--- 产品参数 ---
- 标准型号 ADS54J66IRMP
- 72-Pin 72-Pin VQFN EP Tray
--- 产品详情 ---
Texas Instruments
ADS54J66IRMP
Analog to Digital Converters - ADCs
4-Channel Quad ADC Pipelined 500Msps 14-bit JESD204B 72-Pin VQFN EP Tray
Product Technical Specifications
EU RoHS | Compliant |
ECCN (US) | 3A001a.5.a.4. |
Part Status | Active |
HTS | 8542.39.00.01 |
Automotive | No |
PPAP | No |
Converter Type | General Purpose |
Architecture | Pipelined |
Resolution | 14bit |
Number of ADCs | 4 |
Number of Input Channels | 4 |
Sampling Rate | 500Msps |
Digital Interface Type | JESD204B |
Input Type | Voltage |
Input Signal Type | Differential |
Voltage Reference | External |
Voltage Supply Source | Analog and Digital |
Input Voltage | 1.9Vp-p |
Typical Power Dissipation (mW) | 2680 |
Signal to Noise Ratio | 74.1dBFS(Typ) |
Sample and Hold | Yes |
Single-Ended Input | No |
Minimum Operating Temperature (°C) | -40 |
Maximum Operating Temperature (°C) | 85 |
Packaging | Tray |
Mounting | Surface Mount |
Package Height | 0.85(Max) |
Package Width | 10.1(Max) |
Package Length | 10.1(Max) |
PCB changed | 72 |
Standard Package Name | QFN |
Supplier Package | VQFN EP |
Pin Count | 72 |
Lead Shape | No Lead |
为你推荐
QPD0005M2024-11-11 15:55
产品型号:QPD0005M 工作温度:85 -
QPF45322024-11-11 15:53
产品型号:QPF4532 工作温度:85 -
QPC46142024-11-11 15:52
产品型号:QPC4614 工作温度:85 -
QPF45682024-11-11 15:51
产品型号:QPF4568 工作温度:85 -
QPF45262024-11-11 15:50
产品型号:QPF4526 工作温度:85 -
QPA99402024-11-11 15:49
产品型号:QPA9940 工作温度:85 -
QPC1220Q2024-11-11 15:48
产品型号:QPC1220Q 工作温度:85 -
QPC73322024-11-11 15:48
产品型号:QPC7332 工作温度:85 -
QPA23092024-11-11 15:48
产品型号:QPA2309 工作温度:85 -
QPQ24562024-11-11 15:48
产品型号:QPQ2456 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
