电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>High-Speed I²C for the MA
收藏
查看更多
High Speed IO用户手册
1 IР概述 High Speed l0 IP适用于PH1A(PH1A60、PH1A90、PH1A180、PH1A400)系列器件和PH1A100系列器件,它主要由时钟缓冲、IOL以及延迟单元等原语
2023-08-09 07:43:37
high-speed-selectIO
请问有用过high-speed-selectIO的大佬吗?|生成的例化模板中端口为bg_pin_nc怎么处理的呢?我实现这一步就报错了,想问问应该怎么改?
2022-09-23 11:42:21
high speed counter
high speed counter schematic
2020-12-21 16:50:04
A Practical Guide to High-Speed Printed-Circuit-Board Layout
By John Ardizzoni, (john.ardizzoni@analog.com)Despite its critical nature in high-speed circuitry
2015-01-23 11:01:23
Design And Application Guide For High Speed MOSFET Gate Drive Circuits
Design And Application Guide For High Speed MOSFET Gate Drive CircuitsThe main purpose
2009-03-27 16:04:24
2009-03-31 13:52:49
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计)
Disturbance Observer and Feedforward Design for a High-Speed Direct-Drive Positioning Table(高速直流驱动定位表的扰动观测器和前馈设计).pdf
2017-10-04 11:12:58
Jitter, Noise, and Signal Integrity at High-Speed
Jitter, Noise, and Signal Integrity at High-Speed-Mike PengLi
2015-10-26 15:03:11
TLC2543C, TLC2543I datasheet pdf
of a hostprocessor or peripheral through a serial 3-stateoutput. The device allows high-speed data transfers from the host.[hide][/hide]
2009-11-27 12:26:59
名词解释:协议外设(给的例子是 串口,SPI,I2C
I2C应该是I[sup]2[/sup]C
2013-03-10 14:29:39
启明分享|I2C 的配置
; PAD_TTL14, PAD_TTL15 *4 -> PAD_GPIO6, PAD_GPIO7*/i2c-padmux = ;/**speed: 0 -> HWI2C_HIGH(high
2021-09-08 10:59:45
高速I/O连接和总线中的抖动表征和测试的完整解决方案
Complete solutions for characterization and test of jitter in high-speed digital transmission systems, high-speed I/O connections, and buses.
2019-11-05 14:21:20
2019-11-06 09:33:45
高速时的抖动,噪声和信号完整性Jitter, Noise, and Signal Integrity at High-Speed
material, a common approach used by most of the high-speed I/O standards for cost-effective
2019-02-15 11:53:51
High-Speed Circuit Board Signa
High-Speed Circuit Board Signal Integrity:Characteristics and Construction of Printed Wiring Boards
2009-02-17 10:21:140
High-Speed Interconnect -高速接口I
业界功能最为齐全的高速接口IC产品线-High-Speed Interconnect (8th edition)
2009-03-23 21:36:0615
MAX17088 pdf datasheet (Intern
The MAX17088 includes a high-performance, step-up regulator; a high-speed operational amplifier
2009-03-23 22:02:1118
High-speed Digital Design - Jo
High-speed Digital Design - Johnson & Graham.pdf
2009-04-23 23:19:160
高速微控制器用户指南:High-Speed Microcon
高速微控制器用户指南:High-Speed Microcontroller User’s Guide 1. INTRODUCTION..92. ORDERING INFORMATION103.
2009-05-11 09:40:3020
High-Speed Differential Signal
High-Speed Differential Signaling in Cyclone Devices From high-speed backplane applications
2009-05-14 10:42:2321
MAX7360,pdf datasheet (;
The MAX7360 ;C-interfaced peripheral provides micro-processors with management of up to 64
2009-06-20 21:37:5523
Interfacing to High Speed ADCs
Interfacing to High Speed ADCs via SPI:This application note describes how to use the SPI port
2009-09-30 19:43:3915
High-Speed Audio Ripping,Encod
High-Speed Audio Ripping,Encoding and Playback: Entertainment Systems Get a Makeover:The way
2009-09-30 20:00:0328
TJA1051 High-speed CAN transce
The TJA1051 is a high-speed CAN transceiver that provides an interface between aController Area
2009-11-10 13:43:1521
TJA1042 High-speed CAN transce
The TJA1042 is a high-speed CAN transceiver that provides an interface between aController Area
2009-11-10 13:47:2851
High-Speed Board Design Techni
High-Speed Board Design TechniquesThe most important factor in the design of many systems today
2009-11-22 19:48:0220
High Speed Measurements on Mod
High Speed Measurements on Modulated Signals:This paper deals with the design and construction
2010-03-03 08:39:1529
TLC5540: 8-Bit High-Speed Anal
The TLC5540 is a high-speed, 8-bit analog-to-digital converter (ADC) that converts at sampling
2010-06-02 09:01:0718
ADS8317,pdf ( High-Speed, 2.7V
range from 2.7V to 5.5V. It requires very little power, even when operating at the full data rate. At lower data rates, the high speed o
2010-06-03 14:59:3839
High-Speed ADC THS1041and FPGA
ABSTRACTThe Texas Instruments THS1041 is a 10-bit, 40-MSPS, high-speed analog-to-digitalconverter
2010-06-06 17:01:154
Clamp function of high-speed A
IntroductionThe THS1041 from Texas Instruments (TI) is a 10-bit, 40-MSPS, CMOS high-speed
2010-06-06 17:03:405
TSW1250EVM: High-Speed LVDS De
The TSW1250 includes a High-Speed LVDS Deserializer and Analysis System which provide
2010-06-12 09:41:4610
CD74HC564,pdf(High-Speed CMOS
The ’HC534, ’HCT534, ’HC564, and ’HCT564 are high speed Octal D-Type Flip-Flops manufactured
2010-07-25 18:35:2612
CD74HCT573,pdf(High-Speed CMOS
The ’HC533, ’HCT533, ’HC563, and CD74HCT563 are high speed Octal Transparent Latches manufactured
2010-07-30 12:28:4719
CD74HC40103-Q1,PDF(High-Speed
The CD74HC40103 is manufactured with high-speed silicon-gate technology and consists of an 8-stage
2010-08-09 22:20:3526
CD74HC4017-Q1,pdf(High-Speed C
The CD74HC4017 is a high-speed silicon-gate CMOS 5-stage Johnson counter with ten decoded outputs.
2010-08-10 17:08:3720
CD74HC138-Q1,pdf(High-Speed CM
The CD74HC138 is a high-speed silicon-gate CMOS decoder well suited to memory address decoding
2010-08-12 00:12:5117
CD74HC4543,pdf(High-Speed CMOS
The CD74HC4543 high-speed silicon-gate device is a BCD to 7-segment latch/decoder/driver designed
2010-08-12 15:11:5021
TS3USB221,pdf(High-Speed USB 2
The TS3USB221 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:34:1928
TS3USB30,pdf(High-Speed USB 2.
The TS3USB30 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:37:0212
TS3USB31,pdf(High-Speed USB 2.
The TS3USB31 is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-08-14 00:38:3919
SN74LV4046A,pdf(High-Speed CMO
The SN74LV4046A is a high-speed silicon-gate CMOS device that is pin compatible with the CD4046B
2010-08-20 18:27:0622
UA9638,pdf(Dual High-Speed Dif
The uA9638C is a dual high-speed differential line driver designed to meet ANSI Standard EIA
2010-09-04 17:28:4613
TS3USB221A-Q1,pdf(High-Speed U
The TS3USB221A is a high-bandwidth switch specially designed for the switching of high-speed USB
2010-09-09 23:54:0323
TS3USB221E,pdf(HIGH-SPEED USB
The TS3USB221E is a high-bandwidth switch specially designed for the switching of high-speed USB
2010-09-10 00:00:2632
TS3USB31E,pdf(High-Speed USB 2
The TS3USB31E is a high-bandwidth switch specially designed for the switching of high-speed USB 2.0
2010-09-10 00:07:5515
THS6012,pdf(500-mA Dual Differ
The THS6012 contains two high-speed drivers capable of providing 400 mA output current (min
2010-09-11 22:15:1410
THS3001,pdf(420-MHz High-Speed
The THS3001 is a high-speed current-feedback operational amplifier, ideal for communication
2010-09-11 23:14:1245
THS6022,pdf(250-mA Dual Differ
The THS6022 contains two high-speed drivers capable of providing 200-mA output current (minimum
2010-09-12 22:26:4116
OPA2832,pdf(dual, low-power, high-speed, fixed-gain amplifier)
The OPA2832 is a dual, low-power, high-speed, fixed-gain amplifier designed to operate on a single
2010-09-12 23:31:1611
PGA870,pdf(High-Speed, Fully D
The PGA870 is a wideband programmable-gain amplifier (PGA) for high-speed signal chain and data
2010-09-18 23:49:1327
ADP3654,pdf (High Speed, Dual,
The ADP3654 high current and dual high speed driver is capable of driving two independent N-channel
2010-09-20 09:22:1534
TL714,pdf(HIGH-SPEED DIFFERENT
The TL714C is a high-speed differential comparator fabricated with bipolar Schottky process
2010-09-23 19:34:3222
TPS2811-Q1,pdf(Dual High-Speed
The TPS2811 dual high-speed MOSFET driver is capable of delivering peak currents of 2 A into highly
2010-09-27 21:46:3216
TLE2021-EP,pdf(Excalibur High-Speed Low-Power Precision OP A
The TLE202x and TLE202xA devices are precision, high-speed, low-power operational amplifiers using
2010-12-13 21:20:4846
DS3514 ;C Gamma and VCOM
DS3514 ;C Gamma and VCOM Buffer with EEPROM   DS3514 Description COM voltage
2008-10-24 09:21:311006
MAX6625, MAX6626 带有;C兼容串
MAX6625, MAX6626 9位/12位温度传感器,带有;C兼容串行接口,SOT23封装   MAX6625, MAX6626概述 The MAX6625/MAX6626 combine a tempe
2008-12-08 15:39:15889
How to Use the DS2482 ;C
How to Use the DS2482 ;C 1-Wire® Master  Abstract: The DS2482 is an ;C to 1-Wire bridge. The
2008-12-18 09:54:061317
;C总线的验证及实现--Proven Imple
;C总线的验证及实现--Proven Implementations of the ;C Bus Abstract: This application note
2009-01-22 16:16:251890
INL/DNL Measurements for High-
for high-speed, high dynamic performance data converters, they gain significance when it comes to high-resolution imaging applications. The
2009-04-16 15:53:381891
High-Speed ADC Sets Input Comm
receivers that include baseband-sampling, high-speed ADCs. A VCM is especially important for single-supply, low-voltage circuits with DC-couple
2009-04-16 16:46:49545
High-Speed Pulse Generator Has
Abstract: As integrated circuits (ICs) speed up, the rise/fall times of most pulse and function
2009-04-20 11:17:561455
High-Speed Random-Data Generat
Abstract: A handful of components are integrated into a circuit that creates a high-quality random
2009-04-20 15:05:49916
2009-04-20 15:09:34947
;C串行实时时钟与微控制器的接口
摘要:本应用笔记提供了Dallas ;C接口实时时钟的通用硬件配置和软件例程。本例程适用于采用BCD码时间和日期格式的RTC。
2009-04-21 11:09:272174
高速微型存储器接口时序-High-Speed Micro M
Abstract: This application note addresses external memory interfacing with Maxim high-speed
2009-04-23 15:35:10918
可控制多外设的SPI/;C总线
摘要:本应用笔记对两种模拟IC中常用的串行、数字接口(SPI™或3线、;C或2线)进行了比较,每种接口在不同的设计中都表现出其优点和缺点,具体取决于数据速率、可提供的
2009-04-24 15:07:59614
2009-04-25 09:29:05539
Interfacing the MAX5195 High-S
of the MAX5195 high-speed digital-to-analog converter (DAC) to design a reliable resistor network for interface this LVPECL-based high-speed DAC to
2009-04-25 10:08:30824
Comparing the ;C Bus to
Abstract: The ;C bus and the SMBus™ are popular 2-wire buses that are essentially
2009-04-30 11:00:57736
高速ADC输入共模范围-High-Speed ADC Set
2009-05-01 10:49:50905
2009-05-01 11:06:44527
MAX9257/MAX9258评估板;C模式工作
摘要:为了获得成功的硬件设计,在选择串行器/解串器(SerDes)元件之前最好针对具体的应用进行评估。本应用笔记提供的设计指南有助于快速配置MAX9257/MAX9258评估板的;C模式,逐
2009-05-02 10:39:371564
高速ADC集输入共模范围-High-Speed ADC Se
2009-05-08 10:29:39605
2009-05-08 10:41:03701
如何使用;C接口的DS2482 1-Wire主控
摘要:DS2482是;C到1-Wire的桥接器件。DS2482可以使任何具备;C通信功能的主机产生正确时序和具有摆率控制的1-Wire波形。本应用笔记是DS2482 ;C至1-Wire线驱动器的用户指南,
2009-05-09 08:53:013311
可控制多外设的SPI/;C总线
2009-05-09 09:09:171409
设置高速ADC的共模输入电压范围--High-Speed A
设置高速ADC的共模输入电压范围--High-Speed ADC Sets Input Common-Mode Range Abstract: The input common-mode
2009-06-09 20:41:431378
带有;C接口的4通道输出、高压EL灯驱动器,提供
带有;C接口的4通道输出、高压EL灯驱动器,提供最佳的亮度,并有效降低了噪声
2009-07-18 18:03:33903
DS4426应用电路(四通道、;C、可控制裕量的
DS4426应用电路(四通道、;C、可控制裕量的IDAC,具有三路电源跟踪)
2009-07-25 21:46:50692
ADP3629: High Speed, Dual, 2
ADP3629: High Speed, Dual, 2 A MOSFET Driver The ADP3629/ADP3630/ADP3631 are dual, high current
2009-10-31 11:20:30678
ADP3629:  High Speed, Dual, 2 A MOSFET Driver, inverting A/B input pins The ADP3629/ADP3630
2009-11-09 11:21:03671
ADP3630: High Speed, Dual, 2
ADP3630:  High Speed, Dual, 2 A MOSFET Driver The ADP3629/ADP3630/ADP3631 are dual, high
2009-11-09 11:23:34577
ADP3631: High Speed, Dual, 2
ADP3631:  High Speed, Dual, 2 A MOSFET Driver The ADP3629/ADP3630/ADP3631 are dual, high
2009-11-09 11:26:34623
Maxim推出;C兼容、多通道8/10/12位A
Maxim推出;C兼容、多通道8/10/12位ADC Maxim推出带有内部电压基准的多通道ADC系列产品MAX11600-MAX11617,扩展了业内领先的基于;C的ADC产品线。该系列ADC提供188ksps、8位(MAX11
2009-11-13 09:14:53794
MAXQ314 单相交流电源测量IC,带有;C接
MAXQ314 单相交流电源测量IC,带有;C接口 The MAXQ314 performs voltage and current measurements using an integrate
2009-11-16 08:43:381040
欧司朗推出采用;C数字输出的环境光度传感器
欧司朗推出采用;C数字输出的环境光度传感器 2009年11月18日16:08:34 同时提供标数据速率和高速率3.4 MHz 与人眼相同的方式
2009-11-18 16:08:40493
Maxim推出集成振荡器的微型SPI/;C UA
Maxim推出集成振荡器的微型SPI/;C UART   Maxim推出业内功耗最低、速度最快、尺寸最小的SPI™/;C接口通信的串行UART。MAX3107的功耗极低,可有效延长便携
2010-01-18 10:18:13560
Maxim推出集成振荡器的微型SPI/;C UART MAX3107 Maxim推出业内功耗最低、速度最快、尺寸最小的SPI/;C接口通信的串行UART。MAX3107的功耗极低,可有效延长便携式设备的
2010-01-19 09:25:32475
DS3231M是低成本、高精度;C实时时钟(RT
  DS3231M是低成本、高精度;C实时时钟(RTC)。该器件包含电池输入端,断开主电源时仍可保持精确计时。集成微机电
2010-12-02 09:27:405280
MAX9643 (a high-speed 60V precision unidirectional)
The MAX9643 is a high-speed 60V precision unidirectionalcurrent-sense amplifier ideal for a wide
2011-09-26 11:58:5912
High-speed Digital Design 中文版
电子发烧友网站提供《High-speed Digital Design 中文版.txt》资料免费下载
2012-05-03 16:08:550
buf634_250mA高速缓冲器
buf634——250mA HIGH-SPEED BUFFER 250mA高速缓冲器
2015-11-30 18:25:4050
High-Speed_Digital_System_Design
高速数字系统设计High-speed digital system design
2016-02-23 11:58:0120
PCB制作,A Practical Guide to High-Speed Printed-Circuit-Board Layout
2016-12-17 15:03:580
Designing High Speed Active Filt
Designing High Speed Active Filters
2017-03-24 15:32:380
ADS7-V2EBZ High Speed Evaluation Board
2021-02-19 15:25:308
MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data Sheet MAX22195: High-Speed, Octal, Industrial Digital Input
电子发烧友网为你提供ADI(ADI)MAX22195: High-Speed, Octal, Industrial Digital Input with Parallel Output Data
2023-10-17 19:15:17
已全部加载完成
