--- 产品参数 ---
- 型号 LTC2184CUP#PBF
- 封装 QFN EP Tube
--- 产品详情 ---
Analog Devices LTC2184CUP#PBF Analog to Digital Converters - ADCs
2-Channel Dual ADC Pipelined 105Msps 16-bit Parallel 64-Pin QFN EP Tube
Product Technical Specifications
EU RoHS | Compliant |
ECCN (US) | 3A001a.5.a.5. |
Part Status | Active |
HTS | 8542.39.00.01 |
Automotive | No |
PPAP | No |
Converter Type | General Purpose |
Architecture | Pipelined |
Resolution | 16bit |
Number of ADCs | 2 |
Number of Input Channels | 2 |
Sampling Rate | 105Msps |
Digital Interface Type | Parallel |
Input Type | Voltage |
Input Signal Type | Single-Ended|Differential |
Voltage Reference | Internal|External |
Voltage Supply Source | Single |
Input Voltage | 1Vp-p/2Vp-p |
Typical Power Dissipation (mW) | 454 |
Maximum Power Dissipation (mW) | 500 |
Integral Nonlinearity Error | ±7.5LSB |
Full Scale Error | -2.1/0.4%FSR |
Signal to Noise Ratio | 76.7dBFS(Typ) |
No Missing Codes (bit) | 16 |
Sample and Hold | Yes |
Single-Ended Input | Yes |
Minimum Operating Temperature (°C) | 0 |
Maximum Operating Temperature (°C) | 70 |
Packaging | Tube |
Mounting | Surface Mount |
Package Height | 0.75(Max) |
Package Width | 9 |
Package Length | 9 |
PCB changed | 64 |
Standard Package Name | QFN |
Supplier Package | QFN EP |
Pin Count | 64 |
Lead Shape | No Lead |
为你推荐
QPL74342024-11-11 22:10
产品型号:QPL7434 工作温度:85 -
QPA9124:高性能差分增益块放大器2024-11-11 20:59
产品型号:QPA9124:高性能差分增益块放大器 工作温度:85 -
QPM1021:高功率GaN放大器模块2024-11-11 20:59
产品型号:QPM1021:高功率GaN放大器模块 工作温度:85 -
QPB0066:数字控制可变增益放大器2024-11-11 20:58
产品型号:QPB0066:数字控制可变增益放大器 工作温度:85 -
QPA9424:高线性小型基站功率放大器的理想选择2024-11-11 20:58
产品型号:QPA9424:高线性小型基站功率放大器的理想选择 工作温度:85 -
QPA9903:高效能4瓦特放大器助力5G通信2024-11-11 20:58
产品型号:QPA9903:高效能4瓦特放大器助力5G通信 工作温度:85 -
QPA9127:高线性增益放大器助力5G通信2024-11-11 20:57
产品型号:QPA9127:高线性增益放大器助力5G通信 工作温度:85 -
QPA1006D2024-11-11 20:54
产品型号:QPA1006D 工作温度:85 -
QPA1009D2024-11-11 20:54
产品型号:QPA1009D 工作温度:85 -
QPL90982024-11-11 20:54
产品型号:QPL9098 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
