,支持哪一种低压吊扇?A:家用小功率、风大平稳、低噪轻音●AC 220V电源电压,功率范围50W以下,马达电压DC 24V●独特专利减震降噪技术: - MDSF40使用弦波(Sine-Wave)控制
2023-08-07 11:34:52
WAVE6000仿真软件
2012-05-15 13:42:58
AB-A3AI9F-FREQ - SINE-WAVE UHF VCXO - Nel Frequency Controls,inc
2022-11-04 17:22:44
目前有一个FM立体声调制的项目,打算将38khz 的sine Tone 分频为19khzz作为导频,请问1701是否可以实现呢?
2023-11-28 08:20:38
B82614 - Chokes for Power Lines Sine-Wave Chokes - EPCOS
2022-11-04 17:22:44
delivery.Digitally controlled calibration devices and potentiometers (pots) are replacing mechanical pots in many
2011-06-13 00:15:17
, 3.3V输出正弦波import math from pyb import DAC # create a buffer containing a sine-wave buf = bytearray
2018-05-23 09:25:49
描述This design implements a non-isolated DC/DCbuck converter that is digitally controlled using a
2018-11-09 14:56:12
is the output amplitude.I set it to sine wave, 100mVpp, at 1kHz. I use 50 ohms coax cable and the oscilloscope
2019-05-31 11:18:37
pulses of the sine wave. Its at 1/128step mode. Attached is a picture of the problem. Anyone know what settings need to be changed.#l6480-sine-wave-noise
2018-12-06 16:18:50
LTspice中 Voltage Controlled Switches的使用方法
2021-07-09 06:20:15
firmware inside the N5182A is version A.01.70.We are investigating an issue regarding the Sine-wave
2019-07-11 13:57:50
在21479的工程中使用了SigmaStudio 3.9 的sawtooth wave 和sine tone和 triangle wave,发现这些波形的值最大值并不是1,而是超出去到1.0几了,正确的做法范围应该是从-1到+1才对吧?还有现在其MIN MAX到底是多少呢?谢谢!
2018-10-30 09:48:56
Xilinx FPGA提供了DCI(Digitally Controlled Impedance)技术,包括两个功能:(1).控制驱动器的输出阻抗;(2).为驱动器或发送器添加一个并行端接,在传输线上得到精确的特征阻抗匹配,以提高信号完整性。
2019-05-27 07:22:12
1。Digitally_controlled_sine_and_square_wave_generation2。Polyphonic_piano3
2012-11-19 13:49:07
'sine_wave/siganalProbe':S-function 'SignalProbe' does not exist.其中,sine_wine是VI的名字。可是我在simulink中明明是加了SignalProbe这个模块的,请问各位大侠这是怎么回事。
2013-07-05 21:53:37
sine wave into an analog input to a low pass filter inside the PSoC?Since the PSoC is running
2019-04-29 07:25:18
我遵循了关于如何使用 DAC 和 DMA 生成 SINE 波的教程,这非常好。从逻辑上讲这是有道理的,您设置 DAC,将其设置为由定时器触发,然后设置 DMA 通道,将其设置为循环,并将其设置为
2022-12-22 07:26:15
双击某个“地”符号,style里有一项wave
2011-10-13 08:31:06
与Wave1,WiMAXForum®标准比较,Wave2 Radio Conformance Test标准在移动WiMAX™的系统特性上有些新的规格,因此需要一些新的测试能力。而测试Wave 2
2019-07-16 07:36:10
描述This simple and low-cost digitally programmable gain amplifier design creates non-inverting gains
2018-08-29 09:21:39
請問AD9513 這顆PLL的input CLK spec他可以直接輸入VCTCXO的output sine wave 或 clipped sine wave 嗎?如果可以的話, swing Vp-p 只要大於 150mV 即可嗎?
2018-10-17 15:27:28
專家您好,請問, AD9789 可以透過設定哪個register and value,使其輸出sine wave? Thanks a lot.
2018-12-12 09:16:56
请问, AD9789 可以透过设定哪个register and value,使其输出sine wave?
非常感谢。
2023-11-24 08:29:08
求助大神专家!!我在用开发板Digitally Controlled Solar Micro Inverter Design using C2000 Piccolo Microcontroller
2020-07-24 16:39:20
Hi, 请问为什么把一个5ppm 50MHz TCXO产生的clipped-sine wave 时钟源信号送入一个输出信号模式为LVCMOS的时钟buffer 后再把buffer输出的信号送入VCO
2018-08-22 09:35:21
现在用到IQMath,查看F28M35的手册中,只是提到 Sine / Consine Tablesingle floating point-Table size:1282
2020-05-11 09:54:29
Khz sine wave and cosine wave??? i have gone through the user guide of Spartan 3 E as DAC supports
2019-07-04 07:28:26
to provide a maximumerror of ±0.3 mV ±0.3% of reading with sine-wave inputs. Fur-thermore, it maintains high accuracy while measurin
2008-04-14 18:16:02
113 to provide a maximum error of±0.2 mV ±0.3% of reading with sine-wave inputs. Furthermore,it maintains high accuracy while measuring
2008-04-14 18:17:50
36 Modeling voltage-controlled and temperature-dependent resistorsAnalog Behavioral Modeling (ABM) can
2008-05-12 22:27:55
0 The AD8369 is a high performance, digitally controlled variable gain amplifier, designed to be used
2008-08-14 09:54:24
40 Single Digitally Controlled Potentiometer (XDCP? The ISL95811 integrates a digitally
2008-09-21 22:02:42
9 The Intersil ISL95310 is a digitally controlled potentiometer(XDCP). The device consists
2009-01-10 08:55:42
11 The Intersil ISL95311 is a digitally controlled potentiometer(XDCP). The device consists
2009-01-10 09:34:13
26 The ISL95810 integrates a digitally controlled potentiometer(XDCP) on a monolithic CMOS integrated
2009-01-10 09:36:53
11 integratedcircuit.The digitally controlled potentiometers are implemented witha combination of resistor elements and CMOS switches.
2009-01-10 09:37:35
8 controlledpotentiometers (DCP) configured as variable resistors on amonolithic CMOS integrated circuit.The digitally controlled potentiometer
2009-01-10 09:47:53
11 controlledpotentiometers (XDCP) on a monolithic CMOS integratedcircuit.The digitally controlled potentiometers are implemented witha comb
2009-01-10 09:54:25
9 controlledpotentiometers (XDCP) on a monolithic CMOS integratedcircuit.The digitally controlled potentiometers are implemented witha
2009-01-10 09:56:42
19 The ISL95811 integrates a digitally controlled potentiometer(XDCP) and non-volatile memory
2009-01-18 22:34:46
11 The MAX2027 high-performance, digitally controlled variable-gain amplifier is designed for use from
2009-02-16 16:42:44
21 and non-volatile memoryon a monolithic CMOS integrated circuit.The digitally controlled potentiometers are implemented witha combination of
2009-03-05 10:26:28
27 and non-volatile memoryon a monolithic CMOS integrated circuit.The digitally controlled potentiometers are implemented witha combination o
2009-03-05 10:27:22
14 and non-volatile memoryon a monolithic CMOS integrated circuit.The digitally controlled potentiometer is implemented with acombination
2009-03-05 17:12:28
17 and non-volatile memoryon a monolithic CMOS integrated circuit.The digitally controlled potentiometer is implemented with acombination of r
2009-03-05 17:13:14
23 and non-volatile memoryon a monolithic CMOS integrated circuit.The digitally controlled potentiometer is implemented with acombination of
2009-03-05 17:13:59
33 and non-volatile memoryon a monolithic CMOS integrated circuit.The digitally controlled potentiometer is implemented with acombination
2009-03-05 17:15:15
56 The outputs are a square,triangular and sine wave. The sine wave-generating circuit and thesquare and triangular circuits are ind
2009-06-05 16:11:45
21 MODIFIED SINE WAVE INVERTERS:
• 具备输入极性反接、机内过热、输入过欠压、输出过压等保护功能。• 国标、美式、欧式、德式等交流输出插座可选。• 嵌入式智
2009-06-19 19:48:55
16 The AP2010 series integrates Sine-wave generatorcontrol circuit into a single chip, mainly designed
2009-10-19 15:13:26
17 The MAX1660 digitally controlled fuel-gauge interface executes two essential functions
2010-09-06 12:26:04
12 The PGA2500 is a digitally controlled, analog microphone preamplifier designed for use as a front
2010-09-11 19:56:09
18 The PGA202 is a monolithic instrumentation ampli-
fier with digitally controlled gains of 1, 10
2010-09-27 20:08:40
59 The PGA202 is a monolithic instrumentation ampli-fier with digitally controlled gains of 1, 10, 100
2010-09-27 20:13:06
17 The TPS61045 is a high frequency boost converter with digitally programmable output voltage
2010-10-01 23:51:45
14 The UCD8220 analog pulse-width modulator device is used in digitally managed power supplies using
2010-11-10 16:34:08
26 stable, frequency-accurate sine-wave sources. Many such sine-wave oscillators are available, but finding one with a satisfactory level of absolu
2009-04-20 15:31:03
1528 ![](https://file1.elecfans.com//web2/M00/A4/C8/wKgZomUMNaqAUxX6AABD57OoOJE710.gif)
such as resistors and capacitors, and an operational amplifier to build a digitally controlled phase-shift circuit. Although written specifically fo
2009-04-25 10:39:52
1017 ![](https://file1.elecfans.com//web2/M00/A4/CF/wKgZomUMNciAS-c6AAAmqgWh8Qg451.gif)
The circuit of Figure 1 produces an accurate variable-frequency sine wave for use
2009-04-26 15:37:04
735 ![](https://file1.elecfans.com//web2/M00/A4/D0/wKgZomUMNcyADzsWAAAXHJMPFIw626.gif)
2009-04-28 10:30:52
633 ![](https://file1.elecfans.com//web2/M00/A4/D2/wKgZomUMNdSAOrOjAAAmqgWh8Qg157.gif)
Abstract: The DS3904 contains three digitally controlled nonvolatile (NV) variable resistors.
2009-04-28 11:46:50
991 ![](https://file1.elecfans.com//web2/M00/A4/D2/wKgZomUMNdaAe20PAAAothCPOOc125.gif)
A digitally adjustable voltage reference is useful in many applications. For instance, it can
2009-04-28 13:52:54
1992 ![](https://file1.elecfans.com//web2/M00/A4/D2/wKgZomUMNdaALSFhAAAicPVtop0090.gif)
正弦波振荡器:Sine Wave Oscillator
An amplitude-stabilized sine-wave oscillator is shown in Figure 26. This circuit provides high pu
2009-05-16 16:34:24
2396 ![](https://file1.elecfans.com//web2/M00/A4/E9/wKgZomUMNi6AZDkSAABP22zhURQ433.jpg)
三角波发生器:Triangle-Wave Generator
A constant amplitude triangular-wave generator is shown in Figure 27. This circuit provides a
2009-05-16 16:36:15
7793 ![](https://file1.elecfans.com//web2/M00/A4/E9/wKgZomUMNi6AbLOSAABKjT5zBWs767.jpg)
Wien-bridge Sine-wave Oscillator文桥正弦波震荡电路:
2009-10-22 09:54:22
1745 ![](https://file1.elecfans.com//web2/M00/A5/53/wKgZomUMN-mAAIX4AAASUaFKVi4693.jpg)
Crystal controlled 147.460 MHz FM transmitter
The XFM1 transmitter is a crystal controlled tone
2009-12-22 10:11:49
1446 温控风扇电路--Temperature-controlled Fan
Gradually increases speed as temperature increasesWidely adjustable temperature range
2010-01-17 09:26:24
2498 ![](https://file1.elecfans.com//web2/M00/A5/72/wKgZomUMOHiAbsPtAAA6pJ2dJ9Y448.jpg)
在无线传感器网络(WSN)领域中,目前主要有2个标准,ZigBee与Z-Wave。Z-Wave标准与Z-Wave功效技术细节都有所强化、提升。
2012-03-08 09:36:10
2914 三星公司在上月正式宣布发售Bada平台新机Wave 3,不过遗憾的是,这款Bada平台的旗舰只有一个黑色款选择。为了满足众多女性用户需要,日前三星公司又推出了白色版的Wave 3。据了解,穿
2012-03-20 10:02:01
513 The mosfets are also formed in the push pull format which effectively shuffles the entire 60
volts across the transformer windings 50 times per second
2015-12-25 10:40:13
9 Voltage Controlled Oscillator电路设计
2016-01-12 11:14:59
0 wave6000的使用教程,涵盖的较为全面,适合初学者学习
2016-05-24 13:53:59
4 the image component on the normalized sine-wave frequency estimates returned by the Energy-Based Method (EBM) is derived.
2016-09-22 16:52:30
0 the position of the rotor. The DRV10970 uses this feedback from Hall signals for a 180° sine-wave
2016-11-14 14:23:55
0 The AD2S99 programmable sinusoidal oscillator provides sine wave excitation for resolvers and a wide variety of ac transducers.
2017-09-29 14:16:54
5 The AD5232 device provides a nonvolatile, dual-channel, digitally controlled variable resistor (VR) with 256-position resolution.
2017-10-12 10:42:54
11 The AD5241/AD5242 provide a single-/dual-channel, 256- position, digitally controlled variable resistor (VR) device.
2017-10-12 10:53:45
16 The AD5251/AD5252 are dual-channel, I2 C®, nonvolatile memory, digitally controlled potentiometers with 64/256 positions, respectively.
2017-10-12 11:17:02
6 Z-Wave技术现在在智能家居中运用越来越普遍,包括像美国Aeon、泰家宝、欧西迪、法比奥等都采用Z-Wave技术,Z-Wave技术设计特别适用于住宅、照明商业控制以及状态读取应用。Z-Wave技术
2018-06-04 09:11:00
3261 The TQC9307 is a digitally controlled variable gain amplifier (DVGA) with a broadband frequency range of 0.7 to 4.0 GHz.
2018-08-03 11:29:00
3 The TQC9305 is a digitally controlled variable gain amplifier (DVGA) with a broadband frequency range of 700 to 3600 MHz.
2018-08-06 11:29:00
6 The TQM8M9077 is a digitally controlled variable gain amplifier (DVGA) with a broadband frequency range of 50 to 4000 MHz.
2018-08-03 11:29:00
0 RC正弦波振荡器的实用制作方法,Sine-wave oscillator
关键字:正弦波振荡电路图
一、振荡器组成 振荡电路主要
2018-09-20 18:26:40
3001 无源正弦波-方波转换器,Sine wave - square-wave converter
关键字:无源正弦波-方波转换器
无源正弦波
2018-09-20 19:20:44
1741 正弦波振荡器的设计与制作,Sine Wave Oscillator Design
关键字:正弦波振荡器的设计与制作
正弦波振荡器
2018-09-20 19:21:41
1296 本文介绍了无线网状组网的一些基础知识,特别是 Z-Wave。随后,本文以 Silicon Labs 的 700 系列 Z-Wave 兼容微控制器芯片系列及相关开发工具作为实例,展示如何快速构建经认证的可用 Z-Wave 网络并应用于新型消费类设备。
2019-06-29 09:52:27
4663 ![](https://file.elecfans.com/web1/M00/99/7F/pIYBAF0WxEmAXcEJAAAU22Yse_k659.jpg)
Z-Wave联盟(Z-Wave Alliance)在2020年9月发布了新的Z-Wave远程协议(Z-Wave Long Range, Z-Wave LR)规范。经过短短三个月
2021-01-08 17:13:00
2263 LTC6990: Voltage Controlled Silicon Oscillator
2021-02-04 08:04:02
3 ZigBee 与 Z-Wave:有何区别?
2023-01-03 09:45:03
1127 ![](https://file.elecfans.com/web2/M00/87/63/poYBAGOuNWOAf-w-AABoCTWNEtM112.jpg)
KOAN晶振中的输出波形普遍分为方波Square Wave和正弦波Sine Wave两类。其中方波有非差分和差分输出的选择;正弦波有准正弦波和削峰正弦波的选择。
2023-04-17 16:20:12
1718 电子发烧友网站提供《如何制作Wave Motion.zip》资料免费下载
2023-07-10 09:53:58
0 晶振中的输出波形普遍分为方波Square Wave和正弦波Sine Wave两类。
2023-08-18 17:28:06
1828 (Hershey-kiss, Sine-wave, Triangle):4调制频率,6个扩散外部尺寸:7.0 x 5.0 [mm]利用PLL技术实现短批量生产时间。可用字段振
2024-01-23 10:42:09
0 (Hershey-kiss,Sine-wave,Triangle)和4调制频率,6个扩散。此外,SG-9101CG是SG-9101系列中最小尺寸的2520晶振。随着市场
2024-01-24 11:41:24
