电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Interfacing to the Fractional
收藏
查看更多
41000集成参数分析和表征环境
Covers product configuration, installation overview, site preparation, connecting to a wafer prober, and interfacing to a probe card.
2019-09-29 14:33:00
8563E,8561E频谱分析仪在-50dbc的水平上有大约500KHz的杂散
of -50dbc. I believe the spurious is generated at the Fractional N Synthesizer at the A14 Frequency
2019-05-28 10:02:32
8通道ADC和FPGA之间的接口如何编码
for interfacing those two. So for this i found some of the pdf file's like Xapp485,xapp774 etc and i have
2019-05-28 13:50:34
Interfacing SDRAM Memory on High Performance Microcontrollers
additional memory for code and data when interfacing with High Speed LCD Panels.特性• Designed for (formerly
2015-04-08 10:33:35
AD9361 BBPLL无法锁定是什么原因
accuracySPIWrite 043,28 // BBPLL Freq Word (Fractional[7:0])SPIWrite 042,5C // BBPLL Freq Word
2018-09-26 17:40:47
AD9361 BBPLL锁定的时钟和DATA_CLK的关系是什么
// Set calibration clock to REFCLK/4 for more accuracySPIWrite 043,00 // BBPLL Freq Word (Fractional
2019-03-05 14:36:13
AD9361 BBPLL锁定读到0x5E的值一直是0xCA、0x02、0三个值循环跳变
Word (Fractional[7:0])SPIWrite042,5C// BBPLL Freq Word (Fractional[15:8])SPIWrite041,12// BBPLL Freq
2018-12-25 09:22:23
BU6821G-TR
FRACTIONAL PULSE RATE CONVERTER
2023-03-27 14:12:46
BU6823G-TR
2023-03-27 14:12:46
FPGA配置AD9364怎么操作
Word (Fractional[7:0])SPIWrite 042,5C // BBPLL Freq Word (Fractional[15:8])SPIWrite 041,12 // BBPLL
2018-09-11 21:09:38
GSM调制解调器与PSoC 3接口是否有应用说明
Is there any application note on interfacing GSM modem with PSoC 3. primarly i want to interface the GSM
2019-07-22 07:54:45
HMC4069LP4E
IC PLL FRACTIONAL-N VCO
2023-04-06 12:11:31
HMC824LP6CETR
FRACTIONAL-N PLL WITH INTEGRATED
2023-04-06 17:14:40
HMC826LP6CETR
2023-04-06 17:14:35
HMC828LP6CETR
2023-04-06 17:14:59
HMC829LP6GETR
2023-04-06 17:15:45
HMC831LP6CETR
2023-04-06 17:14:59
HMC839LP6CETR
2023-04-06 17:14:39
HP Instrument BASIC用户手册,版本2.0
;HP Instrument BASIC Interfacing Techniques", and "HP Instrument BASIC Language Reference".
2019-01-24 17:08:05
NCS8805芯片RGB/LVDS转EDP功能(scaler)
Ÿ Advanced fractional scaler Hi-Fidelity scalingSupports any scaling ratio between 1:2 and 2:1Ÿ Low power consumption
2017-07-05 09:09:50
SD卡接口超时问题
我尝试过接口SD卡,但是超时问题。我怎么解决??拉链879字节 以上来自于百度翻译 以下为原文I have tried interfacing SD card.But getting
2019-05-24 08:12:01
Y1270A用于M9018A PXIe机箱的前面板接口套件配置指南
This configuration guide provides the options available for the Y1270A Front Panel Interfacing Kit for the M9018A PXIe 18-slot chassis
2018-10-09 11:47:34
ad9361 rx tx pll无法锁定
280,09 // Set Synth Loop Filter R3SPIWrite 233,F8 // Write Rx Synth Fractional Freq Word[7:0]SPIWrite
2018-09-26 17:43:37
什么时候需要缓冲IC?
interfacing something like a DSP with FPGA, how do we know that when to use a buffer IC? What parameters
2019-04-24 13:41:26
可以使用应用笔记AN61345通过GPIF接口而不是FPGA将图像传感器连接到FX2LP吗?
??如果有的话…让我知道谢谢您 以上来自于百度翻译 以下为原文AN61345 app note is for interfacing fpga to fx2lp...if i interface
2018-11-15 14:15:13
实数错误
两种方法是将其转换为文本并截断它使数字高于95.95(这不是我真正想要的数字)或者我必须打破它的数字Int和fractional,乘以小数100,绕过它,除以100,然后将它们转换为文本,然后将文本重新
2019-03-20 07:51:59
怎么将赛普拉斯SPI主控与Altera Avalon-ST SPI内核连接
以下为原文Hi there, I got problem with interfacing Cypress SPI Master running on PSOC 5 Cortex-M3 MCU
2019-07-02 07:27:42
整数与Q15数据类型的区别
enough to process audio in real time I am using integer math. I was already approximating fractional
2018-12-06 15:40:02
汽车刷式电机纹波计数器位置测量参考设计包括BOM及层图
motor current sensingOperational for typical 9V to 18V battery supplySimple interfacing with MSP430™ LaunchPad™ Development Kit for digital capture
2018-10-24 11:51:17
连接OmniBER 725产品说明
problems interfacing to a wide range of components and modules.
2019-05-10 16:54:41
EL4430, EL4431 pdf datasheet (
, differential-tosingle-ended converters, transducer interfacing, and anysituation where a differential signal must be extracted fro
2009-01-16 21:23:5112
Interfacing Fast Ethernet to P
The roll out of low cost broadband services has led to an ‘IP’ network revolution across factory, office and home. Ethernet has almost exclusively become the physical layer for all networking applications, whether they be industrial co
2009-03-19 16:05:4610
Interfacing 3V and 5V applicat
THE NEED FOR INTERFACING BETWEEN 3VAND 5V SYSTEMSMany reasons exist to introduce 3V1 systems
2009-03-30 00:17:329
Interfacing the DS18X20/DS1822
INTRODUCTIONThere are several methods available for interfacing 1-WireTM devices
2009-04-18 10:18:3028
Interfacing the DS18X20/DS1822 1-Wire Temperature Sensor in a Microcontroller Environment
2009-05-08 11:37:5420
3 V 英特尔StrataFlash存储器28F128J3A
.............................53.0. INTERFACING 3 Volt Intel® StrataFlash™Memory...................................................
2009-05-19 14:06:4333
介绍大型Cypress公司FIFO器件的内部工作和如何应用这
and shows how to use the devices to accomplish depth and width expansion. Other topics covered here include FIFO interfacing, the writing and
2009-05-23 13:23:4422
实现TLC5510模数转换器与TMS320C203 DSP的
This application report is a summary of the application note titled Interfacing the TLC5510Analog
2009-06-12 14:26:1855
AD8250,pdf datasheet (Instrume
impedance, low output noise, and low distortion making it suitable for interfacing with sensors and driving high sample rate analog-to-digital
2009-08-27 11:39:0515
AD8251,pdf datasheet (Instrumentation Amplifier)
; input impedance, low output noise, and low distortion, making it suitable for interfacing with sensors and driving high sample rate analog
2009-08-27 11:46:1416
A New Hybrid Neural System Int
A New Hybrid Neural System Interfacing Neurons and Silicon Hardware for Fast Signal Recognition
2009-09-08 20:42:535
ADF4153,pdf datasheet (Fractio
The ADF4153 is a fractional-N frequency synthesizer that implements local oscillators
2009-09-16 08:40:1917
ADF4154,pdf datasheet (Fractio
The ADF4154 is a fractional-N frequency synthesizer that implements local oscillators in the up
2009-09-16 08:41:5611
ADF4156,pdf datasheet (6 GHz F
The ADF4156 is a 6 GHz fractional-N frequency synthesizer that implements local oscillators
2009-09-16 08:43:1510
ADF4252,pdf datasheet (Frequen
The ADF4252 is a dual fractional-N/integer-N frequencysynthesizer that can be used to implement
2009-09-16 08:51:5812
ADF4350,pdf datasheet (Wideban
The ADF4350 allows implementation of fractional-N or integer-N phase-locked loop (PLL) frequency
2009-09-16 08:53:3043
ADL5310,pdf datasheet (Dual Lo
The ADL5310 addresses a wide variety of interfacing conditions to meet the needs of fiber optic
2009-09-23 09:36:3610
Interfacing to High Speed ADCs
Interfacing to High Speed ADCs via SPI:This application note describes how to use the SPI port
2009-09-30 19:43:3915
AAT3175,pdf datasheet(For Whit
load switch (1X), fractional (1.5X), and doubling (2X) conversion to maximize eff
2010-01-30 11:46:2213
Interfacing the MSP430x11x(1)
This application report describes how to interface an MSP430x11x(1) 16-bit RISC-like mixedsignal microcontroller and a TLV0831 8-bit A/D converter. This report is written for theMSP430x11x(1) family, but can be adapted to any MSP43
2010-06-02 08:58:096
Interfacing the TLC5540 Analog
CMOS analog-to-digital converters (ADCs) are used as basic building blocks in many types of data acquisition systems.This application report describes the interface between the high-speed Texas Instruments (TIä) TLC5540 8-bit para
2010-06-02 09:10:329
Interfacing A/D Converters TLC
1Introduction2 TLC5540/10 Test Circuit 21 Supply Voltages 22 Analog Input221 Direct Input222 Amplifier Input (DC Coupling) 223 Amplifier Input (AC Coupling) 224 Input Range of the TLC5540/10225 Test Points
2010-06-02 09:15:1750
Interfacing the TLC5510 Analog
2010-06-02 09:42:007
Interfacing the MSP430 and TLC
This application report describes how to interface an MSP430 mixed-signalmicrocontroller with TLC549 and TLV1549 3-volt A/D converters. This report is written forthe MSP430x11x(1) family, but can be adapted to any MSP430 derivative
2010-06-02 10:14:3218
Interfacing the TLV2544/TLV254
This application report presents a hardware and software solution for interfacing theTLV2544
2010-06-04 15:46:5013
2010-06-04 15:59:1610
Interfacing the TLC2552 and TL
This application note discusses the features of the TLC2552 and TLV2542 ADC. An SPI interface code  example for the MSP430F149 to the TLC2552 ADC, and for the MSP430F149 to the TLV2542 ADC, are also presented.
2010-06-04 17:10:5614
Interfacing the TLV2541 to the
This application report discusses the SPI interfacing implementation of a system featuringthe
2010-06-04 17:27:1110
Interfacing the TLC2543 ADC to
Texas Instruments (TI) reserves the right to make changes to its products or to discontinue any semiconductorproduct or service without notice, and advises its customers to obtain the latest version of relevant informationto verify
2010-06-05 16:46:1720
Interfacing the TLV1562 Parall
IMPORTANT NOTICETexas Instruments and its subsidiaries (TI) reserve the right to make changes to their products or to discontinueany product or service without notice, and advise customers to obtain the latest version of relevant i
2010-06-06 15:46:102
Interfacing the TLV1544/1548 A
IMPORTANT NOTICETexas Instruments (TI) reserves the right to make changes to its products or todiscontinue any semiconductor product or service without notice, and advises itscustomers to obtain the latest version of relevant i
2010-06-06 16:08:5311
Interfacing the TLC5618A Digit
2010-06-08 10:34:194
Interfacing the TMS320C54x DSP
ABSTRACTThis application report presents a method for interfacing the TLC320AD535 andTLC320AD545
2010-06-23 10:44:098
Synaptics TouchPad Interfacing
This guide describes how computers and other hosts interface to the Synaptics TouchPad.The first section describes the TouchPad generally, including operating modes, features,host interactions, and principles of operation, with man
2010-06-30 21:44:2947
A Fully Integrated, Robust Sol
A Fully Integrated, Robust Solution for Interfacing with Hall-Effect Sensors Maurizio Gavardoni
2008-10-06 14:33:111181
Interfacing 8051-based Microco
Interfacing 8051-based Microcontrollers Abstract: This application note describes how to configure
2009-03-31 22:19:50777
Interfacing to the DS1631 Digi
Abstract: This application note introduces the user to software for interfacing a DS5000 (8051
2009-04-18 10:28:04678
Interfacing the DS1620 to the
Abstract: Communication with the DS1620 digital temperature sensor IC is achieved via a simple 3-wire interface. There are a number of differences between this interface and the Motorola SPI™ interface. However, a few minor hardware
2009-04-18 10:46:14751
Enabling Fractional-T1(FT1) Lo
the receive BERT function in the DS31256 to perform Fractional-T1(FT1)loop-up or loop-down detection (V.54). Overview
2009-04-18 11:23:13907
Interfacing User Devices and t
Abstract: This application note shows how one can access the DST1E1DK via the Expansion Port or the Address/Data bus. DescriptionThis application note is intended to show how to interface a user-defined device-
2009-04-18 11:33:04864
DS2152, DS2154, DS21x5Y, and D
processor to many of the Dallas Semiconductor single chip transceivers (SCTs). The application note covers interfacing both the address and dat
2009-04-20 09:35:221061
Interfacing the DS2155 to the
processor to the DS2155 T1/E1/J1 Single Chip Transceiver (SCT). The application note covers interfacing both the address and data processor bus
2009-04-20 09:46:53575
DS21Q41, DS21Q43 Interfacing t
processor to the DS2141Q or the DS2143Q Dallas Semiconductor T1 or E1 framers. The application note covers interfacing both the address and da
2009-04-20 10:29:40583
DS2152, DS2154 Interfacing to
Abstract: Application Note 321 provides an example circuit for interfacing the Dallas Semiconductor
2009-04-20 10:33:30607
DS2151, DS2153 Interfacing to
Abstract: Interfacing between the Hitachi HD64570 and the DS2151 for T1 lines or the DS2153 for E1 lines. MCSI-0 and MCS-1 are in Bit Synchronous
2009-04-20 10:38:06750
Interfacing the DS21x5y to the
Abstract: This application note show how to connect the DS21x5y family of single chip transceivers (SCTs) to the Texas Instruments TSM320C54x family of digital signal processors (DSPs) utilizing the buffered serial port. Both continuous an
2009-04-20 10:46:57672
Interfacing Switches and Relay
Abstract: This note discusses the effects on switches when used to connect loads. High currents through a switch degrade its quality when used as a power switch. Both mechanical switches and relays exhibit switch bounce during operation. T
2009-04-20 11:21:091661
Interfacing an SPI RTC with a
Abstract: This application note provides an example of hardware and software for interfacing
2009-04-21 09:35:43854
Interfacing a DS3234 Extremely
2009-04-21 09:53:58958
使用DS1814 MicroMonitor来控制微处理器重置
Circuits include interfacing with an 8051 microprocessor, interfacing with a PIC microcontroller, and using an LED to indicate reset.
2009-04-23 09:25:16619
2009-04-23 15:02:56896
2009-04-23 15:11:01666
RS - 232串行通信-Fundamentals of R
interfacing), serial communications is used extensively within the electronics industry. Today, the most popular serial communications standard i
2009-04-24 16:39:082581
2009-04-29 10:15:34698
2009-04-29 10:16:18984
Interfacing the 1-Wire Master
Abstract: This application note provides the reader with information concerning how to interface the Maxim 1-Wire® Master (DS1WM) to an ARM7 processor. Both hardware and software concerns are addressed, including block diagrams and sam
2009-04-30 14:15:40808
Interfacing the MAX195 ADC to
Abstract: Application note for interfacing the MAX195 and MAX194 analog-to-digital converters (ADCs
2009-05-08 09:16:101552
Interfacing the MAX187 to the
Abstract: This application note describes how to interface the MAX187 to the TMS320C3X DSP EV module. This app note can also be used as an example to interface other Maxim ICs to the TMS320 EV module. Example assembly code is provided.
2009-05-08 09:47:46728
基于微处理器的5V系统接口
This application note discusses a variety of approaches for interfacing analog signals to 5V
2012-01-06 14:55:1813
Interfacing with C: Programming
Interfacing with C: Programming Real-World Applications C接口:编程现实世界的应用,教你如何进行专业的C编程!
2015-11-10 17:39:540
DSP systems_ interfacing with th
DSP systems_ interfacing with the outside world
2016-05-06 15:13:287
Synaptics RMI4 Specification
511-000136-01-Rev-E-RMI4-Interfacing-Guide, rmi4 s3202 touch IC synaptics registermap 寄存器手册
2016-06-22 16:12:0182
ds2151,ds2153 interfacing to the mc68mh360 quicc32
(T1) or 0-31 (E1) and TDM channel B is used for the FDL. For more information see the application note on Interfacing to a Non-Multiplex Bus.
2017-04-10 10:26:494
飞思卡尔半导体技术数据H桥驱动MC33186
The 33186 is a monolithic H-Bridge ideal for fractional horsepower DC-motor and bi-directional
2017-09-19 14:36:209
ISO K线串行链路接口MC33660
communication interfacing in automotive diagnostic applications.
2017-09-19 16:43:1033
Interfacing the TLV2541 ADC and the TLV5618A DAC to the TMS320C31 DSP
2017-10-19 09:56:219
振荡器的频率上变频ad9552数据表
The AD9552 is a fractional-N phase locked loop (PLL) based clock generator designed specifically
2017-10-19 14:43:156
2017-10-20 14:46:323
Fractional-N 软件
Fractional-N 软件
2021-03-18 14:29:372
ADMV4530: Dual-Mode, Ka Band Upconverter with Integrated Fractional-N PLL and VCO Data Sheet ADMV4530: Dual-Mode, Ka Band Upconverter with I
电子发烧友网为你提供ADI(ADI)ADMV4530: Dual-Mode, Ka Band Upconverter with Integrated Fractional-N PLL and VCO
2023-10-12 18:46:11
已全部加载完成
