--- 产品参数 ---
- Channel 8-Channel
- ADC ADC
- Pin 64-Pin
- Number of 8
--- 产品详情 ---
AD9252ABCPZ-50
Analog to Digital Converters - ADCs
8-Channel Octal ADC Pipelined 50Msps 14-bit Serial 64-Pin LFCSP EP Tray
Product Technical Specifications
EU RoHS
Compliant
ECCN (US)
3A991c.3.
Part Status
NRND
HTS
8542.39.00.01
Automotive
No
PPAP
No
Converter Type
General Purpose
Architecture
Pipelined
Resolution
14bit
Number of ADCs
8
Number of Input Channels
8
Sampling Rate
50Msps
Digital Interface Type
Serial|LVDS
Input Type
Voltage
Input Signal Type
Single-Ended|Differential
Voltage Reference
Internal|External
Polarity of Input Voltage
Unipolar
Voltage Supply Source
Single
Input Voltage
2Vp-p
Typical Power Dissipation (mW)
748
Maximum Power Dissipation (mW)
773
Integral Nonlinearity Error
±4LSB
Full Scale Error
±2.5%FSR
Signal to Noise Ratio
73.2dB(Typ)
Sample and Hold
Yes
Single-Ended Input
Yes
Minimum Operating Temperature (°C)
-40
Maximum Operating Temperature (°C)
85
Packaging
Tray
Supplier Temperature Grade
Industrial
Mounting
Surface Mount
Package Height
0.83
Package Width
9
Package Length
9
PCB changed
64
Standard Package Name
CSP
Supplier Package
LFCSP EP
Pin Count
64
Lead Shape
No Lead
为你推荐
NVIDIA 900-9X6AF-0056-MT02025-04-26 08:41
产品型号:NVIDIA 900-9X6AF-0056-MT0 工作温度:85 -
MPQ8875AGVE-0019-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:53
产品型号:MPQ8875AGVE-0019-AEC1-Z 工作温度:85 -
MPQ8873GVE-0019-AECC01J-Z是一款高效的同步降压转换器2025-02-23 18:52
产品型号:MPQ8873GVE-0019-AECC01J-Z 工作温度:85 -
MPQ8875AGVE-0128-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:51
产品型号:MPQ8875AGVE-0128-AEC1-Z 工作温度:85 -
MPQ8875AGVE-0129-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:50
产品型号:MPQ8875AGVE-0129-AEC1-Z 工作温度:85 -
R5F10BGECKFB#55特点2025-02-23 18:49
产品型号:R5F10BGECKFB#55 工作温度:85 -
ATA663211-GAQW是一款高性能的N沟道MOSFET驱动器2025-02-23 18:47
产品型号:ATA663211-GAQW 工作温度:85 -
TPS7B6950QDCYRQ1是一款高精度的线性电压调节器2025-02-23 18:45
产品型号:TPS7B6950QDCYRQ1 工作温度:85 -
BCM43465C0KMMLW1G是博通(Broadcom)公司推出的一款集成无线通信解决方案2025-02-18 23:54
产品型号:BCM43465C0KMMLW1G 工作温度:85 -
BCM47623A1KFEBG是博通(Broadcom)公司推出的一款高性能GNSS(全球导航卫星系统)接收器芯片2025-02-18 23:53
产品型号:BCM47623A1KFEBG 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
