Abstract: Application Note 407 provides a focused view of the functionality of the Dallas Semiconductor/Maxim DS2148/DS21348 selectable E1 or T1 line interface unit (LIU) in hardware mode along with references to software mode features to aid designers creating applications using hardware mode only. IntroductionThere are two major modes of operation for the DS2148/DS21348: software and hardware mode. The "mode" refers to the method used to control the functionality of the device. Applications implementing software mode use a microcontroller's serial or parallel bus to communicate to the control registers contained in the DS2148/DS21348. In hardware mode, the functions of the serial/parallel communication bus pins are reassigned such that the pins' logic state provide direct control of the internal functionality of the DS2148/DS21348.The DS2148 and DS21348 data sheets contain all the information required to implement the DS2148/DS21348 in designs using a T1 or E1 interface. The data sheets were written with the software mode user in mind and therefore contain information required to set up the DS2148/DS21348 using the control registers and the additional functionality available in software mode that is not available when using hardware mode. This application note provides a focused view of the functionality of the DS2148/DS21348 in hardware mode along with references to software mode features to aid designers creating applications using hardware mode only. Should Hardware Mode Be Used?The advantage of using the DS2148/DS21348 in hardware mode is that no microcontroller is required to control the functionality. Each application has specific requirements that determine whether or not hardware mode can be used. The primary consideration is whether or not any of the features available only in software mode are required in the application. Table 1 provides a list of all the software mode features that are totally eliminated in hardware mode. The register bit position and name is provided to allow ease in referencing the complete description of the functionality contained in the DS2148 and DS21348 data sheets.Hardware Mode ImplementationAll the primary functions that require the ability to change are controlled by external pins in hardware mode. Table 2 provides a reference for the functionality of the software mode bit positions and the corresponding pin that is used in hardware mode to control the DS2148/348.While some software controllable features are unavailable in hardware mode, the DS2148/DS21348 default functionality was carefully chosen to perform as expected in normal applications. Table 3 lists the features and their default operation in hardware mode. A complete description of the hardware mode functionality of each of the pins is provided in Table 4. Figures 1, 2, and 3 provide block diagrams representative of the functionality of the DS2148/DS21348 in hardware mode and are similar to their software mode counterparts in the data sheets. In contrast to the block diagrams provided in the data sheets, the external pins of the DS2148/DS21348 replace references to the control registers. Software-mode-only functions have also been removed. Although most DS2148/DS21348 applications implement software mode, hardware mode remains a viable option for many customers. Using this document along with the DS2148 and DS21348 data sheets provides the information required to get a hardware mode application up and running with minimal time and effort. Table 1. Software mode features eliminated in hardware mode
Table 2. Hardware mode pin control/register reference
Table 3. Hardware mode default functionality
Table 4. Pin descriptions in hardware mode (sorted by pin name, DS2148/348T pin numbering)
![]() Figure 1. DS2148/DS21348 hardware mode block diagram. ![]() Figure 2. DS2148/DS21348 hardware mode receive logic. ![]() Figure 3. DS2148/DS21348 hardware mode transmit logic.
DS2148/DS21348 Hardware Mode
- DS2(42921)
- DS2148(5650)
DS-5教程-ARM DS-5 添加新芯片至DS-5调试设备列表
utility(/home/userx/DS-5/bin/cdbimporter)Hardware Configuration utility(/home/userx/DS-5/bin/dbghwconfig
2014-10-13 18:17:15
DS1702K
DS75, DS1621, DS1624, DS1629, DS1721, DS1775 - Temperature Sensor Evaluation Board
2023-03-30 11:59:31
DS2431
********************************************************//******************************************函数名称:GPIO_DS2431_Out_Mode功 能:设置DS2431引脚为开漏输出
2014-03-12 11:04:08
LSM9DS0和LSM9DS1之间的磁强计差异
我们正在将IMU从LSM9DS0升级到LSM9DS1。但是我们在LSM9DS1上遇到了磁力计的问题。即使在最小/最大校准之后,它似乎也没有给出正确的航向。我们意识到方向已经改变并考虑到了这一点。当
2019-06-12 13:10:48
STM32与DS1302接口
作者在某STM32的应用中外接了一块DS1302,借鉴原来写过的PIC代码,很快移植成功。在这里与大家分享一下。(1)硬件 CLK PA4DAT PA5 RST PA6(2)硬件初始化 CLK
2011-07-26 09:14:53
arm力天电子 lpc2148基于DS18B20的温度控制系统程序代码之dat=(...
arm力天电子 lpc2148基于DS18B20的温度控制系统程序代码之dat=(j《《7)|(dat》》1)详解//读
2014-03-24 14:22:07
为什么LSM9DS1会无法更改FIFO模式?
LSM9DS1无法更改FIFO模式 #fifo#lsm9ds1 #imu以上来自于谷歌翻译以下为原文 LSM9DS1 unable to change FIFO mode #fifo #lsm9ds1 #imu
2019-06-13 09:32:45
求基于arm的多DS18B20温度测量系
要求利用两个以上DS18B20温度传感器,共用数据线,测量温度, lpc2148,将温度显示在LCD上。完全没有思路 能告诉我该怎么入手?
2016-06-21 18:00:04
DS1992,DS1993 pdf datasheet (1
The DS1992/DS1993 memory iButtons (hereafter referred to as DS199_) are rugged read/write data
2008-10-24 13:57:51
16
![](https://skin.elecfans.com/images/2021-soft/load.png)
DS2155 Monitor Mode Design
Abstract: Application note 400 describes how to connect the Dallas Semiconductor DS2155 single chip
2009-04-20 09:17:26
23
DS1085/DS1085L EconOscillator频
Abstract: The DS1085/DS1085L produces a wide range of frequencies on the main oscillator output
2009-04-22 11:02:49
27
DS1904,pdf,datasheet (RTC iBut
hardware. Data is transferred serially by the 1-Wire® protocol, which requires only a single data lead and a ground return. The DS1
2009-10-03 08:35:25
39
DS17285, DS17287, DS17485,pdf
The DS17285, DS17485, DS17885, DS17287, DS17487,and DS17887 real-time clocks (RTCs) are designed
2010-05-09 10:27:39
16
DS17487, DS17885, DS17887,pdf
2010-05-09 10:29:52
31
1.5/45 Mb/s (DS1/DS3) Line Int
Product Features•Cell based implementation•Selectable mode as DS1 or DS
2010-07-10 10:14:25
12
DS26522 JTAG Scan Chain Mappin
Abstract: This application note describes the JTAG hardware boundary scan chain for the DS
2009-04-18 11:45:52
793
![](https://skin.elecfans.com/images/2021-soft/eye.png)
![](https://file1.elecfans.com//web2/M00/A4/C5/wKgZomUMNZ-AbF7RAAATfDXGayA254.gif)
Additional Pulse Amplitude Set
IntroductionThis application note provides the register settings for the DS2148/DS21348/DS21Q48/DS213Q48 and D
2009-04-20 09:15:14
531
DS31256 and T1/E1 Interface
2155, DS21Q55, DS21Q50 and DS26528 in T1/E1, 2MHz, 4MHz, 8MHz clock mode. The hardware connection and software configuration are given.
2009-04-20 09:26:34
1389
![](https://file1.elecfans.com//web2/M00/A4/C6/wKgZomUMNaSAfUDFAACHM06WWgA020.gif)
DS2151, DS2152, DS2153, DS2154
Transceivers: DS2151, DS2152, DS2153, DS2154, DS21552, DS21554, DS21352, DS21354 and DS2155. Specifications for selecting the approp
2009-04-20 09:38:44
760
Using DS2148/348 as Repeater
Abstract: Application Note 387 describes the use of the Dallas Semiconductor/Maxim DS2148/DS21348
2009-04-20 09:40:41
837
![](https://file1.elecfans.com//web2/M00/A4/C6/wKgZomUMNaSASOTjAAAjFBtc18s767.gif)
Converting the DS2151/DS2153 D
Abstract: The DS2151DK and DS2153DK are ordered and shipped for either T1 or E1 operation. However
2009-04-20 10:25:02
559
DS2141A, DS2143, DS2151 and DS
Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:41:16
744
![](https://file1.elecfans.com//web2/M00/A4/C7/wKgZomUMNaWAfPfEAAARPTUeuVw489.gif)
DS21Q42 vs. DS21Q41B
Abstract: This application note describes the hardware and software differences between the Dallas
2009-04-20 10:47:48
698
DS21Q44 vs. DS21Q43A
2009-04-20 10:49:25
1304
转换DS2151/DS2153演示套件-Converting
2009-04-29 10:13:03
1037
DS2141A , DS2143 , DS2151 , DS
2009-04-29 10:18:40
496
![](https://file1.elecfans.com//web2/M00/A4/D3/wKgZomUMNduAGhtNAAAOkGtLygM278.gif)
2009-04-29 10:21:40
752
![](https://file1.elecfans.com//web2/M00/A4/D3/wKgZomUMNduAJauEAAARPTUeuVw465.gif)
2009-04-29 10:26:37
861
Getting Started with the DS278
The DS2780K Datasheet provides information on connecting the hardware and installing the software on the PC. This Application Note provides a detai
2009-04-30 11:47:19
1302
![](https://file1.elecfans.com//web2/M00/A4/D5/wKgZomUMNeCATffbAAC7ASBUX9Y069.gif)
DS1875 Quick Reference Guide
Abstract: The DS1875 burst-mode PON controller with integrated monitoring allows programmi
2009-09-27 11:19:42
1214
![](https://file1.elecfans.com//web2/M00/A5/48/wKgZomUMN7iASzthAAAh5oPPmYY920.gif)
DS17285, DS17287, DS17485, DS1
DS17285, DS17287, DS17485, DS17487, DS17885, DS17887实时时钟应用电路
2010-05-09 10:34:54
870
![](https://file1.elecfans.com//web2/M00/A5/95/wKgZomUMORqAGOCpAAASHqUacM8340.gif)
DS2148、DS21348、DS21Q48、DS21Q348 和 DS21448 的附加脉冲幅度设置
2022-11-18 23:45:41
DS1834DS PMIC - 监控器
电子发烧友网为你提供Maxim(Maxim)DS1834DS相关产品参数、数据手册,更有DS1834DS的引脚图、接线图、封装手册、中文资料、英文资料,DS1834DS真值表,DS1834DS管脚等资料,希望可以帮助到广大的电子工程师们。
2022-12-07 19:55:11
![](https://file.elecfans.com/web2/M00/70/70/pYYBAGNH-I2AMV23AAAJwg3rnZc603.png)
DS1831DS PMIC - 监控器
电子发烧友网为你提供Maxim(Maxim)DS1831DS相关产品参数、数据手册,更有DS1831DS的引脚图、接线图、封装手册、中文资料、英文资料,DS1831DS真值表,DS1831DS管脚等资料,希望可以帮助到广大的电子工程师们。
2022-12-16 22:21:41
DS1831DS+ PMIC - 监控器
电子发烧友网为你提供Maxim(Maxim)DS1831DS+相关产品参数、数据手册,更有DS1831DS+的引脚图、接线图、封装手册、中文资料、英文资料,DS1831DS+真值表,DS1831DS+管脚等资料,希望可以帮助到广大的电子工程师们。
2022-12-26 11:28:03
DS1834DS+ PMIC - 监控器
电子发烧友网为你提供Maxim(Maxim)DS1834DS+相关产品参数、数据手册,更有DS1834DS+的引脚图、接线图、封装手册、中文资料、英文资料,DS1834DS+真值表,DS1834DS+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-03 19:29:26
DS2148/DS21348硬件模式
随机数用于许多加密和身份验证方案。随机数的生成涉及查找随机行为并使用此行为生成随机值。因此,使用微控制器生成随机数可能是一项艰巨的任务,因为微控制器经常表现出重复行为。
2023-01-12 15:21:36
293
DS2148T+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148T+相关产品参数、数据手册,更有DS2148T+的引脚图、接线图、封装手册、中文资料、英文资料,DS2148T+真值表,DS2148T+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 18:50:15
DS2148TN+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148TN+相关产品参数、数据手册,更有DS2148TN+的引脚图、接线图、封装手册、中文资料、英文资料,DS2148TN+真值表,DS2148TN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 18:59:39
DS21348TN+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348TN+相关产品参数、数据手册,更有DS21348TN+的引脚图、接线图、封装手册、中文资料、英文资料,DS21348TN+真值表,DS21348TN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:00:58
DS21348T+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348T+相关产品参数、数据手册,更有DS21348T+的引脚图、接线图、封装手册、中文资料、英文资料,DS21348T+真值表,DS21348T+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:01:53
DS21348G+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348G+相关产品参数、数据手册,更有DS21348G+的引脚图、接线图、封装手册、中文资料、英文资料,DS21348G+真值表,DS21348G+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:02:51
DS2148TN 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148TN相关产品参数、数据手册,更有DS2148TN的引脚图、接线图、封装手册、中文资料、英文资料,DS2148TN真值表,DS2148TN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:06:36
DS21348GN+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348GN+相关产品参数、数据手册,更有DS21348GN+的引脚图、接线图、封装手册、中文资料、英文资料,DS21348GN+真值表,DS21348GN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:28:09
DS21348G 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348G相关产品参数、数据手册,更有DS21348G的引脚图、接线图、封装手册、中文资料、英文资料,DS21348G真值表,DS21348G管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:40:48
DS21348T 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348T相关产品参数、数据手册,更有DS21348T的引脚图、接线图、封装手册、中文资料、英文资料,DS21348T真值表,DS21348T管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:41:18
DS2148T 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148T相关产品参数、数据手册,更有DS2148T的引脚图、接线图、封装手册、中文资料、英文资料,DS2148T真值表,DS2148T管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:41:47
DS21348TN 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS21348TN相关产品参数、数据手册,更有DS21348TN的引脚图、接线图、封装手册、中文资料、英文资料,DS21348TN真值表,DS21348TN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:42:38
DS2148G+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148G+相关产品参数、数据手册,更有DS2148G+的引脚图、接线图、封装手册、中文资料、英文资料,DS2148G+真值表,DS2148G+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:50:18
DS2148GN+ 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148GN+相关产品参数、数据手册,更有DS2148GN+的引脚图、接线图、封装手册、中文资料、英文资料,DS2148GN+真值表,DS2148GN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:50:30
DS2148G 接口 - 电信
电子发烧友网为你提供Maxim(Maxim)DS2148G相关产品参数、数据手册,更有DS2148G的引脚图、接线图、封装手册、中文资料、英文资料,DS2148G真值表,DS2148G管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-30 18:12:51
DS2148、DS21348、DS21Q48、DS21Q348和DS21448的附加脉冲幅度设置
本应用笔记提供了DS2148/DS21348/DS21Q48/DS213Q48和DS21448的寄存器设置,用于配置发送器的脉冲幅度不同于数据资料中记录的线路构建(LBO)模式。下表列出了寄存器
2023-02-13 15:42:40
583
