电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Transimpedance Amplifier Buffe
收藏
查看更多
解补偿运放是什么意思?解补偿运放为何可正常用于TIA配置?
TIA即跨阻放大器(transimpedance amplifier)。以前总说什么PD放大电路,其实用TIA更加准确和专业。
2023-11-01 11:02:17566
A Low-Noise-Amplifier at 1.9 GHz using BFP405
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGET a25 BFP405.
2009-05-12 14:10:12
A Low-Noise-Amplifier at 900 MHz using SIEGET BFP420
This application note describes a low noise amplifier at 900MHz usingSIEMENS SIEGET?25 BFP420.
2009-05-12 13:43:24
A Low-Noise-Amplifier shows good Noise Figure performance at 1.9 GHz using BF
This application note describes a low noise amplifier at 1.9GHz using SiemensSIEGETa25 BFP405.
2009-05-12 13:36:57
A Low-Noise-Amplifier with good IP3outperformance at 1.9 GHz using BFP420
This application note describes a low noise amplifier at 1.9GHz using SIEMENSSIEGETa25 BFP420.
2009-05-12 13:33:19
A Medium-Power-Amplifier at 1.9 GHz using BFP450
, circuit layout and measured data of a medium power amplifier at1.9GHz using Siemens SIEGET? BFP450.
2009-05-12 13:39:47
Design of low-voltage low-power CMOS operational amplifier cells
分享一本书:Design of low-voltage low-power CMOS operational amplifier cells
2021-06-22 07:01:47
GN1068-CHIP
Transimpedance Amplifier IC Ethernet
2023-04-06 12:17:41
IVC102
Precision Switched Integrator Transimpedance Amplifier datasheet
2022-11-04 17:22:44
Low-Noise-Amplifier optimised for minimum Noise Figure at 1.9 GHz using BFP420
, circuit layout and measured data of a low noise amplifier at1.9GHz using SIEMENS SIEGET?25 BFP420.
2009-05-12 13:48:36
Low-Noise-Amplifier optimized for input and output return loss at 1.9 GHz usi
2009-05-12 14:15:47
MAX40213EWA+T
TRANSIMPEDANCE AMPLIFIER WLP
2024-03-14 20:36:20
ONET2591TA
2.5 Gbps Transimpedance Amplifier with AGC and RSSI datasheet
2022-11-04 17:22:44
ONET4291TA
4.25 Gbps Transimpedance Amplifier with AGC and RGGI datasheet
2022-11-04 17:22:44
ONET8521TY
Transimpedance Amplifier 1 Circuit Differential 0-DIESALE
2023-04-06 20:03:14
OPA2381AIDGKRG4
Transimpedance Amplifier 2 Circuit 8-VSSOP
2023-03-23 08:58:05
OPA381AIDGKTG4
Transimpedance Amplifier 1 Circuit 8-VSSOP
2023-04-06 19:58:20
OPA857宽带,超低噪声互阻抗放大器
描述The OPA857 is a wideband, ultralow noise transimpedance amplifier (TIA) targeted at photodiode
2018-12-24 16:11:31
SA5211D--01,118
Transimpedance Amplifier 1 Circuit Differential 14-SO
2023-04-06 20:10:47
SIEGET25 Low Noise Amplifier with BFP 420 Transistor at 2.4 GHz
junction RF-transistors. This application note describes a low-noise amplifier with thefollowing
2009-05-12 14:02:33
SIEGET45 - Low Noise Amplifier with BFP520 Transistor at 1.9 GHz
This application note describes an example of a Low Noise Amplifier with theBFP520 (5th Generation
2009-05-12 14:00:34
VIVA (昱盛电子)VA2208 15W Filterless Stereo Class D Audio Amplifier
2021-04-20 17:39:00
VIVA(昱盛电子)VA2239 2*50W Stereo Filterless Class D Audio Amplifier
2021-04-20 17:34:35
在PSOC 5LP中一次可以使用多少个MIXERS
:• Programmable gain amplifier (PGA)• Transimpedance amplifier (TIA)• Mixer• Sample and hold circuit Does
2018-08-31 15:25:52
怎么使用网络分析仪测量输入参考噪声
, for following request: +I have designed and fabricated a transimpedance amplifier (TIA) IC chipand need
2019-04-23 14:11:02
高带宽光学前端模块的实现方案含详细数据资料
comprising a high speed transimpedance amplifier, fully differential amplifier, and high speed
2018-10-31 17:20:21
rf power amplifier
rf power amplifier 有完整的RF电源电路图。
2008-07-24 11:12:0547
ONET8501T pdf datasheet (具有RSS
The ONET8501T is a high-speed, high gain, limiting transimpedance amplifier used in optical
2008-08-11 23:29:1313
ONET8511T pdf datasheet (具有RS
The ONET8511T is a high-speed, high linearity transimpedance amplifier used in optical receivers
2008-08-11 23:30:5831
OPA644 pdf datasheet (Low Dist
The OPA644 is a wideband precision current feedbackoperational amplifier featuring exceptionally
2008-12-18 16:27:0520
Op Amplifier Circuit Collectio
Op Amplifier Circuit Collection
2009-01-16 12:51:3972
提高ACF2101开关积分器的噪声性能
and a low-levelinput current is exceptional when compared to the performanceof a classical transimpedance amplifier (Figure 1).
2009-06-12 14:54:3939
AD8222,pdf datasheet (Instrumentation Amplifier)
The AD8222 is a dual-channel, high performance instrumentation amplifier that requires only one
2009-08-27 10:54:2824
AD8307,pdf datasheet (Logarithmic Amplifier)
The AD8307 is the first logarithmic amplifier made available in an 8-lead (SOIC_N) package.
2009-08-27 15:56:0745
AD8001,pdf datasheet (Current
, in familiar terms. Being a currentfeedback amplifier, the AD8001’s open-loop behavior is expressedas transimpedance, ΔVO/ΔI–IN, or T
2009-09-02 10:55:1310
ADN2820,pdf datasheet (TIA wit
The ADN2820 is a compact, high performance, 3.3 V power supply SiGe transimpedance amplifier (TIA
2009-09-23 09:46:248
ADN2882,pdf datasheet (Transim
The ADN2882 is a 3.3 V high gain SiGe transimpedance amplifier (TIA) which converts the small
2009-09-23 09:54:4824
Tiny audio amplifier using LM3
Tiny audio amplifier using LM386:The Tiny Audio Amplifier kit is a good choice for battery
2009-12-26 08:34:2851
射频放大器设计(RF Power Amplifier Des
Contents Basic Amplifier Concepts1.Class A, B, C, F, hHCA2.Linearity Aspects3.Amplifier
2010-01-11 14:34:07267
ONET2591TA,pdf(2.5 Gbps Transi
The ONET2591TA is a high-speed transimpedance amplifier used in optical receivers with data rates
2010-08-28 21:38:0522
ONET4291TA,pdf(4.25 Gbps Trans
The ONET4291TA is a high-speed transimpedance amplifier used in optical receivers with data rates
2010-08-28 21:41:0226
ONET8531T,pdf(11.3Gbps Limitin
The ONET8531T is a high-speed and high-gain limiting-transimpedance amplifier, used in optical
2010-08-28 21:43:0115
OPA656,pdf(Wideband, Unity Gai
stage to offer an ultra high dynamic-range amplifier for ADC (Analog-to-Digital Converter) buffering and transimpedance applications. Extre
2010-09-11 20:37:0318
EL8102 BASED VIDEO AMPLIFIER W
EL8102 BASED VIDEO AMPLIFIER WITH SYNC STRIPPING AND DC RESTORE
2006-04-15 20:51:501649
Ahammer headphone amplifier_pr
Ahammer headphone amplifier_preamplifier双耳式耳机机放大器电路图(带前置放大器
2007-09-29 22:05:102302
to a transimpedance amplifier. About transimpedance and transconductance: The words "transconductance" and "tr
2009-04-20 15:51:03793
Extend Current-Sense Amplifier
Abstract: Adding a charge pump provides ±5V supply rails to the operational amplifier internal
2009-05-06 11:12:161149
Class D Audio Amplifier Output
Abstract: This application note examines the effect of the output filter on audio Class D amplifier
2009-05-06 11:59:231450
2009-05-07 08:54:422023
放大器信号调理的Piezofilm传感器-Amplifier
is a high-input-impedance differential charge amplifier using three op amps in a somewhat classical instrumentation amplifier configuration. The
2009-05-07 10:29:561511
反相放大器-The Inverting Amplifier
反相放大器 The Inverting Amplifier The basic operational amplifier circuit is shown in Figure 1. This circuit gives closed-loop gain of R2/R1 whe
2009-05-16 12:35:092616
加法器:Summing Amplifier
加法器:Summing Amplifier The summing amplifier, a special case of the inverting amplifier, is shown in Figure 4. The circuit gives an
2009-05-16 12:38:342626
差分放大器:The Difference Amplifier
差分放大器:The Difference Amplifier The difference amplifier is the complement of the summing amplifier and allows the subtraction o
2009-05-16 12:40:452151
英特尔Parallel Amplifier入门
英特尔® Parallel Amplifier 入门 英特尔® Parallel Amplifier 可分析并提供关于代码性能的信息。英特尔® Parallel Amplifier 能够显示性能
2009-06-17 07:56:57823
High-Side Current Amplifier Fo
High-Side Current Amplifier Forms 28V Circuit Breaker Abstract: Using the MAX4373 high-side
2009-08-31 17:39:251447
ADN2880: 3.2 Gbps 3.3V Low No
performance 3.3 V power supply SiGe transimpedance amplifier (TIA) optimized for small form factor Metro-Access and Etherne
2009-09-23 09:51:031112
耳机放大器电路 (Headphone Amplifier)
耳机放大器电路 (Headphone Amplifier) Amplifier parts:
2009-12-24 10:19:334565
吉他音箱电路 (Guitar Amplifier)
2009-12-25 10:01:4611886
60W吉他音箱 (60W Guitar Amplifier)
60W吉他音箱 (60W Guitar Amplifier) Amplifier parts: R1___
2009-12-25 10:51:472609
60W低音放大器 (60W Bass Amplifier)
60W低音放大器 (60W Bass Amplifier) Amplifier parts: R1__
2009-12-25 10:59:561679
Programmable-Gain Amplifier, U
Programmable-Gain Amplifier, Using the MAX532 DAC Abstract: This application note discusses how to use the MAX532 to build a programmable gain amplifie
2010-03-05 08:53:522074
onet8541t pdf datasheet (11.3 Gbps Limiting Transimpedance Amplifier)
The ONET8541T is a high-speed, high gain, limiting transimpedance amplifier used in optical
2011-09-17 12:21:5425
opt301 IC datasheet
amplifier on a single dielectrically isolated chip. The transimpedance amplifier consists of a precision FETinput op amp and an on-chip metal fil
2011-11-04 15:10:189
Stabilize Your Transimpedance Amplifier
Abstract: Transimpedance amplifiers (TIAs) are widely used to translate the current output
2012-02-06 11:31:5034
PHY1078-01数据资料
The PHY1078-01 is a combined burst mode laser driver and limiting amplifier for use within fiber
2012-08-20 11:54:4126
MAX24011,pdf datasheet
The MAX24011 is a low-power and high-sensitivity2.5Gbps continuous mode transimpedance amplifier
2013-03-21 18:11:3337
基于741_Operational_Amplifier电路板设计
741 Operational Amplifier电路板设计案例
2016-01-11 17:14:410
Analog_Amplifier电路板设计实例
Analog Amplifier电路板设计实例
2016-01-11 17:14:290
Bandpass Amplifier电路板设计实例
2016-01-11 17:14:150
Common_Source_JFET_Amplifier电路板设计
Common Source JFET Amplifier电路板设计实例
2016-01-11 17:29:080
Common-base_Amplifier电路板设计实例
Common-base Amplifier电路板设计实例
2016-01-11 17:29:230
Common-Emmiter_Amplifier电路板设计实例
Common-Emmiter Amplifier电路板设计实例
2016-01-11 17:29:340
Differential_Amplifier电路板设计实例
Differential Amplifier电路板设计实例
2016-01-11 17:38:480
Push-Pull_Amplifier电路设计
Push-Pull Amplifier电路设计
2016-01-11 17:55:210
RIAA_Amplifier电路设计
RIAA Amplifier电路设计,喜欢的朋友可以下载来学习。
2016-01-11 17:55:420
Vaccum-Tube Power Amplifier电路设计
2016-01-12 11:18:270
绘图案例【Circuit Simulation】741_Operational_Amplifier
绘图案例【Circuit Simulation】741 Operational Amplifier
2016-02-16 11:24:020
绘图案例【Circuit Simulation】Analog_Amplifier
绘图案例【Circuit Simulation】Analog Amplifier
2016-02-16 11:27:210
绘图案例【Circuit Simulation】Bandpass_Amplifier
绘图案例【Circuit Simulation】Bandpass Amplifier
2016-02-16 11:47:320
PCB绘图案例【Circuit Simulation】 Push-Pull_Amplifier
PCB绘图案例【Circuit Simulation】. Push-Pull Amplifier
2016-02-16 11:52:230
PCB绘图案例【Circuit Simulation】 RIAA_Amplifier
PCB绘图案例【Circuit Simulation】. RIAA Amplifier
2016-02-16 11:53:040
PCB绘图案例【Circuit Simulation】Differential_Amplifier
PCB绘图案例【Circuit Simulation】. Differential Amplifier
2016-02-16 11:58:020
PCB绘图案例【Circuit Simulation】Common-Base_Amplifier
PCB绘图案例【Circuit Simulation】. Common-base Amplifier
2016-02-17 14:24:190
AD846_450伏/毫秒精度电流反馈运算放大器
Although technically classed as a current-feedback or transimpedance amplifier, it may be used in much
2016-04-25 17:40:080
TS4871IST_AUDIO POWER AMPLIFIER
TS4871IST_AUDIO POWER AMPLIFIER,有需要的下来看看
2016-07-15 16:23:528
Instrumentation Amplifier Application Note-1298
Instrumentation Amplifier Application Note-1298数据手册,又需要的下来看看。
2016-12-14 21:50:0326
RF放大器设计(II) Amplifier Impedance
RF放大器设计(II) Amplifier Impedance Matching Technique 030422
2017-03-05 15:25:102
RF放大器设计Broadband Amplifier Design
RF放大器设计Broadband Amplifier Design 030724
2017-03-05 15:34:593
Improving Amplifier Noise Figure
Improving Amplifier Noise Figure for High 3rd Intercept Amplifiers
2017-03-24 15:52:190
基于RFHA1025下的280W GaN Wideband Pulsed Power Amplifier
The RFHA1025 is a 50V 280W high power discrete amplifier designed for L-band pulsed radar, air
2018-08-03 11:29:0010
LTC6563: Four-Channel Transimpedance Amplifier with Output Multiplexing Preliminary Data Sheet
2021-01-28 02:30:409
ADA4355: Programmable Transimpedance, Current to Bits Receiver μModule Data Sheet
2021-01-29 10:27:124
LTC6561 Demo Circuit - Four-Channel Multiplexed Transimpedance Amplifier with Output Multiplexing
2021-02-01 15:24:320
LTC2063 Demo Circuit - Low Power Irradiance Sense Amplifier
2021-02-03 11:50:165
LT6200 & LTC2050 Demo Circuit - Low Noise, Low Power Photodiode Transimpedance Amplifier with DC Precision
2021-02-19 10:47:1312
LTC6078 Demo Circuit - pH Probe Amplifier
2021-03-11 16:10:421
跨阻放大器TIA该怎么理解?
TIA的全称是Transimpedance amplifier, 即跨阻放大器。先从字面上理解下,amplifier比较好理解,就是放大器,例如对电压放大。
2023-09-19 09:36:102710
MAX40213: Transimpedance Amplifiers with Selectable Gain and Input Current Clamp Data Sheet MAX40213: Transimpedance Amplifiers with Selecta
电子发烧友网为你提供ADI(ADI)MAX40213: Transimpedance Amplifiers with Selectable Gain and Input Current Clamp
2023-10-16 18:40:19
跨阻放大器工作原理介绍
跨阻放大器(Transimpedance Amplifier,简称TIA)是一种广泛应用于传感器信号处理跨阻放大器(Transimpedance Amplifier,简称TIA)是一种广泛应用
2024-01-02 15:28:09688
已全部加载完成
