--- 产品参数 ---
- 玻璃强效放电管 WSP-141N
--- 数据手册 ---
--- 产品详情 ---
PART NUMBER SYSTEM : | WSA | - | 301 | - | L | - | A | - | 52 |
ⓐ Series
ⓑ DC Spark over voltage : 201(200V) , 301(300V), 401(400V), 501(500V), 601(600V)
ⓒ Tolerance : L (±15%), M (±20%), N (±30%)
ⓓ Taping Form : A (Axial Taping), B (Bulk), R (Radial Taping)
ⓔ Taping Size : 52mm, 26mm, 5mm
Name | Part # | DC Spark over voltage Vs(V) | Insulation resistance IR(MΩ) | Electro static capacitance 1KHz-6Vmax C(pF) | Surge current capacity (8x20) μsec | Surge life test | |
WSA | WSA-201M | 201(160V~240V | 100 min | DC100V | 1 pF max. | 500A | (10x100)μsec 1kV 12times |
WSA-301L | 301(255V~345V) | (100x100)μsec 1kV 12times | |||||
WSA-401M | 401(320V~480V) | DC250V | |||||
WSA-501M | 501(400V~600V) | ||||||
WSA-601M | 601(480V~720V) |
PART NUMBER SYSTEM : | WSP | - | 201 | - | M | - | A | - | 52 |
ⓐ Series
ⓑ DC Spark over voltage : 141(140V),201(200V),301(300V),401(400V),501(500V),601(600V)
Name | Part number | DC Spark over voltage Vs(V) | Insulation resistance IR(MΩ) | Electro static capacitance 1KHz-6Vmax C(pF) | Surge life test | |
WSP | WSP-141N | 141(98V~182V) | 100 min | DC50V | 1 pF max. | 1500pF-0Ω-10kV 200 times at 10sec intervals. |
WSP-201M | 201(160V~240V) | |||||
WSP-301L | 301(240V~360V) | DC100V | ||||
WSP-401M | 401(320V~480V) | |||||
WSP-501M | 501(400V~600V) | |||||
WSP-601M | 601(480V~720V) | DC250V |
应用:
(WSA) Applications of surge absorber (WSA-201, 301and 401) => Communication equipment such as telephone, fax and modem 电话、传真和调制解调器等通信设备 (WSP) Applications of surge absorber (WSP-141, 201 and 301) => Signal lines of car radios, radio equipment and sensors 汽车收音机、无线电设备和传感器的信号线 => Monitor and display equipment (WSP-201, 301,401,501 and 601)CRT LED电源线圈保护,显示设备 |
为你推荐
大功率三极金属陶瓷放电管2024-05-16 16:15
产品型号:3R90TB 3R350TA 3R600TA 通流量:20kA -
低电阻自恢复PPTC2023-10-18 17:31
产品型号:阻SMD1206R450SFL 封装:1206 -
三极气体放电管(8*10)10kA/10A/100A:2023-10-13 16:10
产品型号:3R90 3R230 3R470 3R600 3R800 尺寸:8*10 -
SXV40K550C压敏模块VARISTORS 发电机组整流器用2023-08-22 17:05
产品型号:SXV40K550C 压敏电压:910V -
供应低电容TVS阵列2023-08-22 17:00
产品型号: RCLAMP0504P.TCT 封装:6-UFDFN -
JK600系列通信设备用高分子PTC自复保险丝2023-08-22 16:34
产品型号:JK600-160U JK600-150U 耐压:600V -
压敏电阻MYED-820V20KA固定/可变电阻2023-08-21 15:54
产品型号:MYED-820V20KA 浪涌电流:20kA -
压敏电阻器32D821k2023-08-21 13:38
产品型号:32D431K、32D471K、32D511K、32D621 浪涌电流:25kA -
低电容瞬变二极管ESD静电保护元件2023-08-16 09:48
产品型号: ESD32D03CL ESD32D05CL 系列电压:3.3V 5V 8V 12V 24V 36V -
TMOV热保护型压敏电阻TFMOV2023-08-11 15:12
产品型号:TMOV20D471K,TMOV14D471K 规格:14D 20D 25D 34S
ESD器件常用参数解释和ESD器件选型参考2022-04-09 10:20
HDMI2.1 ESD防护方案带回扫功能的ESD静电保护器件DL0524P5-SB2022-12-07 13:33
RS485总线防雷保护电路2022-06-21 14:41
RJ45以太网口防雷设计DLLC03CI,ESD二极管,气体放电管2022-06-21 14:30
