--- 产品参数 ---
- 标准型号 AD9176BBP-CSH
- GSPS 12.6 GSPS
- BIT 16-Bit
- EP 10x10x1.71 w/6.6 mm EP
--- 产品详情 ---
一、AD9176BBP-CSH 产品描述
1.AD9176BBP-CSH产品特性
PRODUCT HIGHLIGHTS
- A low power, multichannel, dual DAC design reduces power consumption in higher bandwidth and multichannel applications, while maintaining performance.
- Supports single-band and multiband wireless applications with three bypassable complex data channels per RF DAC, or configurations that use the two main datapaths as two wideband complex data channels when using the built in modulator switch.
- A maximum complex data rate (per I or Q) of up to 3.08 GSPS with 16-bit resolution, and up to 4.1 GSPS with 12-bit resolution. The AD9176S-CSH can be alternatively configured as a dual DAC, with each DAC operating across an independent JESD204B link, at the previously described data rates.
- Ultrawide bandwidth single-DAC modes, supporting up to 6.16 GSPS data rates with 16-bit resolution.
2.技术规格
AD9176BBP-CSH Product Details
The AD9176S-CSH is a high performance, dual, 16-bit, digital-to-analog converter (DAC) that supports DAC sample rates up to 12.6 GSPS. The device features an 8-lane, 15.4 Gbps JESD204B data input port, a high performance, on-chip DAC clock multiplier, and digital signal processing capabilities targeted at single-band and multiband direct to RF wireless applications.
The AD9176S-CSH features three complex data input channels per RF DAC datapath. Each input channel is fully bypassable. Each data input channel (or channelizer) includes a configurable gain stage, an interpolation filter, and a channel numerically controlled oscillator (NCO) for flexible, multiband frequency planning. The AD9176S-CSH supports an input data rate of up to a 3.08 GSPS complex (inphase/quadrature (I/Q)), or up to 6.16 GSPS non-complex (real), and is capable of allocating multiple complex input data streams to the assigned channels for individual processing. Each group of three channelizers is summed into a respective main datapath for additional processing when needed. Each main datapath includes an interpolation filter and one 48-bit main NCO ahead of the RF DAC core. Using the modulator switch, the outputs of a main datapath can be either routed to DAC0 alone for operating as a single DAC, or routed to both DAC0 and DAC1 for operating as a dual, intermediate frequency DAC (IF DAC).
The AD9176S-CSH also supports ultrawide data rate modes that allow bypassing the channelizers and main datapaths to provide maximum data rates of up to 6.16 GSPS as a single, 16-bit DAC, up to 3.08 GSPS as a dual, 16-bit DAC, or up to 4.1 GSPS as a dual, 12-bit DAC.
The AD9176S-CSH is available in a 144‑ball BGA_ED package.
Additional application and technical information can be found in the Commercial Space Products Program brochure and the AD9176 data sheet.
AD9176BBP-CSH APPLICATIONS
- Geosynchronous high throughput satellite (GEO HTS)
- Wireless communications infrastructure
- Multiband base station radios
- Microwave/E-band backhaul systems
- Instrumentation, automatic test equipment (ATE)
- Radars and jammers
三、AD9176BBP-CSH 实物图
![](https://file1.elecfans.com/web2/M00/AD/2C/wKgaomVMS0qAMCK5AACnIxxpIEQ826.png)
总结
以上就是今天要讲的内容,本文仅仅简单介绍了AD9176BBP-CSH产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
高度集成的10层工控板方案2024-06-26 09:20
产品型号:10层工控板方案 pcb层数:10 应用范围:工控 -
HDI 板:专为高密度应用而设计的可靠解决方案2024-06-26 09:16
产品型号:rogers5880 型号:rogers5880 类别:HDI -
15mil TMM13i PCB 沉金快速 PCB 原型制作服务2024-06-24 09:42
产品型号:TMM13i 应用:射频和微波电路 Gerber:有 -
AD6676BCBZ华沣恒霖现货2024-05-15 08:46
产品型号:AD6676BCBZ 工作温度:85 -
SE2567L 射频放大器2024-05-09 16:25
产品型号:SE2567L 射频放大器 工作温度:85 -
SKY65404-31 射频放大器 华沣恒霖电子2024-05-09 16:24
产品型号:SKY65404-31 射频放大器 工作温度:85 -
SKY85408-11 射频放大器 华沣恒霖电子2024-05-09 16:23
产品型号:SKY85408-11 射频放大器 工作温度:85 -
SE5004L 射频放大器 华沣恒霖电子2024-05-09 16:22
产品型号:SE5004L 射频放大器 工作温度:85 -
SKY66319-11 华沣恒霖电子2024-05-09 16:16
产品型号:SKY66319-11 工作温度:85 -
SKY67106-306LF 华沣恒霖电子现货2024-05-09 16:14
产品型号:SKY67106-306LF 工作温度:85
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
