企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
深圳市华沣恒霖电子科技有限公司
一站式芯片供应商
可获得潜在客户线索数量50+立即解锁
4.9k 内容数 27w+ 浏览量 38 粉丝
HMC849ALP4CE
AD
型号: HMC849ALP4CE
--- 产品参数 ---
  • 工作温度 85
--- 产品详情 ---
HMC849ALP4CE是一款高隔离非反射DC至6 GHz GaAs pHEMT SPDT开关,采用低成本无引脚表贴封装。 该开关非常适合蜂窝/WiMAX/4G基础设施应用,实现高达60 dB的隔离、0.8 dB的低插入损耗和+52 dBm的输入IP3。 在最高5 - 6 GHz WiMAX频段内,该器件具有很高的功率处理能力,另外提供+31 dBm的P1dB压缩点性能。 片内电路可在极低直流电流下实现0/+3V或0/+5V单正电压控制。 使能输入(EN)设为逻辑高电平可将该开关置于“全关”状态。
HMC849ALP4CE 应用
  • 蜂窝/4G基础设施
  • WiMAX、WiBro与固定无线
  • 汽车远程信息系统
  • 移动无线电
  • 测试设备
The AD9737A/AD9739A are 11-bit and 14-bit, 2.5 GSPS high performance RF DACs that are capable of synthesizing wideband signals from dc up to 3 GHz. The AD9737A/AD9739A are pin and functionally compatible with the AD9739 with the exception that the AD9737A/AD9739A do not support synchronization or RZ mode, and are specified to operate between 1.6 GSPS and 2.5 GSPS.
By elimination of the synchronization circuitry, some nonideal artifacts such as images and discrete clock spurs remain stationary on the AD9737A/AD9739A between power-up cycles, thus allowing for possible system calibration. AC linearity and noise performance remain the same between the AD9739 and the AD9737A/AD9739A.
The inclusion of on-chip controllers simplifies system integration. A dual-port, source synchronous, LVDS interface simplifies the digital interface with existing FGPA/ASIC technology. On-chip controllers are used to manage external and internal clock domain variations over temperature to ensure reliable data transfer from the host to the DAC core. A serial peripheral interface (SPI) is used for device configuration as well as readback of status registers.
The AD9737A/AD9739A are manufactured on a 0.18 µm CMOS process and operate from 1.8 V and 3.3 V supplies. They are supplied in a 160-ball chip scale ball grid array for reduced package parasitics.
AD9739ABBCZ  Product Highlights
Ability to synthesize high quality wideband signals with bandwidths of up to 1.25 GHz in the first or second Nyquist zone.
A proprietary quad-switch DAC architecture provides exceptional ac linearity performance while enabling mixmode operation.
A dual-port, double data rate, LVDS interface supports the maximum conversion rate of 2500 MSPS.
On-chip controllers manage external and internal clock domain skews.
Programmable differential current output with an 8.66 mA to 31.66 mA range.
AD9739ABBCZ  Applications
Broadband communications systems
DOCSIS CMTS systems
Military jammers
Instrumentation, automatic test equipment
Radar, avionics
为你推荐
  • 瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
    瑞萨电子面向不断增长的IO-link市场推出四通道主控IC和传感器信号调节器瑞萨电子为快速增长的IO-Link市场推出了两款半导体解决方案:CCE4511四通道IO-Link主IC和ZSSC3286-支持IO-Link的双通道电阻式传感器信号调节器IC。IO-Link是一种数字通信协议,在工业自动化应用中使用最为广泛。作为一种标准化技术,它能够实现自动化系统
  • Prevayl的下一步是什么2024-02-17 18:10
    Prevayl的下一步是什么2022年,Prevayl推出了SmartWear——这是世界上第一款采用临床级心电图增强的高性能服装,其准确性无与伦比。生物识别先驱还创建了一个功能齐全的智能服装生态系统,为专注于解决方案的服装提供功能性纤维和技术纺织品。普雷维尔首席执行官亚当·克罗夫茨表示:“获得ADI的技术和VSM专业知识使我们比竞争对手更具优势,我们正在利
    719浏览量
  • 什么是放大器?2024-02-17 18:06
    放大器什么是放大器?定义电气或电子放大器是使用外部电源产生输出信号的电路,该输出信号是其输入的更大副本。音频放大器(一种易于识别的应用)用于增加扬声器声音的音量,以便在大范围内更容易听到。虽然电压是最常见的输入信号放大类型,但放大器也可以设计为增加电流。增加输出电流驱动的放大器称为功率放大器。大多数放大器执行线性放大,但有些放大器本质上是对数的。在电路图中,
