--- 产品详情 ---
Local sensor accuracy (Max) (+/- C) | 1 |
Type | Local |
Operating temperature range (C) | -40 to 200 |
Supply voltage (Min) (V) | 3 |
Interface type | SPI |
Supply voltage (Max) (V) | 5.5 |
Supply current (Max) (uA) | 456 |
Temp resolution (Max) (bits) | 16 |
Features | ALERT, One-shot conversion |
Remote channels (#) | 0 |
Rating | Catalog |
- LM95172EWG is AEC-Q100 Grade 0 Qualified and is Manufactured on an Automotive Grade Flow.
- 13-Bit (0.0625°C LSB) to 16-Bit (0.0078125°C LSB) Temperature Resolution
- Wide ?40°C to +200°C Temperature Range
- 35 ms Best Conversion Time Tracks Fast Temp Changes
- OVERTEMP Digital Output Switches
when TDIE > THIGH - Shutdown Mode Saves Power yet Wakes up for One-Shot Temperature Update
- SPI and MICROWIRE Bus Interface
- 10-Pin Cerpack High-Temperature Ceramic Package
Key Specifications
- Analog and Digital Supply Voltage 3.0V to 5.5V
- Total Supply Current ????Operating 400 μA (typ)
- Shutdown??40°C to +140°C 4 μA (max)
- Shutdown??40°C to +175°C 12 μA (max)
- Shutdown??40°C to +200°C 28 μA (max)
- Temperature Accuracy
- +175°C to +200°C ±3.0°C (max)
- +130°C to +160°C ±1.0°C (max)
- +120°C to +130°C ±2.0°C (max)
- +160°C to +175°C ±2.0°C (max)
- ?40°C to +120°C ±3.5°C (max)
- Temperature Resolution
- 13-bit mode 0.0625°C/LSB
- 16-bit mode 0.0078125°C/LSB
- Conversion Time
- 13-bit mode 43 ms (max)
- 16-bit mode 350 ms (max)
All trademarks are the property of their respective owners.
The LM95172EWG is an integrated digital-output temperature sensor with a Serial Peripheral Interface (SPI) and MICROWIRE?-compatible interface in a 10-pin Cerpack high temperature ceramic package. It features a very linear Sigma-Delta Analog-to-Digital Converter (ADC), high accuracy, fast conversion rates, and extremely low output noise. With an operating temperature as low as -40°C and optimized accuracy from 120°C to 200°C, it is ideal for high-temperature applications.
The over-temperature alarm output (OVERTEMP) asserts when the die temperature exceeds a programmed THIGH limit. The user-programmed TLOW limit creates a temperature-stabilizing hysteresis when the ambient temperature is near the trip point.
The LM95172EWG can be programmed to operate from 13 bits (0.0625°C per LSB) to 16 bits (0.0078125°C per LSB) resolution. The LM95172EWG powers up in 35 ms, the fastest conversion time, with temperature output set at 13-bit resolution. The resolution may then be changed to 14-, 15- or 16-bits. When in the 13-, 14- or 15-bit resolution mode, the least significant bit in the 16-bit temperature register toggles after the completion of each conversion. This bit may be monitored to verify that the conversion is complete.
The high noise immunity of the Serial I/O (SI/O) output makes the LM95172EWG ideal for use in challenging electromagnetic environments.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
