--- 产品详情 ---
Number of supplies monitored | 1 |
Threshold voltage 1 (Typ) (V) | 1.2, 2.2, 3.0, 3.1, 3.2, 3.6, 4.0 |
Features | Manual reset capable, Reset time delay |
Reset threshold accuracy (%) | 1 |
Output driver type/reset output | Active-low, Open-drain |
Time delay (ms) | Programmable |
TI functional safety category | Functional Safety-Capable |
Rating | Automotive |
Watchdog timer WDI (sec) | None |
Operating temperature range (C) | -40 to 125 |
Qualified for automotive applications:
- AEC-Q100 qualified with the following results:
- Device temperature grade 1: –40°C to +125°C ambient operating temperature
- Device HBM ESD classification level 2
- Device CDM ESD classification level C7B
Designed for high performance:
- Nano supply current : 120 nA (Typ)
- High accuracy: ±0.5% (Typ)
- Built-in hysteresis (VHYS): 5% (Typ)
- Fixed threshold voltage (VIT-): 0.8 V to 5.4 V
Designed for a wide range of applications:
- Operating voltage range : 0.7 V to 6 V
- Fixed (VIT-) voltage: 0.8 V to 5.4 V in 0.1 V steps
- Programmable reset time delay (tD)
- Min time delay: 40 μs (typ) without capacitor
- Active-low manual reset (MR)
Multiple output topologies / Package type:
- Four output topologies (RESET / RESET):
- TLV840MADL-Q1: open-drain, active-low
- TLV840MAPL-Q1: push-pull, active-low
- TLV840MADH-Q1: open-drain, active-high
- TLV840MAPH-Q1: push-pull, active-high
- Package: SOT23-5 (DBV)
The TLV840-Q1 device is a voltage supervisor or reset IC that can operate at wide input voltage levels from 0.7 V to 6 V while maintaining very low quiescent current across the whole VDD and temperature range. TLV840-Q1 offers the best combination of low power consumption, high accuracy and low propagation delay (tp_HL= 30 μs typical).
Reset output signal is asserted when the voltage at VDD drops below the negative voltage threshold (VIT-). Reset signal is cleared when VDD rise above VIT- plus hysteresis (VHYS) and the reset time delay (tD) expires. Reset time delay can be programmed by connecting a capacitor between the CT pin and ground. For a minimum reset delay time the CT pin can be left floating. The TLV840-Q1, with its manual reset pin (MR), offers program flexibility by forcing the system into a hard reset when the pin is asserted.
Additional features: Low power-on reset voltage (VPOR), built-in glitch immunity protection for VDD, built-in hysteresis, low open-drain output leakage current (Ilkg(OD)). TLV840-Q1 is a perfect voltage monitoring solution for automotive applications and battery-powered / low-power applications.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
