400µA operating quiescent current
100V 400-mΩ high-side MOSFET
Peak Current mode control
2023-11-09 15:48:40
HIGH-SIDE CURRENT-SENSE AMP
2023-03-27 13:31:11
2023-03-27 13:47:19
2023-03-27 13:23:39
2023-03-27 13:29:38
2023-03-27 13:22:19
2023-03-28 02:08:43
2023-03-27 12:05:58
2023-03-27 12:18:47
2023-03-27 13:38:24
2023-03-27 13:29:35
MP1584 is a high frequency step-down switching regulator with an integrated internal high-side high
2021-11-11 07:30:07
the ESD-protection diodes. This circuit protects a particular high-side current-sense amplifier (MAX4080
2011-08-21 16:49:34
TRIPLE GALVANIC INSULATED HIGH SIDE DRIVINGWITH TD310The TD310 is a triple MOS or IGBT driver
2009-05-12 09:50:07
描述The TIDA-01141 TI design provides a reference solution for ±100A shunt-based, high-side
2018-09-26 09:07:53
solenoids (so the high-side current limit is split between two solenoids on each bridge), and would
2018-10-24 11:11:12
on the low side with an integrated fault-detection feature. It consists of a current sense amplifier which
2018-10-24 11:48:37
High-Side Current Sensing: Difference Amplifier vs. Current-Sense Amplifier本文原文的PDF下载 §01 高端电流检测 在
2021-12-30 07:03:09
在低压调光应用领域,通常会采用Buck降压调光驱动器,具有高效率、高集成度和低成本等优势。对于Buck降压调光驱动器,存在High-side Buck和Floating Buck两种输出拓扑。如图1
2022-11-04 06:22:56
for high-side bipolar phase current sensingCalibrated current sense accuracy ±1% (over full range(...)
2018-07-13 03:53:41
off-time of 1μs. Features include integrated N-channel FET, high-side current sense, and shunt FET PWM
2018-12-27 15:23:48
bus. Output current monitoring is done using LMP8481-S high-side current sense amplifiers. NTC
2015-03-10 16:10:35
描述The TIDA-00639 reference design is a non-isolated high-side current and voltage sensing design
2018-11-01 16:44:13
The IA2410 is a complete, uni-directional, high voltage high-side current sense amplifier for use
2008-01-30 09:54:2044 The MAX9928/MAX9929 low-cost, uni-/bidirectional, high-side, current-sense amplifiers are ideal
2008-08-18 12:55:0240 The LTC6102/LTC6102HV are versatile, high voltage, high-side current sense amplifiers. Their high
2008-09-01 18:53:2745 , Current-Sense Amplifiers)
The MAX9928/MAX9929 low-cost, uni-/bidirectional, high-side, current-sense amplifiers are ideal for monitoring b
2008-10-01 11:21:5838 The MAX9938 high-side current-sense amplifier offersprecision accuracy specifications of VOS less
2008-10-01 23:14:4615 The MAX9610 high-side current-sense amplifier offers precision accuracy specifications of VOS less
2008-12-02 23:11:0610 wireless infrastructure equipment. Each controller includes a high-side current-sense amplifier with programmable gains of 2, 10, and 25 to mon
2008-12-10 11:48:4029 Features• Equivalent High Pass P-N-P Transistor• Current Limiting
2008-12-22 22:07:119 in cellular base stations. Each device includes a high-side current-sense amplifier with programmable gains of 2, 10, and 25 to monitor LDMOS drain c
2009-03-02 14:47:0523 The MAX9922/MAX9923 ultra-precision, high-side current-sense amplifiers feature ultra-low offset
2009-03-31 11:00:3319 MAX4376, MAX4377, MAX4378:The MAX4376/MAX4377/MAX4378 single, dual, and quad precision high-side
2009-05-29 11:10:1919 voltages. The MAX16065/MAX16066 can also accurately monitor (±2.5%) one current channel using a dedicated high-side current-sense amplifier. The
2009-08-22 08:21:5316 The ADM4073 is a low cost, high-side, current-sense amplifier ideal for small portable applications
2009-08-25 14:52:2616 Load Sharing, high-side or Low-side current sense, 1% accuracy, Intel SSI load
2022-12-15 15:48:09
The ADL5315 is a wide input current range, precision high-side current mirror featuring a stable
2009-09-23 09:38:5717 Ultraprecise Current Sense Amplifi er Dramatically Enhances Effi ciency and Dynamic Range:Accurate
2009-09-23 22:55:428 The LM5109A is a cost effective, high voltage gate driverdesigned to drive both the high-side
2009-10-06 10:11:5615 The LM5109B is a cost effective, high voltage gate driver designedto drive both the high-side
2009-10-06 10:13:1015 insertion loss (typically0.003W). The LM3824 is used for high-side sensing.A Delta Sigma analog to digital converter is incorporated
2009-10-06 10:48:5721 The MAX16070/MAX16071 can also accurately monitor (±2.5%) one current channel using a dedicated high-side current-sense amplifier. The MAX16070 m
2009-11-16 08:31:2218 The MAX9634 high-side current-sense amplifier offers precision accuracy specifications of VOS less
2009-11-16 16:10:3536 The MAX9934** high-precision low-voltage high-side current-sense amplifier is ideal for both
2009-11-16 17:59:1516 current and is suitable for automotive, industrial, and general lighting applications. The step-down (Buck) regulator contains a high-side N-ch
2009-12-04 14:56:354 current and is suitable for automotive, industrial, and general lighting applications. The step-down (Buck) regulator contains a high-side N-ch
2009-12-10 15:55:0739 The MAX4373/MAX4374/MAX4375 low-cost micropower high-side current-sense supervisors contain
2010-01-01 18:11:0441 The INA138 and INA168 are high-side, unipolar, current shunt monitors. Wide input common-mode
2010-09-24 22:20:4920 The INA139 and INA169 are high-side, unipolar, current shunt monitors. Wide input common-mode
2010-09-24 22:22:5221 The INA139 and INA169 are high-side, unipolar, current shunt monitors. Wide input common-mode
2010-09-24 22:24:2015 The INA139 and INA169 are high-side, unipolar, current shunt monitors. Wide input common-mode
2010-09-24 22:26:1019 The INA170 is a high-side, bidirectional current shunt monitor featuring a wide input common-mode
2010-09-24 22:27:5215 The INA200, INA201, and INA202 are high-side current-shunt monitors with voltage output.
2010-09-24 22:55:0120 The INA209 is a high-side current shunt and power monitor with an I2C interface. The INA209
2010-09-24 23:05:3420 The DRV104 is a DMOS, high-side power switch employinga pulse-width modulated (PWM) output. Its
2010-09-26 02:08:1529 current LED applications. With a low side current sense amplifier threshold of 190mV, the LED current is programmable with one external current
2010-09-30 12:09:35187 中文描述:低成本、SOT23封装、电压输出、高边电流检测放大器 英文描述:Low-Cost, SOT23, Voltage-Output,High-Side Current-Sense Amplifier(低成本,SOT23,电压输出,高边电流感应放大器) The M
2010-12-12 12:05:19144 MAX9928, MAX9929 -0.1V至+28V输入范围、微功耗、单/双向电流检测放大器
2008-10-01 11:26:19628 Current-Sense Amplifiers Provide a Wide -0.1V to +28V Input Range for Charge/Discharge Current
2008-10-01 12:03:59956 MAX9610 Tiny Current-Sense Amplifier Delivers Precision Monitoring and 1µA Supply Current
2009-01-22 16:32:021109 Abstract: This application note describes the use of current sense amplifiers, differential
2009-04-29 11:05:261363 Abstract: A current-sense amplifier, comparator, external CMOS switch, and an external transistor
2009-04-29 11:08:16917 Abstract: Using a current-sense amplifier, a high-side MOSFET driver, and a latching voltage
2009-04-29 11:10:25589 Abstract: This application note describes the use of a current-sense amplifier to monitor the load
2009-04-29 11:12:11840 current sense amplifiers to work at up to 300V. The MAX471 and MAX472 are complete bi-directional high-side current sense
2009-05-04 08:51:062013 Abstract: This application note describes the use of current sense amplifiers, differential
2009-05-04 09:49:511681 to a high-side current-sense amplifier. This modification enables that amplifier to sense currents down to 0V common-mode inputs. The circuit c
2009-05-06 11:12:161149 current sense amplifiers to work at up to 300V. The MAX471 and MAX472 are complete bi-directional high-side current sense
2009-05-06 11:29:051593 Abstract: The MAX4374 high-side current sense amplifier with two internal comparators is used
2009-05-06 11:36:341002 In recent years, tight tolerances for current sharing have made discrete current-sense circuit designs a formidable challenge. This applica
2009-05-06 11:38:061053 regulator by using a MAX4173H current-sense amplifier. Additional Information:
Quick View Data Sheet for the MAX16
2009-05-06 11:40:32940 Abstract: Using a current-sense amplifier, a high-side MOSFET driver, and a latching voltage
2009-05-06 11:41:48782 Abstract: This circuit modifies a standard 32V high-side current monitor to measure load current
2009-05-06 11:47:041809 to a high-side current-sense amplifier. This modification enables that amplifier to sense currents down to 0V common-mode inputs. The circuit c
2009-05-07 08:54:422023 Optocoupler Extends High-Side Current Sensor to 1kV
2009-07-18 10:36:131117 High-Side Current Amplifier Forms 28V Circuit Breaker
Abstract: Using the MAX4373 high-side
2009-08-31 17:39:251447 current-sense supervisors contain a high-side current-sense amplifier, bandgap reference, and comparator with latching outp
2010-01-01 18:14:331401 MAX15054 New high-side FET driver simplifies the design of buck and buck-boost HB LED drivers
2010-01-28 08:39:021324 It consists of a charge-pump voltage doubler (U1), a current-sense amplifier (U2), and two n-channel MOSFETs. The sense-resistor value determi
2010-11-08 08:21:521328 You can shut down a current-sense amplifier by connecting an NMOS transistor in its ground path
2010-12-12 12:04:211483 The ISL28005 is a micropower, uni-directional high-side and low-side current sense amplifier
2011-04-07 17:12:1412 The MAX4372 low-cost, precision, high-side current-sense amplifier is available in a tiny
2011-09-19 11:22:0942 control schemethat emulates hysteretic-mode behavior for transients.It integrates both the high-side and low-side switchesthat are designed to de
2012-01-18 11:23:452 The MAX9928/MAX9929 low-cost, uni-/bidirectional,high-side, current-sense amplifiers are ideal
2012-05-09 12:02:3123 The MAX4073 low-cost, high-side current-sense amplifierfeatures a voltage output that eliminates
2012-09-27 16:51:3425 MAX44285 Dual-Channel, High-Precision, High-Voltage, Current-Sense Amplifier.
2014-02-07 22:01:042183 measurement. It measures the voltage developed across an external sense resistor to represent the high-side current of a battery or voltage regulator.
2017-09-29 11:40:5011 measurement. It measures the voltage developed across an external sense resistor to represent the high-side current of a battery or voltage regulator.
2017-09-29 11:43:3622 measurement. It measures the voltage developed across an external sense resistor to represent the high-side current of a battery or voltage regulator.
2017-09-29 11:46:1611 The MAX4069–MAX4072 low-cost, bidirectional, highside, current-sense amplifiers are ideal
2017-10-14 11:11:4210 LTC2066/LT1389 Demo Circuit - Precision Ultralow Power High Side Current Sense
2021-02-01 14:38:281 LT1997-3 Demo Circuit - Single Supply Current Sense
2021-02-19 10:42:130 High-Side Current Sensing: Difference Amplifier vs. Current-Sense Amplifier 本文原文的PDF下载 §01 高端
2022-01-10 13:11:106 电子发烧友网为你提供ADI(ADI)MAX44284: 36V, Input Common-Mode, High-Precision, Low-Power Current-Sense
2023-10-13 18:35:03
电子发烧友网为你提供ADI(ADI)MAX22205: 65V, 7.6A High Current Single H-Bridge with Integrated Current Sense
2023-10-13 19:22:07
电子发烧友网为你提供ADI(ADI)MAX22204: 65V, 3.8A Stepper Motor Driver with Integrated Current-Sense and 128
2023-10-13 19:22:27
电子发烧友网为你提供ADI(ADI)MAX40080: Precision, Fast Sample-Rate, Digital Current-Sense Amplifier Data Sheet
2023-10-16 18:38:32
电子发烧友网为你提供ADI(ADI)MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet相关产品参数、数据手册
2023-10-16 18:57:04
电子发烧友网为你提供ADI(ADI)MAX9634: nanoPower, 4-Bump UCSP/SOT23, Precision Current-Sense Amplifier Data
2023-10-16 19:17:55
查看更多
