0 引言
利用光纤传输电视节目具有频带宽、容量大、损耗低、重量轻、抗干扰能力强、保真度高、工作性能可靠等优点,不仅能扩大有线电视覆盖面,减少传
2010-09-10 09:35:042558 有线电视的供电系统是交流60V集中供电。CATV放大器的电源通常用电源变压器降压或隔离型开关电源两种。本文介绍一种串联型开关电源,该电源成本低,效率接近90%,电路见附图
2011-10-01 01:00:281395 贸泽电子 (Mouser Electronics) 即日起开售Qorvo®的 QPL181x系列CATV 放大器。
2021-06-04 15:43:591591 OMNIMARKER CATV 165
2023-03-30 17:35:47
UNIMARKER CATV 175
2023-03-30 17:35:46
WIRESTRIPPERRG6/59/CATV
2023-03-29 20:14:35
LOKE CATV/SATTELITE STRIPPER
2023-03-29 20:14:47
CATV COAX TERMINATION KIT
2023-03-29 20:52:40
CATV GROUND WIRE TAG
2023-03-22 22:45:44
IC CATV AMP MOD 550MHZ 7-CATV
2023-04-06 20:16:07
IC CATV AMP MOD 870MHZ 7-CATV
2023-03-23 09:07:44
2023-04-06 20:15:59
2023-04-06 20:16:00
CATV/SATELLITE KIT
2023-03-29 20:52:35
The MAX3660 high-linearity analog RF transimpedanceamplifier (TIA) is intended for passive optical network(PON) video receiver applications. With 66dBΩ maximumvariable gain and integrated uptilt, the MAX3660provides 23dBmV
2008-08-10 10:30:0111 介绍了一种新型的IP - CATV 网关系统模型,给出其基本设计思想,并详细说明在VxWorks实时嵌入式操作系统下如何开发和设计IP - CATV 网关驱动程序。关键词:VxWorks ;CATV ;驱动程序;实
2009-03-25 10:34:4026 介绍基于CATV 的双向FFSK 数据通信线路和软件设计的原理、流程。该装置实现简单、成本低廉、性能可靠, 并在实际应用中得以成功运用。
2009-04-16 10:05:3814 AD8323是ANALOGDEVICES公司生产的、采用5V供电的CATV线驱动器,它具有良好的阶梯输出功率控制功能,同时具有低失真,低噪声,支持SPI接口等优良性能,是一个低功耗、数字控制的可变增益放
2009-04-22 16:48:3922 介绍基于CATV 的双向FFSK 数据通信线路和软件设计的原理、流程。该装置实现简单、成本低廉、性能可靠, 并在实际应用中得以成功运用。
2009-05-15 14:16:1314 The attenuation setting in the AD8321 is determined by the 8-bit word in the data latch. The SDATA load sequence is initiated by a falling edge on DATEN. The gain control data (SDATA) is serially loaded (MSB first) into the 7-bit shift reg
2009-08-26 14:46:5023 The AD8322 is a low-cost, digitally controlled variable gain amplifieroptimized for coaxial line driving applications such as cablemodems that are designed to the MCNS-DOCSIS upstreamstandard. An 8-bit serial word determines th
2009-08-26 14:49:558 The differential output pins VOUT+ and VOUT– are also biased to a dc level of approximately VCC/2. Therefore, the outputs should be ac-coupled before being applied to the load. This is accomplished with a 1:1 transformer as seen in th
2009-08-26 15:06:597 The AD8326 is a high-output power, digitally controlled, variablegain amplifier optimized for coaxial line driving applicationssuch as data and telephony cable modems that are designed tothe MCNS-DOCSIS upstream standard. An 8-
2009-08-26 15:10:2322 The AD8327 is a low-cost, digitally controlled, variable gainamplifier optimized for coaxial line driving applications such ascable modems that are designed to the MCNS-DOCSISupstream standard. An 8-bit serial word determines t
2009-08-26 15:13:5616 本文以FPGA 为核心,采用混频、解调、检波的方法设计了一套电视信号场强测试仪,设计的场强仪工作稳定、操作简单,可以应用于检测有线电视信号的场强大小,鉴定有线电视
2009-08-28 12:20:1233 介绍了一种基于单片机寻址控制的有线电视收费系统,重点对系统应用锁相频率合成技术的2FSK 调制和解调、单片机AT89C51 寻址控制的硬件和软件进行了分析,还对系统利用PIN管宽
2009-09-22 11:25:2419 CATV机顶盒设计的原理与实现:电视机顶盒(Set Top Box,STB)是模拟广播电视向数字广播电视过渡的最好解决方案。将数字机顶盒与普通的模拟电视结合起来,就可以实现数字电视的功能
2010-01-08 22:57:0049 BGY681 产品规格书(CATV amplifier module)
FEATURES· Excellent linearity· Extremely low noise· Silicon
2010-03-24 16:00:5312 美国频道划分表(CATV-STD):
美国频道划分表(AIR) 美国频道划分表(CATV-STD)
2010-06-12 07:32:3141 CATV系统故障分析
网络匹配故障分析:
2010-07-30 15:00:4012 微带线是在坚固的介质基片上沉积薄膜导体构成一个平面电路.图1、图2是一个标准微
带线的截面结构。
除槽线和微波导之外.在微带电路中传播的是横电
2010-11-10 11:58:280 DWDM 可分为开放式和集成式两种系统结构。开放式WDM 系统的特点是复用终端光接口没有特别的要求,WDM 系统采用波长转换技术,将复用终端的光信号转换成指定的波长,而集
2010-11-23 15:42:1526 Voltage Controlled Oscillators (VCOs) have come to theforefront of RF designs together with the first PLL circuits.In the era before the PLL, oscillators were mostly freerunning and only in rare cases were varactors used for
2010-11-25 16:17:4017 1 光纤有线电视系统指标设计在HFC网络中主要考察系统如下三项指标载噪比CNR 要求用户端不低于43dB 通常设计为44dB组合二次差拍 CSO 要求用户端不低于54dB组合三次差拍CTB
2010-12-13 15:55:5434 以往在对旧式彩电如何接收增补频道的改制中,主要采取换头法、调压法、变频法、增接机顶盒
2006-04-17 22:42:361075 MAX3510应用电路(MAX3510是CATV上行放大器)
2008-10-06 22:10:07999 MAX3510上行CATV放大器系统的框图
摘要:文中框图为MAX3510上行CATV放大器系统。此设计符合DOCSIS标准。图中显示了变压器、调谐器模块、基带IC、抗杂
2008-10-06 22:11:32931 MAX3514, MAX3516, MAX3517 CATV上行放大器 (含应用电路和参数资料)
概述
The MAX3514/MAX3516/MAX3517 programmable-gain amplifiers are designed for use in CATV upstream
2008-10-06 22:17:41937 MAX3509 CATV上行放大器(含应用电路和参数资料)
MAX3509
2008-10-06 22:21:10636 MAX3507概述
MAX3507是应用在CATV上行发送器中的可变增益功率放大器。可变增益具有55dB的动态范围,经由3线SPI™接口进行控制。当使用+34dBmV额定输
2008-10-06 22:38:51712 MAX3505应用电路(CATV上行放大器)
典型工作电路
2008-10-06 22:50:04898 CATV上行放大器选择指南
摘要:本选择指南提供了MAX3503、MAX3505、MAX3507、MAX3509、MAX3510、MAX3514和MAX3516上行驱动放大器在电缆调制解调器和CATV系统
2008-10-06 23:13:461060 CATV MAX3509 +68dBmV电缆电话上行通信方案
要:为提高MAX3509电缆上行放大器的输出信号使其支持电路交换电话系统,本应用笔记给出了具体的设计修改
2008-10-06 23:28:03951 CATV中dBm,dBmV和dBµV的转换
摘要:有线电视系统一般基于75Ω接口,但绝大部分射频测试装置的阻抗却是50Ω。本文阐述了这两个环境间功率和电
2008-10-06 23:41:363492 MAX3507 节省空间的EURO-DOCSIS CATV上行放大器
摘要:本应用笔记分析了CATV上行放大器中产生杂散信号干扰的原因。MAX3507的内置滤波器能够抑制这些杂
2008-10-06 23:47:04671
80W CATV交换型电源输入40V-60V,输出20V-27V,3A开关电源电路原理图
2008-11-03 10:35:101043 用于75Ω测量的CATV最小损耗衰减器
摘要:基于75Ω特性阻抗的有线电视CATV系统是用50Ω的实验室测试装置测试的。用一个75Ω至50Ω的最小损耗阻抗转换电路(M
2009-02-21 15:06:581552
CATV用户有源分配器电路
2009-02-28 11:16:49915 1 CATV网络上行传输的原理
CATV网络的上行传输是一个多点对单点的传输[1],必须考虑共享媒体的接入控制问题。DOCSIS是由美国电缆实验
2009-02-28 11:42:421905 介绍了数字电视机顶盒的基本原理和以有线电视传输网络为传播载体的数字电视机顶盒的设计原理,阐述了在实现过程中所用到的数据的调制与解调技术、加解扰技术和复用与解复
2009-05-05 19:47:371326 CATV放大器及其调整
一、 电缆的特性
电缆是组成CATV网络的主要器材,它具有三大特性:阻抗特性、传输特性和温度特性。 放大器在网络中的主要作用是用
2009-05-24 23:45:292071 什么是CATV (Cable TeleVision)
英文缩写: CATV (Cable TeleVision)
中文译名: 有线电视、电缆电视
分 类: 电信设备
2010-02-22 11:06:321099 什么是电缆(CATV)数据网络
在有些国家,有线电视行业已经成为通过升级的CATV(有线电视)网络进行数据传送的主要服务提供商。有线电视行业有许多向
2010-04-06 11:38:012637 MAX3518为集成的CATV上行放大器IC,设计用于满足DOCSIS 3.0的要求,功耗仅为1.25W。该放大器覆盖5MHz至85MHz输入频率范围(3dB带宽为275MHz),能够传输四路同时位于该频率范围的QPSK调制的载波信号
2011-03-04 10:35:07933 PRX10(PROMAX-10)是宝马电子新一代手持式CATV分析仪,集载波电平、扫描、斜率测量于一身,兼具频谱分析、数据记录、瞬时检波和电缆数字电视信号分析功能,频率覆盖SUB、FM、MATV、CATV和
2011-04-01 14:40:5831 1、工程设计规格表(引自GY106-92,GY/T 121-95) 条款内容摘要技术要求 1上行频率范围530MHz 2卫星数字声音广播频率111.0125.0MHz,中心频率为118.0MHz 3调频广播频率范围87.0MHz108.0MHz载波频率间隔
2011-04-25 07:32:4546 CATV图像质量主观评价表,用户端图像质量的主观评价是采用五级损伤标准,应参照国际GB7401第4.2条五级损伤制标准执行,4级图像是CATV系统的设计标准
2011-04-25 07:35:112472 此频率分割配置适合大型综合业务网,上行通路较5-30MHz扩展35 MHz,为开展交互业务提供可能;下行能路有58个模拟电视频道可供使用,同时提供了104MHz的下行数字压缩电视的频率空间。
2011-04-25 07:36:152203 先进半导体解决方案供应商瑞萨电子(Renesas Electronics)日前发表适用于1GHz有线电视(CATV)系统的氮化镓(GaN)功率放大器模组MC-7802
2011-07-11 08:47:191192 美国电缆电视实验室(Cable Labs:Cable Television Laboratories Inc.)与美国主要的数字电视设备供应商及其成员就北美的 数字有线电视 系统规定的主要细节达成一致这一规定建立了数字业务的基本
2011-07-21 15:23:2136 本文分析了CATV宽带放大器在电视发射机技术中的应用中的具体技术要求及工作原理,并对设备技术创新与改造后的调整与测试方法,也做了较详细的介绍。从而达到了预期的目的
2011-09-15 14:31:5372 本文详细介绍了提高通信可靠性的途径、差错控制编码的基本原理、常用的几种差错控制方式以及差错控制技术在CA1中的应用。
2011-12-22 15:16:1619 2012-09-13 15:57:5314 单片机设计资料电子类资料材料,有兴趣的同学可以下载学习
2016-05-03 18:29:384 Qorvo CATV和宽带接入产品部总监Kellie Chong表示:“我们最新的功率倍增器MCM让客户拥有更多工具,从而为更多用户提供更大带宽和更高输出功率。此外,MCM紧凑型封装还提供经济有效的解决方案,相比传统混合封装可节省高达70%的电路板空间。”
2016-06-16 11:33:351366 Qorvo宣布扩展CATV产品组合,推出两款专为DOCSIS 3.1有线网络设计的全新控制产品——QPC3624和QPC3024。新增加的产品为有线运营商提供了更大的网络设计灵活性,从而提高上游和下游带宽并降低功耗。
2016-11-04 15:11:30785 基于FPGA技术的CATV核心网络无阻塞ATM交换结构
2017-01-17 19:54:245 众所周知,雷电是自然现象,雷击释放能量很大,它的放电时间很短,但泄放电流可达几万、甚至几十万安培。因此,直接遭雷击,在放电通道上毁坏性巨大。即使不是直接雷击,而是在落雷点附近的建筑物体,由于电磁感应,在建筑物体上或者在架空线上都会产生高电压冲击波,其感应电压可高达数千伏,甚至上万伏。这种高电压冲击波,沿着建筑物体或沿着导体迅速传播,可破坏各种电器设备,危及人身安全。
2017-12-10 17:18:012370 全球射频产品的领导厂商和晶圆代工服务的重要供应商TriQuint半导体公司近期推出了两款新型低噪声、高灵活性放大器,为CATV/FTTH等热点应用提供强有力的产品和技术支持。 其中
2017-12-10 18:42:50534 TriQuint公司的TriAccessTM CATV/FTTH产品提供的集成方 案能够以更低的成本实现更高效、更有竞争力的网络 全球射频产品的领导厂商和晶圆代工服务的重要供应商 TriQuint
2017-12-12 04:18:35894 CATV技术致力于新的网络元素
2018-07-06 02:00:003308 2012北京射频工程师聚会
2018-07-06 01:09:003295 CATV市场趋势:低成本,高性能,绿色效益
2018-07-02 12:07:003838 流。CGA-33 18Z包含两个放大器,用于宽带推拉式CATV放大器,需要优异的二阶性能。在推挽配置中,第二阶和第三阶非线性大大提高。
2018-08-27 11:26:001 TAT8804是一种超线性的QFN GaAs放大器MMIC,用于CATV基础设施应用中的输出级放大。该器件具有推挽共源共栅设计,提供了平坦的增益以及超低失真,使得它非常适合在需要高输出功率能力的CATV配电系统中使用。ESD保护也在装置的输出端提供。
2018-07-25 11:27:320 TAT9988是一种超线性封装的GaAs/GaN放大器,用于CATV基础设施应用中的输出级放大。
2018-08-16 11:27:0012 TAT8888是一种超线性封装的GaAs/GaN放大器,用于CATV基础设施应用中的输出级放大。
2018-08-07 11:29:0034 成本效益,高性能的GaN和GaAs基CATV功率放大器从QORVO®提供未来证明系统的要求。该家族的CATV功率放大器支持CATV设计者满足严格的系统要求,同时降低总功耗高达20%。这些产品
2018-08-02 11:29:007 用电视开关同步控制CATV放大器,catv amplifier
关键字:用电视开关同步控制CATV放大器
用电视开关同步控制CATV放大器
2018-09-20 19:13:281048 利用淘汰的有线电视放大模块制作CATV无线发射器,CATV Wireless Transmitter
关键字:制作CATV无线发射器
2018-09-20 19:25:04990 有线电视的供电系统是交流60V集中供电。CATV放大器的电源通常用电源变压器降压或隔离型开关电源两种。本文介绍一种串联型开关电源,该电源成本低,效率接近90%,电路见附图。
2019-02-08 10:38:002627 有线电视的供电系统是交流60V集中供电。CATV放大器的电源通常用电源变压器降压或隔离型开关电源两种。
2019-02-09 15:29:003007 ANADIGICS公司推出的5种1GHz线路放大器ACA0862B, ACA0862D, ACA1206, ACA2402 和ACA2407,用于CATV基础设备。这些放大器能帮助CATV服务提供商
2020-12-29 08:00:00601 AD8327:5 V CATV线路驱动器粗步输出功率控制过时数据表
2021-04-15 08:21:453 AD8325:5V CATV线路驱动器精步输出功率控制数据表
2021-04-21 14:17:2036 AD8321:Gain程序变量CATV线驱动数据Sheet
2021-04-21 14:50:059 AD8322:5V CATV线路驱动器粗步输出功率控制过时数据表
2021-05-07 18:00:130 ADCA3990:CATV倍频器混合数据表
2021-05-15 16:01:493 AD8323:5V CATV线路驱动器精步输出功率控制过时数据表
2021-05-17 16:21:152 ADCA3992:45 MHz至1218 MHz,CATV倍频器混合数据表
2021-05-22 10:28:389 DOCSIS 3.1 的出现让 CATV 提供商能够增加上下行容量。新一代 DOCSIS 4.0 产品目前正处于设计阶段。使用正确的 CATV 放大器可显著提高解决方案的效率。
2022-01-21 12:28:351785 2022-11-17 12:42:240 2022-11-18 23:45:320 提高带宽,打造适应未来发展的 CATV 解决方案
2022-12-26 10:16:16431 MAX9930-MAX9933系列RF控制器和检测器适用于各种应用,其中,通过光纤传输有线电视信号(CATV)是该系列器件非常理想的应用之一,利用RF控制器或RF检测器控制互阻放大器(TIA)的增益。本文介绍了如何使用MAX9930构成RF控制器或检波器。
2023-02-10 15:20:52658 随着网络升级,有线电视带宽也不断扩展,这一趋势促使工程师和系统架构师探索新的技术,同时需要新一代的无源和有源产品。为了满足不断增加的带宽和数据速率需求,
2023-02-22 11:45:17626 通过最小损耗阻抗转换电路可以用50Ω的测试设备对宽带的75Ω电路,例如CATV调谐IC,电缆上行放大器,和卫星DBS调谐IC进行测量。当使用最小损耗阻抗转换电路时,你必须清楚是使用MLP的电压损耗
2023-06-08 17:13:121264 绝大部分CATV测量是以电压为参考,以dBmV或dBµV为单位进行测量。按照标准定义,dBmV是以1mVRMS为参考,输出电压(VOUT)以mVRMS为单位进行测量(等式1)。由于等式1得到的是电压
2023-06-08 17:55:591768 CATV放大器能把输入讯号的电压或功率放大的装置,由电子管或晶体管、电源变压器和其他电器元件组成。某终端工厂在设计CATV光模块时,电路设计部分电源供给电压需要一颗12V转5.5V,输出电流大于
2022-07-21 19:06:53459 2023-11-03 08:31:440
查看更多
