--- 产品详情 ---
Drivers per package | 1 |
Switching voltage (Max) (V) | 32 |
Output voltage (Max) (V) | 32 |
Peak output current (mA) | 1200 |
Delay time (Typ) (ns) | 2200 |
Input compatibility | CMOS, TTL |
Vol @ lowest spec current (Typ) (mV) | 50 |
Iout/ch (Max) (mA) | 1200 |
Iout_off (Typ) (uA) | 1 |
Rating | Catalog |
- HIGH OUTPUT DRIVE: 1.2A
- WIDE SUPPLY RANGE: +8V to +32V
- COMPLETE FUNCTION:
- PWM Output
- Adjustable Internal Oscillator: 500Hz to 100kHz
- Digitally Controlled Input
- Adjustable Delay and Duty Cycle
- Over-Current Indicator Flag
- FULLY PROTECTED:
- Thermal Shutdown with Indicator Flag
- Internal Current Limit
- PACKAGE: HTSSOP-14 Surface-Mount PowerPAD?
- APPLICATIONS
- ELECTROMECHANICAL DRIVERS:
- Solenoids, Valves, Positioners, Actuators, Relays, Power Contactor Coils, Heaters, and Lamps
- FLUID AND GAS FLOW SYSTEMS
- FACTORY AUTOMATION
- PART HANDLERS AND SORTERS
- PHOTOGRAPHIC PROCESSING
- ENVIRONMENTAL MONITORING AND HVAC
- THERMOELECTRIC COOLERS
- MOTOR SPEED CONTROLS
- SOLENOID PROTECTORS
- MEDICAL ANALYZERS
PowerPAD is a trademark of Texas Instruments.
All other trademarks are the property of their respective owners.
The DRV104 is a DMOS, high-side power switch employing a pulse-width modulated (PWM) output. Its rugged design is optimized for driving electromechanical devices such as valves, solenoids, relays, actuators, and positioners. It is also ideal for driving thermal devices such as heaters, coolers, and lamps. PWM operation conserves power and reduces heat rise, resulting in higher reliability. In addition, adjustable PWM allows fine control of the power delivered to the load. Time from dc-to-PWM output and oscillator frequency are externally adjustable.
Separate supply pins for the circuit and driver transistor allow the output to operate on a different supply than the rest of the circuit.
The DRV104 can be set to provide a strong initial solenoid closure, automatically switching to a soft hold mode for power savings. The duty cycle can be controlled by a resistor, analog voltage, or a digital-to-analog (D/A) converter for versatility. The Status OK Flag pin indicates when thermal shutdown or over-current occurs.
The DRV104 is specified for ?40°C to +85°C at its case. The exposed lead frame must be soldered to the circuit board.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
