电子发烧友App
硬声App
电子发烧友网>通信网络>通信设计应用>Using Spare NV Digital Pots as
收藏
查看更多
(Delmar) Digital Signal Processing
本帖最后由 ORCAD__PCB 于 2012-8-9 14:38 编辑 (Delmar) Digital Signal Processing
2012-08-09 14:34:16
Digital Image Processing
2016-06-24 14:08:55
Digital video technologies
Digital video technologiesContents What is digital video?Why has digital video become a mainstream
2008-08-04 15:35:24
2008-08-04 15:49:28
NV-BAT01
Battery NV Series
2023-03-29 19:55:43
NV3Q-KBA04
PROTECTIVE SHEETS FOR NV3Q
2023-03-29 19:55:43
NV3W-KBA04
PROTECTIVE SHEETS FOR NV3W
2023-03-29 19:55:43
NV3W-RP001
WATERPROOF PACKINGS FOR NV3W
2023-03-29 19:55:44
NV问题
在zigbee cc2530协议栈中,怎么删除一个NV??
2018-06-24 04:44:28
Using the IBM43RF0100EV19 1900 MHz LNA Evaluation Board
Using the IBM43RF0100EV19 1900 MHz LNA Evaluation BoardThis application note describes using
2009-05-12 11:40:53
ADCAnalog-to-Digital是什么
ADCAnalog-to-Digital指模/数转换器或者模拟/数字转换器是指将连续变量的模拟信号转换为离散的数字信号的器件典型的模拟数字转换器将模拟信号转换为表示一定比例电压值的数字信号
2021-08-12 07:32:51
Analog and Digital Filter Design-老外写的
Analog and Digital Filter Design-老外写的  [hide]Analog and Digital Filter Design.rar[/hide]
2009-10-20 12:11:54
Calibration Circuit Idea Pictorial
note 3077, "A Digitally Controllable Lowpass Filter Using a Digital Potentiometer."LCD
2011-06-13 00:15:17
Chisel 语言入门经典《Digital Design with Chisel》 中文版
using the hardware construction language Chisel.We have seen several simple to medium-sized digital
2022-03-15 17:27:37
ELP-04NV
ELP-04NV
2023-04-06 23:35:38
MCP4341数字电位器中PXA,PXW和PXB引脚的最大电流±2.5 mA指在AND中吗?
MCP431数字POTS数据表将最大电流分为PXA、PXW和PXB管脚……±2.5 MaODs意味着输入和输出? 以上来自于百度翻译 以下为原文 MCP4341 digital pot
2018-10-08 09:50:47
PLV write to digital port.vi
有谁知道PLV write to digital port.vi 这个子vi
2011-08-10 11:01:52
PS仿真问题求助: Digital Simulator Option not present和Digital simulator not present
PS仿真时出现错误: Digital Simulator Option not present和Digital simulator not present。我在网上下载的6N137元器件模型,其中
2019-01-20 10:53:36
RDPS-POTS050
RDPS-POTS050 - Micro filter for South Africa - List of Unclassifed Manufacturers
2022-11-04 17:22:44
Real Analog Solutions for Digital Designers
2017-01-08 14:58:51
Serial_Digital_Scope怎么使用
Serial_Digital_Scope的使用前言前期准备使用步骤1.配置串口2.加入上位机的 API 代码文件3.代码更改和编写4.虚拟示波器配置结束语前言在调试小车的PID的时候,苦恼于无法更直
2022-01-14 07:45:23
一本好书LabVIEW Digital Signal Processing and Digital Communications
LabVIEW Digital Signal Processing and Digital Communications很不错。{:12:}
2014-09-03 08:32:41
为什么NV_RESTORE和NV_INIT都开启,但Flash中ZCD_NV_PANID和变量zgConfigPANID读取出的值都为0xFFFF?
为什么NV_RESTORE和NV_INIT都开启,但Flash中ZCD_NV_PANID和变量zgConfigPANID读取出的值都为0xFFFF。 通过网络抓包看到的PanID是有效的。为什么没有
2018-05-15 04:28:21
如何放大10nV直流信号?
问一下大家. 如何放大10nV 直流信号. (内阻是60K) .用普通运放是放大不了的.太多噪声.
2024-01-02 06:36:47
怎样将数字电位器的带宽从10倍提高到100倍
0.1dB bandwidths of 4MHz and -3dB bandwidths of over 25MHz. Using this technique, digital pots become a
2008-10-04 20:39:26
数字图像处理,Digital Image Processing
数字图像处理,Digital Image ProcessingIntroduction and Digital Image Fundamentals?What is an Image?Picture
2009-06-18 07:49:37
求助,nuc977的rtc spare寄存器有什么用?
想用这个RTC Spare寄存器做不掉电RAM使用,读写都需要写保护
2023-06-27 12:13:51
请问NV条目可以删除么?
是这样的,我用这个osal_nv_item_init(0x600 ,10,NULL)初始化一个条目,并且在这个里面写入了数据,现在我想把这个0x600这个条目删除,或者说把0x600这个条目对应的NV空间大小从10变成20等,这些可以实现么?我只是问问,不可以的话也无所谓~
2018-08-18 07:32:53
请问如何放大10nV直流信号
问一下大家.如何放大10nV 直流信号. (内阻是60K) .用普通运放是放大不了的.太多噪声.
2018-11-23 09:28:09
赛普拉斯NV-SRAM解决方案分享
赛普拉斯NV-SRAM解决方案
2020-12-30 07:15:03
连接到标准POTS电话的最常用接口有哪几种?
本文将重点介绍连接到标准 POTS 电话的两种最常用接口:Foreign eXchange Subscriber (FXS) 与 Foreign eXchange Office (FXO)。重点说明了设计人员在为 VoIP 小区网关的模拟电话接口提供支持时可能面临的某些挑战。
2021-05-31 06:52:12
NV221.pdf
NV221.pdf
2007-12-24 22:12:1612
DS1804 pdf datasheet (NV Trimm
DESCRIPTIONThe DS1804 NV trimmer potentiometer is a nonvolatile digital potentiometer that has 100
2008-10-01 23:57:4223
NV8600显卡电路原理图
NV8600显卡电路图,NV8600显卡原理图
2008-12-14 20:18:48735
使用DAC作为功能发生器-Using the DAC as
devices using the on-chip digital-toanalog converter (DAC).Features• Four different waveforms expandable toany periodic func
2009-01-23 23:14:5412
Digital Signal Processing Syst
Digital Signal Processing System-Level Design Using LabVIEW For many years, I have been teaching
2009-02-17 10:27:310
Digital signal processing (DSP) refers to anything that can be done to asignal using code
2009-02-17 15:36:390
NV SRAM Frequently Asked Quest
Abstract: This application note discusses theory of operation and application of NV SRAMs
2009-04-24 09:40:3914
Modulating Direct Digital Synt
Modulating Direct Digital Synthesizer:DDS Overview In the pursuit of more complex phase continuous
2009-06-14 08:43:4227
Digital Signal Processing--Filtering Approach
Digital Signal Processing--Filtering Approach: Digital signal processing (DSP) refers
2009-07-25 16:16:2422
Using a SAR Analog-to-Digital
Using a SAR Analog-to-Digital Converter for Current Measurement in Motor Control Applications
2009-10-01 19:02:2111
LM26NV,datasheet,pdf(Factory P
The LM26NV is a precision, single digital-output, low-powerthermostat comprised of an internal
2009-10-20 14:51:0619
Using Cyclone III FPGAs for Cl
Using Cycl
2009-11-27 13:55:2515
Battery equalization using a p
Battery equalization using a plug-in charger in a hybrid electric vehicle
2009-11-28 11:56:3511
Digital Control Concepts For P
Control Techniques– Traditional Analog– Traditional Digital– Modern Digital􀁺 Examples
2009-11-28 14:15:46131
NV RAID DISK 64位版
NV RAID DISK 64位版.zip
2010-01-29 16:57:300
Using Wavelet Eigenvalues as t
Using Wavelet Eigenvalues as the Input of Pi-sigma Network to Recognize Movement Pattern
2010-02-22 11:38:0113
Using the TMS320C5402 DMA Chan
This application report presents a hardware and software solution for using the DMA channels
2010-06-04 16:21:457
ABSTRACTThis application report presents hardware and software solutions for using the DMA
2010-06-06 15:36:2710
Using the Agilent U2300A Serie
Using the
2010-08-22 12:34:5618
Using SDCard and SDIO with the
with either:• A MultiMediaCard (MMC)• A Secure Digital (SD) Memory Card• A Secure Digital I/O (SDIO) ca
2010-09-22 08:23:0230
新一代NV SRAM技术
新一代NV SRAM技术 第一代NV SRAM模块问世近20年来,NV SRAM技术不断更新,以保持与各种应用同步发展,同时满足新的封装技术不断增长的需求。 发展与现状
2008-11-26 08:24:53901
Using the DS4412 to Margin the
Using the
2009-01-06 13:45:20776
Using a UART to Implement a 1-
Using a UA
2009-03-31 22:18:451771
12-Bit Thermometer Using an 8-
a 12-bit digital thermometer using a low-cost, 8-bit microcontroller (µC) and the MPASM free assembler. The thermomet
2009-03-31 22:25:39730
Pots, Pans, Logs, and Linear D
Pots, Pans, Logs, and Linear Digital Pots Create Arbitrary Voltage Curves
2009-04-16 16:07:401623
This application note explains how to implement a 12-bit digital thermometer using a low-cost
2009-04-17 10:18:351321
Using the
2009-04-23 08:42:35898
Using a EconOscillator to Cloc
Using a Ec
2009-04-23 10:31:261112
Using Maxim SPI-compatible Dis
Using Maxi
2009-04-27 09:50:061106
音频增益控制用数字电位器-Audio Gain Contro
Abstract: Digital potentiometers (pots) offer advantages in volume control applications over bulky
2009-04-28 10:40:091366
2-Wire Controlled Digital DIP
Abstract: The DS3904 contains three digitally controlled nonvolatile (NV) variable resistors.
2009-04-28 11:46:50991
Using a PC with a DS3900 to Co
to communicate with the three digital pots, the DS1267, DS1867, and DS1868, which use this shift register interface for programming. The DS3
2009-04-28 11:50:56812
利用数字电位器的调节降压DC-DC转换器设计-Using D
Abstract: This application note describes how to use a digital potentiometer to generate
2009-04-28 13:49:322095
2009-05-05 11:08:261870
创建非线性传递函数与线性电位器电路-Creating Non
Abstract: Linear digital potentiometers (pots) can be used in non-linear applications
2009-05-05 11:30:16730
2009-05-08 09:09:22696
数字模拟转换器是一个“位”模拟-Digital-Analog
by analog signals. Digital control systems process real world analog signals by using an analog-to-digital converter (ADC) to convert analog
2009-05-08 09:26:55881
Spare Op Amp Generates Its Own
Spare Op A
2009-06-09 21:01:24676
利用空闲运放产生稳定的负电源 Spare Op Amp Ge
利用空闲运放产生稳定的负电源 Spare Op Amp Generates Its Own Regulated Negative Supply
2009-06-19 07:33:181095
什么是Digital Business
什么是Digital Business  英文缩写: Digital Business 中文译名: 数字企业 分  类: 其它 解  释: 能把新技术与
2010-02-22 17:35:113277
什么是Digital Certificate,also,di
什么是Digital Certificate,also,digital signature  英文缩写: Digital Certificate,also,digital signature 中文译名: 数字证书(也称数
2010-02-22 17:35:581185
DTS Digital
DTS Digital              DTS是“Digital Theatre System”的缩写,
2010-01-04 15:37:08838
DS1350 4096k非易失(NV) SRAM
  DS1350 4096k非易失(NV) SRAM为4,194,304位、全静态NV SRAM,
2010-10-21 09:01:27888
DS1330 256k非易失(NV) SRAM
  DS1330 256k非易失(NV) SRAM为262,144位、全静态非易失SRAM,按照8位、32,768字排列。每个NV SRAM均自带锂电池及控制电
2010-10-22 09:00:581417
DS1265W 8Mb非易失(NV) SRAM
  DS1265W 8Mb非易失(NV) SRAM为8,388,608位、全静态NV SRAM,按
2010-11-07 09:37:51770
Verilog Coding Style for Efficient Digital Design
In this paper, we discuss efficient coding and design styles using verilog. This can beimmensely
2012-01-17 11:26:570
数字集成电路设计Digital Integrated Circuit Design
the natureof the design process in industry. Starting with architecture design, the book explains the why andhow of digital design, using the physics
2012-01-17 16:57:2081
Digital_FIR_Filter_Design_Using_the_MSP430F16x
This application report describes an FIR filter implementation using the MSP430F16x
2016-02-16 18:08:438
Wave_Digital_Filtering_Using_the_MSP430
Digital filtering is an integral part of many digital signal processing algorithms. Digital
2016-02-16 18:18:455
NV200-1000V 电压传感器
NV200-1000V 电压传感器
2017-03-04 17:53:113
NV200-500V 电压传感器
NV200-500V 电压传感器
2017-03-04 17:53:114
Examples Using the DS3930 as Voltage References and Digital I/O
Introduction The DS3930 contains six 256-position nonvolatile (NV) potentiometers (see Figure
2017-04-12 14:35:053
Efficient packet classification using TCAM
Efficient packet classification using TCAM(现代电源技术基础课程)-Efficient packet classification using TCAM
2021-08-04 16:23:0414
NV-SRAM与BBSRAM之间的比较
随着无铅技术在全球的推广,NV-SRAM成为NVRAM的普遍选择。本篇文章主要介绍了NV-SRAM与电池供电SRAM(BBSRAM)相比所具有的优点。
2022-01-25 19:50:512
Digital Thermometer
this is the digital thermometer
2022-02-10 14:05:130
电池备份NV SRAM和NOVRAMS之间的比较
达拉斯半导体非易失性(NV)SRAM由内部电池备份。市场上的其他一些NV存储器,如NOVRAM,使用内部EEPROM备份数据。本应用笔记讨论了电池供电NV SRAM和NOVRAM之间的差异。
2023-01-10 14:25:59796
NV4V31MF 数据表
NV4V31MF 数据表
2023-03-13 19:09:190
NV4V41SF 数据表
NV4V41SF 数据表
2023-03-13 19:09:350
NV4V31SF 数据表
NV4V31SF 数据表
2023-03-13 19:09:540
NV021 Final 数据表
NV021 Final 数据表
2023-03-24 19:10:280
80秒的语音芯片—NV系列
景和功能上都有所不同,语音时长也不同。 目前市面上需求量最多的是40秒和80秒的语音芯片,那么80秒的语音芯片有哪些呢? 一、NV语音芯片系列:NV080C、NV080D、NVG080W、NV080B等; 九芯电子的语音芯片主要是品牌代表N+语音系列V+语音时长(如080)+芯片系
2023-03-30 14:47:16449
NV4V31MF 数据表
NV4V31MF 数据表
2023-07-04 20:27:190
NV4V41SF 数据表
NV4V41SF 数据表
2023-07-04 20:27:360
NV4V31SF 数据表
NV4V31SF 数据表
2023-07-04 20:27:470
NV021 Final 数据表
NV021 Final 数据表
2023-07-10 21:00:310
已全部加载完成
