企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
深圳市华沣恒霖电子科技有限公司
一站式芯片供应商
4.4k 内容数 13w+ 浏览量 19 粉丝
MAX32662GTJ+ Arm Cortex-M4 Processor withFPU-Based Microcontroller (MCU)with 256KB Flash and 80KB SR
型号: MAX32662GTJ+
--- 产品参数 ---
  • 标准型号 MAX32662GTJ+
  • 包装数量 2500
  • 封装 32-pin TQFNEP
  • 尺寸 5mm x 5mm,
--- 产品详情 ---
一、MAX32662GTJ+产品描述
1.MAX32662GTJ+ 产品特性
General DescriptionIn the DARWIN family, the MAX32662 is an ultra-lowpower, cost-effective, highly integrated 32-bitmicrocontroller designed for small battery-powereddevices. It combines a flexible peripheral and feature mixwith the powerful Arm® Cortex®-M4 processor withfloating point unit (FPU) in a small form factor.The MAX32662 enables complex edge-based designswithout compromising battery life, and it also offers legacydesigns an easy and cost optimal upgrade path from 8- or16-bit microcontrollers.Integrating 256KB of flash memory and 80KB of SRAM,the MAX32662 easily accommodates sensor code andcomplex algorithms.Peripherals include SPI, UART, I2C, I2S, CAN 2.0B, anda 12-bit ADC.A ROM-based secure bootloader uses 256-bit ellipticcurve digital signature algorithm (ECDSA-256) encryptionto ensure trusted and authenticated updates of customersoftware.The device is available in a 5mm x 5mm, 32-pin TQFNEP.
2.MAX32662GTJ+技术规格
Benefits and Features• High-Efficiency Microcontroller for Low-Power, HighReliability Devices• 256KB Flash• 80KB SRAM, Optionally Preserved in LowestPower BACKUP Mode• 16KB Unified Cache• Memory Protection Unit (MPU)• Dual- or Single-Supply Operation: 1.7V to 3.6V• Wide Operating Temperature: -40°C to +105°C• Flexible Clock Sources• Internal High-Speed 100MHz• Internal Low-Power 7.3728MHz• Ultra-Low-Power 80kHz• 16MHz–32MHz (External Crystal Required)• 32.768kHz (External Crystal Required)• External Clock Inputs for CPU and Low-PowerTimer• Power Management Maximizes Uptime for BatteryApplications• 50μA/MHz at 0.9V up to 12MHz (CoreMark®) inACTIVE Mode• 44μA/MHz at 1.1V up to 100MHz (While(1)) inACTIVE Mode• 2.15μA Full Memory Retention Current in BACKUPMode at VDDIO = 1.8V• 2.4μA Full Memory Retention Current in BACKUPMode at VDDIO = 3.3V• 350nA Ultra-Low-Power RTC• Wakeup from Low-Power Timer• Optimal Peripheral Mix Provides Platform Scalability• Up to 21 General-Purpose I/O Pins• 4-Channel, 12-Bit, 1Msps ADC• Two SPI Controller/Target• One I2S Controller/Target• Two 4-Wire UART• Two I2C Controller/Target• One CAN 2.0B Controller• 4-Channel Standard DMA Controller• Three 32-Bit Timers• One 32-Bit Low-Power Timer• One Watchdog Timer• CMOS-Level 32.768kHz Calibration Output• AES-128/192/256 Hardware Accelerator
二、MAX32662GTJ+ 应用领域
Applications• Sports Watches• Fitness Monitors• Wearable Medical Patches• Portable Medical Devices• Industrial Sensors• IoT
三、应用电路图
Arm Cortex-M4 Processor withFPU-Based Microcontroller (MCU)with 256KB Flash and 80KB SRAM
总结
以上就是今天要讲的内容,本文仅仅简单介绍了MAX32662GTJ+产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
  • 瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
    瑞萨电子面向不断增长的IO-link市场推出四通道主控IC和传感器信号调节器瑞萨电子为快速增长的IO-Link市场推出了两款半导体解决方案:CCE4511四通道IO-Link主IC和ZSSC3286-支持IO-Link的双通道电阻式传感器信号调节器IC。IO-Link是一种数字通信协议,在工业自动化应用中使用最为广泛。作为一种标准化技术,它能够实现自动化系统
  • Prevayl的下一步是什么2024-02-17 18:10
    Prevayl的下一步是什么2022年,Prevayl推出了SmartWear——这是世界上第一款采用临床级心电图增强的高性能服装,其准确性无与伦比。生物识别先驱还创建了一个功能齐全的智能服装生态系统,为专注于解决方案的服装提供功能性纤维和技术纺织品。普雷维尔首席执行官亚当·克罗夫茨表示:“获得ADI的技术和VSM专业知识使我们比竞争对手更具优势,我们正在利
    463浏览量
  • 什么是放大器?2024-02-17 18:06
    放大器什么是放大器?定义电气或电子放大器是使用外部电源产生输出信号的电路,该输出信号是其输入的更大副本。音频放大器(一种易于识别的应用)用于增加扬声器声音的音量,以便在大范围内更容易听到。虽然电压是最常见的输入信号放大类型,但放大器也可以设计为增加电流。增加输出电流驱动的放大器称为功率放大器。大多数放大器执行线性放大,但有些放大器本质上是对数的。在电路图中,
