电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Video Display Signals and the
收藏
查看更多
Signals And Systems (信号与系统)----Rernd Girod
Signals and Systems》by Rernd Girod;Rudolf Rabenstein;Alexander StengerProduct Details: ISBN
2011-08-19 11:06:15
VIDEO-DC-PRL
SmartFusion®2 - Video, Video Processing Evaluation Board
2023-03-29 22:52:57
Video Processing Using FPGAs in Video Surveillance Systems
Video Processing Using FPGAs in Video Surveillance SystemsVideo surveillance systems are a key
2008-08-08 12:32:39
AVS Video Standard
AVS Video StandardAVS video standard is developed by the AudioVideo Coding Standard Working Group
2008-06-25 09:55:20
Calibration Procedure for Video Equipment
[BR]Calibration Procedure for Video EquipmentProducts:CCVS + COMPONENT GENERATOR SAFCCVS GENERATOR
2009-06-12 23:59:27
DK-Z7-VIDEO-CES-G
ZYNQ-7000 VIDEO AND IMAGING KIT
2023-03-22 19:56:51
DK-Z7-VIDEO-CES-G-J
ZYNQ-7000 VIDEO/IMAGE KIT JAPAN
2023-03-22 19:56:51
Digital video technologies
Digital video technologiesContents What is digital video?Why has digital video become a mainstream
2008-08-04 15:35:24
2008-08-04 15:49:28
HW-XGI-VIDEO-US
DAUGHTER CARD VIDEO I/O VIODC
2023-03-22 20:00:14
Overview of AVS Video Standard
Overview of AVS Video Standard 2004 IEEE International Conference on Multimedia and Expo (ICME
2008-06-04 13:55:04
Simple VGA/Video adapter
Simple VGA/Video adapter(This project is about creating VGA/Video signals using the 8-bit AVR MCU
2009-03-26 22:17:05
String Hex Display to Normal Display(转帖)
VI Name: StringHexDisplayToNormalDisplayTotal VIs: 1Description: Converts String (Hex Display
2012-03-28 15:01:37
String Normal Display to Hex Display(转帖)
VI Name: StringNormalDisplayToHexDisplayTotal VIs: 1Description: Converts String (Normal Display
2012-03-28 14:57:16
TMS320C6678 ZYNQ开发手册之camera_edge_display视频案例
TMS320C6678 ZYNQ的开发手册详细资料将围绕8大板块,分别有cameralink_loopback、sdi_capture_display、fmc_tw2867_display
2021-05-24 11:12:40
The digital Video Standard according to ITU-R BT. 601/656
The digital Video Standard according to ITU-R BT. 601/656Leveldiagram at the input of an A/D converter for theanalogue component signals Y , CB , CR
2009-06-13 00:00:15
dvd-video
dvd-video
2012-08-17 15:41:16
s-video输出接口,s-video接口定义图
s-video接口定义 s-video接口的作用S接口也是非常常见的接口,其全称是Separate Video,也称为SUPER VIDEO。S-Video连接规格是由日本人开发
2009-05-03 22:54:10
zynq中Video On-Screen Display这个IP如何使用?
有没有大佬用过Video On-Screen Display v6.0这个IP,看了一下xilinx官网好像已经停用了,在sdk中动态配置osd参数的例程也找不到了,有没有人有啊
2019-09-04 11:27:23
什么是VIDEO SFP?3G VIDEO SFP光模块怎么样?
`在光通信市场中,SFP光模块是我们比较常听到的,那么VIDEO SFP光模块是什么呢?在本文中,易飞扬通信将详细给大家介绍什么是VIDEO SFP和3G VIDEO SFP光模块怎么样
2018-05-17 14:22:10
在设计FPGA程序时,谁遇到过如下的警告啊: One or more signals are missing in the process sensitivity list.
请问。在设计FPGA程序时,谁遇到过如下的警告啊: One or more signals are missing in the process sensitivity list.
2016-05-17 15:57:59
怎么让video_capture示例工作运行?
当我运行video_capture_rev_1_1的示例时,我收到了以下有线信息
2019-08-14 10:45:39
有人有经验AXI4-Stream到视频输出IP核吗?
AXI4-Stream to Video Out (AIVO). The TPG is the video source, VTC generate the timing signals
2019-03-08 10:00:05
Display port 接口资料
最近需要了解关于Display port和mini display port的相关资料,有大神有相关接口规格书,接口线路的资料,能否分享下,感激不尽不过觉得HDMI蛮好的,不知道为啥display port还要横插一缸子,尤其是微软的surface平板竟然装了mini的display port。
2014-12-23 13:34:20
经过优化的汽车类高速串行视频接口设计
technology to transmit uncompressed MegaPixel video data, bidirectional control signals and power
2018-09-25 10:15:17
采用100万像素成像仪的远程汽车摄像头模块包括BOM及层图
speed serial video interface to a display or machine vision processing system. It uses TIs FPD-Link
2018-10-12 15:26:25
PW1225.PDFdigital video
PW1225.PDF The PW1225 is a high-quality, digital video signalprocessor that incorporates
2007-12-24 21:36:180
lm1881 pdf datasheet
, burst/back porchtiming, and odd/even field information from standard negativegoing sync NTSC, PAL* and SECAM video signals with
2008-07-27 19:45:1272
数字电视技术(Digital video technolog
2008-08-04 15:29:0336
Composite Video Separation Tec
The most fundamental job of a video decoder is to separatethe color from the black and white
2008-08-19 13:37:2422
Overview of AVS Video Standard This paper overviews the AVS video standard interms of basic
2008-08-20 11:48:3215
Component Video Sync Formats (
the sync pulse from componentvideo signals (see Figure 1). The EL8102 is a single supplyVideo Op Amp with rail to rail output
2008-09-21 22:56:4133
Video Amplifier with Sync Stri
IntroductionThe circuit in Figure 1 transmits 200MHz (-3dB bandwidth) video signals while stripping
2008-09-21 22:58:5121
ML86V8208 pdf datasheet (LCD C
The ML86V8208 is an LCD display controller for driving small to medium sized video display panels
2008-10-29 12:37:5543
MSM7652 pdf datasheet (NTSC/PA
656 or ITURBT 601, it outputs selected analog composite video signals, analog S video signals or Y, R-Y, B-Y signals. For the scanning system
2008-10-29 12:39:2515
ML87V2107 pdf datasheet (Video
, can achieve frame recursive noise reduction and frame synchronization of video signals. The noise reduction is performed by making three c
2008-10-29 12:41:5624
ML87V2105 pdf datasheet (Video
to reduce frame-recursive 3D noise in video signals. The motion adaptive noise reduction is performed between frames, between fields, or bet
2008-10-29 12:42:5835
EL4543 pdf datasheet (Triple D
signals. The inputsare suitable for handling high speed video or othercommunications signals in either single-ended or different
2009-01-16 20:54:3622
EL4501 pdf datasheet (Video Fr
conditioning functions foranalog video signals. It provides a flexible front-end interfacefor analog or analog/digital video sub-systems
2009-01-16 20:55:3025
MAX9657, MAX9658 pdf datasheet
a bandwidth of 15MHz, making it suitable for not only standard-definition video signals, but also video graphics array (VGA) signals with a 640
2009-02-12 20:15:2312
Signals and Systems with MATLA
This text contains a comprehensive discussion on continuous and discrete time signals and systems
2009-02-17 10:31:272
The effects on digital signals
The effects on digital signals of slotted ground
2009-03-24 14:13:000
Video Demystified
previously unrelated. One of the key elements of multimedia convergence in the home and business has been video.A few short years ago
2009-07-27 14:30:090
ADA4410-6,pdf datasheet (Frequ
designers the flexibility to easily filter and drive many types of video signals, including high definition video. In the RGB/component chann
2009-09-04 08:27:287
ADV7188,pdf datasheet (with Fa
television signals compatible with worldwide NTSC, PAL, and SECAM standards into 4:2:2 component video data compatible with 20-/
2009-09-11 09:24:4216
ADV7202,pdf datasheet (Video R
The ADV7202 is a video rate sampling codec.It has the capability of sampling up to five NTSC/PAL
2009-09-14 09:43:2426
VIDEO PROCESSING FOR DLPTM DIS
VIDEO PROCESSING FOR DLPTM DISPLAY SYSTEMS:Texas Instruments’ Digital Light ProcessingTM (DLPTM
2009-10-01 16:56:4117
Video and Image Processing Up
The Altera® video and image processing up conversion example designdemonstrates up conversion
2009-11-24 11:12:5711
Spectra of EMI Signals
Spectra of EMI Signals:•Spectra of impulse-like signals•Spectra of periodic
2009-11-29 17:25:3427
Differential Signals Rules to
We generally think of signals propagating through ourcircuits in one of three modes, single-ended
2010-01-15 10:15:010
TLC5602C,TLC5602M,PDF(Video 8-Bit Digital-to-Analog Converte
The TLC5602x devices are low-power, ultra-high-speed video, digital-to-analog converters that use
2010-06-07 15:02:5972
Video视频电路原理图
Video视频电路原理图:protel 文件文档。
2010-06-19 23:24:15111
Digital Video Standards The 19
The world of digital video standards is a complicated one,with many different standards groups
2010-07-11 16:27:093
OPA361,pdf(3V Video Amplifier)
The OPA361 high-speed amplifier is optimized for 3V portable video applications. It is specifically
2010-09-12 23:16:2911
OPA362,pdf(3V VIDEO AMPLIFIER)
The OPA362 high-speed amplifier is optimized for 3V portable video applications. It is specifically
2010-09-27 19:30:1910
Design and Layout of a Video G
Design and Layout of a Video Graphics System for Reduced EMI
2010-10-02 09:19:1528
Video Formats and Required Loa
Video Formats and Required Load Terminations:视频格式和负荷的终端。
2010-10-02 09:27:1918
#硬声创作季 树莓派教程:14-Display Demo
Display树莓派
Mr_haohao发布于 2022-10-02 07:52:31
#硬声创作季 树莓派教程:Using a 16x2 LCD Display with a Raspberry
ASPDisplay树莓派
Mr_haohao发布于 2022-10-02 12:19:26
Display Backlighting Using Hig
Display Backlighting Using High-Brightness LEDs and SEPIC Power Modules Abstract:
2009-02-06 12:16:381091
Switching VGA Signals in a Not
Switching VGA Signals in a Notebook Abstract: This application shows how the MAX4885
2009-03-31 10:43:34793
S-Video接口图片,s-video接口接线图
2009-05-03 22:49:1117579
s-video接口定义,s-video接口的作用
s-video接口定义
2009-05-03 22:52:0410551
设计基于LED的视频显示板,Designing an LED
设计基于LED的视频显示板 Designing an LED-Based Video-Display Board Abstract: Currently, all of the top LED
2009-07-18 11:12:251631
Level Shifting Digital Signals
Level Shifting Digital Signals By: Budge Ing
2009-08-21 07:49:531085
2009-08-21 07:49:531176
Logarithmic LED Panel Display
Logarithmic LED Panel Display Has 72dB Range Abstract: This application note presents a simple
2009-09-27 14:47:371213
Video CD盘片/CD EXTRA盘片
Video CD盘片/CD EXTRA盘片 Video CD盘片
2009-12-25 16:30:051121
S-Video端口
S-Video端口              S-Video具体英文全称
2009-12-26 15:20:00799
WinCE Display驱动开发介绍
在WinCE中,Display驱动由GWES模块来管理。WinCE提供了两种架构的Display驱动模型,可以满足不同的硬件需求。一种是基于WinCE DDI的Display驱动模型,另一种是基于DirectDraw的Display驱动模型。
2011-05-24 11:58:121310
Wi-Fi Display
主要介绍Wi-Fi Display的定义及特色。
2012-02-03 16:20:1112276
VIDEO接口EMC设计标准电路
VIDEO接口EMC设计标准电路:
2012-03-26 15:37:1263
(Oppenheim)Signals and Systems Solutions(2nd edition)习题答案
2015-12-24 15:04:340
Video_and_Vision_Guide
Video and Vision 设计用户指南
2016-01-12 15:38:420
static_display实验
static_display实验,喜欢的朋友可以下载来学习。
2016-01-14 15:44:316
Text_Display.Constraint
Text Display,好东西,喜欢的朋友可以下载来学习。
2016-02-17 17:15:570
VGA_Video
VGA Video,好东西,喜欢的朋友可以下载来学习。
2016-02-17 17:30:520
Video_Demo
Video Demo,好东西,喜欢的朋友可以下载来学习。
2016-02-17 17:31:150
Soft-Designs--Display
2016-02-17 18:00:590
FPGA_Video_Windows
FPGA_Video_Windows,好东西,喜欢的朋友可以下载来学习。
2016-02-22 14:33:270
Display-Graphics
Display-Graphics,好东西,喜欢的朋友可以下载来学习。
2016-02-22 15:03:430
auto_TFT_display
auto_TFT_display,有需要的下来看看。
2016-02-22 15:48:0614
1 Channel Video System User Manu
1 Channel Video System User Manual V2.2
2016-12-23 01:52:450
TI_Video-ImagingGuide
Digital television (DTV) broadcasts and receives digitally, in contrast to the analog signals used
2017-05-21 11:22:549
TW8809低成本视频格式转换器
RGB format video and output these signals in ITU-R.656 format.
2017-09-18 09:22:129
Flat Panel Display Controller
2017-10-17 10:22:274
Video processor description
2017-10-19 09:20:207
WinCE Display驱动开发介绍
2017-12-01 09:13:01273
一文让你懂SDI Video SFP光模块
SDI Video SFP光模块不同于市场的其他类型的光模块,它的出现专用于高清SDI光端机,解决高清图像传输过程中无闪屏、黑屏等现象。但是,很多人对于视讯光模块的认识是非常少的。而在本文中易飞扬
2018-05-24 11:06:0011367
In Home Display的特点与应用
瑞萨电子公司MCU产品中心的孙炜将讲述:In Home Display解决方案。
2018-06-14 01:00:003382
学会USB Video Class的实现原理
由于目前支持Video Class的设备还很少,所以在Linux上还没有开源的Video Class的主机端驱动,设备端的Video Class驱动就更没有见到开源的代码了。
2019-05-16 14:59:044001
ADI Signals+ Smart Industry
2021-01-29 09:52:100
ADI Signals+ Electrification
2021-01-29 09:55:100
ADI Signals+ Digital Health
2021-01-29 09:56:100
ADI Signals+ Connectivity
2021-01-29 09:58:101
关于Video out IP和Video Timing Controller IP的介绍
本文对Video out IP和Video Timing Controller IP进行简要介绍,为后文完成使用带有HDMI接口的显示器构建图像视频显示的测试工程做准备。
2021-05-08 10:03:165452
修改V4L2的Video Pipeline的devicetree
PetaLinux 能够根据Vivado的设计,自动生成V4L2的Video Pipeline的devicetree。但是它主要为Xilinx的VCU TRD服务,测试的组合比较少。很多时候,需要根据自己的工程,修改V4L2的Video Pipeline的devicetree。
2022-08-02 08:03:351689
华为常用display命令大全
此命令主要用于系统基本信息的收集,集合了多条常用display命令的输出信息,包括display device、display current-configuration等等,任何网上问题发生时必须
2023-04-24 11:18:441817
浅谈S-VIDEO接口静电浪涌防护
浅谈S-VIDEO接口静电浪涌防护S-Video接口曾经在一些旧款的电视机、录像机、游戏机等设备上广泛应用,用于传输视频信号。不过,随着技术的发展,S-Video接口已经逐渐被其他更先进的接口所取
2024-03-07 08:02:40120
已全部加载完成
