05402-90010 (July 1971) The 5402A MCA/Basic System is a discontinued product. This manual is provided for information only.
2018-11-01 11:42:52
BU2614锁相频率合成器参数资料下载内容主要介绍了:BU2614外观图BU2614引脚功能BU2614内部方框图BU2614特点BU2614极限参数BU2614频率锁定控制方框图
2021-03-29 08:05:09
BU38603 - System control servo - Rohm
2022-11-04 17:22:44
BU38803 - System control servo - Rohm
2022-11-04 17:22:44
BU943x音频解码系统包括主控板和音频解码播放板两大部分:主控板的功能包括电源管理;由MSP430F135 MCU检测2X4矩阵键盘,对音频解码芯片BU943x发送一些控制命令,来控制BU
2011-03-08 23:18:50
ARM Target Development System User Guide[hide][/hide]Proprietary NoticeARM, the ARM Powered logo
2010-03-19 21:10:57
ATT7053BU带零线计量的单相多功能电子计量芯片ATT7053BU是一颗高精度、低功耗、带SPI/UART接口的单相计量芯片,工作电压是4.5V – 5.5V。 该芯片采用3路22位
2014-03-18 08:52:39
请问有谁用过ATT7053BU吗?为什么我读其他寄存器可以,但是写数据进入电压峰值寄存器之后,读出来的值总是零。有什么需要注意的吗?希望大家帮帮忙,谢谢。
2015-03-25 17:03:19
ATxmegaA3BU-XPLD,AVR XMEGA-A3BU Xplained评估套件是评估ATxmega256A3BU微控制器的硬件平台。该套件提供了更多功能,使AVR XMEGA用户可以立即开始使用XMEGA外设,并了解如何将XMEGA器件集成到他们自己的设计中
2020-06-10 15:03:57
The 2nd International Workshop on Information Technology with its
2010-01-15 10:16:54
Upgrade procedure for E5070BU/E5071BU Opt.017
2019-09-25 13:06:04
Upgrade procedure for E5070BU/E5071BU Opt.018
2019-09-23 12:28:26
IQVIEW LAYOUT INFORMATION
2015-06-26 21:15:49
Ip link RF test information
2015-07-04 15:45:25
location information or the device or resource is not present in the system。是不是要配置示波器?该怎么解决?
2012-07-14 16:09:50
information:-1.Does itsupport System verilog forverification?2. Code coverage support.3.Assertion support.Whichversionof Modelsim XE supports these feature.
2018-11-27 14:20:41
PADS INFORMATION STUDY STUDY!!!11
2015-07-13 18:21:19
PC CAMERA INFORMATION
2015-07-04 16:20:23
RF Trobe information
2015-06-24 17:59:37
RF Trobe information 2
2015-06-24 18:01:49
Is there any bootstrap pin that could be setup for booting from extended User Area on a RH850 D1M?Thanks,
2019-09-12 15:16:50
i.mx6平台,在使用一款USB接口的蓝牙wifi二何以模块RL-UM02WBS-8723BU,目前因为主芯片RTL8723BU即将停产,请作好对应的升级准备!同时有对应的硬件完全兼容的升级模块,只需要根据kernel版本吻合的驱动,重新更新驱动就可以,原有硬件设计不用做任何更改,只做软件升级就性
2022-01-07 07:53:44
RT8011A ic information!!!!!!!!!!
2015-06-24 19:26:00
RT8059A IC INFORMATION
2015-06-24 19:27:18
RT8723BU模块RL-UM02WBS-8723BU是一款2.4G单频单通道USB接口蓝牙wifi二合一模块,硬件兼容性强,分享其linux系统下的驱动。可以提供对应硬件平台/linux内核版/kernel版本 ,有对应的驱动包
2018-04-08 10:59:45
应用RTL8723BU设计的一款USB接口蓝牙wifi二合一模块RL-UM02WBS-8723BU在实际的应用设计中,总有客户发应不知道如何处理模块对应的外围电路。现在分享参考应用电路,希望对广大初级用户有帮助
2016-12-22 12:18:22
RTL8723BU是一款USB接口的蓝牙WiFi二合一方案,很多集成领域应用,分享芯片规格书,希望对开发这有帮助
2018-01-22 11:12:35
SPC STUDY INFORMATION!!!
2015-06-25 16:34:49
环境:HI3559/3519内核:4.9.37蓝牙芯片:USB 8723bu1.驱动添加8723bu驱动。内核自带,不过在热插拔时提示找不到bin文件,需要在/lib/firmware/rtl_bt
2021-12-23 06:42:53
I am trying to debug aself-build board based on FMCOMMS2. When I run ad9361 linux system
2018-08-03 08:40:45
bt test information
2015-06-17 19:08:04
本文档介绍 iMX6 的 qte 系统下 u***-wifi-RTL8723BU 的使用。请确认,底板是否有 RTL8723BU 的 u***-wifi 模组,老版本上使用的是 SDIO
2019-06-11 10:15:03
re0801ds ic Information!!!!!!
2015-06-24 19:28:30
rtl8723bu下面红色接点怎么接,改接到主板USB插针还需要接PCM吗?RF0 RF1 XIN BT_PCM_CLK BT_PCM_IN BT_PCM_OUT BT_PCM_SYNC
2020-07-18 08:04:46
wangluojiekou information
2015-06-24 18:33:13
了与罗姆日本同样的集开发、生产、销售于一体的一条龙体制。BU7445HFV/BU7445SHFV是ROHM推出的两款低电压工作的CMOS运算放大器,BU7445HFV具有输入接地检测功能,输出全摆幅
2019-04-19 01:21:05
RTL8812BU-CG 哪位大佬有这个物料的数据手册,麻烦发一份给我。谢谢
2023-09-04 20:25:57
罗姆(ROHM)半导体集团是全球最知名的半导体厂商之一,BU97981xxx是其推出的多功能LCD段驱动器系列。该系列LCD段驱动器最多可显示196段,其占空比支持静态、1/3、1/4可选,其内
2019-04-22 02:10:32
、连接wifi后也无法ping通网关(返回信息是包全部丢失)4、怎么配置rtl8723bu的bluetooth??看资料里面没有讲怎么配置蓝牙,也未从源码中看到相关rtl8723bu的蓝牙的驱动,是否
2022-01-11 07:45:55
文章目录前言AT指令前言BU01这个模块是相对其他基于DW1000的模块中比较便宜的了,我买了两块官方的开发板NodeMCU-BU01(好像不是官方店下的单子),上手给我的感觉不够人性化.1.预置了
2021-11-24 06:19:40
Root FS skeleton:System hostname:填写JZ2440 System bannerPasswords encodingInit system:系统初始化,选择
2022-11-04 15:31:51
现货日本SMC气管TU1208BU-20 ***SMC 嵌入式系统管道和附件SMC 管道适用于一般工业水应用,且可用于运输 SMC 规定的许多其它液体(详细信息,请咨询 SMC)。 提供多种
2022-01-20 16:36:12
我在调试BU2614,鉴相器输出一直为低电平,上的是100k圆柱无源晶振,测XIN先是骑在1V左右的正弦,然后逐渐变为直流,XOUT是骑在2V左右的正弦,上电后PD1一直输出为低电平。
2015-08-14 16:18:26
概述:BU2520DF是一款新一代高压高速开关NPN晶体管,全塑料集成阻尼二极管,一般常用作于CRT大屏幕彩色电视接收机行偏转电路中。
2021-04-07 06:33:54
addr1 = &READ.Dat1[0];const uint32 addr2 = &READ.Dat1[1];keil编译会警告 #1296-D:extended constant
2018-11-01 08:33:30
请问:Zigbee3.0 开发手册中Extended PAN IDs 包括两个:zgApsUseExtendedPANID, zgExtendedPANID。 再加上 PAN ID 共 3个ID 到底有什么不同? 如何使用?
2018-08-10 06:54:41
反汇编代码中经常出现,例如 .fphead n, l, W, BU, br, nosat, 1001101b或者.fphead p, l, W, BU, nobr, nosat, 1011111b 请问这种语句有什么用? 如果自己写汇编代码,是不是一般不会用到这种语句?
2020-08-03 10:52:16
在使用 Modelsim 时遇到ERROR: No extended dataflow license exists。在网上搜了下,有人给出下面的解释,不知道正不正确,请大家探讨下。在进行FPGA
2014-02-20 23:57:24
高通Vuforia SDK 2.8已经正式推出了,此次SDK更新的亮点:增加Extended Tracking功能,即使目标离开视野仍能继续进行图像识别。使用Java API使开发更简单。采用基于云
2018-09-20 10:13:28
System Management Bus(SMBus)SpecificationVersion 2.0August 3, 2000
The System Management Bus
2008-09-12 16:31:32
32 ALLEGRO SYSTEM ARCHITECT GXLCadence Allegro System Architect GXL is the industry°Os first
2008-10-16 09:46:55
0 The Application of PLC System in Urban Water Supplying system
Abstract The controlsy stemis
2009-01-22 18:25:37
11 The 74F Extended Octal-Plus Family incorporates all of the latestPhilips Semiconductors octal
2009-03-30 00:12:56
10 In-System FLASH Programming with hardwareimplemented bank switching capabilityThe following
2009-04-01 21:42:19
16 USB System Architecture (USB 2.0)The MindShare Architecture book series includes: ISA System
2009-04-22 16:49:53
11 BU8874/BU8874F是ROHM公司生产的DTMF电话语音应答器.它的最大特点是其动态范围很宽,并可将16种不同的DTMF信号转换成4位二进制串行数据.文中介绍了BU8874/BU8874F的主要特点、内部结构、功
2009-04-30 17:24:15
34 参数表节选:的技术参数 KC-CJC-1BU产品阐述 Resistance thermometer for cold junction compensation for KC
2022-09-27 13:37:53
Terminal Block for Cold Junction Compensation K-CJC-BU3-pin screw terminalFor KF modules
2022-11-08 13:28:05
2022-11-08 13:37:53
The Mindshare Architecture book series ISA System Architecture,EISA Syseten Architecture,80486
2009-07-17 16:55:47
41 The Mindshare Architecture book series includes:ISA System Architecture,EISA System Architecture
2009-07-17 17:36:58
0 Many advantages of distributed power system prompted its use in theseapplications. First, with fast
2009-10-16 15:19:53
19 Abstract—Power system architecture for servers with backup power based on HV DC bus concept
2010-02-21 17:25:11
22 SYSTEM VIEW教材
SYSTEM VIEW是一个用于现代工程与科学系统设计及仿真的动态系统分析平台。
2010-04-10 11:08:05
32 Abstract: This application note demonstrates how to make a simple system that monitors temperature
2009-04-17 11:15:27
876 ![](https://file1.elecfans.com//web2/M00/A4/C3/wKgZomUMNZeAJw5mAACP5XgY6p8218.gif)
什么是CIR (Committed Information Rate)
英文缩写: CIR (Committed Information Rate)
中文译名: 承诺信息速率,约定信息速率
分
2010-02-22 10:44:56
1266 什么是C-3/C3 system (Command、Control and Communication System)
英文缩写: C-3、C3 system (Command、Control and Communication System)
中文译名:
2010-02-22 10:54:48
817 什么是COS (Card Operating System)
英文缩写: COS (Card Operating System)
中文译名: 卡片操作系统
分 类:
解 释
2010-02-22 11:36:46
1323 什么是Extended Enterprise
英文缩写: Extended Enterprise
中文译名: 外延的企业
分 类: IP与多媒体
解 释:
2010-02-23 10:09:24
823 VPN术语-EXTENDED COMMUNITY 英文原义:EXTENDED COMMUNITY
中文释义:扩展团体属性
注 解:
2010-02-24 10:40:51
1052 支持Baseline和Extended Sequential的JPEG编码IP核
CAST公司宣布提供独有的同时支持Baseline(8位)和Extended Sequential(12位)
2010-05-18 09:22:08
581 Noise Extended Technologies(原Aeroflex-Europtest)公司在国际微波大会展览上展出高性能相位噪声产品系列
美国加州Anaheim – 国际微波大会 – 展
2010-05-26 23:05:47
675 some information about bluetooth found on the internet。
2016-05-17 15:22:32
0 HPE Apollo 4500 System
2017-09-05 09:44:44
6 XMC4K_System_Core
2017-09-29 08:57:51
6 CP 443-5 Extended 通信处理器专用于 SIMATIC S7-400(标准)和 S7-400H(容错系统)自动化系统中。CP 443-5 Extended 可用于将 S7-400
2017-10-26 15:32:52
12 纳拓科技应用RTL8812BU设计一款双通道11AC双频WiFi模块RL-UM02SPC-8812BU
2017-11-04 11:15:16
46 BU406属于硅NPN型大功率三极管,就是通常说的硅NPN型双极型晶体管。接下来了解一下关于bu406的参数以及什么是三级管的知识普及。
2017-11-27 09:28:49
46764 全景球:ANAFI Extended旋转360°,因为其相机垂直扫描场景180°。 借助FreeFlight 6应用程序的强大功能,可以组合镜头创建360度图像,您可以“移动”并轻松分享社交媒体,带您体验从未见过的沉浸感。
2018-10-29 11:33:43
3072 了解如何使用SYSTEM Management Wizard使用System Monitor配置和构建设计。
2018-11-23 06:13:00
4231 Eterna Extended Range Reference Design
2021-02-21 10:41:12
9 DTMF电话语音接收器集成电路BU8874/BU8874F是ROMHM公司生产的一类电话语音应答器。它们可以将16种不同的DTMF信号转换成4位二进制串行数据。其中BU8874采用8脚DIP封装形式
2021-03-23 11:10:50
2163 ADV7194:专业Extended-10™视频编码器,具有54 MHZ过采样数据表
2021-04-24 19:23:13
2 SCU(System Control Units)SCU模块组成The System Control Unit (SCU) is a cluster of sub-modules which
2021-11-16 21:06:05
26 RTKA223012DR0050BU, RTKA223012DR0060BU DEMO手册
2023-01-30 19:02:30
0 RTKA223012DR0010BU、RTKA223012DR0020BU演示板说明书
2023-01-30 19:09:38
0 DA9061/2 评估板 Ordering Information
2023-03-16 19:37:07
0 SH-4A Core Extended Functions 用户手册: 硬件
2023-03-31 18:53:17
0 SH-4A Extended Functions 软件手册
2023-04-03 20:06:31
0 SuperH Simulator/Debugger V.9.10.00 Supplementary Information for 用户手册
2023-04-19 19:09:52
0 MINICUBE2 Setup 手册 Information (U17966CA3V0IF00)
2023-05-04 19:35:10
0 RTKA223012DR0050BU, RTKA223012DR0060BU DEMO手册
2023-07-03 20:42:44
2023-07-03 20:56:38
2023-07-06 20:23:50
2023-07-13 19:59:45
2023-07-14 11:14:04
