--- 产品详情 ---
Local sensor accuracy (Max) (+/- C) | 2.5 |
Operating temperature range (C) | -55 to 130 |
Supply voltage (Min) (V) | 2.4 |
Supply voltage (Max) (V) | 5.5 |
Supply current (Max) (uA) | 7 |
Interface type | Analog output |
Sensor gain (mV/Deg C) | -11.77 |
Rating | Catalog |
Features | UL recognized |
- Rated for Full ?55°C to +130°C Range
- Available in a TO-92 Package
- Predictable Curvature Error
- Suitable for Remote Applications
- UL Recognized Component
Key Specifications
- Accuracy at +30°C ±2.5 °C (max)
- Accuracy at +130°C & ?55°C ±3.5 to ±3.8 °C (max)
- Power Supply Voltage Range +2.4V to +5.5V
- Current Drain 10 μA (max)
- Nonlinearity ±0.4 % (typ)
- Output Impedance 160 Ω (max)
- Load Regulation
- 0μA < IL< +16 μA
All trademarks are the property of their respective owners.
The LM19 is a precision analog output CMOS integrated-circuit temperature sensor that operates over a ?55°C to +130°C temperature range. The power supply operating range is +2.4 V to +5.5 V. The transfer function of LM19 is predominately linear, yet has a slight predictable parabolic curvature. The accuracy of the LM19 when specified to a parabolic transfer function is ±2.5°C at an ambient temperature of +30°C. The temperature error increases linearly and reaches a maximum of ±3.8°C at the temperature range extremes. The temperature range is affected by the power supply voltage. At a power supply voltage of 2.7 V to 5.5 V the temperature range extremes are +130°C and ?55°C. Decreasing the power supply voltage to 2.4 V changes the negative extreme to ?30°C, while the positive remains at +130°C.
The LM19's quiescent current is less than 10μA. Therefore, self-heating is less than 0.02°C in still air. Shutdown capability for the LM19 is intrinsic because its inherent low power consumption allows it to be powered directly from the output of many logic gates or does not necessitate shutdown at all.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
