--- 产品详情 ---
具有 1.8V 输入逻辑的 0.9Ω、3.3V、1:1 (SPST)、2 通道模拟开关(2 个高电平有效)
Configuration | 1:1 SPST |
Number of channels (#) | 2 |
Power supply voltage - single (V) | 1.8, 2.5, 3.3 |
Protocols | Analog |
Ron (Typ) (Ohms) | 0.7 |
CON (Typ) (pF) | 43 |
ON-state leakage current (Max) (μA) | 0.005 |
Bandwidth (MHz) | 125 |
Operating temperature range (C) | -40 to 85 |
Features | 1.8-V compatible control inputs |
Input/output continuous current (Max) (mA) | 100 |
Rating | Catalog |
- Low ON-State Resistance (Ron)
- 0.9-Ω Max (3-V Supply)
- 1.5-Ω Max (1.8-V Supply)
- 0.4-Ω Max Ron Flatness (3-V Supply)
- 1.6-V to 3.6-V Single-Supply Operation
- Available in SOT-23 and VSSOP Packages
- High Current-Handling Capacity (100 mA
Continuous) - 1.8-V CMOS Logic Compatible (3-V Supply)
- Fast Switching: tON = 14 ns, tOFF = 9 ns
The TS3A4741 and TS3A4742 are bi-directional, 2-channel single-pole/single-throw (SPST) analog switches with low ON-state resistance (Ron), low-voltage, that operate from a single 1.6-V to 3.6-V supply. These devices have fast switching speeds, handle rail-to-rail analog signals, and consume very low quiescent power.
The digital logic input is 1.8-V CMOS compatible when using a single 3-V supply.
The TS3A4741 has two normally open (NO) switches, and the TS3A4742 has two normally closed (NC) switches.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
