电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>DS2172 Simplified Receiver Ope
收藏
查看更多
2178-LL-2172
CLOSURE W/2172 2 GND STUDS
2023-03-22 23:09:25
2178-LS-2172
2023-03-22 23:09:25
2172
2172 - Lowpass Filter - KR Electronics, Inc.
2022-11-04 17:22:44
DS14C89A
DS14C89A Quad CMOS Receiver datasheet (Rev. C)
2022-11-04 17:22:44
DS26C32AT
DS26C32AT/DS26C32AM Quad Differential Line Receiver datasheet (Rev. C)
2022-11-04 17:22:44
DS9637A
DS9637A Dual Differential Line Receiver datasheet (Rev. D)
2022-11-04 17:22:44
OPE5194
OPE5194 - GaAs Infrared Emitter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE5194WK
OPE5194WK - GAAIAS INFRARED EMITTER - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE5294
OPE5294 - GaAs Infrared Emitter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE5585
OPE5585 - High Speed GaAlAs Infrared Emitter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE5587
OPE5587 - High Speed GaAlAs Infrared Emitter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE5794
OPE5794 - GaAlAs Infrared Emitter - OPTEK Technologies
2022-11-04 17:22:44
OPE5985
OPE5985 - High Speed GaAlAs Infrared Emitter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE5T62UO
OPE5T62UO - AIGaInP Ultra Bright Orange LED Lamp - List of Unclassifed Manufacturers
2022-11-04 17:22:44
OPE6794WK
OPE6794WK - GaAlAs Infrared Emitter - List of Unclassifed Manufacturers
2022-11-04 17:22:44
ADSP-2172
ADSP-2172 - DSP Microcomputer - Analog Devices
2022-11-04 17:22:44
AutoCAD_2012_Simplified_Chinese免费下载
]AutoCAD_2012_Simplified_Chinese_Win_32bit_Trial.exe[hide]http://115.com/file/dp505l17#[/hide]AutoCAD_2012_Simplified_Chinese_Win_64bit_Trial.exe
2012-03-01 16:12:06
B82614R2172A030
B82614R2172A030 - Power line chokes - EPCOS
2022-11-04 17:22:44
B82732-W2172-B30
B82732-W2172-B30 - Chokes for Power Lines D Core Chokes - EPCOS
2022-11-04 17:22:44
B82732R2172B030
B82732R2172B030 - Power line chokes - EPCOS
2022-11-04 17:22:44
B82734R2172B030
B82734R2172B030 - Power line chokes - EPCOS
2022-11-04 17:22:44
B82734W2172B030
B82734W2172B030 - Power line chokes - EPCOS
2022-11-04 17:22:44
EUS-704.01-2172
* (704-01-2172) LIGHTED PUSHBUTT
2024-03-14 21:15:03
Gowin SPDIF Receiver IP用户手册
Gowin SPDIF Receiver IP用户手册主要包括功能特征、整体框图、工作原理、信号定义、参数介绍、接口时序、GUI 调用等,旨在帮助用户快速了解高云半导体 SPDIF Receiver IP 的产品特性和使用方法,加速用户产品开发。
2022-10-09 06:20:52
Gowin SPDIF Receiver IP用户指南
本次发布 Gowin SPDIF Receiver IP 及其用户指南。Gowin SPDIF Receiver IP 的用户指南可在高云官网下载
2022-10-09 06:20:21
H8S2172
H8S2172 - Renesas 16-Bit Single-Chip Microcomputer H8S Family/H8S/2100 Series - Renesas Technology Corp
2022-11-04 17:22:44
IR2172
IR2172 - LINEAR CURRENT SENSING IC - International Rectifier
2022-11-04 17:22:44
MAX2172EVKIT+
KIT EVAL FOR MAX2172
2023-03-22 19:18:40
NJM2172V
NJM2172V - OPERATIONAL AMPLIFIER WITH EVR - New Japan Radio
2022-11-04 17:22:44
上广电D2173D2172彩电原理图相关资料下载
上广电D2173/D2172彩电原理图文件下载
2021-07-05 06:00:08
关于Rx receiver的问题
我在FPGA中例化了两个RX receiver,有时候其中一个接收器的输入端悬空(也就是该接收器没有跟发送器有数据链路链接),这样该接收器送出的rx_ctrldetect不会是10(假设设计中约定
2014-11-18 15:12:49
如何去简化Simplified TCP/IP协议栈?
Simplified TCP/IP协议栈的特点是什么?如何去简化Simplified TCP/IP协议栈?Simplified TCP/IP协议栈处理流程是怎样的?
2021-05-26 07:23:37
运行RTD示例“I2s_Sai_example_S32K344”,I2S_SAI_RECEIVER 的超时问题如何解决?
我正在尝试运行 RTD 示例“I2s_Sai_example_S32K344”,但我遇到了 I2S_SAI_RECEIVER 的超时问题。 你能给我一些建议吗? 硬件:S32K3X4EVB-Q257
2023-06-01 08:22:14
DS3150 pdf datasheet (3.3V, DS
layer to DS3, E3, andSTS-1 lines. The receiver performs clock and datarecovery, B3ZS/HDB3 decoding, and loss-of-signalmon
2008-09-19 16:18:0119
Elcard GPS20 GPS receiver modu
The Elcard GPS2020 GPS-receiver is designed to fit the needs of today’s GPSmarket.The compact size
2009-03-16 09:49:308
NE564,SE564锁相环演示板在FM和FSK和BPSK解
applications: An FM demodulatorfor wideband analog signals; a data receiver for high speed FSKsignals; and a simplified BPSK adapta
2009-05-19 17:05:5196
康佳P2172S(CKP1604S,24C16) EPROM
康佳P2172S(CKP1604S,24C16) EPROM数据
2009-05-27 11:58:1412
Mobile Digital TV Receiver Sys
Mobile Digital TV Receiver System-On-Chip:The AS-101 is a highly integrated RF System-on-Chip
2009-10-05 08:45:419
DS90C402,pdf datasheet (Dual L
The DS90C402 is a dual receiver device optimized for highdata rate and low power applications.
2009-10-13 08:58:5816
DS90CR286A/DS90CR286AQ/DS90CR2
The DS90CR286A receiver converts the four LVDS datastreams (Up to 1.848 Gbps throughput or 231
2009-10-14 09:26:0612
DS90C387/DS90CF388,pdf datashe
The DS90C387/DS90CF388 transmitter/receiver pair is designedto support dual pixel data transmission
2009-10-14 10:11:0124
DS90C387A/DS90CF388A,pdf datas
The DS90C387A/DS90CF388A transmitter/receiver pair isdesigned to support dual pixel data
2009-10-14 10:18:2233
DS26C32AT/DS26C32AM,pdf,datash
The DS26C32A is a quad differential line receiver designedto meet the RS-422, RS-423, and Federal
2009-10-20 10:36:2815
DS8922/DS8922A/DS8923A,pdf,dat
The DS8922/22A and DS8923A are Dual Differential LineDriver and Receiver pairs. These devices
2009-10-20 11:26:0020
DS78LS120,datasheet,pdf(Dual D
The DS78LS120 is a high performance, dual differential, TTLcompatible line receiver for both
2009-10-20 13:44:2322
DUAL RS-232 DRIVER RECEIVER WI
The TRS232E is a dual driver/receiver that includes a capacitive voltage generator to supply TIA
2009-11-10 11:52:3679
Simplified Approach for Predic
Simplified Approach for Predicting Dynamic Thermal Behavior of Switching Electronic Devices
2009-11-29 17:18:0318
RFPA2172 模拟增益控制放大器
RFPA2172产品简介Qorvo 的 RFPA2172 是一款面向 3.6 V 手持系统的中功率高效放大器 IC。该器件采用先进的砷化镓异质结双极晶体管 (HBT) 工艺制造,设计用作 2.45
2023-04-20 11:32:23
A DSP-Based DS?CDMA Multiuser Receiver Employing Partial Par
Abstract— The implementation of advanced DS–CDMA re- ceivers based on multiuser
2010-07-01 16:42:3813
DF2172C交流毫伏表简易使用说明
DF2172C 具有双路输入,可选择通道测量交流信号的有效值。测电压灵敏度高,测频范围宽。
2010-08-13 18:49:020
SN75140,pdf(Dual Line Receiver
This device consists of a dual single-ended line receiver with TTL-compatible strobes and outputs.
2010-08-28 23:23:4913
基于DS2172的误码测试仪的设计
 在数字通信工程中,误码率是检验数据传输设备及其信道工作质量的一个主要指标,给出了采用AT89C51单片机结合误码测试器DS2172实现简单误码测试仪的设计。
2010-12-11 15:54:2528
Improving Receiver Sensitivity
Improving Receiver Sensitivity with External LNA Abstract: This application note presents
2008-09-17 16:20:08774
DVB-T Receiver Reference Desig
DVB-T Receiver Reference Design with the MAX3580 Abstract: The MAX3580 DVB-T reference design meets NorDig 1.0.3 and
2008-10-01 00:27:001756
MAX2172 Direct-Conversion to L
MAX2172 Direct-Conversion to Low-IF Tuner for Digital Audio Broadcast The MAX2172
2009-01-11 11:36:391183
MAX2172 直接变频至低IF的调谐器,用于数字音频广播
MAX2172 直接变频至低IF的调谐器,用于数字音频广播 MAX2172概述 The MAX2172 direct-conversion to low-IF tuner is designed for digital a
2009-01-22 13:40:09950
DS2172 BERT Interface to all D
Abstract: How to interface the DS2172/DS21372 BERT to all Dallas Semiconductor family of T1/E1
2009-04-18 11:33:54718
DS2172 Pattern Synchronization
Abstract: This application note describes the operation of pattern synchronization of the DS2172
2009-04-18 11:36:04716
DS2151, DS2153 Interfacing to
and DS2153 E1 single chip transceiver to the Brooktree Bt8221 and Bt8222 (ATM Receiver/Transmitter w/UTOPIA).
2009-04-20 10:44:041043
DS1020/DS1021 8位可编程延迟线-DS1020/
Abstract: This application note is designed to assist in the use of the DS1020/DS1021 programmable
2009-04-22 11:26:533057
MAX2172 直接变频至低IF的调谐器,用于数字音频广播 MAX2172直接变频至较低IF的调谐器设计用于数字音频广播(DAB)和地面数字多媒体广播(T-DMB),输入频
2009-07-18 17:27:35897
MAX2172 集成快速RSSI功能的数字无线调谐器,用于D
MAX2172 集成快速RSSI功能的数字无线调谐器,用于DAB和FM信号
2009-07-18 17:28:31817
MC3362 pdf(Low-Power Narrowband FM Receiver)
2011-04-11 10:54:24115
DS1884 pdf datesheet(SFF, SFP, and SFP+ modules)
SFF-8472 functionality. The combination of the DS1884 with the MAX3710 supports all transmitter and receiver functionality. The DS1884 includes modu
2011-08-04 11:29:0033
MAX2079 pdf datasheet_Octal Ultrasound Receiver
The MAX2079 fully integrated octal ultrasound receiver is optimized for high channel count
2012-01-19 16:16:3128
DS1886数据资料
functionalityfor GPON/EPON and 10G PON ONU applications.The combination of the DS1886 with the MAX3710supports all transmitter and receiver
2012-04-16 15:19:0022
TTP229_SPEC_V1.1(Simplified_Chin
TTP229_SPEC_V1.1(Simplified_Chinese) (1)中文资料,48脚
2015-11-25 10:13:4228
IrRC_Receiver_System
IrRC_Receiver_System,好东西,喜欢的朋友可以下载来学习。
2016-02-17 14:47:420
Part_E1_SDIO_Simplified_Specification
SDIO_Simplified_Specifcation_Ver3.00_20110225
2016-02-23 16:22:2020
伯特ds2155内部编程
的半导体独立伯特设备如ds2172ds2174能力,它 提供了许多常用的电信测试系统模式。本文档包含 初始化ds2155伯特开始误码率测试过程的必要步骤。
2017-04-12 09:03:173
TLV2172-Q1 汽车类 36V 单电源 10MHz 轨至轨输出运算放大器
电子发烧友网为你提供TI(ti)TLV2172-Q1相关产品参数、数据手册,更有TLV2172-Q1的引脚图、接线图、封装手册、中文资料、英文资料,TLV2172-Q1真值表,TLV2172-Q1管脚等资料,希望可以帮助到广大的电子工程师们。
2018-11-02 18:34:06
OPA2172 36V 单电源 10MHz 轨至轨输出运算放大器
电子发烧友网为你提供TI(ti)OPA2172相关产品参数、数据手册,更有OPA2172的引脚图、接线图、封装手册、中文资料、英文资料,OPA2172真值表,OPA2172管脚等资料,希望可以帮助到广大的电子工程师们。
2018-11-02 18:28:06
OPA2172-Q1 汽车类 36V 单电源 10MHz 轨至轨输出运算放大器
电子发烧友网为你提供TI(ti)OPA2172-Q1相关产品参数、数据手册,更有OPA2172-Q1的引脚图、接线图、封装手册、中文资料、英文资料,OPA2172-Q1真值表,OPA2172-Q1管脚等资料,希望可以帮助到广大的电子工程师们。
2018-11-02 18:28:06
TLV2172 36V 单电源 10MHz 轨至轨输出运算放大器
电子发烧友网为你提供TI(ti)TLV2172相关产品参数、数据手册,更有TLV2172的引脚图、接线图、封装手册、中文资料、英文资料,TLV2172真值表,TLV2172管脚等资料,希望可以帮助到广大的电子工程师们。
2018-11-02 18:26:06
两管FM接收头电路,FM receiver
两管FM接收头电路,FM receiver 关键字:两管FM接收头电路 两管FM接收头电路,使用晶体管搭建,电路零件容易取得,可以试试,不知道效果如何
2018-09-20 19:13:461103
LTC2172-12 12 位、65Msps 低功率 4 通道 ADC
电子发烧友网为你提供ADI(ti)LTC2172-12相关产品参数、数据手册,更有LTC2172-12的引脚图、接线图、封装手册、中文资料、英文资料,LTC2172-12真值表,LTC2172-12管脚等资料,希望可以帮助到广大的电子工程师们。
2019-02-22 12:59:34
LTC2172-14 14 位、65Msps 低功率 4 通道 ADC
电子发烧友网为你提供ADI(ADI)LTC2172-14相关产品参数、数据手册,更有LTC2172-14的引脚图、接线图、封装手册、中文资料、英文资料,LTC2172-14真值表,LTC2172-14管脚等资料,希望可以帮助到广大的电子工程师们。
2019-02-22 12:25:34
HMC920LP5 Simplified Gerber Files
2021-02-19 08:50:050
DC2172A-模式
DC2172A-模式
2021-04-19 13:13:070
DC2172A-演示手册
DC2172A-演示手册
2021-04-19 18:22:302
ADSP-2171/ADSP-2172/ADSP-2173:DSP微机报废数据表
2021-05-13 11:18:220
DC2172A-设计文件
DC2172A-设计文件
2021-06-05 15:51:260
基于DC2172A直流到直流多输出电源的参考设计
View the reference design for DC2172A. http://www.elecfans.com/soft/ has thousands of reference designs to help bring your project to life.
2021-07-04 10:00:392
基于LTC2172-14_Typical Application模拟到数字转换的参考设计
View the reference design for LTC2172-14_Typical Application. http://www.elecfans.com/soft/ has
2021-07-09 09:12:281
CS5265替代RTD2172TYPEC转HDMI2.0芯片
CS5265与RTD2172不管是在功能应用上,还是各项系统参数上都是一致,所有CS5265是完全可以替代兼容RTD2172,且CS5265设计简单外围器件较少,整体BOM成本较低且板子功耗较低,长时间的转换或者投屏不会使板子急速升温,导致投屏的效率和兼容性出现不良问题。
2021-11-04 09:49:43628
CS5265替代RTD2172转HDMI芯片的方案
瑞昱RTD2172是TYPEC转HDMI4K60HZ音视频数据转换器芯片。CapstoneCS5265可以替代兼容RTD2172,除了实现同等的转换功能外且整体方案成本和性价比方面比RTD2172
2021-12-03 17:40:361834
Gowin SPDIF Receiver IP 用户手册主要包括功能特征、整体框图、工 作原理、信号定义、参数介绍、接口时序、GUI 调用等,旨在帮助用户快速 了解高云半导体 SPDIF Receiver IP 的产品特性和使用方法,加速用户产品 开发。
2022-09-15 09:37:051
DS2172 BERT 接口到所有 Dallas 成帧器和收发器
2022-11-18 23:45:280
DS2172 BERT接口连接所有达拉斯成帧器和收发器
如何将DS2172/DS21372 BERT连接至达拉斯半导体的所有T1/E1成帧器和单芯片收发器(SCT)。
2023-01-10 09:38:29421
DS2172T 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172T相关产品参数、数据手册,更有DS2172T的引脚图、接线图、封装手册、中文资料、英文资料,DS2172T真值表,DS2172T管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:03:30
DS2172T/T&R 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172T/T&R相关产品参数、数据手册,更有DS2172T/T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS2172T/T&R真值表,DS2172T/T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:03:52
DS2172TN 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172TN相关产品参数、数据手册,更有DS2172TN的引脚图、接线图、封装手册、中文资料、英文资料,DS2172TN真值表,DS2172TN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:40:24
DS2172T+T&R 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172T+T&R相关产品参数、数据手册,更有DS2172T+T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS2172T+T&R真值表,DS2172T+T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:52:45
DS2172TN+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172TN+相关产品参数、数据手册,更有DS2172TN+的引脚图、接线图、封装手册、中文资料、英文资料,DS2172TN+真值表,DS2172TN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:52:57
DS2172TN+T&R 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172TN+T&R相关产品参数、数据手册,更有DS2172TN+T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS2172TN+T&R真值表,DS2172TN+T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-15 18:09:01
DS2172T+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2172T+相关产品参数、数据手册,更有DS2172T+的引脚图、接线图、封装手册、中文资料、英文资料,DS2172T+真值表,DS2172T+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-30 18:13:21
HAT2172N 数据表
HAT2172N 数据表
2023-04-27 18:40:460
HAT2172H 数据表
HAT2172H 数据表
2023-05-11 18:59:430
HAT2172H 数据表
HAT2172H 数据表
2023-06-28 19:22:210
已全部加载完成
