企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
深圳市华沣恒霖电子科技有限公司
一站式芯片供应商
4.8k 内容数 20w+ 浏览量 29 粉丝
MAX32672GTL+ High-Reliability, Tiny, Ultra-Low-PowerArm Cortex-M4F Microcontrollerwith 12-Bit, 1Msps
型号: MAX32672GTL+
--- 产品参数 ---
  • 标准型号 MAX32672GTL+
  • 封装 High-Reliability
  • 包装数量 5000
--- 产品详情 ---
MAX32672GTL+   General Description
In the DARWIN family, the MAX32672 is an ultra-lowpower, cost-effective, highly integrated, and highly reliable32-bit microcontroller enabling designs with complex sensor processing without compromising battery life. It combines a flexible and versatile power management unit withthe powerful Arm® Cortex®-M4 processor with a floatingpoint unit (FPU). The MAX32672 also offers legacy designs an easy and cost-optimal upgrade path from 8- or16-bit microcontrollers.The device integrates 1MB of flash and 200KB of SRAMto accommodate application and sensor code. Error correction coding (ECC) is implemented on the entire flash,RAM, and cache to ensure extremely reliable code execution even in the harshest of environments. Brownout detection ensures proper operation during power-down andpower-up events and unexpected supply transients. Theflash is organized into two equal-size physical banks to allow execute-while-write and facilitate "live upgrades."Multiple high-speed peripherals such as 3.4MHz I2C,50MHz SPI, and UART are included to maximize communication bandwidth. In addition, a low-power UART(LPUART) is available for operation in the lowest powersleep modes to facilitate wake-up activity without any lossof data. A total of six timers with I/O capability are provided, including two low-power timers to enable pulse counting, capture/compare, and pulse-width modulation (PWM)generation, even in the lowest power sleep modes. An incremental/quadrature encoder interface with multiple diagnostics is included specifically for motor control applications. A 1Msps, 12-channel, 12-bit successive approximation register (SAR) ADC is integrated for the digitizationof analog sensor signals or other analog measurements.Two low-power comparators, available in all low-powermodes, allow energy-efficient monitoring and wake-up onexternal analog signals. An Elliptic Curve Digital Signature Algorithm (ECDSA)-based cryptographic secure bootloader is available in ROM. The device is available in a5mm x 5mm, 40-pin TQFN-EP or 7mm x 7mm, 56-pin
MAX32672GTL+  Applications● Motion/Motor Control, Industrial Sensors● Optical Communication Modules, Secure RadioModem Controller● Battery-Powered Medical Devices
为你推荐
  • 瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
    瑞萨电子面向不断增长的IO-link市场推出四通道主控IC和传感器信号调节器瑞萨电子为快速增长的IO-Link市场推出了两款半导体解决方案:CCE4511四通道IO-Link主IC和ZSSC3286-支持IO-Link的双通道电阻式传感器信号调节器IC。IO-Link是一种数字通信协议,在工业自动化应用中使用最为广泛。作为一种标准化技术,它能够实现自动化系统
  • Prevayl的下一步是什么2024-02-17 18:10
    Prevayl的下一步是什么2022年,Prevayl推出了SmartWear——这是世界上第一款采用临床级心电图增强的高性能服装,其准确性无与伦比。生物识别先驱还创建了一个功能齐全的智能服装生态系统,为专注于解决方案的服装提供功能性纤维和技术纺织品。普雷维尔首席执行官亚当·克罗夫茨表示:“获得ADI的技术和VSM专业知识使我们比竞争对手更具优势,我们正在利
    618浏览量
  • 什么是放大器?2024-02-17 18:06
    放大器什么是放大器?定义电气或电子放大器是使用外部电源产生输出信号的电路,该输出信号是其输入的更大副本。音频放大器(一种易于识别的应用)用于增加扬声器声音的音量,以便在大范围内更容易听到。虽然电压是最常见的输入信号放大类型,但放大器也可以设计为增加电流。增加输出电流驱动的放大器称为功率放大器。大多数放大器执行线性放大,但有些放大器本质上是对数的。在电路图中,
