Using the MAX4196 instrumentation amplifier (IA) as a pre-amplification circuit, adds a factor of 10V/V gain to the signal path enabling low output strain gauge sensors to be temperature compensated and calibrated. Complete circuits for high-gain amplification and temperature compensation of such sensors will be presented and discussed.
Pressure sensors and force sensors that use thin-film or thick-film (TF) strain gauge technology typically require signal amplification of several hundred volts per volt. The sensor signal must be compensated for changes in offset and span due to temperature changes.
The MAX1452 Precision Sensor Signal Conditioner provides all of the functions required for sensor bridge excitation (offset and span temperature compensation, and output offset adjustment with 16-bit trim resolutions). However, the MAX1452 design was optimized for piezo-resistive transducers (PRT), silicon micro-machined devices which typically require low signal gain due to their high bridge sensitivity.
The MAX1452 has a selectable gain range of 39-234V/V. PRT sensors can have full-scale (FS) output signal levels of 20-40 mV/V¹ and thus require a gain in the range of 42-83V/V when using 3V of bridge excitation voltage to produce an output voltage swing of 5V. TF sensors typically have much lower bridge sensitivity levels of 1.5 to 2.5 mV/V and thus require gains of 360-830V/V with a bridge excitation voltage of 4V to produce a 5V output swing.
Using the MAX4196 instrumentation amplifier (IA) as a pre-amplification circuit adds a factor of 10V/V gain to the signal path enabling TF sensor calibration and temperature compensation with the MAX1452. A complete circuit for amplifying and temperature compensating a TF sensor using this architecture is shown in Figure 1.
Figure 1. The MAX4196 IA amplifies the sensor signal by a fixed gain of 10.
The MAX4196 was chosen² for its internally set fixed gain of 10 and requires no external components other than a bypass capacitor on the power supply. The op-amp in the MAX1452 is used to set an arbitrary mid-rail voltage of 2.5V to provide a reference signal to the MAX4196 REF input and to the MAX1452 INM input. The differential sensor signal is converted to a single-ended signal at the MAX4196 OUT pin with respect to the REF pin. The MAX1452 differential input is driven by this single-ended signal into the INP pin with respect to the INM input.
This provides a bipolar signal swing of the sensor signal about a zero-point set by the op-amp and resistor divider formed by the 47KΩ resistors. For sensors that have a positive offset at no-load and only swing in the positive output direction (such as typically found in weight sensor applications), the op-amp and resistor circuit can be eliminated by tying the MAX4196 REF and the MAX1452 INM pins directly to VSS. This is shown in Figure 2.
Figure 2. Unidirectional sensor connections.
The MAX1452 provides the bridge excitation for the sensor bridge. The excitation source is limited to 2mA in drive current capability when configured as a current source for PRT devices, but can deliver as much as 4mA of current when wired as a voltage excitation source (Pins BDR and ISRC connected together) and even higher currents with additional circuitry. With this current drive capability, TF sensors with bridge resistances as low as 1200Ω can be driven with excitation voltages of 4.5V. Since TF sensors typically have a very low temperature coefficient of resistance (TCR) and temperature coefficient of sensitivity (TCS) of the bridge, the excitation voltage does not require much compensation adjustment range and thus can be set to a value near the upper supply rail (typically VBDR = 4.5V). The higher the excitation voltage, the lower the required signal gains.
There are 16 gain settings for the MAX1452 that range from 39 to 234 in increments of 13. This range is expanded to 390 to 2340³ in increments of 130. The calibrated gain of the overall circuit is also a function of the bridge excitation voltage, VBDR, as shown in the following equation:
VOUT = BridgeOutput(mV/V) × VBDR(V) × GMAX4196(V/V) × GMAX1452(V/V)
In order to have a continuous gain selection range, it is important that the fixed gain steps of the circuit overlap when using reasonable excitation voltages. A reasonable range of excitation voltages for TF sensors is 3.0-4.5V. The lower limit of 3.0V is imposed by consideration of system noise and the upper limit of 4.5V is imposed by the bridge excitation source requiring VBDR to be 0.5V below VDD for compliance or headroom for circuit operation. The overlapping gain selection ranges is shown graphically in Figure 3.
Figure 3. The overall selectable gain ranges provide overlap with various sensor outputs.
Since the MAX1452 modulates the bridge excitation voltage as a means to adjust the overall gain for compensation of span over temperature, it is important to look at this effect on the MAX4196 pre-amplifier. Typical TF sensors have very good TCS performance and may vary by only a few percent over a 100°C temperature range. This requires that the bridge excitation be varied by only a few percent, typically only Δ150mV, over the same temperature range in order to compensate the effect. This small change in VBDR will produce a small change in the common mode output voltage into the MAX4196. The MAX4196 provides a common-mode rejection of 88dB minimum over the operating range of -40°C to 85°C. At an overall system gain of 910V/V (worst-case calculations is at high gains) this translates into an output error signal of 0.1%.
An additional bonus of this increased gain architecture over those circuits that use a gain stage on the output of the MAX1452 is a significant improvement in noise performance. The MAX1452 programmable gain amplifier (PGA) is a switched capacitor architecture that generates a small, but significant, output noise. This noise level scales (non-linearly) with the PGA gain setting. Higher PGA gain settings produce a higher output noise. Placing the additional gain circuitry at the input to the MAX1452, and using the lower PGA gain settings can realize a high signal gain system.
Notes
¹Sensors wired in the Wheatstone bridge configuration are typically rated in millivolts of differential output signal per volt of bridge excitation voltage applied at the rated full-scale load of the sensor. Hence, a sensor rated at 2mV/V output at full-scale load will produce 8mV of differential output voltage when excited with 4V and full-scale load applied.
²The MAX4194 IA could be used equally well and provides a user-settable gain with the addition of an external gain setting resistor.
³Gains in excess of 1000 become dominated by system noise and are not suitable for general applications.
High-Gain Signal Conditioning
Abstract: Sensors that use thin-film or thick-film strain gauge technology typically require high-gain signal conditioning. For typical applications where signal gain of less than 250V/V is sufficient, any of the high precision signal conditioners, MAX1452, MAX1455, MAX1457, and MAX1463 ASICs can be used without any external amplification of the signal. For applications where high-gain compensation (larger than 250V/V) is required, external amplification circuit must me added.
- High-Gain(6806)
5962-9457203MPA 产品描述
Input Signal Conditioning (AD9042 Core ADC)封装68 ld CLCCAD10242TZ产品描述Dual Channel, 12-Bit, 40 MSPS MCM A
2019-09-07 07:49:02
8通道模拟前端SONAR接收路径子系统参考设计
the integrated analog front end (AFE) AFE5809. The AFE5809 features 8 channels of analog signal conditioning
2018-11-08 14:21:49
A 1.9 GHz Low Noise Amplifier optimised for high IP3 using BFP540
noiseapplications. Applying Infineon’s BFP540, lownoise, high gain, high linearity at low powerconsumption
2009-05-12 13:30:36
AMPLIFIERS FOR SIGNAL CONDITIONING
layout.AMPLIFIERS FOR SIGNAL CONDITIONING1. I.put Offset Voltage <100μV2. I.put Offset Voltage Drift
2009-11-19 17:16:37
Car radio multimedia signal processor
adjust gain-stages■ Independent soft-mute and direct-muteOutputs■ Three independent signal paths■ Six
2012-12-12 14:55:28
HIP5061 HIGH EFFICIENCY, HIGH PERFORMANCE,HIGH POWER CONVERTER
IntroductionAs the complexity of sophisticated, modern day equipmentgrows, the need for high
2009-05-12 11:13:19
HMC1087F10的中英文资料
dB· High Output IP3: +43.5 dBm· Small Signal Gain: 11 dB· Supply Voltage: +28V @ 850 mA· 50 Ohm Matched Input/Output· 10-Lead Flange Package
2018-08-06 07:55:21
HMC8415LP6GE 原厂新产品
· High output power: 46 dBm typical at PIN = 23 dBm· High small signal gain: 32.5 dB typical· High
2018-12-19 09:35:04
Jitter, Noise, and Signal Integrity at High-Speed
Jitter, Noise, and Signal Integrity at High-Speed-Mike PengLi
2015-10-26 15:03:11
VPS_VIP_POLARITY_HIGH 是什么意思?
VPS_VIP_POLARITY_HIGH,是上升沿有的意思吗?还是高电平时有效?
struct Vps_VipDiscreteConfig [ /* Post count value when
2018-05-31 07:20:22
【AMD社招】Signal Validation Engineer
and effectively to meet time requirements.o Familiar with display interface high speed signal
2017-03-13 16:30:55
使用磁通门传感器并用于电流和电压测量的4通道信号调理解决方案包含BOM,PCB文件及光绘文件
描述This design provides a 4-channel signal conditioning solution for differential ADCs integrated
2018-08-10 07:02:58
前端口USB Type-C扩展器设计包括BOM及层图
connectors and provides signal conditioning to both High-Speed and SuperSpeed signals to the remotely
2018-09-04 09:01:37
天线资料全书(上/下部)
increases. On the other hand, even today high gain antennas rely on large reflectors (dish antennas
2009-12-14 10:11:54
带有DSP和存储器的E1438C/D 100 MSa/s数字转换器
Along with -90 dBfs spurious free dynamic range and 100 MSa/s digitizing, they feature full input signal conditioning, tunable digital filtering.
2019-09-09 09:44:44
电子加热阀测试(AN 1270-4)
Production testing of heater/air conditioning system valves is performed on high speed HP automatic
2019-01-25 12:30:07
符合仪表规范的高品质因数(Q因子)有源差分带通滤波器
) module testing. This filter may also be used to design a signal conditioning circuit in a DAQ(...)主要
2018-12-06 11:47:22
高速时的抖动,噪声和信号完整性Jitter, Noise, and Signal Integrity at High-Speed
and much-increased high-frequencycontents associated with the higher data rate. The signal integrity (SI) due
2019-02-15 11:53:51
MAX2659 pdf
The MAX2659 high-gain, low-noise amplifier (LNA) isdesigned for GPS, Galileo, and GLONASS
2008-06-30 12:44:02
101
![](https://skin.elecfans.com/images/2021-soft/load.png)
LM358A pdf datasheet(双路运算放大器芯片
These devices consist of two independent, high-gain, frequency-compensated operational amplifiers
2008-07-31 23:02:19
135
BUF634 pdf datasheet(high speed unity-gain open-loop buffer)
The BUF634 is a high speed unity-gain open-loopbuffer recommended for a wide range
2008-08-06 13:10:51
44
OPA633 pdf datasheet (High Spe
The OPA633 is a monolithic unity-gain buffer amplifierfeaturing very wide bandwidth and high slew
2008-08-06 13:20:15
13
INA146 pdf datasheet (High-Vol
differentialvoltages and reject high common-mode voltages forcompatibility with common signal processing voltagelevels. High-voltag
2008-10-14 15:26:00
15
CA741, CA741C, CA1458, CA1558,
Applications
The CA1458, CA1558 (dual types); CA741C, CA741 (singletypes); high-gain o
2008-12-21 19:22:39
30
CA124, CA224, CA324, LM324, LM
, CA224, CA324, LM324, and LM2902 consist offour independent, high-gain operational amplifiers on asingle mono
2008-12-21 20:00:50
34
HFA-0005 pdf datasheet (High S
The HFA-0005 is an all bipolar op amp featuring high slewrate (420V/μs), and high unity gain
2009-01-07 14:54:33
13
MAX9922, MAX9923 pdf datashee
voltage (VOS) of 25µV (max) and laser-trimmed gain accuracy better than 0.5%. The combination of low VOS and high-gain accuracy allows p
2009-03-31 11:00:33
19
High-Speed Differential Signal
High-Speed Differential Signaling in Cyclone Devices
From high-speed backplane applications
2009-05-14 10:42:23
21
CA3094系列可编程电源开关 放大器的应用实例
The CA3094 unique monolithic programmable powerswitch/amplifier IC consists of a high-gain
2009-06-02 10:53:56
19
MAX3806,pdf datasheet (用于光测距系统
The MAX3806 is a high-gain linear preamplifier for distance measurement applications using a laser
2009-07-18 17:54:19
40
AD8276/AD8277,pdf datasheet (U
signal conditioning in power critical applications that require both high performance and low power. They provide exceptional common-mode reject
2009-08-23 13:32:33
26
AD22103,pdf datasheet (Voltage
The AD22103 is a monolithic temperature sensor with on-chip signal conditioning. It can be operated
2009-08-23 13:57:06
9
AD8211,pdf,datasheet (high vol
The AD8211 is a high voltage, precision current shunt amplifier. It features a set gain of 20
2009-08-25 15:28:23
23
AD8279,pdf datasheet (Low Cost
conditioning in powercritical applications that require both high performance and lowpower. The AD8279 provides exceptional common-mo
2009-08-26 09:51:11
46
AD8375,pdf datasheet (Ultralow
gain control, high IP3, and low noise figure. The excellent distortion performance and high signal bandwidth make the AD8375 an excellent g
2009-08-26 16:44:43
26
AD8376,pdf datasheet (Ultralow
that provides precise gain control, high IP3, and low noise figure. The excellent distortion perform-ance and high signal bandwidth make the AD8376
2009-08-26 16:53:57
17
AD825,pdf datasheet (High Spee
, making it ideally suited for a broad range of signal conditioning and data acquisition applications. The ac performance, gain, bandwidth,
2009-09-02 08:52:04
13
A New High Gain Low Voltage 1.
A New High Gain Low Voltage 1.45GHz CMOS Mixer:Abstract—A new architecture of CMOS downconversion
2009-09-08 20:41:48
9
AD10465,pdf datasheet (Signal
The AD10465 is a full channel ADC solution with on-module signal conditioning for improved dynamic
2009-09-09 09:19:08
9
AD7712,pdf datasheet (Signal Conditioning ADC)
has two analog input
channels and accepts either low level signals directly from a transducer
or high level (±4
2009-09-10 15:27:07
54
upc3403,pdf datasheet (high pe
The upc3403 is monolithic quad operational amplifier consists of four indeperndent high-gain
2009-09-28 12:08:05
30
High Linearity Components Simp
receiver takes a high frequencyinput signal, often in the 800MHz to 3GHz frequency range,and utilizes one mixer/demodulator stage to co
2009-09-30 19:57:13
17
High-Speed Audio Ripping,Encod
consumers enjoy entertainmentcontent will be getting a makeover in theyears to come as high-speed audio encodingdigital signal proce
2009-09-30 20:00:03
28
LM6171,pdf datasheet (High Spe
The LM6171 is a high speed unity-gain stable voltage feedbackamplifier. It offers a high slew rate
2009-10-07 09:53:14
41
DS40MB200,pdf datasheet (Empha
The DS40MB200 is a dual signal conditioning 2:1 multiplexerand 1:2 fan-out buffer designed for use
2009-10-12 15:30:28
13
DS25MB100,pdf datasheet (2.5 G
The DS25MB100 is a signal conditioning 2:1 multiplexer and1:2 fan-out buffer designed for use
2009-10-12 15:33:51
13
DS25MB200,pdf datasheet (Dual
The DS25MB200 is a dual signal conditioning 2:1 multiplexerand 1:2 fan-out buffer designed for use
2009-10-12 15:35:29
11
DS42MB100,pdf datasheet (4.25
The DS42MB100 is a signal conditioning 2:1 multiplexer and1:2 fan-out buffer designed for use
2009-10-12 15:39:03
12
DS42MB200,pdf datasheet (Dual
The DS42MB200 is a dual signal conditioning 2:1 multiplexerand 1:2 fan-out buffer designed for use
2009-10-12 15:41:14
16
CCD Signal Processor for Digit
The VSP2270 device is a complete mixed-signal processing IC for digital cameras providing signal
2010-06-11 11:49:11
39
VSP2272,pdf(CCD Signal Process
The VSP2272 device is a complete mixed-signal processing IC for digital cameras providing signal
2010-06-11 11:50:55
19
Small-signal modelling of self
onswitch-mode audio power amplifiers. The assignment targets modelling the small signal gain ofthe only intended nonlinear component in co
2010-06-12 09:04:59
13
SN65LVCP418,pdf(8-Channel Gigi
The SN65LVCP418 is an 8 Channel signal conditioning buffer in a flow-through pin-out allowing
2010-08-28 18:06:03
13
ONET8531T,pdf(11.3Gbps Limitin
The ONET8531T is a high-speed and high-gain limiting-transimpedance amplifier, used in optical
2010-08-28 21:43:01
15
TLK1002A,pdf(Dual Signal Condi
TLK1002A is a single-chip dual signal conditioning transceiver.
This chip supports data rates from
2010-09-09 20:40:47
7
OPA4820,pdf(Quad, Unity-Gain,
input noise voltage and high output current using a low 5.7mA/ch supply current. At unity-gain, the OPA4820 gives > 600MHz bandwidth with
2010-09-11 20:34:13
25
THS4631,pdf(High-Voltage High
wideband operation, high-input impedance, and high-power supply voltages. By providing a 210-MHz gain bandwidth product, ±15-V supply oper
2010-09-11 22:06:28
31
OPA2832,pdf(dual, low-power, high-speed, fixed-gain amplifier)
The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single
2010-09-12 23:31:16
11
OPA2614,pdf(Dual, High Gain Ba
The OPA2614 offers very low 1.8nVHz input noise in a wideband, high gain bandwidth
2010-09-12 23:43:43
14
LM124,LM124A,LM224,LM224A,LM32
These devices consist of four independent high-gain frequency-compensated operational amplifiers
2010-09-17 02:29:35
29
LM158,LM158A,LM258,LM258A,LM35
2010-09-17 02:37:34
45
LM2900,LM3900,pdf(Quadruple Op
These devices consist of four independent, high-gain frequency-compensated Norton operational
2010-09-17 02:40:37
16
LM2902-Q1,pdf(Quadruple Operat
This device consists of four independent high-gain frequency-compensated operational amplifiers
2010-09-17 02:43:20
17
LM2904-Q1,pdf(Dual Operational
This device consists of two independent, high-gain, frequency-compensated operational amplifiers
2010-09-17 02:46:47
24
RC4559,pdf(Dual High-Performan
The RC4559 is a dual high-performance operational amplifier. The high common-mode input voltage
2010-09-17 04:47:23
11
TL4581,pdf(DUAL LOW-NOISE HIGH
, such as improving tone control. It offers low noise, high-gain bandwidth, good slew, and high output current drive for driving capacitiv
2010-09-18 19:55:08
14
TL5580,TL5580A,pdf(DUAL LOW-NOISE WIDE-BANDWIDTH PRECISION A
with its low offset voltage, high-gain bandwidth, low harmonic distortion, and low-noise characteristics. In addition, its output is capabl
2010-09-18 19:57:37
13
PGA870,pdf(High-Speed, Fully D
The PGA870 is a wideband programmable-gain amplifier (PGA) for high-speed signal chain and data
2010-09-18 23:49:13
27
INA154,pdf(High-Speed, Precisi
The INA154 is a high slew rate, unity-gain differenceamplifier consisting of a precision op amp
2010-09-24 21:49:22
5
INA159-EP,pdf(Precision, Gain
The INA159 is a high slew rate, G = 1/5 differenceamplifier consisting of a precision op amp
2010-09-24 21:57:44
6
TL026,pdf(Differential High-Fr
and outputs.
Internal feedback provides wide bandwidth, low phase distortion, and excellent gain stability. Variable gain based on signal summa
2010-09-27 20:30:11
13
VCA810,pdf(High Gain Adjust Ra
It provides a differential input to single-ended output conversion with a high-impedance gain control input used to vary the gain over a –
2010-09-27 20:51:43
68
ADL5201,pdf (31.5 dB Range, 0.
precise gain control, high IP3 and low noise figure. The excellent distortion performance and high signal bandwidt
2010-10-09 10:28:20
42
ADL5202,pdf (31.5 dB Range, 0.
2010-10-09 10:29:49
26
Precision Instrumentation Ampl
Precision Instrumentation Amplifiers with Rejustors Solve High-Gain Applications
Abstract:
2008-12-20 15:01:48
1021
![](https://skin.elecfans.com/images/2021-soft/eye.png)
![](https://file1.elecfans.com//web2/M00/A4/81/wKgZomUMNH6AP8ubAAAqV5cyggA124.jpg)
INL/DNL Measurements for High-
for high-speed, high dynamic performance data converters, they gain significance when it comes to high-resolution imaging applications. The
2009-04-16 15:53:38
1891
![](https://file1.elecfans.com//web2/M00/A4/C3/wKgZomUMNZWAX-P0AAAuBc3bp_c403.gif)
AC耦合放大器无需直流偏置-AC-Coupled Ampli
Abstract: Unity gain op amp buffers capacitive transducer and other high-impedance signal sources
2009-05-07 09:44:11
1774
![](https://file1.elecfans.com//web2/M00/A4/DB/wKgZomUMNfqAAyFHAAASi8WHmrA254.gif)
高增益的信号调理电路的薄膜和厚膜传感器-High-Gain
2009-05-07 10:32:27
791
![](https://file1.elecfans.com//web2/M00/A4/DB/wKgZomUMNfuANgZ1AAAYVu3W4Qg928.gif)
Methods for Calibrating Gain E
Methods for Calibrating Gain Error in Data-Converter Systems
Abstract: All data-converter systems
2009-09-27 10:55:57
1233
![](https://file1.elecfans.com//web2/M00/A5/48/wKgZomUMN7iAXwkEAAAC15dwoh8824.gif)
MAX2657, MAX2658 美信电子推出的GPS/GN
MAX2657, MAX2658 美信电子推出的GPS/GNSS低噪声放大器
状态
The MAX2657/MAX2658 high-gain, low-noise amplifiers (LNAs) are designed for GPS
2009-10-16 10:08:14
880
![](https://file1.elecfans.com//web2/M00/A5/51/wKgZomUMN-CAQIcIAAAx0WvxR3w881.gif)
Programmable-Gain Amplifier, U
Programmable-Gain Amplifier, Using the MAX532 DAC
Abstract: This application note discusses how to use the MAX532 to build a programmable gain amplifie
2010-03-05 08:53:52
2074
![](https://file1.elecfans.com//web2/M00/A5/7D/wKgZomUMOKuAeICUAAABVjDruoE725.gif)
Resistor network sets gain for
By adding an external resistor network you can lower the gain of a fixed-gain differential
2010-07-18 15:34:44
1061
![](https://file1.elecfans.com//web2/M00/A5/A6/wKgZomUMOWiAbi3JAAAFeac1Zd8125.gif)
Signal conditioning for a sigm
This application note will help the designer of a high-performance, multichannel data acquisition
2010-07-18 15:37:13
1124
![](https://file1.elecfans.com//web2/M00/A5/A6/wKgZomUMOWiAFQS_AABJxcxizgI730.gif)
Dual Sigma-Delta ADCwith Auxiliary DAC AD7729
This monolithic 3 V CMOS device is a low power, two-channel, input port with signal conditioning
2017-09-30 15:35:27
11
基于TQC9074 下的 High Linearity Variable Gain Amplifier
The TQC9074 is a high dynamic range analog controlled variable gain amplifier (VGA) which operates from 0.7 to 2.8 GHz.
2018-08-03 11:29:00
3
基于TQC9312下的3.3 – 3.8 GHz ½ W Digital Variable Gain Amplifier
The TQC9312 is a digital variable gain amplifier (DVGA) featuring high linearity over the entire gain control range.
2018-08-03 11:29:00
4
基于TQM879008下的1.5-2.7 GHz ½ W Digital Variable Gain Amplifier
The TQM879008 is a digital variable gain amplifier (DVGA) featuring high linearity over the entire gain control range.
2018-08-03 11:29:00
6
基于TQM879026下的0.7-4 GHz ¼W Digital Variable Gain Amplifier Datasheet
The TQM879026 is a digital variable gain amplifier (DVGA) featuring high linearity and digital variable gain control in 0.5 dB step sizes.
2018-08-03 11:29:00
1
基于TQM879028下的0.7−4.0 GHz ½ W Digital Variable Gain Amplifier
The TQM879028 is a digital variable gain amplifier (DVGA) featuring high linearity over the entire gain control range.
2018-08-03 11:29:00
4
高频信号发生器电路,High frequency signal generator
关键字:高频信号发生电路图
一个抽头线圈科尔皮兹振荡器
2018-09-20 18:28:10
1956
NE5532音量控制电路,Gain and Volume Adjustment for Balance Input
noise voltage of 8 nV, common mode rejection ratio, 9 V/us slew rate, high DC voltage gain
2018-09-20 19:03:44
1183
AD8353:1 MHz到2.7 GHz Gain Gain Capital数据Sheet
2021-04-14 15:56:46
9
AD8354:1 MHz对2.7 GHz Gain Gain Capital数据Sheet
2021-04-18 16:42:50
5
