电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Calculating Energy Usage: How
收藏
查看更多
1hid设备报告的usage minimum定义中bitmap是位图的意思吗为什么hid设备和位图有关
1hid设备报告的usage minimum定义中bitmap是位图的意思吗为什么hid设备和位图有关2array是input output feature项目的数据项中array variable中的那个array吗
2019-07-09 21:55:25
2.4-GHz Bluetooth® low energy System-on-Chip(蓝牙4.0)
2011-02-13 11:39:23
ENERGY-HARVEST-RD
C8051F342, Si1012, Si4431 EZRadioPRO® Series Power Management, Energy Harvesting Evaluation Board
2023-03-30 11:45:43
Energy Micro将32位MCU能效提高4倍
管理成为工程师共同关注的话题。为此,专注于低功耗设计的Energy Micro公司推出了高能效的32位EFM32 Gecko微控制器系列。 在本届IIC上,Energy Micro公司展出了可延长4倍
2010-03-16 16:00:20
Energy harvesting and LPD当ST25管脚置于LPD模式时,EH是否仍然有效?
Energy harvesting and LPD:当ST25管脚置于LPD模式时,EH是否仍然有效(目标是降低EH模式下的整体功耗)?
2023-01-16 07:40:20
How to Read a Datasheet
How to Read a DatasheetIn order to use a PIC microcontroller, a flip-flop, a photodetector
2008-10-31 17:16:25
How to caculate the addresses in LDF file
'ss_block7_code', how can we caculate new end address of 'seg_sigma_extdata' and new start address of 'ss_block7_code'? Thanks.
2018-08-06 09:36:56
How to implement the circuit in EAB within VHDL coding
How to implement the circuit in EAB within VHDL codingState Machine Design?Design a state machine
2008-09-09 16:18:58
How to upload document?
How to upload document? 谢谢
2014-09-19 09:02:59
HID Usage Tables 1.12
2020-05-20 10:13:30
IAR的energy trace仿真技术,有人知道吗,一起交流下
想测单片机在不同低功耗模式下的电流和工作时间,了解到energy trace仿真可以实现,想找人一起交流,谢谢
2020-09-09 20:15:55
That is how long?
;How Ling-feng is a stingy person, since many generals Treat!" "Really? Thank military
2011-07-05 15:47:16
Use of Light Sensors to Enable Smart Features in Energy Efficient Electronics
Use of Light Sensors to Enable Smart Features in Energy Efficient ElectronicsBrightness Control
2011-08-06 21:29:59
Windows的隐藏式能源和电池工具揭秘
There's been a lot of talk about power and energy usage by PCs lately, especially ones on battery.
2021-12-31 06:15:31
Z-STACK-HOME、 Z-STACK-LIGHTING、 Z-STACK-ENERGY有什么区别?
Z-STACK-HOME、 Z-STACK-LIGHTING、 Z-STACK-ENERGY有什么区别呢?我是新手,我应该下载哪个协议栈?
2018-06-01 05:10:30
了解太阳能逆变器最大功率点跟踪效率的重要性
is the metric used to ensure a solar inverter is operating at the maximum power point as often as possible, to maximize solar energy usage from the PV array.
2018-10-24 10:47:16
使用Energy Monitor ASIC进行面包板测试的分线板
描述CS5490 突破使用Energy Monitor ASIC进行面包板测试的分线板。代码https://github.com/tiagolobao/CS5490
2022-08-16 06:35:56
压力测试和元件评估的可编程刺激应用笔记
switch quickly enough to avoid burning energy on the reverse part of the cycle? How much does a resistor
2019-08-28 09:04:37
在DIVW和DIV中断会发生什么
, when an interrupt occurs while calculating is active - with the registers (A, X, Y) and - how does
2018-10-25 10:48:09
在看hid usage tables 1.12对实际键盘没有的按键不是很清楚
在看hid usage tables 1.12对实际键盘没有的按键不是很清楚international 1到9是什么LANG1到9是什么alternate erase是什么sysreqattentionpriorcrsel props是什么能解释下吗
2019-07-04 22:30:44
怎么计算并联电容1端口
Display and calculating it there. How do I access Im(Y11) and Frequency to make the calculations? Thanks.
2019-04-24 10:17:53
浅析Nano Energy技术
关键词:世界最小消耗电流180nAIoT设备Nano Energy技术使电池驱动时间延长1.4倍Seamless Switching Mode Control(SSMC)功能评估板
2019-06-03 03:03:43
编译"energy meter code library"时出错
使用的是IAR FOR430 6.107编译"energy meter code library"时出错.这个错误,就是说语句错,我找不到原因?
2014-10-10 23:21:31
请问Energy Filter,Attack Filters ,Decay Filters该怎么理解?
请问DRC中,Energy Filter,Attack Filters ,Decay Filters怎样理解?设置不同的值起什么不同的作用?
2019-08-07 09:02:46
请问Z-stack只有HomeAutomation,没有Smart Energy吗?
本帖最后由 一只耳朵怪 于 2018-6-1 16:47 编辑 Z-stack只有HomeAutomation,没有Smart Energy吗?
2018-06-01 07:03:09
架空裸导线载流量和温度的关系计算(Calculating t
IEEE Standard for Calculating theCurrent-Temperature Relationship ofBare Overhead ConductorsIEEE
2008-05-24 14:28:06113
理解Altera器件IO输出的时间参数
;devices, explains how Altera defines tCO results, and presents techniquesfor calculating the output ti
2009-03-28 14:49:4419
Understanding I/O OutputTiming
This application note describes the output timing parameters for Altera®devices, explains how
2009-03-28 14:50:2816
Universal Serial Bus Usage Tab
Universal Serial Bus Usage Tables for HID Power Devices Universal Serial Bus Usage Tables for HID
2009-04-11 19:18:4635
使用AT90S8535 带A D转换器的AVR微控制器和AT
This application note describes how to record, store and play back sound using any AVR
2009-05-23 16:42:3040
keys to longer life for cmos here's how cmos can be protecte
keys to longer life for cmos here's how cmos can be protected against abuses
2009-06-21 10:27:0910
How to Design Battery Charger
How to Design Battery Charger Applications that Require External Microcontrollers and Related
2009-10-29 15:03:4813
Vehicle Hybrid Energy System.
2009-11-30 16:13:2320
Calculating Power Dissipation
Calculating the current needed to drive the MOSFET isstraight forward, but requires using
2009-12-03 13:39:5229
华擎 主板Intelligent Energy Saver智
华擎主板Intelligent Energy Saver智能节能器1.68版.zip
2010-01-26 14:10:154
技嘉 主板Easy Energy Saver轻松节能工具B8
技嘉 主板Easy Energy Saver轻松节能工具B8.1105.1版.zip
2010-01-26 15:42:3130
技嘉 主板Dynamic Energy Saver动态节能工
技嘉 主板Dynamic Energy Saver动态节能工具B8.0128.1版.zip
2010-01-27 14:27:2015
How to select the right eSATA
How to select the right eSATA connector and cable:External SATA (or called eSATA) is popular
2010-04-08 15:33:569
How to Select the Right eSATA
How to Select the Right eSATA Connector and Cable:External SATA (eSATA) applications range from
2010-04-11 08:40:2018
Energy Effi cient, Low Power O
Energy Effi cient, Low Power Off-Line Switcher IC:LinkSwitch-XT incorporates a 700 V power MOSFET
2010-06-19 23:35:158
TWL92230C,pdf(Energy Managemen
The TWL92230 is an energy management device optimized to be a companion device for the OMAP24xx
2010-10-05 00:08:2629
How to Tune and Antenna Match
How to Tune and Antenna Match the MAX1470 Circuit The MAX1470evkit is tuned and tested at the factory to obtain the highest se
2008-09-17 16:16:441302
How to Calculate the Wiper Vol
How to Calculate the Wiper Voltage of a Digital Potentiometer How to Calculate the Wiper Voltage of a Digital Potentiometer
2008-10-01 12:08:38882
How to Use the DS2482 I²C
How to Use the DS2482 I²C 1-Wire® Master  Abstract: The DS2482 is an I²C to 1-Wire bridge. The
2008-12-18 09:54:061317
Calculating the Error Budget i
Calculating the Error Budget in Precision Digital-to-Analog Converter (DAC) Applications Abstract
2009-01-06 13:44:18876
How to Reduce Reference Noise
How to Reduce Reference Noise by Half Abstract: A low-noise, 2.5V reference is constructed
2009-01-23 22:39:581537
How to Replace a DS1213 SmartS
How to Replace a DS1213 SmartSocket with an Equivalent-Density NV SRAM Module Abstract: The DS1213 SmartSocket products have reache
2009-03-31 08:20:10965
How to Interpret DS1847/DS1848
How to Interpret DS1847/DS1848 Temperature Readings Abstract: The DS1847 and DS1848 have
2009-04-17 11:43:37821
How to Use the Bit-Error-Rate
Abstract: This application note explains how to configure the bit-error-rate tester (BERT
2009-04-18 11:39:25888
Abstract: The MAX5481/MAX5483 data sheet provides a complicated formula for calculating wiper
2009-04-20 11:44:31752
DVD Formats and How to Drive L
: DVD-ROM, DVD-R, DVD-RW, DVD-RAM, DVD+R, and DVD+RW. It explains how recording and rewriting work, including the bit stream coding and recording/re
2009-04-20 15:05:02847
在断电时如何保存数据-How to Save Data Du
Abstract: The following application note discusses how the DS1233 can be used to save data during
2009-04-23 09:58:011940
How to Generate PWM Waveforms
Abstract: This application note describes how to set up and use the Timer B in the MAXQ® family
2009-04-23 16:16:061168
如何使用MAXQ串行驱动程序开发应用-How to Use
Abstract: The application note demonstrates how to configure the MAXQ2000 microcontroller EV kit
2009-04-23 16:34:16676
How to Use the MAX15005 Curren
Abstract: This reference design shows how to use a MAX15005 automotive power-supply controller
2009-05-02 10:30:11752
How to Configure the DS1852 Al
Abstract: The purpose of this application note is to explain how to configure the DS1852 so
2009-05-07 11:49:01728
Saving Energy: Little Things M
for nonportable devices, increasing energy costs and the latest Energy Star® guidelines are focusing public awareness on wasted standby power. Thus,
2009-07-02 09:20:44577
How to Pick a Click-and-Pop Su
How to Pick a Click-and-Pop Suppressor Abstract: This application note presents the MAX9890
2009-07-18 08:31:12918
Saving Energy: Little Things Mean a Lot,节能:小事情意味着许多 Abstract: Consumers demand long battery life
2009-07-18 08:41:03577
How to Calibrate the MAX9979 P
How to Cal
2009-09-27 14:22:091127
How to Switch the DisplayPort
How to Switch the DisplayPort Hot-Plug-Detect Signal with the MAX4928 Abstract: The MAX4928A/B are DisplayPort™ swi
2009-09-27 14:44:331861
如何选择咔嗒/噼噗声抑制器(How to Pick a Cl
如何选择咔嗒/噼噗声抑制器-How to Pick a Click-and-Pop Suppressor Abstract: This application note presents the M
2009-10-16 10:11:44973
IAR Systems和Energy Micro合作以简化M
IAR Systems和Energy Micro合作以简化MCU应用开发  IAR Systems宣布与低耗能MCU供应商 Energy Micro AS进行合作。Energy Micro在新发布的EFM32 Gecko开发套件中,选择了IAR Embedded Workbench f
2010-02-06 10:17:03954
How to Use High-Voltage and Hi
How to Use High-Voltage and High-Current-Drive Op Amps in 4–20mA Current-Loop Systems Abstract
2010-02-21 11:45:051576
Energy Micro推出EFM 32 Gecko节能环保
Energy Micro推出EFM 32 Gecko节能环保微控制器入门套件 节能环保微控制器生产商Energy Micro日前推出其EFM 32 Gecko(壁虎)微控制器系列中的一个低成本入门套件。价格为69美元,
2010-03-02 08:42:401109
Energy Micro获得32-位微控制器节能Embedd
Energy Micro获得32-位微控制器节能Embedded奖  Energy Micro®已在Embedded World 2010展会上获得了其渴望已久的Embedded 硬件奖, 其获奖产品是EFM® 32Gecko(壁虎)节能微控制器。该
2010-03-10 10:52:47881
大幅面扫描仪技术术语:能源之星/Energy Star
大幅面扫描仪技术术语:能源之星/Energy Star 能源之星(Energy Star),是一项由美国政府所主导,主要针对消费性电
2010-03-18 10:14:31857
How do I Choose the Best FireW
How do I Choose the Best FireWire Hard Drive? When looking for a FireWire hard drive, remember
2010-03-25 11:12:211038
REC Peak Energy新型太阳能组件
REC Peak Energy新型太阳能组件  REC Peak Energy模组是REC位于新加坡的新制造工厂生产的首批商用产品。这个工厂是业界综合和自动化程度最高的工厂之
2010-04-26 11:59:541119
Calculating the tachometer reg
This application note explains how the MAX6615/MAX6616 temperature monitors and fan-speed
2010-07-05 08:20:23767
How to build a simple, interac
How to bui
2010-08-01 11:38:28935
Energy Micro选定北高智为中国区代理商
专着于低功耗的微控制器射频组件的Energy Micro 正式宣布授权北高智科技有限公司(Honestar Technology),作为中国区域的代理商。
2011-06-28 08:39:25833
路灯电力线通信自动化系统讨论
a real-world example of a systemfor reducing energy usage and lowering maintenance costs in tunnels. The basic system design is explained and key
2012-03-28 16:16:4957
如何从可再生能源中获取可观的电力
Abstract: Renewable energy sources hold tremendous potential for transformation of how
2013-03-25 17:08:0229
Bluetooth 4.0 Low Energy (BLE)
Bluetooth 4.0 Low Energy (BLE)。
2016-05-16 17:38:4118
Energy_Efficient_Smart_Phones_for_5G_Networks
design requirements that include energy efficiency, multimode operation, cooperation, and smart enabling features.
2016-06-21 14:17:300
CSR_μEnergy®CSR1010_QFN_Bluetooth_Smart_IC
高通CSR Bluetooth Smart系列中的1010,CSR1010 QFN is a CSR μEnergy platform device.CSR μEnergy are CSR
2016-09-12 15:10:0119
CSR_μEnergy®CSR1011_QFN_Bluetooth_Smart_IC
高通CSR Bluetooth Smart系列中的1011,CSR1011 QFN is a CSR μEnergy platform device. CSR μEnergy are CSR
2016-09-12 15:10:014
CSR_μEnergy®CSR1012_QFN_Bluetooth_Smart_IC
高通CSR Bluetooth Smart系列中的1012,CSR1012 QFN is a CSR μEnergy platform device.CSR μEnergy are CSR
2016-09-12 15:10:018
CSR_μEnergy®CSR1013_WLCSP_Bluetooth_Smart_IC
高通CSR Bluetooth Smart系列中的1013,CSR1013 WLCSP is a CSR μEnergy platform device.CSR μEnergy are CSR
2016-09-12 15:10:015
high-energy数据手册
The HE-series is a range of high pulse energy picosecond and femtosecondfiber lasers providing
2016-12-25 21:49:500
How to Make the Most of Your Energy
想象一下你已经预测到所有你的未来需要一个资源基于单个数据点;每日、每周、甚至一个月。这会给你足够的空间来预测你在一年、两年甚至十年中需要多少资源吗?也许不会,但这本质上是公用事业提供商今天面临的困境。
2017-06-13 10:44:068
智能电网解决方案分析
  The smart grid represents a new vision for how we can harness technology to renew energy
2017-09-12 14:25:383
How-to-drive-a-lot-of-LEDs-from-a-few-microcontrol
2017-09-18 14:36:515
Bluetooth Low Energy Brochure
2017-10-24 15:32:133
如何使用英特尔®Advisor来优化多核的矢量化性能、功耗和能量效率
Learn how you can use Intel® Advisor to optimize vectorization performance, power, and energy efficiency of multi-cores.
2018-09-10 05:35:004304
节能灯的选购与使用,how to Select energy-saving lamps
节能灯的选购与使用,how to Select energy-saving lamps 关键字:节能灯的选购与使用 现在市场上有的所谓
2018-09-20 18:20:34483
Energy Micro新增12款针对低功耗应用的Cortex
关键词:Cortex-M3 , Energy , 微控制器 低功耗微控制器公司Energy Microreg;日前公布了其QFP64封装的EFM32 Gecko和Tiny Gecko产品线。全新64
2019-01-13 18:23:01253
Energy Vault获软银1.1亿美元投资
Energy Vault获软银1.1亿美元投资。
2019-08-15 15:15:463802
德国GMC万用表METRAHIT ENERGY
如今,万用表仍然是电气工程领域不可或缺的应用很广的测试工具。专业便携功率表 METRAHIT ENERGY 带电能质量分析功能,在同类型产品中脱颖而出,卓尔不凡 。 德国GMC万用表METRAHIT
2020-04-10 10:07:111106
手持式功率万用表 手持式功率计 METRAHIT ENERGY
手持式功率万用表 手持式功率计 METRAHIT ENERGY 广泛适用于电气工程 测量行业 如今,万用表仍然是电气工程领域不可或缺的应用很广的测试工具.专业便携功率表 METRAHIT
2020-04-23 10:05:471082
PowerCfg-您未使用的Windows的隐藏式能源和电池工具
2022-01-11 12:22:430
Helion Energy 将产生超过 1 亿摄氏度的核聚变
美国 Helion Energy 公司的第6 台聚变发生器原型Trenta已超过 1 亿摄氏度。Helion Energy的突破性技术包括使用脉冲聚变系统和小型装置,并使用由氘和氦 3 (D-³He
2022-08-03 09:53:032979
Notes on Usage of the RX Family C/C++ Compiler V.1.00 Release 01 and Corrections in the 用户手册
2023-04-18 19:26:490
Notes on Usage of C/C++ Compiler Package for H8SX H8S H8 Family V.6.01 Release 02and Corrections in 用户手册
Notes on Usage of C/C++ Compiler Package for H8SX H8S H8 Family V.6.01 Release 02 and Corrections in 用户手册
2023-05-08 20:18:460
2023-06-27 19:58:380
加大电池生产!亿纬锂能与Energy Absolute签订谅解备忘录
7月,惠州亿纬锂能股份有限公司(以下简称“亿纬锂能”)与Energy Absolute Public Co.,Ltd.(以下简称“Energy Absolute”)在惠州签订谅解备忘录。经过共同研究
2023-08-01 11:34:24607
Advanced Energy推出新电商平台
2月28日,Advanced Energy又迎来了一个激动人心的时刻 ,其电商平台正式于AE官网上线啦!
2024-03-11 11:42:45177
已全部加载完成
