--- 产品参数 ---
- 标准型号 AD9680BCPZ-500
- 特点 ADC
--- 产品详情 ---
Analog Devices
AD9680BCPZ-500
Analog to Digital Converters - ADCs
2-Channel Dual ADC Pipelined 500Msps 14-bit JESD204B 64-Pin LFCSP EP Tray
Product Technical Specifications
EU RoHS
Compliant
ECCN (US)
3A001a.5.a.5.
Part Status
Active
HTS
8542.39.00.01
Automotive
No
PPAP
No
Converter Type
General Purpose
Architecture
Pipelined
Resolution
14bit
Number of ADCs
2
Number of Input Channels
2
Sampling Rate
500Msps
Digital Interface Type
JESD204B
Input Type
Voltage
Input Signal Type
Differential
Voltage Reference
Internal|External
Voltage Supply Source
Analog and Digital
Input Voltage
2.06Vp-p
Typical Power Dissipation (mW)
2200
Integral Nonlinearity Error
-4.5/5LSB
Full Scale Error
±6%FSR
Signal to Noise Ratio
69.2dBFS(Typ)
Sample and Hold
Yes
Single-Ended Input
No
Minimum Operating Temperature (°C)
-40
Maximum Operating Temperature (°C)
85
Packaging
Tray
Supplier Temperature Grade
Industrial
Mounting
Surface Mount
Package Height
0.73
Package Width
9
Package Length
9
PCB changed
64
Standard Package Name
CSP
Supplier Package
LFCSP EP
Pin Count
64
Lead Shape
No Lead
为你推荐
QPL74342024-11-11 22:10
产品型号:QPL7434 工作温度:85 -
QPA9124:高性能差分增益块放大器2024-11-11 20:59
产品型号:QPA9124:高性能差分增益块放大器 工作温度:85 -
QPM1021:高功率GaN放大器模块2024-11-11 20:59
产品型号:QPM1021:高功率GaN放大器模块 工作温度:85 -
QPB0066:数字控制可变增益放大器2024-11-11 20:58
产品型号:QPB0066:数字控制可变增益放大器 工作温度:85 -
QPA9424:高线性小型基站功率放大器的理想选择2024-11-11 20:58
产品型号:QPA9424:高线性小型基站功率放大器的理想选择 工作温度:85 -
QPA9903:高效能4瓦特放大器助力5G通信2024-11-11 20:58
产品型号:QPA9903:高效能4瓦特放大器助力5G通信 工作温度:85 -
QPA9127:高线性增益放大器助力5G通信2024-11-11 20:57
产品型号:QPA9127:高线性增益放大器助力5G通信 工作温度:85 -
QPA1006D2024-11-11 20:54
产品型号:QPA1006D 工作温度:85 -
QPA1009D2024-11-11 20:54
产品型号:QPA1009D 工作温度:85 -
QPL90982024-11-11 20:54
产品型号:QPL9098 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
