--- 产品参数 ---
- BIT 16-Bit
- 温度 -55 to 125
- 48-CFP 48-CFP
--- 产品详情 ---
HMC545A和HMC545AE均为低成本SPDT开关,采用6引脚SOT26塑料封装,适用于要求极低插入损耗和极小尺寸的通用开关应用。 这些器件具有0.25 dB的典型损耗,可控制频率范围为DC至3.0 GHz的信号,尤其适合IF和RF应用,包括蜂窝/3G、ISM、汽车和笔记本电脑。 该设计提供出色的插入损耗性能,非常适合滤波器和接收机开关应用。 “关断”状态下,RF1和RF2反射短路。 两个控制电压所需的直流电流非常小,并与CMOS和一些TTL逻辑系列兼容。
HMC545AE应用
HMC545A / HMC545AE适合:
- 蜂窝/3G基础设施
- 专用移动无线手机
- WLAN、WiMAX和WiBro
- 汽车远程信息系统
- 测试设备
5962-9680901VXA 特价现货 常备现货 价格好
5962-9680901VXA的分类 Bus Driver/Transceivers
3.3.-V ABT 16-Bit Buffers/Drivers With 3-State Outputs 48-CFP -55 to 125
5962-9680901VXA的详细资料
芯片详细信息
Manufacturer Part Number:5962-9680901VXA
Brand Name:Texas Instruments
Part Life Cycle Code:Active
Ihs Manufacturer:TEXAS INSTRUMENTS INC
Part Package Code:DFP
Package Description:DFP, FL48,.4,25
Pin Count:48
Reach Compliance Code:not_compliant
HTS Code:8542.39.00.01
Factory Lead Time:1 Week
Manufacturer:Texas Instruments
Risk Rank:5.22
Control Type:ENABLE LOW
Count Direction:UNIDIRECTIONAL
Family:LVT
JESD-30 Code:R-GDFP-F48
Length:15.875 mm
Load Capacitance (CL):50 pF
Logic IC Type:BUS DRIVER
Max I(ol):0.012 A
Number of Bits:4
Number of Functions:4
Number of Ports:2
Number of Terminals:48
Operating Temperature-Max:125 °C
Operating Temperature-Min:-55 °C
Output Characteristics:3-STATE WITH SERIES RESISTOR
Output Polarity:TRUE
Package Body Material:CERAMIC, GLASS-SEALED
Package Code:DFP
Package Equivalence Code:FL48,.4,25
Package Shape:RECTANGULAR
Package Style:FLATPACK
Packing Method:TUBE
Peak Reflow Temperature (Cel):NOT SPECIFIED
Power Supplies:3.3 V
Power Supply Current-Max (ICC):5 mA
Prop. Delay@Nom-Sup:4.6 ns
Propagation Delay (tpd):5.1 ns
Qualification Status:Qualified
Screening Level:MIL-PRF-38535 Class V
Seated Height-Max:3.05 mm
Subcategory:Bus Driver/Transceiver
Supply Voltage-Max (Vsup):3.6 V
Supply Voltage-Min (Vsup):2.7 V
Supply Voltage-Nom (Vsup):3.3 V
Surface Mount:YES
Technology:BICMOS
Temperature Grade:MILITARY
Terminal Form:FLAT
Terminal Pitch:0.635 mm
Terminal Position:DUAL
Time@Peak Reflow Temperature-Max (s):NOT SPECIFIED
Translation:N/A
Width:9.655 mm
为你推荐
MT29GZ6A6BPIET-53AAT.112闪存2025-02-14 07:36
产品型号:MT29GZ6A6BPIET-53AAT.112闪存 工作温度:85 -
MT29GZ5A5BPGGA-53AIT.87J闪存2025-02-14 07:36
产品型号:MT29GZ5A5BPGGA-53AIT.87J闪存 工作温度:85 -
MT29AZ5A5CHGSQ-18AIT.87U 内存2025-02-14 07:35
产品型号:MT29AZ5A5CHGSQ-18AIT.87U 工作温度:85 -
MT29AZ5A3CHHTB-18AIT.109闪存2025-02-14 07:34
产品型号:MT29AZ5A3CHHTB-18AIT.109闪存 工作温度:85 -
MT28EW512ABA1LJS-0SIT闪存2025-02-14 07:32
产品型号:MT28EW512ABA1LJS-0SIT闪存 工作温度:85 -
MT25QL512ABB8E12-0SIT闪存2025-02-14 07:31
产品型号:MT25QL512ABB8E12-0SIT闪存 工作温度:85 -
MT28EW128ABA1HJS-0SIT 内存2025-02-14 07:30
产品型号:MT28EW128ABA1HJS-0SIT 工作温度:85 -
MT28EW256ABA1LJS-0SIT闪存2025-02-14 07:29
产品型号:MT28EW256ABA1LJS-0SIT闪存 工作温度:85 -
MT25QU512ABB1EW9-0SIT 内存2025-02-14 07:29
产品型号:MT25QU512ABB1EW9-0SIT 工作温度:85 -
MT48LC4M32B2P-6A:L DRAM2025-02-14 07:28
产品型号:MT48LC4M32B2P-6A:L DRAM 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
