电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>NRZ Applications
NRZ Applications
收藏
查看更多
54TRAAV2HPS
MOD OPT 1550NM EML NRZ 300PIN
2023-03-22 15:28:58
Analog Applications Journal 模拟应用
Analog Applications Journal 模拟应用Analog Applications Journal is a collection of analog application
2009-11-20 08:55:44
Data Isolation for loop powered applications
applications. The challenge of such a solution is first of all the limited size within sensor
2015-03-23 10:12:22
Evaluating the IBM43RF0100 SiGe HBT for CDMA Driver Applications at 1.9 GHz
discreteheterojunction bipolar transistor (HBT) suitable for awide range of RF driver applications
2009-05-12 11:35:41
H.264/AVC for Wireless Applications
) and “non-conversational” (i.e.,storage, broadcast, or streaming) applications. The video compression
2008-06-25 10:08:56
HDB3码有什么优点?
和最常用的NRZ码(Non—Return Zero,非归零码)相比,HDB3码具有很多优点,例如:消除了NRZ码的直流成分,具有时钟恢复和更好的抗干扰性能,这使它更适合于长距离信道传输。
2019-09-26 09:12:23
LT8644高清矩阵-Lontium-HDMI矩阵成熟方案
compatible inputs and 16 differential CML outputs. The LT8644 is optimized for nonreturn-to-zero (NRZ
2019-01-10 00:10:19
LVGL 8.20 lv_conf.h放在applications/lvgl文件夹下提示错误咋办?
LVGL 8.20 lv_conf.h 放在applications/lvgl 文件夹下提示未包含
2023-03-13 15:31:23
Optimize Network Applications for Multi-core
Optimize Network Applications for Multi-core Agenda1.Technical Trends in Multi-Core2.Solution of Wind River[hide][/hide]
2009-12-10 14:02:54
PAM-4信令取代NRZ有哪些优势?
本文介绍了PAM-4多级信令,及其与56G数据速率的NRZ相比较后得出的权衡和优势。
2021-06-17 10:43:43
PAM4和NRZ信号的区别是什么
PAM4和NRZ信号的区别是什么PAM4测试信号是怎么产生的?
2021-03-11 07:46:17
PLL - Design, Simulation and Applications
="Simulation"and="and"Applications="Applications&quot
2009-09-25 17:06:37
《Low Voltage Power MOSFETs Design, Performance and Applications
`求书《Low Voltage Power MOSFETs Design, Performance and Applications》,这本书里主要讲了什么内容?`
2021-06-22 08:07:36
【Qorvo招聘】Sr. Field Applications Engineer 上海
`QorvoSr. Field Applications Engineer 15K-20K上海5年以上本科及以上全职 职位诱惑: 美资上市公司,绩效奖金, 五险一金,额外商业保险,各类津贴,定期体检
2015-12-31 10:23:24
NRZ到AMI转换器为何要使用单电源供电?
2021-05-21 07:04:02
关于200G NRZ光模块选择(推荐收藏)
`200G光模块有两种技术方向,一种是采用QSFP-DD封装的经济型8x25G NRZ网络;另外一种是采用QSFP56封装的4x50G PAM4网络。(这次我们先简单介绍200G NRZ。日后,我会
2021-06-03 10:36:04
在28377D技术手册中2.7.3.7 CPU Timer2 Clock (TIMER2CLK)节中“In most applications, timer 2 will run off of the SYSCLK.”是什么意思
在28377D技术手册中2.7.3.7 CPU Timer2 Clock (TIMER2CLK)节中“In most applications, timer 2 will run off of the SYSCLK.”是什么意思?没看懂
2018-08-29 11:05:41
如何去分析把NRZ信号变为一个GSG信号可以回归共模信号的电路?
各位大神,想问下面的电路,把NRZ信号变为一个GSG信号有毛刺的可以回归共模信号的电路(GSG转换电路)如何分析呢1、就是图2(a)是图1左面(NRZ信号)到右面(GSG信号)发生器,这个图2(a
2021-06-25 07:57:50
如何在applications目录下添加自己的文件和文件夹呢?
在工程的applications目录下添加了自己的.c和子目录,子目录中也有.h和.c,编译下载都正常。此时由于需要新增一些软硬件模块,通过打开RT-Thread Settings后勾选相应的模块
2022-12-30 15:43:04
如何在Spartan3中将NRZ-单极(即(0,1))中的序列数据转换为NRZ-双极性?
嗨,这个问题长期困扰着我。我有一个NRZ单极格式的串行数据,即(0,1),我必须在VHDL中将其转换为NRZ-双极格式,即(-1,+ 1)。我必须在spartan3 fpga中合成代码,并在模拟
2019-10-28 07:53:32
实现10GHz信号的NRZ-RZ转换,请问应该选择的器件/模块型号是什么呢?
大家好,我想实现10GHz信号的NRZ-RZ转换,但是在“NRZ-RZ转换器”目录下没有看到相关的器件。请问我应该选择的器件/模块型号是什么呢?谢谢了!
2018-08-10 06:34:58
有谁知道《 Technologies and Applications》吗?
求书《Fundamentals of Device and Systems Packaging: Technologies and Applications
2021-06-22 06:46:37
本周推荐:关于200G PAM4光模块(推荐分享)
``上期我们讲《关于200G NRZ光模块选择》时,提到200G光模块有两种技术方向,即NRZ调制技术和PAM4调制技术。所以这期我们来了解下200G PAM4光模块。封装200G PAM4光模块
2021-06-24 18:30:42
本周推荐:基于NRZ及相干传输DCI解决方案(欢迎留言评论)
主要讲解基于NRZ的DCI传输解决方案以及超长距离的相干DCI解决方案。 产品明细:客户侧采用10G SFP+ SR灰光模块,10G OEO客户侧方向使用10G SR灰光模块与客户侧对接,线路侧
2021-07-26 16:37:31
求电子书 FPGA Frontiers: New Applications and Trends in Reconfigurable Computing
求电子书《 FPGA Frontiers: New Applications and Trends in Reconfigurable Computing》,跪谢大神分享
2017-03-07 10:18:48
请问ADN2873传输HDTV信号如何设计ADN2873与激光器以及外围之间的电路
我想采用ADN2873传输HDTV信号,NRZ码,但datasheet里面没有给出NRZ码的应用电路,或者说和datasheet上给出的常规8B10B码电路之间的差异,请教如何设计ADN2873与激光器以及外围之间的电路
2018-08-20 08:00:37
请问大佬们对两路NRZ数据鉴相有什么好主意吗?
本来想试一下用这种结构(拉扎维书中)来对两路有延时的数据进行鉴相的,即CK和Din都是输入数据,后来自己画了一下发现不行的。。。所以请问大佬们对两路NRZ数据鉴相有什么好主意吗?
2021-06-25 07:34:04
问答专栏丨PAM4常见问题解答
常见的问题,让我们一起来看一下吧。1. 什么是PAM4?答:PAM4是PAM(Pulse Amplitude Modulation,脉冲幅度调制)调制技术的一种。PAM信号是继NRZ
2021-06-28 10:04:46
MAX3981 pdf datasheet (3.125Gb
" of digital NRZ data at a data rate of 3.125Gbps in one package. It is tailor-made for 10Gigabit Ethernet applications that require attenuation
2008-12-16 09:54:4313
MAX3980 pdf datasheet (3.125Gb
" of digital NRZ data at a 3.125Gbps data rate in one package. It is tailor-made for 10-Gigabit Ethernet (10GbE) backplane applications requirin
2008-12-16 10:33:0625
中子束于半导体薄膜材料之运用 Applications of
中子束于半导体薄膜材料之运用Applications of neutron beam on semiconductor thin films一、缘起与目的本计划于清华水池式反应器(THOR)中子束,建立一条多功能之仪器测试中子
2009-03-06 13:57:2525
Ethernet Applications
Stand Alone Un-Managed SwitcStand Alone Un-Managed Switch Residential Gateway BoResidential Gateway Box Dual Media ConverteDual Media Converter Simple 16 port SwitcSimple 16 port Switch Capacitively Coupl
2009-03-19 16:07:0215
NRZ-HDB3码转换器的高速长距离通信设计
HDB3 码无直流分量,具有时钟恢复和较好的抗干扰能力。本文提出使用HDB3码用于高速长距离的数据传输, 并给出使用单片机AT89C51 控制E1 收发芯片DS2153Q 实现NRZ-HDB3 的码制转换,包括
2009-04-15 11:31:1619
An Applications Guide for OP A
An Applications Guide for OP Amps:1. Introduction....32. The Inverting Amplifier.53.
2009-05-16 09:44:0470
Foundations and Applications o
Broadly interpreted, sensor management denotes the theory and applicationof dynamic resource allocation in a diverse system of sensors and sensingmodalities. Over the past few years the problem of sensor management foractive
2009-07-22 08:07:520
Applications of Specification
Today’s increasing design complexity requires innovative methods for verificationand debug. With verification consuming up to 70% of the design cycle,assertion-based design (Foster et al., 2003) is viewed as one key method for
2009-07-23 08:27:270
Analog Applications Journal利用線性穩壓器實現同步斷電定序功能
2009-11-30 16:30:0810
Autonomous Management of Edge Applications on RISC -1
RISC-V
RISCV国际基金会发布于 2022-09-01 14:54:28
Autonomous Management of Edge Applications on RISC-2
RISC-V
RISCV国际基金会发布于 2022-09-01 14:55:47
Automotive Driver Requirements Topologies and Applications
Automotive Driver RequirementsTopologies and Applications Low-Side Powertrain Loads • Motors • Solenoids • Heaters • Lighting
2010-04-17 10:52:0324
APPLICATIONS电动自行车
APPLICATIONS电动自行车
2010-08-04 22:03:4820
OMAP-L138,pdf(Low-Power Applications Processor)
The device is a Low-power applications processor based on an ARM926EJ-S™ and a C674x DSP
2010-12-12 22:42:5497
HDB3码无直流分量,具有时钟恢复和较好的抗干扰能力。本文提出使用HDB3码用于高速长距离的数据传输,并给出使用单片机AT89C51控制E1收发芯片DS2153Q实现NRZ-HDB3的码制转换,包括码转换器的电路设计和控制软件设计。
2006-03-11 13:25:322263
Phase-Lock Loop Applications U
Phase-Lock Loop Applications Using the MAX9382
2009-02-21 15:14:001252
Force/Sense DAC Applications
converters (DACs). Applications include: selectable fixed-gain DAC, programmable gain DAC, photodiode bias control, amperometric sensor control,
2009-04-18 10:45:191845
2009-04-20 16:30:28782
2009-04-24 16:09:15568
NRZ码应用-NRZ Applications
) so that the user can connect the LIU/framer to a Bipolar or NRZ mode device. This application note applies to following si
2009-04-29 09:57:392127
不归零码(NRZ),不归零码(NRZ)是什么意思
不归零码(NRZ),不归零码(NRZ)是什么意思 数字信号可以直接采用基带传输,所谓基带就是指基本频带。基带传输就是在线路中直接传送数字信号的电脉
2010-03-17 16:49:4127150
[4.3.1]--NRZ及其修正码字
通信无线
学习电子知识发布于 2022-11-30 23:37:01
[8.6.2]--07D1-2.Applications
数据结构
jf_60701476发布于 2022-12-02 14:17:08
NRZ测试码型的频谱成分
非归零码(NRZ)数字信号广泛用于数字通讯系统中的数据传输。许多NRZ测试码型已被产生于系统测试和验证。这些码型通常设计用来模拟实际的数据或者着重考验系统某方面的性能。为理解
2012-03-07 15:45:5071
OMAP3530 and OMAP3525 Applications Processors
TI 出品的OMAP3530 and OMAP3525 Applications Processors应用处理器,OMAP 3 Architecture,ARM Cortex-A8 core,图形加速等,支持Linux、WINCE、安卓系统。
2015-11-26 16:35:417
NRZ_DPSK_spectrum
RFID系统的核心功能是实现读写器与电子标签之间的信息传输。以读写器向电子标签的数据传输为例,被传输的信息分别需要经过读写器中的信号编码、调制,然后经过传输介质(无线信道),以及电子标签中的解调和信号解码。
2015-12-15 11:33:240
i.MX 6Solo/6DualLite Applications Processors for Consumer Products
2015-12-29 14:26:2027
i.MX 6Solo/6DualLite Applications Processors for Industrial Products
2015-12-29 14:27:0011
MAPS-KL43 Demo Applications User
MAPS-KL43 Demo Applications Users Guide
2016-06-03 15:37:0310
DSP applications using C and the TMS320C6x DSK
2016-06-21 16:49:3314
Digital Signal Processing and Applications with the C6713 and C6416 DSK
Digital.Signal.Processing.and.Applications.with.the.C6713.and.C6416.DSK
2016-07-13 16:12:5729
UWB Applications
UWB Applications,有需要的下来看看。
2017-01-12 22:55:1523
OP_AMP_APPLICATIONS_(运算放大器应用手册英文
OP_AMP_APPLICATIONS_(运算放大器应用手册英文版_ADI公司)__886页.pdf
2017-03-05 15:25:1010
An Applications Guide for Op Amp
An Applications Guide for Op Amps
2017-03-24 15:59:474
NRZ码的应用资料下载
概述 线路接口单元(刘)可以完全脱离者/格式化程序接口,光学,HDSL,或与NRZ接口的其他设备。然后,它可以用来破坏数据,插入帧错误,或插入CRC错误,等等。 成帧器/格式化程序可以生成/检测
2017-04-12 09:22:3412
Circuit.Cellar.-.Cortex-M3.Applications.Using.Stellaris.MCUs
2017-10-26 09:24:442
NRZ信号的波形、眼图与PAM4信号的对比及PAM4技术逐渐走向应用
的数字信号最多采用的是NRZ(Non-Return-to-Zero)信号,即采用两种信号电平来表示数字逻辑信号的1、0信息,每个符号周期可传输1bit的逻辑信息;而PAM信号则可以采用更多信号电平,从而每个符号周期可传输更多bit信息。
2017-11-15 14:35:3533197
标准和白光发光二极管LED的基础知识与驱动,LED circuits and applications
标准和白光发光二极管LED的基础知识与驱动,LED circuits and applications 关键字:LED,驱动,元件选择
2018-09-20 18:24:051345
关于NRZ与PAM4信号差异
/56/100/400GHz)、PAM5(IEEE P802.3ab)、PAM8(IEEE P802.3bm)。..等多种不同位阶数的编码方式。PAM信号是继NRZ(NonReturn-to-Zero
2020-07-02 14:40:0331635
HMC706LC3C:13 Gbps,NRZ至RZ转换器+3.3V电源陈旧数据表
2021-04-27 17:45:082
关于200G NRZ光模块的相关基础知识介绍
目前由协议定义的200G光模块主要有2种,第一种是8*25G NRZ QSFP-DD(double density)封装形式;第二种是QSFP56封装的4*50G PAM4形式。在这篇文章中,我主要
2021-06-26 14:39:161080
50G SFP56 DWDM光模块与100G QSFP28 DWDM光模块方案
DWDM密集波分技术经历了越来越高的调制速率,包括1.25G NRZ,2.5G NRZ,10G NRZ以及25G NRZ,采用高阶调制PAM4的有50G PAM4和100G PAM4两种速率;以及当前非常具有竞争力的DWDM相干调制技术,主要面向200G和400G,以及未来的800G高带宽业务。
2022-06-06 16:23:192795
易天光通信 | 200G QSFP56 AOC有源光缆解析
00G AOC有源光缆主要以QSFP-DD和QSFP56两种封装形式为主,波长都为850nm。200G QSFP-DD AOC调制方式为NRZ,应用于传输距离为1-100M的200G以太网。200G
2022-10-27 17:10:59410
如何将LIU/成帧器连接到双极性或NRZ模式器件
本应用笔记介绍了如何将成帧器与线路接口单元(LIU)去耦,以便用户可以将LIU/成帧器连接到双极性或NRZ模式器件。
2023-02-13 15:42:07604
Multimedia Processor for Mobile Applications(EMMA Mobile1-D512) One Chip 用户手册(R19UH0030EJ0800_EMMAMOBIL)
Multimedia Processor for Mobile Applications (EMMA Mobile1-D512) One Chip 用户手册 (R19UH0030EJ0800_EMMAMOBIL)
2023-04-18 19:45:580
Multimedia Processor for Mobile Applications(EMMA Mobile1-S) One Chip 用户手册(R19UH0031EJ0500_EMMAMOBIL)
Multimedia Processor for Mobile Applications (EMMA Mobile1-S) One Chip 用户手册 (R19UH0031EJ0500_EMMAMOBIL)
2023-04-18 19:46:110
Multimedia Processor for Mobile Applications(EMMA Mobile1-D512) One Chip 用户手册(R19UH0030JJ0900_EMMAMOBIL)
Multimedia Processor for Mobile Applications (EMMA Mobile1-D512) One Chip 用户手册 (R19UH0030JJ0900_EMMAMOBIL)
2023-04-18 19:46:310
Multimedia Processor for Mobile Applications(EMMA Mobile1-S) One Chip 用户手册(R19UH0031JJ0600_EMMAMOBIL)
Multimedia Processor for Mobile Applications (EMMA Mobile1-S) One Chip 用户手册 (R19UH0031JJ0600_EMMAMOBIL)
2023-04-18 19:46:480
Multimedia Processor for Mobile Applications(EMMA Mobile1) DDR SDRAM Interface 用户手册(R19UH0028EJ0500_EMMAMOBIL)
Multimedia Processor for Mobile Applications (EMMA Mobile1) DDR SDRAM Interface 用户手册 (R19UH0028EJ0500_EMMAMOBIL)
2023-04-18 19:47:170
MAX20310: Ultra-Low Quiescent Current PMIC with SIMO Buck-Boost for Wearable Applications Data Sheet MAX20310: Ultra-Low Quiescent Current P
Applications Data Sheet相关产品参数、数据手册,更有MAX20310: Ultra-Low Quiescent Current PMIC with SIMO Buck-Boost
2023-10-13 19:06:54
MAX17552AEVKIT: Evaluation Kit for the MAX17552A (TDFN) in 5V Output Voltage Applications Data Sheet MAX17552AEVKIT: Evaluation Kit for the
Applications Data Sheet相关产品参数、数据手册,更有MAX17552AEVKIT: Evaluation Kit for the MAX17552A (TDFN) in 5V
2023-10-13 19:19:06
MAX25201-MAX25202: 36V HV Synchronous Boost Controller for Automotive Infotainment Applications Data Sheet MAX25201-MAX25202: 36V HV Synchro
Infotainment Applications Data Sheet相关产品参数、数据手册,更有MAX25201-MAX25202: 36V HV Synchronous Boost Controller
2023-10-16 19:08:42
MAX25405: IR Gesture Sensor with Lens for Automotive Applications Data Sheet MAX25405: IR Gesture Sensor with Lens for Automotive Applicatio
电子发烧友网为你提供ADI(ADI)MAX25405: IR Gesture Sensor with Lens for Automotive Applications Data Sheet相关产品
2023-10-17 18:44:54
MAX25250: Four Output Mini PMIC for Camera Applications Data Sheet MAX25250: Four Output Mini PMIC for Camera Applications Data Sheet
电子发烧友网为你提供ADI(ADI)MAX25250: Four Output Mini PMIC for Camera Applications Data Sheet相关产品参数、数据手册,更有
2023-10-17 18:51:43
MAX32570: Low-Power Arm Cortex-M4 Microcontroller with Contactless Radio for Secure Applications Data Sheet MAX32570: Low-Power Arm Cortex-M
for Secure Applications Data Sheet相关产品参数、数据手册,更有MAX32570: Low-Power Arm Cortex-M4 Microcontroller
2023-10-17 19:18:31
ISO 11898里的CAN总线:帧编码
帧中的位采用**NRZ**(Non-return-to-zero 非归零)方法编码。相同带宽,NRZ编码信息量更大。
2023-10-31 14:15:17355
易飞扬发布COLOR ZR+系列四载波(4×25G NRZ)平行100G QSFP28 DWDM4光模块
长距离传输有非相干和相干两种模式。易飞扬即日官宣发布两款创新的100G QSFP28 PSM DWDM4非相干长距离光模块。这是一种基于4×25G NRZ的四载波DWDM解决方案,有C-band
2023-11-29 17:42:12469
pam4和nrz区别
在通信领域中,数字调制技术是实现高速数据传输的关键。主流的数字调制技术包括脉冲振幅调制(PAM)和非返回零(NRZ)调制。本文将详细解释PAM-4(四进制脉冲振幅调制)与NRZ(非返回零)编码的区别
2023-12-29 10:05:321020
三星将展示16Gb GDDR7技术,重点关注PAM3优化TRX均衡和ZQ校准
该款高性能的 DRAM 采用 PAM3 编码技术,兼具 PAM4 和 NRZ 的优点,相较于 NRZ,它能够以更高的数据传输率运行,且无需过高的内存总线频率,表现优于 GDDR6,能耗及成本则低于 GDDR6X。
2024-01-29 10:13:44259
已全部加载完成
