--- 产品参数 ---
- 具体型号 CGHV38375F
- 电压 1
- 功率 400 W
- 类型 GaN on SiC Transistor
- 特点 2.75 - 3.75 GHz
--- 产品详情 ---
一、CGHV38375F产品描述
1.CGHV38375F 产品特性
CGHV38375F 400 W, 2.75 - 3.75 GHz, Internally-Matched, GaN on SiC Transistor (IM-FET)PN: CGHV38375FPackage Type: 440226Typical Performance Over 2.75 - 3.75 GHz (TC = 25˚C)Notes:1 VDD = 50 V, IDQ = 500 mA2 Measured at Pin = -10 dBm3 Measured at Pin = 46 dBm and 100 μs; Duty Cycle = 10%Parameter 2.75 GHz 2.9 GHz 3.3 GHz 3.5 GHz 3.75 GHz UnitsSmall Signal Gain1,2 10.0 12.5 12.6 12.6 13.5 dBOutput Power1,3 55.9 57.4 57.5 57.7 56.8 dBmPower Gain1,3 9.9 11.4 11.5 11.7 10.8 dBDrain Efficiency1,3 50 67 62 60 60 %Figure 1.Features• Full S-Band Radar Coverge• 400 W Typical PSAT• 55% Typical Drain Efficiency• >10 dB Large Signal Gain• Pulsed and CW OperationNote: Features are typical performance acrossfrequency under 25°C, pulsed operation. Pleasereference performance charts for additionaldetails.Applications• Civil and Military, Pulsedand CW S-Band RadarDescriptionWolfspeed's CGHV38375F is a packaged, 400 W HPA matched to 50 ohms at both input andoutput ports. The CGHV38375F operates from 2.75 - 3.75 GHz providing coverage over theentire S-Band radar band. This high-power amplifier provides >10 dB of large signal gain and40% power-added efficiency and is ideally suited as a high-power building block supportingboth pulsed and CW radar applications.
2.CGHV38375F技术规格
二、CGHV38375F 应用领域
CGHV38375F Features• Full S-Band Radar Coverge• 400 W Typical PSAT• 55% Typical Drain Efficiency• >10 dB Large Signal Gain• Pulsed and CW OperationNote: Features are typical performance acrossfrequency under 25°C, pulsed operation. Pleasereference performance charts for additionaldetails.
CGHV38375F Applications• Civil and Military, Pulsedand CW S-Band Radar
三、CGHV38375F 应用电路图
CGHV38375F 总结
以上就是今天要讲的内容,本文仅仅简单介绍了CGHV38375F 产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
QPL74342024-11-11 22:10
产品型号:QPL7434 工作温度:85 -
QPA9124:高性能差分增益块放大器2024-11-11 20:59
产品型号:QPA9124:高性能差分增益块放大器 工作温度:85 -
QPM1021:高功率GaN放大器模块2024-11-11 20:59
产品型号:QPM1021:高功率GaN放大器模块 工作温度:85 -
QPB0066:数字控制可变增益放大器2024-11-11 20:58
产品型号:QPB0066:数字控制可变增益放大器 工作温度:85 -
QPA9424:高线性小型基站功率放大器的理想选择2024-11-11 20:58
产品型号:QPA9424:高线性小型基站功率放大器的理想选择 工作温度:85 -
QPA9903:高效能4瓦特放大器助力5G通信2024-11-11 20:58
产品型号:QPA9903:高效能4瓦特放大器助力5G通信 工作温度:85 -
QPA9127:高线性增益放大器助力5G通信2024-11-11 20:57
产品型号:QPA9127:高线性增益放大器助力5G通信 工作温度:85 -
QPA1006D2024-11-11 20:54
产品型号:QPA1006D 工作温度:85 -
QPA1009D2024-11-11 20:54
产品型号:QPA1009D 工作温度:85 -
QPL90982024-11-11 20:54
产品型号:QPL9098 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
