电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Phase-Lock Loop Applications U
收藏
查看更多
8753A衰减器怎么了?
phase lock above 1.7Ghz but not below and when I ask for CW of 10MHz breaking the phase loop
2019-08-21 12:59:05
A question on for loop
If there're more than one array come into the for loop(more than one auto—index),than how many times should the loop runs?
2012-05-31 19:32:51
Analog Applications Journal 模拟应用
Analog Applications Journal 模拟应用Analog Applications Journal is a collection of analog application
2009-11-20 08:55:44
CD4046BE
IC PHASE-LOCK LOOP MCPWR 16-DIP
2023-03-28 18:26:07
CD4046BEE4
2023-03-27 13:31:20
CD4046BNSR
IC PHASE-LOCK LOOP MCPWR 16SO
2023-04-06 12:10:44
CD4046BNSRE4
2023-04-06 12:11:57
CD4046BNSRG4
2023-04-06 17:04:00
CD4046BPW
IC PHASE-LOCK LOOP MCPWR 16TSSOP
2023-04-06 12:10:57
CD4046BPWR
2023-04-06 12:10:44
CD4046BPWRG4
2023-04-06 17:03:59
CDC2509C
CDC2509C: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. A)
2022-11-04 17:22:44
CDC2510
CDC2510: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. B)
2022-11-04 17:22:44
CDC2510C
CDC2510C: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. A)
2022-11-04 17:22:44
CDC2516
CDC2516: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. C)
2022-11-04 17:22:44
CDC2516DGGR
CDC2516 3.3-V PHASE-LOCK LOOP CL
2023-04-06 12:11:18
CDC2582
3.3-V Phase-Lock Loop Clock Driver With Differential LVPECL Clock Inputs datasheet (Rev. B)
2022-11-04 17:22:44
CDC509
CDC509: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. C)
2022-11-04 17:22:44
CDC516
CDC516: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. B)
2022-11-04 17:22:44
CDC582
2022-11-04 17:22:44
CDCF2509
CDCF2509: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. C)
2022-11-04 17:22:44
CDCF2510
CDCF2510: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. D)
2022-11-04 17:22:44
CDCU2A877NMKT
1.8V PHASE-LOCK LOOP CLOCK DRIVE
2023-03-27 13:47:06
CDCU877ANMKR
2023-03-27 13:47:08
CDCUA877NMKR
2023-03-27 13:47:06
CDCV855
2.5-V Phase-Lock Loop Clock Driver datasheet (Rev. A)
2022-11-04 17:22:44
CDCVF2505
CDCVF2505 3.3-V Clock Phase-Lock Loop Clock Driver datasheet (Rev. G)
2022-11-04 17:22:44
CDCVF2509
CDCVF2509: 3.3-V Phase-Lock Loop Clock Driver datasheet (Rev. D)
2022-11-04 17:22:44
CDCVF2509PWR
CDCVF2509 3.3-V PHASE-LOCK LOOP
2023-04-06 12:11:18
CDCVF2510
2022-11-04 17:22:44
CDCVF2510A
2022-11-04 17:22:44
CDCVF2510PWR
CDCVF2510 3.3-V PHASE-LOCK LOOP
2023-04-06 12:11:15
CDCVF855
1.5-V Phase-Lock Loop Clock Driver datasheet (Rev. A)
2022-11-04 17:22:44
CDCVF857
2.5V Phase-Lock Loop Clock Driver datasheet (Rev. F)
2022-11-04 17:22:44
Data Isolation for loop powered applications
`描述The focus of this design is the bidirectional communication across an isolation for loop powered
2015-03-23 10:12:22
Design considerations for three-phase power factor correction
John Bottrill, Senior Applications Manager, Texas InstrumentsThe need for the current waveform
2016-06-12 09:26:32
FPGA配置AD9364怎么操作
// Increase BBPLL KV and phase marginWAIT_CALDONE BBPLL,2000 // Wait for BBPLL to lock, Timeout 2sec, Max
2018-09-11 21:09:38
HCF4046BEY
IC PHASE-LOCK LOOP MCRPWR 16-DIP
2023-04-06 17:24:33
HCF4046M013TR
IC PHASE-LOCK LOOP MCRPWR 16SOIC
2023-04-06 17:24:33
HEF4046BP,652
2023-04-06 17:20:09
HEF4046BT,652
IC PHASE-LOCK LOOP W/VCO 16SOIC
2024-03-14 22:09:05
PLL - Design, Simulation and Applications
="Simulation"and="and"Applications="Applications&quot
2009-09-25 17:06:37
SINGLE PHASE MOTOR
`SINGLE PHASE MOTOR,USING THE 220V-440V 3PHASE AC INDUCTION MOTOR`
2016-01-07 16:12:29
SJ-3533N-LOOP-BLACK-1"
BLACK LOOP
2023-03-22 22:58:56
Unified Constant-Frequency Integration Control of Three-Phase Standard Bridge Bo
Unified Constant-Frequency Integration Control of Three-Phase Standard Bridge Boost Rectifiers
2011-09-10 23:19:15
hmc838 phase noise and loop filter BW
The loop filter's BW is so strange on my HMC838 board, The BW gets so large at lower frequency
2018-07-30 07:51:10
【Qorvo招聘】Sr. Field Applications Engineer 上海
`QorvoSr. Field Applications Engineer 15K-20K上海5年以上本科及以上全职 职位诱惑: 美资上市公司,绩效奖金, 五险一金,额外商业保险,各类津贴,定期体检
2015-12-31 10:23:24
历年IEEE 关于电荷泵Charge-Pump的好资料 !!!!!(好东西)
]Charge-pump phase-lock loops.pdf (880.95 KB)  [1995]Performance limits of switched-capacitor DC-DC
2010-04-19 20:55:10
如何将FIELD_RETURN_LOCK设置为1b =启用?
我想启用 OCOTP_SW_STICKY 寄存器中的 FIELD_RETURN_LOCK 位。IMX6DQ6SDLSRM 描述它设置为始终启用以保护 FIELD_RETURN 保险丝。但是,当我检查
2023-04-07 07:26:16
适用于工业机器人和电机驱动器的PMP15025技术资料下载
current30kHz Loop Bandwidth with 75° of Phase Margin for fast, stable, transient response
2018-07-13 14:07:54
74HC4046 pdf datasheet
MM54HC4046/MM74HC4046CMOS Phase Lock LoopGeneral DescriptionThe MM54HC4046/MM74HC4046 is a low
2008-08-06 10:28:26110
IDT2305 pdf datasheet (3.3V ZE
The IDT2305 is a high-speed phase-lock loop (PLL) clock buffer,designed to address high-speed clock
2008-08-06 13:17:0919
MAX3679 pdf datasheet (Low-Jit
LVCMOS outputs optimized for Ethernet applications. The device integrates a crystal oscillator and a phase-locked loop (PLL) clock multip
2008-12-25 17:37:297
EL4584 pdf datasheet (EL4584 H
The EL4584 is a PLL (Phase Lock Loop) sub system,designed for video applications but also suitable
2009-01-16 21:48:286
EL4585 pdf datasheet (Horizont
The EL4585 is a PLL (Phase Lock Loop) sub-system,designed for video applications and also suitable
2009-01-16 21:49:189
MAX3629 pdf datasheet (Precisi
. The device integrates a crystal oscillator and a phase-locked loop (PLL) to generate high-frequency clock outputs for Ethernet applications.M
2009-02-11 18:03:229
MAX9382, MAX9383 pdf datasheet
in high-bandwidth phase-locked loop (PLL) applications. The devices compare a single-ended reference (R) and a VCO (V) input and produce pulse streams o
2009-02-21 15:12:4622
MAX3627,pdf,datasheet (+3.3V,
2009-05-02 09:43:5826
以MPC505 PC509为例,介绍在微控制器应用中锁相环性
Microcontroller-based applications can be delayed or jeopardized byreduced phase locked loop (PLL
2009-06-19 10:25:0915
Phase-Locked Loop Circuit Design
Phase-Locked Loop Circuit Design:
2009-07-25 17:01:130
MAX3679/MAX3679A,pdf datasheet
LVCMOS outputs optimized for Ethernet applications. The device integrates a crystal oscillator and a phase-locked loop (PLL) clock multipli
2009-08-17 00:11:3924
锁相环理论教程,PLL Theory Tutorial
This tutorials discusses the key areas of Phase Locked Loop (PLL) design, covering the main
2009-09-03 08:02:5026
Phase Noise Analysis in CMOS L
Phase Noise Analysis in CMOS LC Qudrature VCOver the years, several phase noise analyses have been
2009-09-08 08:21:5617
AD808,pdf datasheet (Clock Rec
The AD808 acquires frequency and phase lock on input datausing two control loops that work without
2009-09-15 08:25:4515
MAX3624,pdf,datasheet (Low-Jit
. The device integratesa crystal oscillator and a phase-locked loop(PLL) clock multiplier to generate high-frequency clockoutputs for
2009-09-18 08:54:3717
3-Phase BLDC Motor Control wit
This document describes the design of a 3-phase BLDC(Brushless DC) motor drive based on Freescale
2010-02-26 14:26:0844
CD74ACT297,pdf(Digital Phase-L
, phase-locked-loop applications. This device contains all the necessary circuits, with the exception of the divide-by-N counter, to build first-order ph
2010-08-20 18:00:1315
SN54LS297,SN74LS297,pdf(Digita
to high-accuracy, digital, phase-locked-loop applications. These devices contain all the necessary circuits, with the exception of the divide-
2010-08-20 18:14:5211
TPS40131,pdf(Two-Phase Synchro
, high-output current applications powered from a supply between 1 V and 40 V. A multi-phase converter offers several advantages over a singl
2010-10-05 20:19:5821
UCD9224,pdf(Digital PWM System Controller)
for non-isolated DC/DC power applications. This device integrates dedicated circuitry for DC/DC loop management with flash memory and a serial int
2010-11-10 15:47:3929
UCD9248,pdf(Digital PWM System
2010-11-10 16:06:0123
UCD9246,pdf(Digital PWM System
2010-11-10 16:09:357
QuickChip Design Example 1 - A
Abstract: A broadband phase-lock loop (PLL) building block integrated circuit (IC) that can accommodate
2008-09-17 16:14:12905
A Silicon Bipolar Broadband PL
A Silicon Bipolar Broadband PLL Building Block Integrated Circuit Abstract: A broadband phase-lock
2008-09-17 16:44:49842
Phase-Lock Loop Applications Using the MAX9382
2009-02-21 15:14:001252
Selectable-Range Current Loop
Abstract: This article shows an example of implementing a 4-20mA or 0-20mA current-loop output
2009-04-20 11:22:47957
2009-04-20 15:19:44815
硅双极宽带锁相环积木块集成电路-A Silicon Bipo
2009-05-06 09:01:28814
锁相环应用的MAX9382-Phase-Lock Loop
phase-locked loop (PLL) dead band and jitter performance. In PLLs that employ charge pump loop filter designs the provision of a minimum duratio
2009-05-08 10:48:511049
什么是Arbitrated loop
什么是Arbitrated loop  英文缩写: Arbitrated loop 中文译名: 已裁定的环路 分
2010-02-22 10:18:13445
AD9577,pdf datasheet (Clock Generator)
The AD9577 provides a multioutput clock generator function along with two on-chip phase-locked loop
2011-10-29 17:14:2721
LTC1062的低通滤波器应用
Highlights the LTC1062 as a lowpass filter in a phase lock loop. Describes how the loops bandwidth
2012-01-06 14:34:3654
Phase_Lock_Loop电路设计
Phase Lock Loop电路设计,喜欢的朋友可以下载来学习。
2016-01-11 17:42:360
Proteus在MCS&ARM中的应用之Key_Lock (2)
【好程序系列】Proteus在MCS&ARM中的应用之Key Lock (2)
2016-01-20 15:13:387
PCB绘图案例【Circuit Simulation】. Phase_Lock_Loop
PCB绘图案例【Circuit Simulation】. Phase Lock Loop
2016-02-16 11:47:050
UWB Applications
UWB Applications,有需要的下来看看。
2017-01-12 22:55:1523
ad9550用于有线通信的整数N时钟转换器
The AD9550 is a phase-locked loop (PLL) based clock translator designed to address the needs of wireline communication and base station applications.
2017-10-19 14:41:114
以太网千兆以太网时钟发生器ad9574数据表
-locked loop (PLL) core optimized for Ethernet and gigabit Ethernet line card applications.
2017-10-19 15:15:0317
双锁相环扩频和冗余时钟发生器ad9577数据表
-locked loop cores, PLL1 and PLL2, optimized for network clocking applications.
2017-10-19 15:19:2417
双锁相环邻频调制器制作,Phase-locked loop
双锁相环邻频调制器制作,Phase-locked loop 关键字:锁相环调制器电路图 作者:林德耀 本制作是在单片机控制下,通过
2018-09-20 19:15:04673
LOOP指令——汇编语言学习笔记3
因为嵌入式系统学习需要,开始学习汇编语言学习资料是B站的视频:汇编语言程序设计 贺利坚主讲 (P25)这里写目录标题LOOP功能与格式一、LOOP指令实例二、LOOP指令执行的要求三、用LOOP指令
2022-01-18 08:30:554
UVM里的phase机制
run phase可以和其他12个小phase 的关系是可以在run phase里执行12个小phase的功能,也可以在12个小phase中分步进行。run phase和其他12个phse是一个并行关系,而12个phase是顺序执行的。
2022-09-05 15:34:132673
新型Wyze Lock Bolt智能锁的应用案例
  SiliconLabs(亦称“芯科科技”)副产品经理Sean Scannell近期撰写了一篇博客文章,介绍一个新型Wyze Lock Bolt智能锁(Smart Lock)的应用案例,该产品采用
2022-10-20 10:34:40879
Turning Lock转锁拼图开源分享
电子发烧友网站提供《Turning Lock转锁拼图开源分享.zip》资料免费下载
2022-11-04 14:37:250
UVM中phase的执行顺序
代码的书写顺序会影响代码的实现(代码之间存在依赖关系,如代码B依赖于代码A),所以区分出build_phase、connect_phase
2023-05-26 15:00:14499
锁相环PLL是什么?它是如何工作的?
今天想来聊一下芯片设计中的一个重要macro——PLL,全称Phase lock loop,锁相环。我主要就介绍一下它是什么以及它是如何工作的。
2023-12-06 15:21:13387
DLL/PI的原理简述
如果有准频率,但相位不准的时钟,那么常用DLL(delay loop lock)来锁定时钟的相位,而PI(phase interpolation)是DLL最重要的部分。
2023-12-15 15:14:17263
loop指令执行时,隐含的寄存器是
当执行loop指令时,隐含的寄存器是CX寄存器。CX寄存器是循环计数器寄存器,它存储了循环的迭代次数。 在汇编语言中,loop指令用于实现循环控制结构。它的工作原理是将CX寄存器的值减1,并检查CX
2024-02-14 16:15:00270
arduino如何停止loop循环
Arduino的loop循环是其主要的程序执行部分,该循环将在Arduino开发板上持续运行,并且只有在程序被重新上传或开发板断电重启时才会停止。然而,在某些情况下,你可能需要在程序执行过程中停止
2024-02-14 16:24:00761
已全部加载完成
