--- 产品参数 ---
- 具体型号 LTC2207IUK-14#PBF
- BIT 16
- 1-Channel 1-Channel
- 48-Pin 48-Pin QFN
- 105Msps 105Msps
--- 产品详情 ---
Analog Devices
LTC2207IUK-14#PBF
Analog to Digital Converters - ADCs
1-Channel Single ADC Pipelined 105Msps 14-bit Parallel 48-Pin QFN EP Tube
LTC2207IUK-14#PBF Product Technical Specifications
EU RoHS
Compliant
ECCN (US)
3A991c.3.
Part Status
Active
HTS
8542.39.00.01
Automotive
No
PPAP
No
Converter Type
General Purpose
Architecture
Pipelined
Resolution
14bit
Number of ADCs
1
Number of Input Channels
1
Sampling Rate
105Msps
Digital Interface Type
Parallel
Input Type
Voltage
Input Signal Type
Differential
Voltage Reference
External|Internal
Voltage Supply Source
Single
Input Voltage
1.5Vp-p/2.25Vp-p
Typical Power Dissipation (mW)
947
Maximum Power Dissipation (mW)
1155
Integral Nonlinearity Error
±1.5LSB
Full Scale Error
±2.3%FSR
Signal to Noise Ratio
77.3dB(Typ)
Sample and Hold
Yes
Single-Ended Input
No
Minimum Operating Temperature (°C)
-40
Maximum Operating Temperature (°C)
85
Packaging
Tube
Supplier Temperature Grade
Industrial
Mounting
Surface Mount
Package Height
0.75(Max)
Package Width
7
Package Length
7
PCB changed
48
Standard Package Name
QFN
Supplier Package
QFN EP
Pin Count
48
Lead Shape
No Lead
为你推荐
MPQ8875AGVE-0019-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:53
产品型号:MPQ8875AGVE-0019-AEC1-Z 工作温度:85 -
MPQ8873GVE-0019-AECC01J-Z是一款高效的同步降压转换器2025-02-23 18:52
产品型号:MPQ8873GVE-0019-AECC01J-Z 工作温度:85 -
MPQ8875AGVE-0128-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:51
产品型号:MPQ8875AGVE-0128-AEC1-Z 工作温度:85 -
MPQ8875AGVE-0129-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:50
产品型号:MPQ8875AGVE-0129-AEC1-Z 工作温度:85 -
R5F10BGECKFB#55特点2025-02-23 18:49
产品型号:R5F10BGECKFB#55 工作温度:85 -
ATA663211-GAQW是一款高性能的N沟道MOSFET驱动器2025-02-23 18:47
产品型号:ATA663211-GAQW 工作温度:85 -
TPS7B6950QDCYRQ1是一款高精度的线性电压调节器2025-02-23 18:45
产品型号:TPS7B6950QDCYRQ1 工作温度:85 -
BCM43465C0KMMLW1G是博通(Broadcom)公司推出的一款集成无线通信解决方案2025-02-18 23:54
产品型号:BCM43465C0KMMLW1G 工作温度:85 -
BCM47623A1KFEBG是博通(Broadcom)公司推出的一款高性能GNSS(全球导航卫星系统)接收器芯片2025-02-18 23:53
产品型号:BCM47623A1KFEBG 工作温度:85 -
BCM49418B0KFEBG是博通(Broadcom)公司推出的一款高性能无线通信芯片2025-02-18 23:50
产品型号:BCM49418B0KFEBG 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
