUT Less Than 0.5V At 5A Load With External Pass Device
- Equally Usable For Either Positive or Negative Regulator Design
- Adjustable Low Threshold Current Sense Amplifier
- Under And Over-Voltage Fault Alert With Programmable Delay
- Over-Voltage Fault Latch With 100mA Crowbar Drive Output
The UC1834 family of integrated circuits is optimized for the design of low input-output differential linear regulators. A high gain amplifier and 200mA sink or source drive outputs facilitate high output current designs which use an external pass device. With both positive and negative precision references, either polarity of regulator can be implemented. A current sense amplifier with a low, adjustable, threshold can be used to sense and limit currents in either the positive or negative supply lines.
In addition, this series of parts has a fault monitoring circuit which senses both under and over-voltage fault conditions. After a user defined delay for transient rejection, this circuitry provides a fault alert output for either fault condition. In the over-voltage case, a 100mA crowbar output is activated. An over-voltage latch will maintain the crowbar output and can be used to shutdown the driver outputs. System control to the device can be accommodated at a single input which will act as both a supply reset and remote shutdown terminal. These die are protected against excessive power dissipation by an internal thermal shutdown function.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
