电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Dual Voltage Tracking Circuit
收藏
查看更多
Calibration Circuit Idea Pictorial
variety of digital calibration parts enables quick automated testing and adjustment.Calibration Circuit
2011-06-13 00:15:17
TI bq25570超低功耗能量收集解决方案
sampling network to optimize the transfer of power into the device. The fraction of open circuit voltage
2015-04-23 11:31:24
可实现直接反馈调节得路由器降压/升压电荷泵含BOM和设计方法
描述This circuit creates dual-inverting outputs from a 3.3V input, while being very compact.
2018-11-02 17:11:49
用于路由器的降压-升压电荷泵 (-24V (0.04A))
描述及特性This circuit creates dual-inverting outputs from a 3.3V input, while being very compact.
2015-04-24 11:37:44
用于路由器的降压-升压电荷泵 (-48V (0.03A))
2015-04-24 11:52:12
用于音频功率放大器的包络跟踪电源设计包括BOM及层图
描述This reference design delivers an envelope-tracking power supply circuit for audio power
2018-08-30 09:31:54
请问STM32 flash dual bank擦除失败怎么解决?
429 FLASH 为1M, 我想配置为dual bank, 每块512M.设置DB1M成功。现在想擦除dual bank 15 sector, 即#define
2018-09-19 09:24:23
高通Vuforia SDK 2.8的Extended Tracking功能
高通Vuforia SDK 2.8已经正式推出了,此次SDK更新的亮点:增加Extended Tracking功能,即使目标离开视野仍能继续进行图像识别。使用Java API使开发更简单。采用基于云
2018-09-20 10:13:28
FXM2IC102 pdf datasheet (Dual
The FXM2IC102 is a configurable dual-voltage-supplytranslator designed for bi-directional voltage
2008-09-02 08:55:2317
LM4558 pdf datasheet (DUAL OPE
The LM4558 devices is a monolithic integrated circuit designed for dual operational amplifier.The
2008-12-11 15:41:5973
LM393 DUAL VOLTAGE COMPARATOR
The LM393 series consists of two independent precision voltage comparators with an offset voltage
2008-12-12 00:31:1743
X55060 pdf datasheet (Dual Vol
This device combines power-on reset control, batteryswitch circuit, watchdog timer, supply voltage
2009-01-11 09:59:3517
l298电机芯片驱动原理 (DUAL FULL-BRIDGE
It is a high voltage, high current dual full-bridge driver designedtoacceptstandardTTLlogic levels anddriveinductive loads such as relays,
2009-05-29 08:22:40161
1.6W Dual Output Flyback Conve
describing a universal input dual outputFlyback converter providing an isolated and non-isolated output voltage for a motorapplicatio
2009-06-28 22:38:4017
OP220,pdf datasheet (Operation
supply operation. The low offsetvoltage and input offset voltage tracking as low as 1.0 mV/∞C,make this the first micropower precis
2009-08-31 08:55:4416
AD9248,pdf datasheet (Dual AD
). It features dual high performance sample-and hold amplifiers (SHAs) and an integrated voltage reference. The AD9248 uses a multistage differentia
2009-09-09 09:07:329
GC5325 Envelope Tracking
Solutiondevice operating in conjunction with a Nujira High Accuracy Tracking (HAT) Voltage Modulator in anEnvelope Tracking and D
2010-07-08 17:40:5113
SN75372,pdf(Dual MOSFET Driver
The SN75372 is a dual NAND gate interface circuit designed to drive power MOSFETs from TTL inputs.
2010-08-30 10:53:2629
UA7908,pdf(NEGATIVE-VOLTAGE RE
This series of fixed-negative-voltage integrated-circuit voltage regulators is designed
2010-10-23 00:12:227
UA7905,pdf(NEGATIVE-VOLTAGE RE
2010-10-23 00:14:2635
UA78L15A,pdf(POSITIVE-VOLTAGE
This series of fixed-voltage integrated-circuit voltage regulators is designed for a wide range
2010-10-23 22:07:0318
UA78L12A,pdf(POSITIVE-VOLTAGE
2010-10-23 22:09:1921
UA78L08A,pdf(POSITIVE-VOLTAGE
2010-10-23 22:21:4015
UA78L08,pdf(POSITIVE-VOLTAGE R
2010-10-23 22:24:077
UA78L05,pdf(POSITIVE-VOLTAGE R
2010-10-23 22:38:3516
UA78L02A,pdf(POSITIVE-VOLTAGE
2010-10-23 22:41:084
UA7824,pdf(POSITIVE-VOLTAGE RE
2010-10-23 22:44:087
UA7810,pdf(POSITIVE-VOLTAGE RE
2010-10-23 22:53:2310
UA7808,pdf(POSITIVE-VOLTAGE RE
2010-10-23 22:55:549
UA723pdf(Precision Voltage regulator)
The uA723 is a precision integrated-circuit voltage regulator featuring high ripple rejection
2010-10-23 23:00:0932
MC79L15A,pdf(POSITIVE-VOLTAGE
This series of fixed negative-voltage integrated-circuit voltage regulators is designed for a wide
2010-10-23 23:16:3111
MC79L05A,pdf(NEGATIVE-VOLTAGE
2010-10-23 23:24:4614
TPS65193,pdf(Dual High-Voltage
The TPS65193 is dual high-voltage scan driver to drive an amorphous-silicon-gate (ASG) circuit
2010-11-03 22:49:487
BQ24351,pdf(OVER-VOLTAGE AND O
failures of the charging circuit. The IC continuously monitors the input voltage and the battery voltage. In case of an input over-voltag
2010-11-10 14:34:4512
BQ24308,pdf(OVER-VOLTAGE AND O
failures of the charging circuit. The IC continuously monitors the input voltage, the input current and the battery voltage. In case of a
2010-11-10 14:49:0024
双结型场效应管混频器电路图(Dual JFET mixer
双结型场效应管混频器射频电路(Dual JFET mixer RF circuit
2008-11-22 00:13:471131
Dual, Voltage-Output DAC Consu
Dual, Voltage-Output DAC Consumes Miniscule Power The dual, voltage-output DACs shown
2008-11-24 10:19:58882
Dual Comparator Forms Temperat
Dual Comparator Forms Temperature-Compensated Proximity Detector Abstract: Simple comparator
2008-11-24 10:42:241358
复位电路确保有效的电源电压-Reset Circuit En
Abstract: This article focuses on using an external MOSFET switch to ensure a valid system voltage
2009-04-23 09:20:401723
Abstract: This note describes a dual tracking controller for a single I/O voltage and two core
2009-04-23 17:44:281174
Reset Circuit Ensures Valid Su
2009-05-04 09:35:331090
双电压输出数模转换器耗用小功率-Dual, Voltage-
The dual, voltage-output DACs shown in the figure below employ a combination of power-conserving
2009-05-08 09:30:18598
自动跟踪对称电源:Tracking Regulated Po
自动跟踪对称电源:Tracking Regulated Power Supply A tracking regulated power supply is shown in Figure 29. This supply is very suitable f
2009-05-16 16:40:302552
Sequencing Circuit Provides Ps
Sequencing Circuit Provides Pseudo Voltage Tracker Abstract: This application note presents three
2009-08-31 17:47:321175
FM跟踪发射器FM Tracking Transmitter
FM跟踪发射器FM Tracking Transmitter Kit (small) This kit is the small version of the FM 108 MHz
2009-12-22 10:14:062373
In-circuit programming switch
A simple bidirectional analog switch (MAX4525) facilitates in-circuit programming by providing dual
2010-08-07 21:46:351205
Automotive protection circuit
This circuit maintains power to the load regardless of momentary shorts or opens in the supply
2011-01-02 13:40:141390
MAX14811,pdf datasheet (Dual, Unipolar/Bipolar, High-Voltage
The MAX14811 integrated circuit generates high-voltage, high-frequency unipolar or bipolar pulses
2011-02-06 10:36:4681
低压断路器概览 (Overview of low voltage circuit breakers)
低压断路器概览-Overview of low voltage circuit breakers 技术资料-Technical data 适合所有应用的领域。
2011-02-27 21:03:2750
绘图案例【Circuit Simulation】Voltage
绘图案例【Circuit Simulation】Voltage Controlled Oscillator
2016-02-16 11:24:260
PCB绘图案例【Circuit Simulation】Dual_Polarity_Power_Supply
PCB绘图案例【Circuit Simulation】. Dual Polarity Power Supply
2016-02-16 11:54:450
PCB绘图案例【Circuit Simulation】Frequency_To_Voltage_Converter
PCB绘图案例【Circuit Simulation】. Frequency To Voltage Converter
2016-02-16 11:55:480
电压刻度延伸电路,a circuit to extend Voltage calibration
电压刻度延伸电路,a circuit to extend Voltage calibration 关键字:电压量程扩展电路
2018-09-20 18:31:19636
UG-1932: Evaluating the ADuM4146 Single-/Dual-Supply, High Voltage, Isolated SiC Gate Driver with Miller Clamp
2021-01-27 22:26:258
ADuM4146: Single-/Dual-Supply, High Voltage, Isolated SiC Gate Driver with Miller Clamp Data Sheet
2021-01-27 22:28:2510
LTC7138/LT8330 Demo Circuit - Wide Input Voltage Range, Buck or Boost Bias Voltage Power Supply (5-140V to 12.5V @ 100mA)
2021-01-29 10:57:151
LTC3115-1 Demo Circuit - Wide Input Voltage, High Efficiency, Low Noise 5V Regulator (2.7-40V to 5V @ 2A)
2021-01-31 13:33:220
LTC6115 Demo Circuit - Current and Voltage Sensor Monitor Circuit for 16-Bit ∆Σ ADC
2021-02-01 14:52:2810
LT3070-1 Demo Circuit - Low Voltage, UltraFast™ Transient Response Linear Regulator (1.2V to .9V @ 5A)
2021-02-01 16:00:345
LTC7820 Demo Circuit - High Efficiency, High Density, Switched Capacitor Voltage Divider (6-72V to 0.5*Vin @ 480W)
2021-02-03 10:23:101
LTC7820 Demo Circuit - High Efficiency, High Density, Switched Capacitor Voltage Doubler (6-36V to 2*Vin @ 170W)
2021-02-03 10:25:113
LTC2063 Demo Circuit - Low Power Battery Voltage Measurement Amplifier
2021-02-03 11:51:161
LTC2966 Dual Voltage Monitor Design Tool
2021-02-04 08:11:034
LTM4622A Demo Circuit - Dual Step-Down µModule Regulator (4-20V to 5V @ 2A & 3.3V @ 2A)
2021-02-04 08:49:0511
LTC3649 Demo Circuit - High Voltage Synchronous Buck Regulator with Output Voltage Control (10-60V to 5V @ 4A)
2021-02-04 09:01:063
LTC6258 Demo Circuit - Lower Power LED Driver with Voltage Command
2021-02-05 10:37:142
LTC3810-5 Demo Circuit - High Efficiency High Voltage Buck Converter (12-60V to 5V @ 6A)
2021-02-19 10:41:133
LT8609S Demo Circuit - 2MHz Low EMI High Voltage Synchronous Buck Regulator (5.5-42V to 5V @ 2A)
2021-02-19 12:08:1810
LTC7860 Demo Circuit - High Voltage, High Efficiency Switching Surge Stopper with Timer (7-100V to 34Vmax @ 10A)
2021-02-19 13:54:251
LTC3895 Demo Circuit - High Efficiency High Voltage Buck Converter (14-130V to 12V @ 5.0A)
2021-02-19 14:33:270
LT8609B Demo Circuit - 2MHz Low EMI High Voltage Synchronous Buck Regulator (5.5-42V to 5V @ 2A)
2021-02-20 13:48:258
LTM4642 Demo Circuit - Wide Input Voltage, High Efficiency, Dual Buck Regulator (4.5-20V to 1.8V @ 4A, 1.2V @ 4A)
2021-02-21 12:50:210
LT8608 Demo Circuit - 2MHz Low EMI High Voltage Synchronous Buck Regulator (5.5-42V to 5V @ 1.5A)
2021-02-21 13:11:2210
LTM4650 Demo Circuit - High Efficiency Dual 25A Step-Down Regulator with Output Tracking (4.5-15V to 1.5 V @ 25A & 1V @ 25A)
2021-02-21 15:03:291
2021-02-21 15:20:290
LTC3860 Project - Dual, 2-Phase Step-Down Voltage Mode Supply (6-14V to 1.5V @ 50A)
2021-02-22 12:58:241
2021-03-06 11:49:420
2021-03-07 10:11:331
2021-03-09 08:25:550
2021-03-09 08:35:550
LTC3810-5 Demo Circuit - High Efficiency High Voltage Step-Down Converter (13-60V to 12V @ 6A)
2021-03-09 13:39:170
LTC3810 Demo Circuit - 36V to 72V Input Voltage to 12V @ 10A Buck Regulator
2021-03-09 13:41:177
LTC3649 Demo Circuit - High Voltage Monolithic Synchronous Buck Regulator with Output Voltage Control (10-60V to 2.5-7.5V @ 4A)
2021-03-09 14:28:202
LT6015 Demo Circuit - Precision Voltage Limiter
2021-03-09 15:22:243
LTC7149 Demo Circuit - Inverting Buck Regulator with Output Voltage Control (3.4-50Vin, 2.5 to -10Vout @ 2A)
2021-03-11 10:43:171
LTC7138 Demo Circuit - High Voltage Input Buck Regulator (4-140V to 3.3V @ 400mA)
2021-03-11 15:05:375
LTC3649 Demo Circuit - High Voltage Monolothic Synchronous Buck Regulator with Cable Drop Compensation (4-60V to 5V @ 4A)
2021-03-11 16:12:423
LTC3649 Demo Circuit - High Voltage Monolothic Synchronous Buck Regulator (4-60V to 5V @ 4A)
2021-03-11 16:14:433
LTM4675 Demo Circuit - Dual Output µModule Buck Regulator with Digital Interface (4.5-17V to 1V & 1.8V @ 9A)
2021-03-24 10:45:296
LT3095 Demo Circuit - Dual Low Noise, Low Ripple Bias Generator (3-20V to 5V & 15V @ 50mA)
2021-03-24 11:12:276
LTM4630A演示电路-高效双18A降压,带输出跟踪(6-15V至3.3V和5.0V@18A)
LTM4630A Demo Circuit - High Efficiency Dual 18A Buck with Output Tracking (6-15V to 3.3 V & 5.0V @ 18A)
2021-03-24 15:27:030
RFID-based-indoor-tracking-method
RFID-based-indoor-tracking-method(通信电源技术206期)-文档为An-RFID-based-indoor-tracking-method-for-navigating-visually-impaired-people总结文档,是一份不错的参考资料,感兴趣的可以下载看看,,,,,,,,,,,,,
2021-09-17 14:47:5715
MAX16193: 0.3% Accuracy Dual-Channel Supervisory Circuit Data Sheet MAX16193: 0.3% Accuracy Dual-Channel Supervisory Circuit Data Sheet
电子发烧友网为你提供ADI(ADI)MAX16193: 0.3% Accuracy Dual-Channel Supervisory Circuit Data Sheet相关产品参数、数据手册,更有
2023-10-12 18:39:12
MAX77720: Wide Output-Voltage Range, Dual- Polarity PMIC Data Sheet MAX77720: Wide Output-Voltage Range, Dual- Polarity PMIC Data Sheet
电子发烧友网为你提供ADI(ADI)MAX77720: Wide Output-Voltage Range, Dual- Polarity PMIC Data Sheet相关产品参数、数据手册,更有
2023-10-12 18:40:53
MAX16132-MAX16135: Low-Voltage, Precision, Single/Dual/Triple/Quad-Voltage μP Supervisors Data Sheet MAX16132-MAX16135: Low-Voltage, Precisi
电子发烧友网为你提供ADI(ADI)MAX16132-MAX16135: Low-Voltage, Precision, Single/Dual/Triple/Quad-Voltage
2023-10-13 18:38:22
MAX20796: Dual-Phase Scalable Integrated Voltage Regulator with PMBus Interface Data Sheet MAX20796: Dual-Phase Scalable Integrated Voltage
电子发烧友网为你提供ADI(ADI)MAX20796: Dual-Phase Scalable Integrated Voltage Regulator with PMBus Interface
2023-10-13 19:13:39
ADG7421F: Low Voltage Fault Protection and Detection, 20 Ω Ron, Dual SPST Switch Data Sheet ADG7421F: Low Voltage Fault Protection and Detec
电子发烧友网为你提供ADI(ADI)ADG7421F: Low Voltage Fault Protection and Detection, 20 Ω Ron, Dual SPST Switch
2023-10-16 19:27:47
MAX17524EVKITE: Evaluation Kit for the MAX17524 Dual-Output Voltage 3.3V and 5V Application Data Sheet MAX17524EVKITE: Evaluation Kit for th
电子发烧友网为你提供ADI(ADI)MAX17524EVKITE: Evaluation Kit for the MAX17524 Dual-Output Voltage 3.3V and 5V
2023-10-17 19:02:54
MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sheet MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sh
电子发烧友网为你提供ADI(ADI)MAX20429: Dual 6A High-Efficiency Low Voltage Buck Converter Data Sheet相关产品参数、数据
2023-10-17 19:19:34
已全部加载完成
