--- 产品详情 ---
Local sensor accuracy (Max) (+/- C) | 2 |
Type | Local |
Operating temperature range (C) | -20 to 125 |
Supply voltage (Min) (V) | 3 |
Interface type | 1-wire Sensor Path |
Supply voltage (Max) (V) | 3.6 |
Supply current (Max) (uA) | 750 |
Temp resolution (Max) (bits) | 10 |
Remote channels (#) | 0 |
Addresses | 4 |
Rating | Catalog |
- SensorPath Bus
- 4 Hardware Programmable Addresses
- Temperature Sensing
- 0.25 °C Resolution
- 127.75 °C Maximum Temperature Reading
- 8-Lead VSSOP Package
Key Specifications
- Temperature Sensor Accuracy ±2°C (max)
- Temperature Range ?20 to +125°C
- Power Supply Voltage +3.0 to +3.6 V
- Power Supply Current 0.5 mA (typ)
- Conversion Time 14 to 1456 ms
All trademarks are the property of their respective owners.
The LM95010 is a digital output temperature sensor that has single-wire interface compatible with the SensorPath interface. It uses a ΔVbe analog temperature sensing technique that generates a differential voltage that is proportional to temperature. This voltage is digitized using a Sigma-Delta analog-to-digital converter. The LM95010 is part of a hardware monitor system, comprised of two parts: the PC System Health Controller (Master), such as a Super I/O, and up to seven slaves of which four can be LM95010s. Using SensorPath, the LM95010 will be controlled by the master and report to the master its own die temperature. SensorPath data is pulse width encoded, thereby allowing the LM95010 to be easily connected to many general purpose micro-controllers.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
