企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
深圳市华沣恒霖电子科技有限公司
一站式芯片供应商
4.4k 内容数 16w+ 浏览量 26 粉丝
AD9154-FMC-EBZ 模数转换器
型号: AD9154-FMC-EBZ
--- 产品参数 ---
  • 具体型号 AD9154-FMC-EBZ
--- 产品详情 ---
前言
以下是本篇文章正文内容,下面案例可供参考
一、AD9154-FMC-EBZ 产品描述
1.AD9154-FMC-EBZ 产品特性
PRODUCT HIGHLIGHTS1. Ultrawide signal bandwidth enables emerging widebandand multiband wireless applications.2. Advanced low spurious and distortion design techniquesprovide high quality synthesis of wideband signals frombaseband to high intermediate frequencies.3. JESD204B Subclass 1 support simplifies multichipsynchronization.4. Small package size with a 12 mm × 12 mm footprint.
2.AD9154-FMC-EBZ技术规格
FEATURES
Supports input data rates up to 1.096 GSPSProprietary, low spurious and distortion designSingle carrier LTE 20 MHz bandwidth (BW), ACLR = 77 dBc at180 MHz IFSix carrier GSM IMD = 78 dBc, 600 kHz carrier spacing at180 MHz IFSFDR = 72 dBc at 180 MHz IF, −6 dBFS single toneFlexible 8-lane JESD204B interfaceMultiple chip synchronizationFixed latencyData generator latency compensationInput signal power detectionHigh performance, low noise phase-locked loop (PLL) clockmultiplierDigital inverse sinc filterDigital quadrature modulation using a numericallycontrolled oscillator (NCO)Nyquist band selection—mix modeSelectable 1×, 2×, 4×, and 8× interpolation filtersLow power: 2.11 W at 1.6 GSPS, full operating conditions88-lead, exposed pad LFCSPAPPLICATIONSWireless communicationsMulticarrier LTE and GSM base stationsWideband repeatersSoftware defined radiosWideband communicationsPoint to point microwave radioTransmit diversity, multiple input/multiple output (MIMO)InstrumentationAutomated test equipment
二、AD9154-FMC-EBZ 应用领域
GENERAL DESCRIPTIONThe AD9154 is a quad, 16-bit, high dynamic range digital-toanalog converter (DAC) that provides a maximum sample rateof 2.4 GSPS, permitting multicarrier generation up to the Nyquistfrequency in baseband mode. The AD9154 includes featuresoptimized for direct conversion transmit applications, includingcomplex digital modulation, input signal power detection, andgain, phase, and offset compensation. The DAC outputs areoptimized to interface seamlessly with the ADRF6720-27 radiofrequency quadrature modulator (AQM) from Analog Devices,Inc. In mix mode, the AD9154 DAC can reconstruct carriers inthe second and third Nyquist zones. A serial port interface (SPI)provides the programming/readback of internal parameters.
三、AD9154-FMC-EBZ应用电路图
示例:
总结
这里对文章进行总结:
以上就是今天要讲的内容,本文仅仅简单介绍了AD9154-FMC-EBZ产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
  • 瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
    瑞萨电子面向不断增长的IO-link市场推出四通道主控IC和传感器信号调节器瑞萨电子为快速增长的IO-Link市场推出了两款半导体解决方案:CCE4511四通道IO-Link主IC和ZSSC3286-支持IO-Link的双通道电阻式传感器信号调节器IC。IO-Link是一种数字通信协议,在工业自动化应用中使用最为广泛。作为一种标准化技术,它能够实现自动化系统
  • Prevayl的下一步是什么2024-02-17 18:10
    Prevayl的下一步是什么2022年,Prevayl推出了SmartWear——这是世界上第一款采用临床级心电图增强的高性能服装,其准确性无与伦比。生物识别先驱还创建了一个功能齐全的智能服装生态系统,为专注于解决方案的服装提供功能性纤维和技术纺织品。普雷维尔首席执行官亚当·克罗夫茨表示:“获得ADI的技术和VSM专业知识使我们比竞争对手更具优势,我们正在利
    541浏览量
  • 什么是放大器?2024-02-17 18:06
    放大器什么是放大器?定义电气或电子放大器是使用外部电源产生输出信号的电路,该输出信号是其输入的更大副本。音频放大器(一种易于识别的应用)用于增加扬声器声音的音量,以便在大范围内更容易听到。虽然电压是最常见的输入信号放大类型,但放大器也可以设计为增加电流。增加输出电流驱动的放大器称为功率放大器。大多数放大器执行线性放大,但有些放大器本质上是对数的。在电路图中,
