Abstract: Application Note 325 is a Crystal Selection Guide for these Dallas Single Chip Transceivers: DS2151, DS2152, DS2153, DS2154, DS21552, DS21554, DS21352, DS21354 and DS2155.
Specifications for selecting the appropriate crystal in a T1 or E1 application are given in the following order.
Figure 1. Crystal connection.
Specifications for selecting the appropriate crystal in a T1 or E1 application are given in Table 1. A list of crystal manufacturers is in Table 2. Table 5 lists oscillator manufacturers.
Table 1. DS2155, DS21x5Y, DS2154 and DS2152 Crystal Specifications
Table 2. Recommended Crystal Manufacturers for DS2155, DS21x5Y, DS2154, and DS2152
Table 3. Recommended Oscillator Manufacturers
The DS2151 and DS2153 require a crystal that can be pulled off its center frequency. Table 5 lists manufacturers. The part numbers given are for leaded packages. Surface-mount devices typically do not meet the pullability specification. Some of the following manufacturers may offer surface-mountable packages in which the leads have been preformed (gull-winged) with a clip added to provide a third contact point.
Table 4. DS2151 and DS2153 Crystal Specifications
Table 5. Recommended Crystal Manufacturers for DS2151 and DS2153
Maxim has qualified a sample of each device from the above manufacturers and has found that the device meets or exceeds our specifications. We do not conduct an ongoing qualification of these manufacturers.
- Table 1: DS2155, DS21x5y, DS2154, and DS2152 Crystal Specifications
- Table 2: Recommended Crystal Manufacturers that meet DS2155, DS21x5y, DS2154, and DS2152 Crystal Specifications
- Table 3: Oscillator Manufacturers
- Table 4: DS2151 and DS2153 Crystal Specifications
- Table 5: Recommended Crystal Manufacturers that meet DS2151 and DS2153 Crystal Specifications
Parameter | Specification |
Parallel Resonant Frequency | 1.544MHz (T1), 2.048MHz (E1) |
Mode | Fundamental |
Load Capacitance | See Figure 1 |
Tolerance | ±50ppm |
Crystal Cut | AT |
Manufacturer | Address | Part |
Saronix | 141 Jefferson Drive Menlo Park CA 94025 650-470-7700 or 800-227-8974 |
Commercial Temp Range (T1, 3.088 MHz) NYP0308-XXGHE(L)* (E1, 4.096 MHz) NYP0409-XXGHE (L)* *Need to use divider for MCLK. |
Ecliptek | 3545 Cadillac Ave. Costa Mesa, CA 92626-1401 714-433-1200 |
Commercial Temp Range Crystal available for both T1 and E1 mode of operations. |
Saronix | 141 Jefferson Drive Menlo Park, CA 94025-1114 650-470-7700 or 800-227-8974 |
5V 8-Pin DIP SCS-DS-1046 1.544MHz SCS-DS-1047 2.048MHz |
3V 8-Pin DIP SCS-DS-1048 1.544MHz SCS-DS-1049 2.048MHz |
Parallel Resonant Frequency | 6.176 (T1), 8.192 (E1) |
Load Capacitance | 18pF to 20pF |
Pullability | CL = 10pF, f = + 175 to + 250ppm CL = 45pF, f = + 175 to - 250ppm |
Effective Series Resistance | 35 (max) |
Crystal Cut | AT |
M-Tron | 100 Douglas Ave. P.O. Box 630 Yankton, SD 57078-0630 605-665-9321 605-665-1709 |
Commercial Temp Range (T1, 6.176MHz) 4575-032 (E1, 8.192MHz) 4575-031 Industrial Temp Range (T1, 6.176MHz) 4144-002 (E1, 8.192MHz) 4144-001 Note: Do not use MP-1 Prefix |
Raltron | 2315 N.W. 107th Ave. Miami, FL 33172 305-593-6033 FAX: 305-594-3973 |
Commercial Temp Range (T1, 6.176MHz) A-6.176-18.5-DS (E1, 8.192MHz) A-8.192-18.5-DS Industrial Temp Range (T1, 6.176MHz) A-6.176-18.5-DSE (E1, 8.192MHz) A-8, 192-18.5-DSE |
Sunny-Emi Co. Suntrac (Dist) |
11925 Ventura Blvd. Studio City, CA 91604 818-509-8985 |
Industrial Temp Range (T1, 6.176MHz) SE 061-32 (E1, 8.192MHz) SE 081-30 |
JAN | 2341 Crystal Dr. P.O. Box 6017 Fort Myers, FL 33906-6017 941-936-2297 FAX: 941-936-3750 |
Commercial Temp Range (T1, 6.176MHz) JC6B18 (E1, 8.192MHz) JC8B18 |
Commercial Temp Range (T1, 6.176MHz) ECX-4173-6.176M (E1, 8.192MHz) ECX-3876-8.192M |
Saronix | Strategic Marketing, Inc. 624 W. University Suite 265 Denton, TX 76201 |
COMMERCIAL TEMP RANGE (T1, 6.176MHz) SRX5310(L) (E1, 8.192MHz) SRX5469(L) |
查看更多
