--- 产品参数 ---
- 工作温度 125
--- 产品详情 ---
Part # | Package Description | Temp Range | Flow | Moisture Sensitivity Level | RoHS Compliant |
HI-3582PCI | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | No |
HI-3582PCI-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | No |
HI-3582PCIF | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | Yes |
HI-3582PCIF-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | Yes |
HI-3582PCM | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | No |
HI-3582PCM-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | No |
HI-3582PCMF | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | Yes |
HI-3582PCMF-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | Yes |
HI-3582PCT | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | No |
HI-3582PCT-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | No |
HI-3582PCTF | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | Yes |
HI-3582PCTF-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | Yes |
HI-3582PQI | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | No |
HI-3582PQI-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | No |
HI-3582PQIF | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | Yes |
HI-3582PQIF-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | Yes |
HI-3582PQM | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | No |
HI-3582PQM-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | No |
HI-3582PQMF | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | Yes |
HI-3582PQMF-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | Yes |
HI-3582PQT | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | No |
HI-3582PQT-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | No |
HI-3582PQTF | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | Yes |
HI-3582PQTF-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | Yes |
HI-3583PCI | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | No |
HI-3583PCI-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | No |
HI-3583PCIF | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | Yes |
HI-3583PCIF-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -40°C to +85°C | I | 3 | Yes |
HI-3583PCM | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | No |
HI-3583PCM-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | No |
HI-3583PCMF | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | Yes |
HI-3583PCMF-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | M | 3 | Yes |
HI-3583PCT | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | No |
HI-3583PCT-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | No |
HI-3583PCTF | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | Yes |
HI-3583PCTF-10 | 64 Pin Plastic 9mm x 9mm Chip-scale Package (QFN) | -55°C to +125°C | T | 3 | Yes |
HI-3583PQI | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | No |
HI-3583PQI-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | No |
HI-3583PQIF | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | Yes |
HI-3583PQIF-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -40°C to +85°C | I | 3 | Yes |
HI-3583PQM | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | No |
HI-3583PQM-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | No |
HI-3583PQMF | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | Yes |
HI-3583PQMF-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | M | 3 | Yes |
HI-3583PQT | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | No |
HI-3583PQT-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | No |
HI-3583PQTF | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | Yes |
HI-3583PQTF-10 | 52 Pin Plastic Quad Flat Pack (MQFP) | -55°C to +125°C | T | 3 | Yes |
霍尔特集成电路公司的HI-3582/HI-3583是一款硅栅互补式金属氧化物半导体器件,用于将3.3V 16位并行数据总线直接连接到ARINC 429串行总线。HI-3582/HI-3583设计为行业标准HI-8282架构提供了许多增强功能。该器件提供两个接收器,每个接收器都具有标签识别、32 x 32 FIFO和模拟线路接收器。每个接收器最多可以编程16个标签。独立的发射器具有32 x 32 FIFO和内置线路驱动器。所有三个FIFO的状态都可以使用外部状态引脚或通过轮询HI-3582/HI-3583状态寄存器来监控。其他新功能包括32位数据或奇偶校验的可编程选项以及解读32位字的能力。此外,还提供具有不同输入电阻和输出电阻值的版本,以便用户更轻松地添加外部防雷电路。
HI-3582与每个线路驱动器输出串联37.5欧姆,以匹配ARINC 429总线阻抗要求,并且可以直接连接到总线。HI-3583提供较低的输出电阻,因此防雷电路中使用的外部电阻将提供正确的37.5欧姆阻抗匹配。
虽然内置线路驱动器与接收器共享一个公共基板,但物理隔离的设计不允许寄生串扰,从而实现与常见混合布局相同的隔离。
HI-3582PCM特点 HOLT代理商华沣恒霖电子 如想了解价格 货期等具体信息欢迎联系黄云艳
- ARINC规范429兼容
- 3.3V逻辑电源
- 双接收器和发射器接口
- 模拟线路驱动器和接收器直接连接到ARINC总线
- ARINC输入内部防雷,符合DO-160D,3级(仅-10个选项)
- 可编程标签识别
- 每个接收器的片上16标签存储器
- 每个接收器和发送器32 x 32 FIFO
- 发送器和每个接收器的独立数据速率选择
- 状态寄存器
- 数据加扰控制
- 第32位传输位可以是数据或奇偶校验
- 自检模式
- 低功率
- 提供工业和扩展温度范围
HI-3582PCM应用程序 HOLT代理商华沣恒霖电子 如想了解价格 货期等具体信息欢迎联系黄云艳
- 航空电子数据通信
- 串行到并行转换
- 并行到串行转换
为你推荐
MPQ8875AGVE-0019-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:53
产品型号:MPQ8875AGVE-0019-AEC1-Z 工作温度:85 -
MPQ8873GVE-0019-AECC01J-Z是一款高效的同步降压转换器2025-02-23 18:52
产品型号:MPQ8873GVE-0019-AECC01J-Z 工作温度:85 -
MPQ8875AGVE-0128-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:51
产品型号:MPQ8875AGVE-0128-AEC1-Z 工作温度:85 -
MPQ8875AGVE-0129-AEC1-Z是一款高效的同步降压转换器2025-02-23 18:50
产品型号:MPQ8875AGVE-0129-AEC1-Z 工作温度:85 -
R5F10BGECKFB#55特点2025-02-23 18:49
产品型号:R5F10BGECKFB#55 工作温度:85 -
ATA663211-GAQW是一款高性能的N沟道MOSFET驱动器2025-02-23 18:47
产品型号:ATA663211-GAQW 工作温度:85 -
TPS7B6950QDCYRQ1是一款高精度的线性电压调节器2025-02-23 18:45
产品型号:TPS7B6950QDCYRQ1 工作温度:85 -
BCM43465C0KMMLW1G是博通(Broadcom)公司推出的一款集成无线通信解决方案2025-02-18 23:54
产品型号:BCM43465C0KMMLW1G 工作温度:85 -
BCM47623A1KFEBG是博通(Broadcom)公司推出的一款高性能GNSS(全球导航卫星系统)接收器芯片2025-02-18 23:53
产品型号:BCM47623A1KFEBG 工作温度:85 -
BCM49418B0KFEBG是博通(Broadcom)公司推出的一款高性能无线通信芯片2025-02-18 23:50
产品型号:BCM49418B0KFEBG 工作温度:85
瑞萨电子面向不断增长的 IO-link 市场推出四通道主控 IC 和传感器信号调节器2024-10-22 19:02
Prevayl的下一步是什么2024-02-17 18:10
什么是放大器?2024-02-17 18:06
