write_ds(uchar,uchar);void set_alarm(uchar,uchar,uchar);uchar read_ds(uchar);void set_time();void delay
2019-02-20 04:13:19
char a=0; unsigned char b=0; unsigned int t=0; float tt=0; Init_DS18B20(); WriteOneChar(0xCC);//跳过读序号
2018-07-19 00:30:10
);uchar Read_Ds1302 ( uchar address );void Read_RTC(void); void Set_RTC(void);void delay(uchar a
2013-05-03 22:54:57
IC TELECOM INTERFACE 40DIP
2023-04-06 11:49:49
DS2151 - Telecom Evaluation Board
2023-03-22 19:54:49
JUMPER03DS-8E-03DS-8E12"
2023-03-22 22:25:57
JUMPER03DS-8E-03DS-8E2"
2023-03-22 22:25:55
JUMPER04DS-8E-04DS-8E2"
2023-03-22 22:25:42
JUMPER05DS-8E-05DS-8E2"
2023-03-22 22:26:00
JUMPER06DS-8E-06DS-8E6"
2023-03-22 22:25:45
JUMPER07DS-8E-07DS-8E6"
2023-03-22 22:26:03
JUMPER07DS-8E-07DS-8E12"
2023-03-22 22:26:06
JUMPER07DS-8E-07DS-8E2"
2023-03-22 22:26:01
JUMPER08DS-8E-08DS-8E6"
2023-03-22 22:25:47
JUMPER08DS-8E-08DS-8E12"
2023-03-22 22:25:49
JUMPER09DS-8E-09DS-8E6"
2023-03-22 22:26:07
JUMPER09DS-8E-09DS-8E12"
2023-03-22 22:26:11
JUMPER09DS-8E-09DS-8E2"
2023-03-22 22:26:05
JUMPER10DS-8E-10DS-8E6"
2023-03-22 22:26:08
JUMPER10DS-8E-10DS-8E12"
2023-03-22 22:26:13
JUMPER11DS-8E-11DS-8E12"
2023-03-22 22:26:16
JUMPER11DS-8E-11DS-8E2"
2023-03-22 22:26:10
JUMPER12DS-8E-12DS-8E12"
2023-03-22 22:26:19
JUMPER12DS-8E-12DS-8E2"
2023-03-22 22:26:13
JUMPER13DS-8E-13DS-8E6"
2023-03-22 22:26:15
JUMPER13DS-8E-13DS-8E12"
2023-03-22 22:26:20
JUMPER13DS-8E-13DS-8E2"
2023-03-22 22:26:13
JUMPER14DS-8E-14DS-8E6"
2023-03-22 22:26:18
JUMPER14DS-8E-14DS-8E12"
2023-03-22 22:26:21
JUMPER14DS-8E-14DS-8E2"
2023-03-22 22:26:14
on INT1_CTRL and INT2_CTRL. Does enabling the INT1_IG_Gset the gyro interrupt in INT1_A/G pin and automatically set the acc interrupt on to INT2_A/G? #lsm9ds1
2018-10-10 16:04:30
1302_CLK_Clr();DS1302_RST_Set();DS1302_DAT_Write();for(i=0;i>=1; DS1302_CLK_Set();} for(i=0;i>=1; DS1302_CLK_Set
2018-03-28 10:05:03
代码贴出来如下,逻辑无错误,加载到板子也能正常显示,但是中断器无法正常工作。#include#include"ds1302.h"***it alarm=P3^4
2015-03-26 20:18:06
12C887_Peri_Write(MIN_ALARM,time->minute);DS12C887_Peri_Write(HOUR_ALARM,time->hour);Set_Bit(ctrl,5);//????AIE
2020-03-17 12:06:01
Buffer[1]={0x00};void init();void init_USART();uint TQ(uchar n);void set_time();void set_alarm(uchar
2016-03-18 15:19:40
急!急!求大神帮助!!基于DS18B20和STC12C5A16S2的温度控制设计在lcd上显示不了温度,程序是基于AT89C51编写的,但是硬件是STC12C5A16S2,同样的程序
2012-06-15 22:02:52
the DS1285 and DS1287. The devices provide areal-time clock/calendar, one time-of-day alarm, threemaskable interrupts with
2008-10-08 11:09:00
12 the DS1285 and DS1287. The devices provide areal-time clock/calendar, one time-of-day alarm, threemaskable interrupts with
2008-10-08 11:10:00
173 Product Features•Cell based implementation•Selectable mode as DS1 or DS
2010-07-10 10:14:25
12
DS1375 pdf datasheet (I2C Digital Input RTC with Alarm)
2008-10-22 18:27:05
689
Transceivers: DS2151, DS2152, DS2153, DS2154, DS21552, DS21554, DS21352, DS21354 and DS2155. Specifications for selecting the approp
2009-04-20 09:38:44
760 channels. The idle registers in the DS2152, DS2154, DS21X5Y and DS2155 can be used to fill unused (if any) channels. The used channels do not
2009-04-20 09:43:04
774
and Yellow Alarm options for the DS2141A and DS2151 transceivers.
Transmit FramingIn D4 framing applications, the
2009-04-20 10:17:01
581 Abstract: Application note on the DS2151 implementation of the key performance indicators
2009-04-20 10:17:45
629 processor to the following Dallas Semiconductor T1 or E1 framers and single chip transceivers (SCTs): DS2141A, DS2143, DS2151, or the DS2153.
2009-04-20 10:19:15
655
Abstract: The DS2151DK and DS2153DK are ordered and shipped for either T1 or E1 operation. However
2009-04-20 10:25:02
559 Semiconductor DS2151 T1 single chip transceiver (SCT) and how to configure them.
Special Mode #1: 3 State OutputsWhen the S
2009-04-20 10:27:55
1173
processor to the DS2141Q or the DS2143Q Dallas Semiconductor T1 or E1 framers. The application note covers interfacing both the address and da
2009-04-20 10:29:40
583
Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:31:04
536
Abstract: This application note provides a logical diagram of the interface of the Dallas Semiconductor/Maxim DS2151 and DS2153 to the PMC-Sierra 7345.
2009-04-20 10:32:06
686
Abstract: DS2141A can be used for creating a DS/ESF Channel Service Unit. This application note has
2009-04-20 10:32:45
904
Abstract: The DS2151, DS2152, DS2153 and DS2154 single chip transceivers (SCTs) can be used
2009-04-20 10:34:09
929
Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the Motorola MC68MH360 QUICC32. Interconnections be
2009-04-20 10:35:31
568
the Dallas Semiconductor/Maxim DS2151 or DS2153 single chip transceivers (SCTs). Figure 1 describes a method for building a CSU usi
2009-04-20 10:36:22
985
2009-04-20 10:37:00
899
Abstract: Interfacing between the Hitachi HD64570 and the DS2151 for T1 lines or the DS2153 for E1 lines. MCSI-0 and MCS-1 are in Bit Synchronous
2009-04-20 10:38:06
750
Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the Siemens PEB20320.
2009-04-20 10:38:51
830
loopback application using the Dallas Semiconductor/Maxim DS2141A, DS2142, DS2151, or DS2153. With Elastic Store Disabled DS21
2009-04-20 10:39:41
882
drop and insert application using the Dallas Semiconductor/Maxim DS2141A T1 framer or DS2143 E1 framer.
2009-04-20 10:40:36
701
2009-04-20 10:41:16
744
Abstract: Application note 303 provides information on connecting the DS2151 and DS2153 single chip
2009-04-20 10:42:38
840
Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the AT&T T7270.
2009-04-20 10:43:22
578
Abstract: This application note shows connection of the DS2151 T1 single chip transceiver
2009-04-20 10:44:04
1043
connects to any four framers of the following: DS21Q41 quad T1 framer, DS21Q43 E1 framer, DS2141 T1 controller, DS2151 T1 single chip transc
2009-04-20 10:45:06
917
Semiconductor DS21Q42 and the DS21Q41B quad port framer devices. The DS21Q42 enhanced quad T1 framer offers a broader feature set while reta
2009-04-20 10:47:48
698 Semiconductor DS21Q44 and the DS21Q43A quad port framer devices. The DS21Q44 quad E1 framer, offers a broader feature set while retaining th
2009-04-20 10:49:25
1304 Semiconductor/Maxim DS2141A T1 Controller and DS2151 Single Chip Transceiver (SCT).
2009-04-29 10:07:14
803 processor to the following Dallas Semiconductor T1 or E1 framers and single chip transceivers (SCTs): DS2141A, DS2143, DS2151, or the DS2153.
2009-04-29 10:09:06
795
2009-04-29 10:13:03
1037 processor to the DS2141Q or the DS2143Q Dallas Semiconductor T1 or E1 framers. The application note covers interfacing both the address and da
2009-04-29 10:15:34
698
2009-04-29 10:17:37
754
2009-04-29 10:18:40
496
2009-04-29 10:19:22
665
2009-04-29 10:20:01
1154
2009-04-29 10:21:02
1323
2009-04-29 10:21:40
752
2009-04-29 10:22:39
736
2009-04-29 10:24:04
1142
2152L that are not included in the DS2151Q T1 single chip transceiver (SCT). All of the original features of the DS2151Q have been retained. All soft
2009-04-29 10:25:42
881 Semiconductor DS21Q42 and the DS21Q41B quad port framer devices. The DS21Q42 enhanced quad T1 framer offers a broader feature set while reta
2009-04-29 10:26:37
861 特殊的模式 2:允许访问之间的framer和刘在发送侧 40hex对写作测试电阻会退化这一模式。当内部化,tlink结冰捆绑到TS引脚。这是有用的应用程序来访问的冰在冰desired对网络数据流的purposely corrupt之前,它是被淘汰的transmitted左转到T1线路通过TTIP(四异丙醇和tring引脚。有一个精确的冰从TS延迟双极输出引脚的SO的格式化程序的用户的能力,有必要知道的当RCLK和appear咬在rlink引脚。这10 tclk冰期的延迟。
2017-04-10 08:56:38
1 摘要:本应用笔记介绍了如何ds2141a,ds2143,ds2151,和ds2153接口的西门子peb2045。这也显示波形和不同的引脚,用于对peb2045接口时序图。
2017-04-10 10:10:19
6 Interconnections between the DS2151 or DS2153 and the Motorola MC68MH360 (QUICC32) are shown
2017-04-10 10:26:49
4 摘要:应用笔记312提供了一个对达拉斯半导体/格言ds2151 T1单芯片收发器接口逻辑图(SCT)和ds2153 E1 SCT的西门子PEB20320。
2017-04-10 10:46:16
2 摘要:应用笔记304提供了一个对达拉斯半导体/格言ds2151 T1单芯片收发器接口逻辑图(SCT)和ds2153 E1 SCT的ATT T7270。
2017-04-11 11:08:13
4 电子发烧友网为你提供Maxim(Maxim)DS2141AN相关产品参数、数据手册,更有DS2141AN的引脚图、接线图、封装手册、中文资料、英文资料,DS2141AN真值表,DS2141AN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 18:57:01
电子发烧友网为你提供Maxim(Maxim)DS2141AQ+相关产品参数、数据手册,更有DS2141AQ+的引脚图、接线图、封装手册、中文资料、英文资料,DS2141AQ+真值表,DS2141AQ+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 18:58:31
电子发烧友网为你提供Maxim(Maxim)DS2141AQ/T&R相关产品参数、数据手册,更有DS2141AQ/T&R的引脚图、接线图、封装手册、中文资料、英文资料
2023-01-14 19:11:38
电子发烧友网为你提供Maxim(Maxim)DS2141AQ相关产品参数、数据手册,更有DS2141AQ的引脚图、接线图、封装手册、中文资料、英文资料,DS2141AQ真值表,DS2141AQ管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:13:04
电子发烧友网为你提供Maxim(Maxim)DS2141AQN相关产品参数、数据手册,更有DS2141AQN的引脚图、接线图、封装手册、中文资料、英文资料,DS2141AQN真值表,DS2141AQN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:14:43
电子发烧友网为你提供Maxim(Maxim)DS2151QB相关产品参数、数据手册,更有DS2151QB的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QB真值表,DS2151QB管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:17:03
电子发烧友网为你提供Maxim(Maxim)DS2151QNB相关产品参数、数据手册,更有DS2151QNB的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QNB真值表,DS2151QNB管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:19:33
电子发烧友网为你提供Maxim(Maxim)DS2151QN相关产品参数、数据手册,更有DS2151QN的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QN真值表,DS2151QN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:32:30
电子发烧友网为你提供Maxim(Maxim)DS2141A相关产品参数、数据手册,更有DS2141A的引脚图、接线图、封装手册、中文资料、英文资料,DS2141A真值表,DS2141A管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:43:40
电子发烧友网为你提供Maxim(Maxim)DS2151QB+相关产品参数、数据手册,更有DS2151QB+的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QB+真值表,DS2151QB+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:46:23
电子发烧友网为你提供Maxim(Maxim)DS2141AQ+T&R相关产品参数、数据手册,更有DS2141AQ+T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS2141AQ+T&R真值表,DS2141AQ+T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:48:21
电子发烧友网为你提供Maxim(Maxim)DS2141AQN+相关产品参数、数据手册,更有DS2141AQN+的引脚图、接线图、封装手册、中文资料、英文资料,DS2141AQN+真值表,DS2141AQN+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:48:37
关于DS2151实现ANSI T1.231-1993要求的关键性能指标的应用笔记,标题为“数字层次结构 - 第1层在线数字传输性能监测”。此外,还列出了DS2151单芯片收发器(SCT)中的所有重要参数及其位置。
2023-02-08 10:53:51
400 本应用笔记包含将非多路复用总线处理器连接至以下达拉斯半导体T1或E1成帧器和单芯片收发器(SCT)所需的信息:DS2141A、DS2143、DS2151或DS2153。这些器件最初设计用于与使用多路复用总线配置的处理器接口。
2023-02-09 12:08:21
540
本应用笔记重点介绍DS2152L和DS2151Q T1单芯片收发器的区别。DS2152L是DS2151Q的超集。DS2151Q的所有原始特性都得以保留,为DS2151Q创建的软件可以毫不费力地转移到DS2152L上。
2023-06-13 16:31:24
345
正在加载...
