--- 产品参数 ---
- 工作温度 125
--- 产品详情 ---
The HI-8598 is the world’s first galvanically isolated ARINC 429 line driver, available in a compact 18-pin SOIC plastic package. The device uses a patented capacitive isolation and power regulation to provide 800V galvanic isolation between the analog line driver and the logic interface, ensuring isolation between the ARINC 429 data bus and sensitive digital circuitry. This device is intended for use in safety critical systems, where it is essential to completely isolate any faults on the bus from mission critical electronics, making the HI-8598 a good choice for systems that will ultimately require FAA or EASA DO-254 DAL A certification.
The HI-8598 line driver converts logic signals to ARINC 429 levels (such as when using an FPGA or Holt’s HI-3220 or HI-35860 ARINC 429 protocol ICs). The logic inputs feature built-in 4kV ESD input protection (HBM) as well 3.3V logic level compatibility. 37.5 Ohm or 5 Ohm resistors in series with each ARINC output are available to allow the use of external resistors for lightning protection.
The part is available in Industrial -40oC to +85oC, or Extended, -55oC to +125oC temperature ranges. Optional burn-in is available on the extended temperature range.
HI-8598PSMF 特点 HOLT代理商华沣恒霖电子 如想了解价格 货期等具体信息欢迎联系黄云艳
符合空客ABD0100H规范
电流隔离ARINC 429线路驱动器在模拟线路驱动器和逻辑接口之间提供800V隔离
兼容3.3V逻辑电源
片上生成的所有ARINC 429电压电平
数字可选的上升和下降时间
5欧姆或37.5欧姆输出电阻
工业和扩展温度范围
提供老化
HI-8598PSMF 应用程序 HOLT代理商华沣恒霖电子 如想了解价格 货期等具体信息欢迎联系黄云艳
航空电子数据通信
容错、安全关键的ARINC 429系统
ARINC 429数据总线与数字逻辑电路的隔离
互补式金属氧化物半导体/TTL到ARINC 429电平转换
为你推荐
QPL74342024-11-11 22:10
产品型号:QPL7434 工作温度:85 -
QPA9124:高性能差分增益块放大器2024-11-11 20:59
产品型号:QPA9124:高性能差分增益块放大器 工作温度:85 -
QPM1021:高功率GaN放大器模块2024-11-11 20:59
产品型号:QPM1021:高功率GaN放大器模块 工作温度:85 -
QPB0066:数字控制可变增益放大器2024-11-11 20:58
产品型号:QPB0066:数字控制可变增益放大器 工作温度:85 -
QPA9424:高线性小型基站功率放大器的理想选择2024-11-11 20:58
产品型号:QPA9424:高线性小型基站功率放大器的理想选择 工作温度:85 -
QPA9903:高效能4瓦特放大器助力5G通信2024-11-11 20:58
产品型号:QPA9903:高效能4瓦特放大器助力5G通信 工作温度:85 -
QPA9127:高线性增益放大器助力5G通信2024-11-11 20:57
产品型号:QPA9127:高线性增益放大器助力5G通信 工作温度:85 -
QPA1006D2024-11-11 20:54
产品型号:QPA1006D 工作温度:85 -
QPA1009D2024-11-11 20:54
产品型号:QPA1009D 工作温度:85 -
QPL90982024-11-11 20:54
产品型号:QPL9098 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
