电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Generating Switched-Capacitor-
收藏
查看更多
为什么要讨论用来升压的电荷泵电路呢?
今天我们一起来讨论一下用来升压的 **电荷泵电路** (Charge Pump),也称为 **开关电容转换器** (Switched Capacitor Converter)。
2023-11-10 14:11:29691
ADM8660ARZ
CMOS SWITCHED-CAPACITOR VOLTAGE
2023-04-06 11:05:38
ICL7660ACBA
SWITCHED CAPACITOR CONVERTER
2023-03-27 11:59:21
ICL7660AIBA-T
2023-03-23 08:37:58
ICL7660CBA-T
2023-03-27 13:39:24
ICL7660CPA
2023-03-27 13:12:31
ICL7660SCBA
2023-03-27 13:31:13
ICL7660SIBA
2023-03-27 13:03:53
ICL7660SIBAT
2023-03-23 08:29:05
ICL7660SIBAT
2023-03-27 12:53:37
LM2660M`
SWITCHED CAPACITOR VOLTAGE CONVE
2023-03-27 13:31:55
LM2765M6X
SWITCHED CAPACITOR CONVERTER, 0.
2023-04-06 19:58:04
LM2770SD-12157--NOPB
SWITCHED CAPACITOR REGULATOR
2023-03-23 08:56:17
LM2794BL
2023-04-06 09:54:40
LM2798MM-2.0--NOPB
2023-03-23 08:56:09
LM3351MM--NOPB
2023-04-06 19:53:48
LM3351MMX--NOPB
2023-04-06 19:54:05
LM3354MM-1.8--NOPB
2023-03-23 08:56:09
LM3354MM-3.3--NOPB
2023-03-23 08:56:10
LMC7660IM
2023-03-23 08:37:50
MAX660M-TI
2023-03-27 13:34:17
MAX8630YETD15+
SWITCHED CAPACITOR REGULATOR, 10
2023-03-27 12:17:04
MAX8630YETD25+
2023-03-27 12:24:12
MAX8630ZETD20+
2023-03-27 12:14:36
PSoC 1评估套件包括过时的设备? SC电路的替代品?
devices that work with this kit? My applications require the versatility of the switched capacitor
2018-12-18 15:51:15
PW5410B两节干电池升压3.3V芯片
) switched capacitor voltage doubler. It produces a regulated output voltage from 1.8V to 5V input
2020-07-28 21:18:10
REG710NA-2.5/3K
2023-10-31 17:34:47
REG711EA-3.3--250G4
2023-03-23 08:38:02
SL1203
DescriptionThe SL1203 is a low noise, constantfrequency (1.2MHz) switched capacitor voltagedoubler.
2021-06-29 11:01:06
SP6660EU-L
SWITCHED CAPACITOR CONVERTER, 16
2023-03-28 02:10:11
TPS2015DG4
2023-04-06 18:25:19
TPS60132PWPR
2023-04-06 19:56:19
TPS60301DGSRG4
2023-04-06 18:59:53
TPS60503DGSG4
2023-03-23 08:38:12
TPS65573DSSR
2023-10-31 18:15:35
共模抑制比和电源抑制比区别
读论文analysis of switched-capacitor commom-mode feedback circuit1.与单端输出相比,全差分电路有更好的共模抑制比和电源抑制比。2.共模环路
2021-10-29 07:10:25
无电感锂电池升压IC(5V 230MA)PS3120A
The PS3120A is a low noise switched capacitor voltage doubler. It produces a regulated output
2020-10-31 13:59:31
TLC542 pdf datasheet
The TLC542 is a CMOS converter built around an8-bit switched-capacitor
2008-07-20 23:41:4216
REG71050 pdf datasheet (降压/升压充
The REG710 is a switched capacitor voltage converterthat produces a regulated, low-ripple output
2008-08-08 00:12:4519
MAX1044 pdf datasheet (Switche
The MAX1044 and ICL7660 are monolithic, CMOS switched-capacitor voltage converters that invert
2008-10-24 13:21:0433
tlc1549 pdf datasheet (10-BIT
The TLC1549C, TLC1549I, and TLC1549M are 10-bit, switched-capacitor, successiveapproximation
2009-02-08 11:26:212
ACF2101用作双极型开关积分器
The ACF2101 is a dual, switched integrator that is typicallyused to convert a positive input
2009-06-10 09:20:4144
LM2753,pdf,datasheet (High Pow
of 3.6V. A switched capacitor doubler, the LM2753 provides a regulated 5V output (VOUT
2009-09-08 20:09:5614
LM2757,pdf datasheet ( Switche
The LM2757 is a constant frequency pre-regulated switched-capacitor charge pump that operates
2009-09-28 13:11:5523
LM2756,pdf datasheet (Multi-Di
The LM2756 is a highly integrated, switched-capacitor, multi-display LED driver that can drive up
2009-09-28 13:13:4027
LM2771,pdf datasheet (250mA Sw
The LM2771 is a switched capacitor step-down regulatorthat produces a 1.5V output without the use
2009-09-29 14:24:138
LM27951,pdf datasheet (White L
The LM27951 is a switched capacitor white-LED driver capableof driving up to 4 LEDs with 30mA
2009-09-30 09:37:5920
LM3550,pdf datasheet (5A Flash
LM3550 is a low noise, switched capacitor DC/DC converterdesigned to operate as a current-limited
2009-09-30 10:07:3418
LM2758,pdf datasheet (Switched
LM2758 is an integrated low-noise, high-current switched capacitorDC/DC converter with a regulated
2009-09-30 10:25:4613
ADP3610,datasheet,pdf(320 mA S
The ADP3610 is a push-pull switched-capacitor converter voltagedoubler. The term “push-pull” refers
2009-10-23 08:44:3921
Chip tantalum Capacitor 贴片型钽质电
Chip tantalum Capacitor 贴片型钽质电容器
2009-11-16 11:35:2428
RC Snubber Resonant Design
RC Snubber Resonant DesignAn RC snubber is just a resistor and capacitor in series that damps
2009-11-28 11:52:3628
Switched-Mode Power Supply Des
Switched-Mode Power Supply Design Manual:Switched-Mode Power Supply (SMPS) design is a slow
2009-11-28 15:29:1434
UltraCAD’s Bypass Capacitor Im
to generate the capacitorvalues for you or whether you want to enter them from afile.Internally generated capacitor values range logar
2010-01-15 09:18:260
ESR and Bypass Capacitor Self
ESR and Bypass Capacitor Self Resonant Behavior:It’s no news that the band pass requirements
2010-01-15 10:39:230
DC滤波直流链设计应用,DC-Link Capacitor
DC滤波直流链设计应用DC-Link Capacitor MKP1849 客户定制系列 应用:DC-Filtering DC滤波混合动力汽车,纯电动汽车, 太阳能焊机设备
2010-03-08 14:27:1735
TLV2553-Q1,pdf (12-Bit 200-ksp
The TLV2553 is a 12-bit switched-capacitor successive-approximation analog-to-digital converter
2010-06-04 15:32:0222
TLC2543-Q1,pdf(12-Bit Analog-t
The TLC2543 is a 12-bit, switched-capacitor, successive-approximation, analog-to-digital
2010-06-05 16:35:1410
TLC1550I,TLC1550M,TLC1551I,pdf
, switched-capacitor, successive-approximation network. A high-speed, 3-state parallel port directly interfaces to a digital signal processo
2010-06-06 16:32:5527
TLC1541,pdf(10-Bit Analog-to-D
The TLC1541 is a CMOS A/D converter built around a 10-bit switched-capacitor
2010-06-06 16:48:3423
SN75LBC775,pdf(Single-Chip App
for an AppleTalk or a LocalTalk interface and a switched-capacitor voltage converter for a single 5-V supply operation. LocalTalk us
2010-08-30 10:28:2113
TL7660,pdf(CMOS VOLTAGE CONVER
The TL7660 is a CMOS switched-capacitor voltage converter that perform supply-voltage conversions
2010-09-13 19:12:1113
ACF2101,pdf(Low Noise, Dual Sw
The ACF2101 is a dual switched integrator for preci-sion applications. Each channel can convert
2010-09-14 07:29:5431
TPS60150,pdf(5V/140mA Charge P
The TPS60150 is a switched capacitor voltage converter which produces a regulated, low noise
2010-10-06 19:37:4221
REG71055,pdf(60mA, 5.0V, Buck/
2010-10-06 19:58:024
REG710-33,pdf(60mA, 5.0V, Buck
2010-10-06 20:06:208
REG710-27,pdf(60mA, 5.0V, Buck
2010-10-06 20:15:4919
REG711-5,REG711-3,pdf(50mA Swi
The REG711 is a switched capacitor voltage converter, which produces a regulated, low ripple output
2010-10-06 21:15:1414
REG71055-Q1,pdf(30-mA 5-V Buck
The REG71055 is a switched capacitor voltage converter that produces a regulated, low-ripple output
2010-10-06 21:20:4421
LT1054,pdf(SWITCHED-CAPACITOR
The LT1054 is a bipolar, switched-capacitor voltage converter with regulator. It provides higher
2010-10-06 21:23:0335
ICL7660, MAX1044 开关电容电压转换器
ICL7660, MAX1044 开关电容电压转换器 ICL7660, MAX1044 概述 The MAX1044 and ICL7660 are monolithic, CMOS switched-capacitor voltage converters t
2008-10-24 13:23:462273
新增数字调整,连续时间滤波器-Add Digital Adj
Tuned-bandpass applications often incorporate switched-capacitor filters—these filters enable
2009-04-25 12:01:17580
发电机开关电容滤波器时钟-Generating Switch
the prices of switched-capacitor filters (SCFs) by a factor of three. As an example, five-pole Butterworth low-pass filters sell for less t
2009-04-25 16:03:571983
开关电容集成电路形式陷波器-Switched-Capacit
Switched-capacitor filters (SCFs) are renowned for ease of use. They are accurate, require
2009-04-25 16:05:471242
电压型逆变器集成电路形式高效轨道器-Voltage-Inve
A switched-capacitor voltage inverter configured as a "rail splitter" (IC1 in Figure 1) provides
2009-05-04 10:35:15653
Integrated Solutions Make Anal
advances of switched-capacitor analog filters for anti-aliasing and noise filtering for ADCs (analog-to-digital converters), as
2009-11-08 17:40:42932
2009-11-08 17:40:59995
什么是ASTN (Automatic Switched Tr
什么是ASTN (Automatic Switched Transport Network)  英文缩写: ASTN (Automatic Switched Transport Network) 中文译名: 自动交
2010-02-22 09:53:57804
什么是Fabric, Switched交换结构
什么是Fabric, Switched交换结构 考虑一种多连接装置,连接中一个网孔上一边连接输入,另一边连接输出。任意输入可立刻交换为任意输出
2010-04-03 14:39:181888
LTC6943-微功率、精准仪表双开关电容器单元式部件
LTC6943描述The LTC®6943 is a monolithic, charge-balanced, dual switched capacitor instrumentation buildi
2010-12-01 16:56:011058
LTC660-100mA CMOS Voltage Conv
LTC660描述The LTC®660 is a monolithic CMOS switched-capacitor voltage converter. It performs supply volt
2010-12-07 16:56:011268
LTC1044-Switched Capacitor Vol
LTC1044描述The H (Metal Can), J (Ceramic), and K (Metal Can) Packages From Linear Technology Are Now Obsolete The LTC1044 provides several volt
2010-12-07 17:06:101775
LT1054-Switched-Capacitor Volt
LT1054描述The LT®1054 is a monolithic, bipolar, switched-capacitor voltage converter and regulator. The
2010-12-07 17:15:392099
LTC1144-Switched-Capacitor Wid
LTC1144描述The LTC1144 is a monolithic CMOS switched-capacitor voltage converter. It performs supply voltage
2010-12-07 17:19:231889
电压基准对总谐波失真的影响_英版
delta-sigma ADCs) consists of switched-capacitor loads. During the conversion process
2016-11-02 14:56:250
低通滤波器的应用考虑
presently available lowpass switched-capacitor fi lters because it uses an external
2017-05-05 14:42:4015
16位100/200kSPS双极A/D转换器AD976/AD976A数据表
5 V supply. The part contains a successive approximation, switched capacitor ADC
2017-10-11 14:37:177
On-chip Starter Circuit for Switched-inductor DC–DC Harvester Systems
2017-10-17 11:30:222
120毫安开关稳压输出电容电压逆变器ADP3605数据表
The ADP3605 is a 120 mA regulated output, switched capacitor voltage inverter. It provides
2017-10-27 11:30:087
LMC7660 Switched Capacitor Voltage Converter
电子发烧友网为你提供TI(ti)LMC7660相关产品参数、数据手册,更有LMC7660的引脚图、接线图、封装手册、中文资料、英文资料,LMC7660真值表,LMC7660管脚等资料,希望可以帮助到广大的电子工程师们。
2018-10-16 19:11:24
LM828 Switched Capacitor Voltage Converter
电子发烧友网为你提供TI(ti)LM828相关产品参数、数据手册,更有LM828的引脚图、接线图、封装手册、中文资料、英文资料,LM828真值表,LM828管脚等资料,希望可以帮助到广大的电子工程师们。
2018-10-16 16:31:48
MAX660 Switched Capacitor Voltage Converter
电子发烧友网为你提供TI(ti)MAX660相关产品参数、数据手册,更有MAX660的引脚图、接线图、封装手册、中文资料、英文资料,MAX660真值表,MAX660管脚等资料,希望可以帮助到广大的电子工程师们。
2018-10-16 16:31:48
谐振型开关电容变换器的工作原理和参数设计方法
开关电容变换器(Switched Capacitor Convert-er)仅由电容器和开关管来实现电压的变换。由于不含电感和变压器,因此可以大大缩小开关电源的体积和重量,并且易于在芯片中实现集成。
2020-07-28 10:53:486454
LTC7820 Demo Circuit - High Efficiency, High Density, Switched Capacitor Voltage Divider (6-72V to 0.5*Vin @ 480W)
2021-02-03 10:23:101
LTC7820 Demo Circuit - High Efficiency, High Density, Switched Capacitor Voltage Doubler (6-36V to 2*Vin @ 170W)
2021-02-03 10:25:113
LT3468 Demo Circuit - Strobe Capacitor Charger (2.5-8V to 320V)
2021-02-20 13:55:268
LT3420 Demo Circuit - High Charge Rate Strobe Capacitor Charger (2.5-6V to 320V)
2021-02-20 13:57:266
LT3468: Photoflash Capacitor Chargers in ThinSOT<sup>™</sup> 数据手册
LT3468: Photoflash Capacitor Chargers in ThinSOT™ 数据手册
2021-03-20 10:38:4611
Super capacitor超级电容能当成电池用吗?
2023-12-18 10:55:47269
Farad capacitor法拉电容优点及缺点
Farad capacitor 法拉电容又称Electrical Double-Layer Capacitor双电层电容器、Gold capacitor黄金电容、Super capacitor 超级
2024-01-11 12:01:31136
已全部加载完成
