DS2151 - Telecom Evaluation Board
2023-03-22 19:54:49
DS2153 - Telecom Evaluation Board
2023-03-22 19:54:49
:write_data('S');delay(***);write_data('A');delay(***);write_data('T');break;case 7:write_data('S');delay
2013-08-22 10:33:04
设备 1、PC机 x 1台 2、DS-5软件开发工具 x 1套 3、DSTREAM仿真器 x 1套 4、ARM内核开发板(本文以米尔MYD-LPC4357开发板为例) x 1套 5、其他相关
2014-10-13 18:17:15
void jia11() interrupt 0{fen=DS1302Read(0x83);fen=fen+1.6;DS1302Write(0x8e,0x00);DS1302Write(0x82
2016-09-20 20:37:10
DS2175 T1/CEPT ELASTIC STORE
2023-04-06 11:49:48
DS2180 T1 TRANSCEIVER
2023-04-06 11:49:47
[]="ds1302实时时钟";***itscl=P1^0;***itio=P1^1;***itrst=P1^2;***it dula=P1^3;***it wela=P1^4
2013-08-20 10:18:16
The Keysight J3913A T1 WanProbe is a MIPS-based, SNMP-managed WANinterface monitor for T1 Wide Area Networks (WAN).
2019-07-03 11:04:49
],IMU_FIFO_samples);void LSM9DS1_readAccelGyro_nAll(uint8_t * data,uint8_t n) { LSM9DS1
2018-09-10 17:18:56
thing I can't do is connect it to a microcontroller pin, because I've run out of those. Thanks for any help #data-enable #lsm9ds1 #den_a/g
2018-09-30 10:31:02
位置吗?如何对磁力计进行自检?谢谢Yair Sarid #self-test#lsm9ds1以上来自于谷歌翻译以下为原文 Hello, I want to do a self test to lsm9ds1
2018-11-12 16:46:51
};//0,1,2,3,4,5,6,7,8,9,c,e,j,u, ,uchar t,t1,t2,t3;uchar dis_play[4];//数码管显示函数void extern_16m(){WDTCTL = WDTPW
2018-07-09 08:30:20
_OUT_Low();delay_us(T_LOW1);DS_OUT_High();delay_us(T_SLOT-T_LOW1); } else {DS_OUT_Low();delay_us(T
2019-08-29 20:44:46
/命令选择***it rw=P1^1;//读写控制***it e=P1^0;//片选信号***it rst=P3^0; //ds1302***it sclk=P3^1; ***it io=P3^2
2011-10-04 17:02:33
(0x44);//initiates a single temperature conversion}uint get(){uchar a,b;uint t=0;float tt;/*ds
2013-01-06 15:17:04
compensate. Is there a difference between the LSM9DS0 and LSM9DS1 which would break this? E.g. Accel
2018-11-09 09:46:34
Delay1ms(unsigned int t)//误差 0us
unsigned char a,b,c;
for(t;t>0;t--)
for(c=1;c>0
2023-06-27 08:38:46
= wifi.sta.getmac() .. \"\\n\"
for sensorID, temperature in pairs(temps) do
t1 = temperature / 10000
t
2023-04-27 07:07:09
(//Clock Input:48MinputCLK,//Digital tubeoutputDS_A,DS_B,DS_E,DS_F,DS_C,DS_D,DS_G,DS_DP,outputDS_EN1,DS
2018-05-08 22:07:46
DS2153Q 是DALLAS 公司生产的E1 收发器, 能完成E1 PCM30/ ISDN - PRI收发器功能, 可提供随路信令或共路信令工作方式, 线路接口符合ITU - T G. 703 、G. 704、G. 706、G. 823 及ETSI 300011 和300233 标准。
2009-04-29 16:42:01
46 DS26503是一个楼宇综合定时供给系统(BITS)时钟恢复元件,还可用作基本T1/E1收发器。接收部分可从T1, E1和6312kHz同步时序接口中恢复时钟。在T1和E1模式下,还可恢复出同步状态
2023-07-18 08:58:07
DS33R11 以太网映射器,集成了T1/E1/J1收发器
DS33R11 概述
DS33R11将MAC帧按照HDLC或X.86 (LAPS)格式进行打包,以T1/E1/J1数据流
2008-10-06 14:51:08
1135 Abstract: This application note discusses the differences between the DS2155 T1/E1/J1 Single Chip
2009-04-20 08:49:07
1947 摘要:DS21458是一款四端口T1/E1/J1单片收发器(SCT),具有和DS2155单端口T1/E1/J1 SCT相同的寄存器组。DS2155和DS21458具有相同的软件架构,因而从单端口的DS2155向四端口的DS21458移植比较容易
2009-04-20 08:50:02
918 Semiconductor/Maxim DS2148/DS21348 selectable E1 or T1 line interface unit (LIU) in hardwar
2009-04-20 09:09:35
1420
design based on the DS2155 T1/E1/J1 single chip transceiver (SCT) to the DS26401 T1/E1/J1 octal framer. In comparison, the Dallas Semiconductor
2009-04-20 09:10:47
1599 2155, DS21Q55, DS21Q50 and DS26528 in T1/E1, 2MHz, 4MHz, 8MHz clock mode. The hardware connection and software configuration are given.
2009-04-20 09:26:34
1389
Abstract: This application note highlights the differences between the DS2154L and the DS2153Q E1
2009-04-20 09:27:16
870 Transceivers: DS2151, DS2152, DS2153, DS2154, DS21552, DS21554, DS21352, DS21354 and DS2155. Specifications for selecting the approp
2009-04-20 09:38:44
760 channels. The idle registers in the DS2152, DS2154, DS21X5Y and DS2155 can be used to fill unused (if any) channels. The used channels do not
2009-04-20 09:43:04
774
Semiconductor DS21X52 and DS21X54 single chip transceivers (SCTs) with the DS216xx clock adapter (CLAD). The DS21X52 SCT is used for T1 signals an
2009-04-20 09:47:42
947
Abstract: Application Note 341 describes how to identify the device correctly by software. This application note provides the procedure that allows the software to identify the device or poll the device identification register to determine
2009-04-20 10:11:34
836 Semiconductor/Maxim DS2141A T1 Controller and DS2151 Single Chip Transceiver (SCT).
2009-04-20 10:14:45
589 and Yellow Alarm options for the DS2141A and DS2151 transceivers.
Transmit FramingIn D4 framing applications, the
2009-04-20 10:17:01
581 Abstract: Application note on the DS2151 implementation of the key performance indicators
2009-04-20 10:17:45
629 Semiconductor T1 framers and single chip transceivers (SCTs). The SLC-96 mode is used in T1 was designed by AT&T as a digital loop carrier system
2009-04-20 10:18:28
750
processor to the following Dallas Semiconductor T1 or E1 framers and single chip transceivers (SCTs): DS2141A, DS2143, DS2151, or the DS2153.
2009-04-20 10:19:15
655
DS2152/DS2154 T1/E1 demo kits. The DS2152DK & DS2154DK are ordered and shipped for either T1 or E1 operation. However,
2009-04-20 10:24:12
747 Abstract: The DS2151DK and DS2153DK are ordered and shipped for either T1 or E1 operation. However
2009-04-20 10:25:02
559 Semiconductor DS2151 T1 single chip transceiver (SCT) and how to configure them.
Special Mode #1: 3 State OutputsWhen the S
2009-04-20 10:27:55
1173
Abstract: Different values of resistor can be selected between DS2153 or DS2154 single chip
2009-04-20 10:30:24
624
Abstract: This application note describes how the DS2141A, DS2143, DS2151, and DS2153 interface
2009-04-20 10:31:04
536
Abstract: This application note provides a logical diagram of the interface of the Dallas Semiconductor/Maxim DS2151 and DS2153 to the PMC-Sierra 7345.
2009-04-20 10:32:06
686
Abstract: DS2141A can be used for creating a DS/ESF Channel Service Unit. This application note has
2009-04-20 10:32:45
904
Abstract: The DS2151, DS2152, DS2153 and DS2154 single chip transceivers (SCTs) can be used
2009-04-20 10:34:09
929
Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the Motorola MC68MH360 QUICC32. Interconnections be
2009-04-20 10:35:31
568
2009-04-20 10:37:00
899
Abstract: Interfacing between the Hitachi HD64570 and the DS2151 for T1 lines or the DS2153 for E1 lines. MCSI-0 and MCS-1 are in Bit Synchronous
2009-04-20 10:38:06
750
Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the Siemens PEB20320.
2009-04-20 10:38:51
830
loopback application using the Dallas Semiconductor/Maxim DS2141A, DS2142, DS2151, or DS2153. With Elastic Store Disabled DS21
2009-04-20 10:39:41
882
drop and insert application using the Dallas Semiconductor/Maxim DS2141A T1 framer or DS2143 E1 framer.
2009-04-20 10:40:36
701
2009-04-20 10:41:16
744
Abstract: Application note 303 provides information on connecting the DS2151 and DS2153 single chip
2009-04-20 10:42:38
840
Semiconductor/Maxim DS2151 T1 single chip transceiver (SCT) and DS2153 E1 SCT to the AT&T T7270.
2009-04-20 10:43:22
578
Abstract: This application note shows connection of the DS2151 T1 single chip transceiver
2009-04-20 10:44:04
1043
connects to any four framers of the following: DS21Q41 quad T1 framer, DS21Q43 E1 framer, DS2141 T1 controller, DS2151 T1 single chip transc
2009-04-20 10:45:06
917
system backplane using the Dallas Semiconductor/Maxim DS2152 and DS2154 T1/E1 single chip tranceivers (SCTs). The DS2155, DS26528, DS26524, DS
2009-04-20 10:46:00
1036
Semiconductor DS21Q42 and the DS21Q41B quad port framer devices. The DS21Q42 enhanced quad T1 framer offers a broader feature set while reta
2009-04-20 10:47:48
698 Semiconductor/Maxim DS2141A T1 Controller and DS2151 Single Chip Transceiver (SCT).
2009-04-29 10:07:14
803 processor to the following Dallas Semiconductor T1 or E1 framers and single chip transceivers (SCTs): DS2141A, DS2143, DS2151, or the DS2153.
2009-04-29 10:09:06
795
2009-04-29 10:13:03
1037 DS2152/DS2154 T1/E1 demo kits. The DS2152DK & DS2154DK are ordered and shipped for either T1 or E1 operation. However,
2009-04-29 10:14:01
1059 Abstract: Different values of resistor can be selected between DS2153 or DS2154 single chip
2009-04-29 10:16:57
1062
2009-04-29 10:17:37
754
2009-04-29 10:18:40
496
2009-04-29 10:19:22
665
2009-04-29 10:20:01
1154
2009-04-29 10:21:02
1323
2009-04-29 10:21:40
752
2009-04-29 10:22:39
736
2009-04-29 10:24:04
1142
2009-04-29 10:24:57
1000
2152L that are not included in the DS2151Q T1 single chip transceiver (SCT). All of the original features of the DS2151Q have been retained. All soft
2009-04-29 10:25:42
881 Semiconductor DS21Q42 and the DS21Q41B quad port framer devices. The DS21Q42 enhanced quad T1 framer offers a broader feature set while reta
2009-04-29 10:26:37
861 的purposely corrupt之前,它是被淘汰的transmitted左转到T1线路通过TTIP(四异丙醇和tring引脚。有一个精确的冰从TS延迟双极输出引脚的SO的格式化程序的用户的能力,有必要知道的当RCLK和appear咬在rlink引脚。这10 tclk冰期的延迟。
2017-04-10 08:56:38
1 摘要:本应用笔记介绍了如何ds2141a,ds2143,ds2151,和ds2153接口的西门子peb2045。这也显示波形和不同的引脚,用于对peb2045接口时序图。
2017-04-10 10:10:19
6 Interconnections between the DS2151 or DS2153 and the Motorola MC68MH360 (QUICC32) are shown
2017-04-10 10:26:49
4 摘要:应用笔记312提供了一个对达拉斯半导体/格言ds2151 T1单芯片收发器接口逻辑图(SCT)和ds2153 E1 SCT的西门子PEB20320。
2017-04-10 10:46:16
2 摘要:应用笔记304提供了一个对达拉斯半导体/格言ds2151 T1单芯片收发器接口逻辑图(SCT)和ds2153 E1 SCT的ATT T7270。
2017-04-11 11:08:13
4 2022-11-18 23:45:26
0 DS21458为四端口T1/E1/J1单芯片收发器(SCT),与DS2155共享一个公共寄存器组,即单端口T1/E1/J1 SCT。DS2155和DS21458共享通用的软件架构,因此从单端口DS2155迁移到四端口DS21458相对简单。本文详细介绍了DS2155和DS21458之间的细微差别。
2023-01-09 21:22:11
870 本应用笔记介绍如何使用达拉斯半导体DS21X52和DS21X54单芯片收发器(SCT)和DS216xx时钟适配器(CLAD)将T1转换为E1,反之亦然。DS21X52 SCT用于T1信号
2023-01-10 13:45:37
1068
本应用笔记介绍了E1收发器芯片接口电路的一般形式,并展示了如何在变压器周围分配电阻。它解释了为什么发射器和接收器引脚需要不同的保护技术。它讨论了回波损耗的重要性,并展示了如何计算它。内置DS2153/DS2154 E1单芯片收发器IC。
2023-01-13 15:13:26
634
电子发烧友网为你提供Maxim(Maxim)DS2151QB相关产品参数、数据手册,更有DS2151QB的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QB真值表,DS2151QB管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:17:03
电子发烧友网为你提供Maxim(Maxim)DS2153Q-A7相关产品参数、数据手册,更有DS2153Q-A7的引脚图、接线图、封装手册、中文资料、英文资料,DS2153Q-A7真值表,DS2153Q-A7管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:17:31
电子发烧友网为你提供Maxim(Maxim)DS2153QN-A7相关产品参数、数据手册,更有DS2153QN-A7的引脚图、接线图、封装手册、中文资料、英文资料,DS2153QN-A7真值表,DS2153QN-A7管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:18:28
电子发烧友网为你提供Maxim(Maxim)DS2153QN-A7/T&R相关产品参数、数据手册,更有DS2153QN-A7/T&R的引脚图、接线图、封装手册、中文资料、英文资料
2023-01-14 19:18:46
电子发烧友网为你提供Maxim(Maxim)DS2151QNB相关产品参数、数据手册,更有DS2151QNB的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QNB真值表,DS2151QNB管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:19:33
电子发烧友网为你提供Maxim(Maxim)DS2151QN相关产品参数、数据手册,更有DS2151QN的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QN真值表,DS2151QN管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:32:30
电子发烧友网为你提供Maxim(Maxim)DS2151QB+相关产品参数、数据手册,更有DS2151QB+的引脚图、接线图、封装手册、中文资料、英文资料,DS2151QB+真值表,DS2151QB+管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:46:23
电子发烧友网为你提供Maxim(Maxim)DS2153Q-A7+T&R相关产品参数、数据手册,更有DS2153Q-A7+T&R的引脚图、接线图、封装手册、中文资料、英文资料,DS2153Q-A7+T&R真值表,DS2153Q-A7+T&R管脚等资料,希望可以帮助到广大的电子工程师们。
2023-01-14 19:50:51
关于DS2151实现ANSI T1.231-1993要求的关键性能指标的应用笔记,标题为“数字层次结构 - 第1层在线数字传输性能监测”。此外,还列出了DS2151单芯片收发器(SCT)中的所有重要参数及其位置。
2023-02-08 10:53:51
400 本应用笔记包含将非多路复用总线处理器连接至以下达拉斯半导体T1或E1成帧器和单芯片收发器(SCT)所需的信息:DS2141A、DS2143、DS2151或DS2153。这些器件最初设计用于与使用多路复用总线配置的处理器接口。
2023-02-09 12:08:21
540
本应用笔记介绍如何使用DS31256的接收BERT功能执行分数T1(FT1)环路或环路下降检测(V.54),如分数T1.403附录B规范中所述。工作算法和编码示例说明了DS31256易于适应终端用户应用。
2023-02-22 10:08:35
464
本应用笔记重点介绍DS2152L和DS2151Q T1单芯片收发器的区别。DS2152L是DS2151Q的超集。DS2151Q的所有原始特性都得以保留,为DS2151Q创建的软件可以毫不费力地转移到DS2152L上。
2023-06-13 16:31:24
345
