--- 产品详情 ---
2.5V、1:1 (SPST)、单通道模拟开关
Configuration | 1:1 SPST |
Number of channels (#) | 1 |
Power supply voltage - single (V) | 0.8, 1.2, 1.8, 2.5 |
Protocols | Analog |
Ron (Typ) (Ohms) | 10 |
CON (Typ) (pF) | 7 |
ON-state leakage current (Max) (μA) | 1 |
Bandwidth (MHz) | 500 |
Operating temperature range (C) | -40 to 85 |
Input/output continuous current (Max) (mA) | 50 |
Rating | Catalog |
- Available in the Texas Instruments NanoFree? Package
- Wide VCC Range of 0.8 V to 2.7 V
- Sub-1-V Operable
- Low Power Consumption, 10-μA Max ICC
- High On-Off Output Voltage Ratio
- High Degree of Linearity
- High Speed – Max 0.2 ns
(VCC = 1.8 V, CL = 15 pF) - Low On-State Impedance – Typically 9
(VCC = 2.3 V) - Latch-Up Performance Exceeds 100 mA Per
JESD 78, Class II - ESD Protection Exceeds JESD 22
- 2000-V Human-Body Model (A114-A)
- 200-V Machine Model (A115-A)
- 1000-V Charged-Device Model (C101)
NanoFree Is a trademark of Texas Instruments.
This single analog switch is operational at 0.8-V to 2.7-V VCC, but is designed specifically for 1.65-V to 1.95-V VCC operation.
The SN74AUC1G66 can handle both analog and digital signals. The combined AC and DC signal has to be between VCC and GND for it to be transmitted in either direction.
NanoFree? package technology is a major breakthrough in IC packaging concepts, using the die as the package.
Applications include signal gating, chopping, modulation or demodulation (modem), and signal multiplexing for analog-to-digital and digital-to-analog conversion systems.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
