--- 产品参数 ---
- 封装 SMT
- 封装 SMT
- 封装 SMT
--- 产品详情 ---
The HMC748 is a 2:1 Selector designed to support data transmission rates of up to 13 Gbps, and selector port operation of up to 13 GHz. The selector routes one of the two single-ended inputs to the differential output upon assertion of the proper select port. The HMC748 also features an output level control pin, VR, which allows for loss compensation or for signal level optimization.
All single-ended input signals to the HMC748 are terminated with 50 ohms to VCC on-chip, and may be either AC or DC coupled. The outputs of the HMC748 may be operated either differentially or single-ended. Inputs or outputs can be connected directly to a 50 ohm to VCC terminated system, while DC blocking capacitors may be used if the terminating system is 50 ohms to ground. The HMC748 operates from a single +3.3V DC supply and is housed in a ceramic RoHS compliant 3x3 mm SMT package.
APPLICATIONS
- 2:1 Multiplexer up to 13 Gbps
- RF ATE Applications
- Broadband Test & Measurement
- Serial Data Transmission up to 13 Gbps
- Redundant Path Switching
- Built-in Test
- Supports High Data Rates: up to 13 Gbps
- Single-Ended Inputs
- Differential & Single-Ended Outputs
- Propagation Delay: 125 ps
- Fast Rise & Fall Times: 22 / 22 ps
- Programmable Differential
Output Voltage Swing: 600 - 1200 mV - Low Power Consumption: 250 mW typ.
- Single Supply: +3.3V
- 16 Lead Ceramic 3x3mm SMT Package: 9mm2
MAX96715
MAX9257A
MAX9258A
HMC858
HMC954
HMC955
HMC958
HMC854
HMC855
HMC748
HMC678
HMC728
MAX9250
MAX9247
MAX9248
MAX9217
MAX9218
ADG3248
MAX9213
ADG3257
MAX9206
MAX9208
为你推荐
RMK-5-51+ 是一款5 倍倍频器2024-11-27 13:41
产品型号:RMK-5-51+ 描述: 7.5 至 10.5 MHz,5 倍倍频器 输入频率: 7.5 至 10.5 兆赫 输出频率:37.5 至 52.5 兆赫 输入功率:0 至 5 分贝 -
RKK-4-252+是4 倍频器2024-11-27 13:38
产品型号:RKK-4-252+ 描述:430 至 630 MHz,4 倍频器 输入频率:430 至 630 兆赫 输出频率:1.72 至 2.52 GHz 输入功率:16 至 19 分贝 -
RMK-5-352+是5 倍倍频器2024-11-27 13:34
产品型号:RMK-5-352+ 描述:550 至 700 MHz,5 倍频器 输入频率:550 至 700 兆赫 输出频率:2.75 至 3.5 GHz -
MK-2是一款2x 倍频器2024-11-27 13:31
产品型号:MK-2 描述:5 至 500 MHz,2x 倍频器 输出频率:10 MHz 至 1 GHz 输入功率:1至15dBm -
FK-5是2x 倍频器2024-11-27 13:27
产品型号:FK-5 描述:10 MHz 至 1 GHz,2x 倍频器 输入频率:10 MHz 至 1 GHz 输出频率: 20 MHz 至 2 GHz -
RMK-5-472+是5 倍频器2024-11-27 13:24
产品型号:RMK-5-472+ 描述:675 至 950 MHz,5 倍频器 输出频率:3.375 至 4.75 GHz 输入功率:10 至 15 分贝 -
RMK-5-571+是5 倍频器2024-11-27 13:21
产品型号:RMK-5-571+ 描述:70 至 115 MHz,5 倍频器 输入频率:70 至 115 兆赫 输出频率:350 至 575 兆赫 -
RMK-3-1262+是3 倍频器2024-11-27 13:17
产品型号:RMK-3-1262+ 描述:2.25 至 4.2 GHz,3 倍频器 输入频率:2.25 至 4.2 GHz 输出频率:6.75 至 12.6 GHz -
ZX90-2-19+是2x 倍频器2024-11-27 13:12
产品型号: ZX90-2-19+ 描述: 1.1 至 1.9 GHz,2x 倍频器 输出频率:2.2 至 3.8 GHz 输入功率:5 至 10 分贝 -
ZX90-2-11+是2x 倍频器2024-11-27 13:01
产品型号:ZX90-2-11+ 描述:500 MHz 至 1.1 GHz,2x 倍频器 输入频率:500 MHz 至 1.1 GHz 输出频率:1 至 2.2 GHz
