电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>DS3112 LRCLKx Low Speed Clock
收藏
查看更多
DS3112
IC TELECOM INTERFACE 256BGA
2023-04-06 11:49:52
DS3112DK
KIT DEMO FOR DS3112
2023-03-30 11:45:09
STM32F4时钟系统参数含义解释
外部时钟, 最大可接受50MHz时钟(可外接最大的晶振为26MHz).LSI: Low Speed Internal clock, 低速内部时钟, 32KHz.LSE: Low Spe...
2021-08-12 07:03:16
STM32时钟可大致分为几大类
)、HSE(High Speed External Clock)、LSI(low Speed Internal Clock)、LSE(Low Speed External Clock )、PLL(Phas...
2021-08-12 06:18:55
USB Low Speed 设备可以实现CDC虚拟串口功能吗?
2023-06-07 08:44:06
配置RCCHigh Speed Clock(HSE)
1 配置RCCHigh Speed Clock(HSE)选择第三项(即外部时钟源)2 配置SYSDebug选择第二项Serial Wire3 设置时钟切换到Clock Configuration,按
2021-08-10 06:25:36
ds3231 pdf
Extremely Accurate I2C-Integrated RTC/TXO/Crystal The DS3231 is a low-cost, extremely accurate
2008-04-14 14:04:3464
DS1080CL pdf
The DS1080CL is a low-jitter, crystal-based clock gen-erator with an integrated phase-locked loop
2008-06-30 12:50:5014
DS108x Spread-spectrum clock m
DS108x Spread-spectrum clock modulators reduce peak EMI Pin-selectable dither rate and magnitude
2008-07-25 01:26:0610
DS1337/DS1337C pdf datasheet (
The DS1337 serial real-time clock is a low-powerclock/calendar with two programmable
2008-08-10 10:38:5036
DS83C520/DS87C520 pdf datashee
The DS87C520/DS83C520 EPROM/ROM high-speed microcontrollers are fast 8051-compatible
2008-08-13 14:02:2518
ISL12082 pdf datasheet (Low Po
CompensationThe ISL12082 device is a low power real time clock withtiming and crystal compensation, clock/calendar, power failindicator,
2009-01-18 22:23:5614
ISL12030 pdf datasheet (Low Po
is a low power real time clock with50/60 AC input for timing synchronization, clock/calendarregisters, single periodic or polled
2009-01-19 11:28:5816
2009-01-19 11:34:306
ISL12022 pdf datasheet (Low Po
real time clock with anembedded Temp sensor for oscillator compensation,clock/calendar, power fail, low battery monitor, brownout
2009-01-19 12:01:2316
ISL12008 pdf datasheet (Low Po
Low Power RTC with Battery ReSeal™ FunctionThe ISL12008 device is a low power real time clock
2009-01-19 12:12:5818
ISL12023 pdf datasheet (Low Po
SavingThe ISL12023 device is a low power real time clock with anembedded Temp sensor for oscillator compensation,clock/calendar,
2009-01-19 12:15:149
W83116WG pdf Datasheet(V11 Low Power Clock Gen for Intel CK50
The W83116WG-511 is a low power clock synthesizer for Intel CK505 compatible platform, which has
2009-01-20 14:37:47138
High Speed/Low Loss, CAF Resis
High Speed/Low Loss, CAF Resistant, Lead-Free SolutionTypical Engineering Values
2009-03-24 13:09:290
DS4625 pdf datasheet (3.3V Dua
The DS4625 is a dual-output, low-jitter clock oscillator capable of producing frequency output pair
2009-03-31 11:03:0214
High-Speed Differential Signal
High-Speed Differential Signaling in Cyclone Devices From high-speed backplane applications
2009-05-14 10:42:2321
Interfacing to High Speed ADCs
on The SPI port consists of three pins: the serial clock pin (SCLK), Analog Devices, Inc., high speed converters. In addition, this the serial d
2009-09-30 19:43:3915
Motor Speed Measurement Consid
; generation of DSPs provide appropriate internal hardware forinterfacing with low-cost, external-speed sensors for motor speed measureme
2009-10-01 19:03:2417
DS90LV110AT,pdf datasheet (1 t
DS90LV110A is a 1 to 10 data/clock distributor utilizing LVDS(Low Voltage Differential Signaling
2009-10-12 15:54:0915
DS90LV110T,pdf datasheet (1 to
DS90LV110 is a 1 to 10 data/clock distributor utilizing LVDS(Low Voltage Differential Signaling
2009-10-12 15:56:2611
DS32EL0124/DS32ELX0124,pdf dat
The DS32EL0124/DS32ELX0124 integrates clock and datarecovery modules for high-speed serial
2009-10-14 08:52:5020
DS92LV1021A,pdf datasheet (16-
The DS92LV1021A transforms a 10-bit wide parallelLVCMOS/LVTTL data bus into a single high speed
2009-10-14 09:15:3717
DS90CR287/DS90CR288A,pdf datas
The DS90CR287 transmitter converts 28 bits of LVCMOS/LVTTL data into four LVDS (Low Voltage
2009-10-14 09:24:0249
DS90CR483A/DS90CR484A,pdf data
The DS90CR483A transmitter converts 48 bits of CMOS/TTLdata into eight LVDS (Low Voltage
2009-10-14 09:30:3713
DS90CR481/DS90CR482,pdf datash
The DS90CR481 transmitter converts 48 bits of CMOS/TTLdata into eight LVDS (Low Voltage
2009-10-14 09:35:4311
DS90CR285/DS90CR286,pdf datash
The DS90CR285 transmitter converts 28 bits of LVCMOS/LVTTL data into four LVDS (Low Voltage
2009-10-14 09:39:0929
DS90CR215/DS90CR216,pdf datash
The DS90CR215 transmitter converts 21 bits of CMOS/TTLdata into three LVDS (Low Voltage
2009-10-14 09:44:2623
DS90CR485,pdf datasheet (133MH
The DS90CR485 serializes the 24 LVCMOS/LVTTL doubleedge inputs (48 bits data latched in per clock
2009-10-14 09:45:4315
DS90UR908Q,pdf datasheet (5 -
The DS90UR908Q converts FPD-Link II to FPD Link. It translatesa high-speed serialized interface
2009-10-14 09:49:3411
DS90UR905Q/DS90UR906Q,pdf data
The DS90UR905Q/906Q chipset translates a parallel RGBVideo Interface into a high-speed serialized
2009-10-14 10:00:2442
DS99R421,pdf datasheet (5-43 M
The DS99R421 converts a FPD-Link input with 4 non-DCBalanced LVDS (3 LVDS Data + LVDS Clock) plus
2009-10-14 10:08:529
DS90C363/DS90CF364,pdf datashe
The DS90C363 transmitter converts 21 bits of CMOS/TTLdata into three LVDS (Low Voltage Differential
2009-10-14 10:13:4426
DS90CF563/DS90CF564,pdf datash
The DS90CF563 transmitter converts 21 bits of CMOS/TTLdata into three LVDS (Low Voltage
2009-10-14 10:20:3324
DS90C383/DS90CF384,pdf datashe
The DS90C383 transmitter converts 28 bits of LVCMOS/LVTTL data into four LVDS (Low Voltage
2009-10-14 10:22:2522
DS34LV86T,pdf,datasheet (3V En
The DS34LV86T is a high speed quad differential CMOS receiverthat meets the requirements of both
2009-10-20 10:33:5420
DS26LV31T,pdf,datasheet (3V En
The DS26LV31T is a high-speed quad differential CMOSdriver that meets the requirements of both TIA
2009-10-20 10:58:582
2009-10-20 10:59:0524
DS34LV87T,pdf,datasheet (Enhan
The DS34LV87T is a high speed quad differential CMOSdriver that meets the requirements of both TIA
2009-10-20 11:36:0518
DS89C386,datasheet,pdf(Twelve
The DS89C386 is a high speed twelve channel CMOS differentialreceiver that meets the requirements
2009-10-20 13:38:0212
DS89C387,datasheet,pdf(Twelve
The DS89C387 is a high speed twelve channel CMOS differentialdriver that meets the requirements
2009-10-20 13:50:4018
SIL3112RAID 2口SATA卡驱动
SIL3112RAID 2口SATA卡驱动下载.
2009-12-09 21:22:4117
MAX9150,pdf,datasheet (low-vol
for applications that require high-speed data or clock distribution while minimizing power, space, and noise. The device accepts a single LVDS
2009-12-19 10:28:2136
AAT3112,pdf datasheet(500mA Hi
AAT3112,pd
2010-01-30 09:57:119
ZXGD3112N7 MOSFET 控制器
ZXGD3112N7产品简介 DIODES 的 ZXGD3112N7 是一款 400V 有源 OR'ing MOSFET 控制器,设计用于驱动极低 R DS(ON)功率 MOSFET 作为
2023-06-02 16:07:39
CD54HC4017,CD74HC4017,pdf(High
of the decoded outputs is normally low and sequentially goes high on the low to high transition clock period of the 10 clock period cy
2010-08-10 17:06:5815
CD74HC4017-Q1,pdf(High-Speed C
Each of the decoded outputs normally is low and sequentially goes high on the low-to-high transition clock period of the ten-clock-period
2010-08-10 17:08:3720
SN74ACT3631,pdf(512 X 36 Clock
The SN74ACT3631 is a high-speed, low-power, CMOS clocked FIFO memory. It supports clock frequencies
2010-08-19 16:45:237
TMP814,pdf(Variable Speed Sing
with an external PWM signal. A highly efficient, quiet and low power consumption motor driver circuit, with a large variable speed, can be implement
2010-08-30 11:26:2812
TMP816,pdf(Variable Speed Sing
PWM signal. A highly efficient, quiet and low power consumption motor driver circuit with a large variable speed can be implemented by a
2010-08-30 11:28:538
THS3112,THS3115,pdf(Low-Noise,
The THS3112/5 are low-noise, high-speed current feedback amplifiers, ideal for any application
2010-09-12 19:08:4615
OPA2832,pdf(dual, low-power, high-speed, fixed-gain amplifier)
The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single
2010-09-12 23:31:1611
TLE2021-EP,pdf(Excalibur High-Speed Low-Power Precision OP A
The TLE202x and TLE202xA devices are precision, high-speed, low-power operational amplifiers using
2010-12-13 21:20:4846
Design a Low-Jitter Clock for
Abstract: High-speed applications using ultra-fast data converters in their design often require
2009-04-16 16:34:231576
Using the DS87C530/DS5250 Real
Abstract: The Dallas Semiconductor DS87C530 high-speed microcontroller with real-time clock (RTC
2009-04-18 10:48:58562
DS31256 Gapped Clock Applicati
Abstract: This application note discusses how to realize gapped clock applications with the DS
2009-04-18 11:32:20921
DS31256 -- T3/E3 MUX/DS3112 Ha
Abstract: Application Note 3344 shows how to configure the hardware connections that can be utilized with various Dallas Semiconductor devices. It includes the HDLC Controller, Framer, MUX and Line Interface Unit. O
2009-04-20 08:44:22851
DS3112 Clock Rates and Frequen
Abstract: The DS3112 has six different transmit clock and six different receive clock types
2009-04-20 09:51:19625
DS2152, DS2154 Clock Map
Semiconductor/Maxim DS2154 and DS2152 single chip transceivers (SCTs). Figure 1 logically describes the clock map of the DS2152 and
2009-04-20 10:21:38788
DS1375 Power Line to 60Hz Cloc
Abstract: The DS1375 2-wire digital real-time clock (RTC) is a low-power, clock/calendar that can
2009-04-21 09:29:481131
Replacing the DS1287/DS12887 R
Abstract: This application note describes the replacement of the DS1287/DS12887 real-time clock
2009-04-21 10:02:462052
使用DS87C530/DS5250实时时钟-Using th
2009-04-23 10:28:461120
DS89C430/DS89C450超高速闪存微控制器存储器接
Abstract: The Dallas Semiconductor DS89C430 ultra high-speed microcontroller
2009-04-23 15:04:36878
DS2152,DS2154时钟地图-DS2152, DS21
2009-04-29 10:12:051523
DS4426 Low-cost, quad sink/sou
DS4426 Low-cost, quad sink/source current DAC for power-supply adjustments and tracking
2009-08-27 15:10:18712
MAX44260,MAX44261(high speed,precision,low noiseoperation)
The MAX44260/MAX44261 offer a unique combination ofhigh speed, precision, low noise
2011-08-16 09:47:3227
MAX24188 pdf( low-cost IEEE 1588 clock )
The MAX24188 is a flexible, low-cost IEEE 1588 clock designed to be the central 1588 time base
2011-08-24 10:37:5018
DS1338串行实时时钟资料
The DS1338 serial real-time clock (RTC) is a low-power, full binary-coded decimal (BCD) clock
2011-10-18 15:40:1247
DS1088英文资料
The DS1088L is a low-cost clock generator that producesa square-wave output without external timing
2012-01-17 17:11:183
DS3232M数据资料
The DS3232M is a low-cost, extremely accurate, I2Creal-time clock (RTC) with 236 bytes
2012-03-23 11:16:0153
DS1080L数据资料
The DS1080L is a low-jitter, crystal-based clock generatorwith an integrated phase-locked loop (PLL
2012-05-30 10:47:1620
DS1308数据资料
The DS1308 serial real-time clock (RTC) is a low-power,full binary-coded decimal (BCD) clock
2012-06-08 14:44:1224
DS1135L数据资料
The DS1135L series is a low-power, 3V high-speed version of the popular DS1013, DS1033, and DS
2012-09-11 17:30:4039
DS1088C,datasheet资料
The DS1088C is a low-cost clock generator that producesa square-wave output without external
2012-12-12 18:16:3419
DS92LV2421和DS92LV2422串行器与解串器资料
LVCMOS data interface into a single high-speed CML serial interface with embedded clock information.
2017-09-11 11:51:3414
TPA3112D1-Q1 具有 SpeakerGuardT 功能的汽车类 25W 无滤波器单声道 D 类音频放大器 (TPA3112)
电子发烧友网为你提供TI(ti)TPA3112D1-Q1相关产品参数、数据手册,更有TPA3112D1-Q1的引脚图、接线图、封装手册、中文资料、英文资料,TPA3112D1-Q1真值表,TPA3112D1-Q1管脚等资料,希望可以帮助到广大的电子工程师们。
2018-11-02 17:57:06
TPA3112D1 具有 SpeakerGuard™ 的 25W 单声道无滤波器 D 类音频放大器 (TPA3112)
电子发烧友网为你提供TI(ti)TPA3112D1相关产品参数、数据手册,更有TPA3112D1的引脚图、接线图、封装手册、中文资料、英文资料,TPA3112D1真值表,TPA3112D1管脚等资料,希望可以帮助到广大的电子工程师们。
2018-11-02 17:56:06
NUP3112UPMUTAG 电涌保护器 四路 超低电容
电子发烧友网为你提供ON Semiconductor(ti)NUP3112UPMUTAG相关产品参数、数据手册,更有NUP3112UPMUTAG的引脚图、接线图、封装手册、中文资料、英文资料,NUP3112UPMUTAG真值表,NUP3112UPMUTAG管脚等资料,希望可以帮助到广大的电子工程师们。
2019-08-05 08:02:22
NUD3112 继电器驱动器 12 V
电子发烧友网为你提供ON Semiconductor(ti)NUD3112相关产品参数、数据手册,更有NUD3112的引脚图、接线图、封装手册、中文资料、英文资料,NUD3112真值表,NUD3112管脚等资料,希望可以帮助到广大的电子工程师们。
2019-07-30 11:02:20
ADCLK854: 1.8 V, 12-LVDS/24-CMOS Output, Low Power Clock Fanout Buffer Data Sheet
2021-01-28 02:20:390
AD9540: 655 MHz Low Jitter Clock Generator Data Sheet
2021-01-28 15:37:316
DS3112 时钟速率和发送时钟的频率容差
2022-11-18 23:45:230
SN3112-12路LED驱动
简介 SN3112-12 是一款 12 路呼吸灯驱动芯片,每路单独256 级细腻亮度可控。单路最大输出电流可以通过一个外部电阻设定,最大电流为38mA。 主控器件通过I2C 接口
2022-11-28 17:48:19674
DS3112 DS3/E3多路复用成帧器如何恢复低速时钟信号
第一级,即M23级,将DS3信号解复用为7个独立的DS2信号。不是恢复单个DS2时钟,而是创建DS2使能。七个DS2使能中的每一个都处于活动状态,每个DS3帧的DS3时钟周期为84 x 7 +(84或83)。恢复最后的84或83个DS3时钟周期的决定基于DS2填充位控制。
2023-01-13 10:50:26760
DS3112+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112+相关产品参数、数据手册,更有DS3112+的引脚图、接线图、封装手册、中文资料、英文资料,DS3112+真值表,DS3112+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 18:49:49
DS3112D1 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112D1相关产品参数、数据手册,更有DS3112D1的引脚图、接线图、封装手册、中文资料、英文资料,DS3112D1真值表,DS3112D1管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:25:53
DS3112N+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112N+相关产品参数、数据手册,更有DS3112N+的引脚图、接线图、封装手册、中文资料、英文资料,DS3112N+真值表,DS3112N+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:27:14
DS3112 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112相关产品参数、数据手册,更有DS3112的引脚图、接线图、封装手册、中文资料、英文资料,DS3112真值表,DS3112管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:35:23
DS3112N 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112N相关产品参数、数据手册,更有DS3112N的引脚图、接线图、封装手册、中文资料、英文资料,DS3112N真值表,DS3112N管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:36:01
DS3112+W 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112+W相关产品参数、数据手册,更有DS3112+W的引脚图、接线图、封装手册、中文资料、英文资料,DS3112+W真值表,DS3112+W管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 20:12:57
DS3112D1+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS3112D1+相关产品参数、数据手册,更有DS3112D1+的引脚图、接线图、封装手册、中文资料、英文资料,DS3112D1+真值表,DS3112D1+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 20:13:44
DS3112 LRCLKx低速时钟恢复工作原理
DS3112 DS3/E3多路复用成帧器具有三种多路复用工作模式。本应用笔记描述了器件如何从三种工作模式下的高速多路复用信号中恢复低速时钟信号。该说明解释了高速信号中的数据如何影响恢复过程。
2023-02-07 11:36:46495
DS3112发送时钟的时钟速率和频率容差
在发射端,DS3(E3)时钟和DS1(E1)时钟由输入引脚派生,但DS2(E2)时钟频率是DS3(E3)时钟频率的一小部分。出于设计原因,分数将表示为整数比率,这取决于设备的模式。DS1(E1)时钟可以容忍基于DS3(E3)时钟频率和器件模式的频率范围。
2023-02-22 10:10:18467
2023-06-12 10:06:22248
DS3112具有六种不同的发送时钟和六种不同的接收时钟类型:发送DS3、DS2、DS1、E3、E2和E1时钟,以及接收DS3、DS2、DS1、E3、E2和E1时钟。由于电路中同一级的时钟具有相似
2023-06-13 15:39:46317
已全部加载完成
