`source`命令用于在当前Shell运行文件中的命令,source命令可用于将函数,变量和配置文件加载当前Shell。
2022-12-05 16:19:14
2454 06186-90005 (January 1975) The 6186C Precision Constant Current Source is a discontinued product. This manual is provided for information only.
2018-11-15 10:42:38
运放的PCB的布局布线AN1258 - OP AMP PRECISION DESIGN: PCB LAYOUT - MICROCHIP强烈建议看多遍。
2015-01-23 11:15:42
I learned a current source made by amplifier and transistor , I checked it in the book, but I can't
2011-09-06 16:01:12
【作者】:欧阳联华;谷鸣;刘波;陈嵘;【来源】:《中国物理C》2010年03期【摘要】:There are 6 in-vacuum eddy current septum magnets used
2010-04-24 08:59:53
嗨伙计们,我买了一台二手HP 66311A DC Source。电压输出很完美,但电流限制在0.600安培左右。我试图重新校准当前值,任何程序的尝试都会以“超出范围”的方式返回。此外,15伏稳压器中
2019-02-12 06:51:23
NumericScale 和 Precision 属性范例 (VB)本范例使用 NumericScale 和 Precision 属性来显示 Pubs 数据库 Discounts 表中字段的数值范围
2009-01-08 10:22:55
the current-sense amplifier's precision input characteristics.A better solution, then, is to connect PMOS
2011-08-21 16:49:34
matlab中如何通过设置使AC Current Source模块成为直流电流源模块。1.如下图路径中找到AC Current Source模块。2.拖拽到model中后,左键双击出现如下情形。3.对应公式如图。4.根据需要修改对应值,我需要2A的...
2021-12-31 06:01:53
accuracy40 A DC support with the Agilent 42841A Bias Current Source Wide Range DC Current Biased
2020-04-24 14:58:11
以上来自于谷歌翻译 以下为原文I have Agilent 5747A power supply and I like to operate it in current source mode.
2019-07-25 11:49:11
在MATLAB中怎样通过设置AC Current Source模块使成为直流电流源模块?有哪些步骤?
2021-10-08 09:14:05
精工Precision(SEIKO Precision)日前开发出了带有自动对焦(AF)功能的相机模块P0029。该产品主要用于手机,但该公司也受理此用途以外的需求,计划3月开始量产。该公司
2018-10-25 11:33:52
shunt-based phase current sensing for accurate control of precision drives such as servo drives. One
2018-10-19 15:34:32
这是AD5765DATASHEET里面关于输出电流的说明
Short-Circuit Current10mA typRISCC = 6 kΩ; see Figure 23
Load
2023-12-21 06:34:24
想将histreaming.app代码移植到鸿蒙侧,发现在调用liblink_core.so文件时报错,请大佬帮忙解答一下,感谢这个是CMakeLists.txt相关内容这个是项目.so文件存放位置
2021-01-25 16:54:15
2021-01-29 09:44:06
instrumentationamplifier (IA), a voltage-controlled output current source,and dual-matched precision current reference. Thiscombination is
2008-10-14 15:27:37
23 The XTR105 is a monolithic 4-20mA, two-wirecurrent transmitter with two precision current
2008-12-19 19:45:34
91 电路的基本概念及定律电源 source电压源 voltage source电流源 current source理想电压源 ideal voltage source理想电流源 ideal current source伏安特性 volt-ampere characteristic电动
2009-02-10 11:25:31
48 accurate current source and current sink?” Figures 1 and 2 respectively show the circuits for making precision current sources and sink
2009-06-01 11:13:38
57
The design adopts self-designed high accurate voltage source, Micro Control Unit
(MCU
2009-08-18 10:56:11
10 PRECISION ABSOLUTE VALUE CIRCUITS:You can build a precision absolute value circuit using two opamps
2009-09-08 00:36:43
5 (DAC) offering a pro-grammable current source and programmable voltage output designed to meet the requirements of industrial process contr
2009-09-18 09:55:53
22 Ultraprecise Current Sense Amplifi er Dramatically Enhances Effi ciency and Dynamic Range:Accurate
2009-09-23 22:55:42
8 at a supply voltageas low as 1.5 Volts. A class-AB output structure gives theLM94022 strong output source and sink current capabili
2009-10-20 14:23:26
11 The ADR121/ADR125/ADR127 are a family of micropower, high precision, series mode, band gap
2009-10-23 09:53:02
9 LinCMOSE PRECISION DUAL OPERATIONAL AMPLIFIERS
description (continued)In general, many features
2009-11-28 12:08:38
8 a programmable current source output designed to meet the requirements of industrial process control applications. The output current range is progr
2010-01-07 17:08:19
42 Z-Source Inverter for Power Conditioning and Utility Interface of Renewable Energy Sources
2010-02-21 17:07:35
15 This high power LED light source represents a viable alternative to halogen light sources.
2010-05-08 08:56:21
11 100µA currentsources and a current mirror. The sections aredielectrically isolated, making them completelyindependent.
2010-06-13 09:44:48
5 Slide 1A signal source produces sine waves. This is the most basic definition of a signal
2010-07-10 11:09:23
11 Noise Source CalibrationOne of the key performance parameters for noise figure is the level
2010-07-19 15:40:45
6 The Agilent E5052A signal source analyzer is designed to help R&D and manufacturing engineers
2010-07-25 10:43:33
16 The AS3691 features four high precision current sources for driving up to four LED strings (RGB
2010-09-06 09:34:09
37 The OPA121 is a precision monolithic dielectrically-isolated FET (Difet®) operational
2010-09-14 08:02:29
26 The OPA2107 dual operational amplifier provides precision Difet performance with the cost and space
2010-09-14 08:14:34
27 The LT1013 devices are dual precision operational amplifiers, featuring high gain, low supply
2010-09-15 22:42:17
15 The OPA177 precision bipolar op amp feature verylow offset voltage and drift. Laser-trimmed offset
2010-09-15 22:49:50
36 The LT1014D is a quad precision operational amplifier with 14-pin industry-standard configuration.
2010-09-17 03:48:03
19 The RCV420 is a precision current-loop receiver de-signed to convert a 4–20mA input signal
2010-09-25 23:53:17
65 The XTR110 is a precision voltage-to-current converter designed for analog signal transmission.
2010-09-26 00:15:50
31 The XTR111 is a precision voltage-to-current converter designed for the standard 0mA–20mA or 4mA
2010-09-26 00:20:33
80 The XTR117 is a precision current output converter designed to transmit analog 4-20mA signals over
2010-09-26 00:28:52
120 The uA723 is a precision integrated-circuit voltage regulator featuring high ripple rejection
2010-10-23 23:00:09
32 SO DIMM 72线内存条引脚定义
DIMM 是 Dual Inline Memory Module (双列直插)的缩写,SO 是 Small Outline 的缩写
引脚定义
2007-11-21 12:50:12
1423 Precision Instrumentation Amplifiers with Rejustors Solve High-Gain Applications
Abstract:
2008-12-20 15:01:48
1021 ![](https://file1.elecfans.com//web2/M00/A4/81/wKgZomUMNH6AP8ubAAAqV5cyggA124.jpg)
MAX9610 Tiny Current-Sense Amplifier Delivers Precision Monitoring and 1µA Supply Current
2009-01-22 16:32:02
1109 ![](https://file1.elecfans.com//web2/M00/A4/8B/wKgZomUMNKyAZ7TqAAA3WJGJ3Y0895.jpg)
switch-mode current source that is useful for battery charging. The voltage control loop is disabled so that the current control loop provides regula
2009-04-30 11:06:53
1315 ![](https://file1.elecfans.com//web2/M00/A4/D4/wKgZomUMNd-AXU6hAAAUyJEdlGg287.gif)
精密电流源:Precision Current SourceThe precision current source is shown in Figures 17, 18.
2009-05-16 16:08:04
5293 ![](https://file1.elecfans.com//web2/M00/A4/E9/wKgZomUMNi6ARLGJAAA9AD14l9M758.jpg)
, and a separate control voltage, this adjustable current source provides a 1-to-1 ratio of control voltage to load current (1A/V). A similar ver
2010-08-07 22:03:30
1130 ![](https://file1.elecfans.com//web2/M00/A5/AA/wKgZomUMOYGADR0iAAAYgiChklw371.gif)
Precision constant-current sink provides wide, close-to-the-rail compliance
Abstract
2010-08-21 21:10:27
1482 ![](https://file1.elecfans.com//web2/M00/A5/AE/wKgZomUMOZSADBxzAAAd9QR37QA347.gif)
Based on a precision op amp (MAX4236), this loop-powered, high-compliance, precision current sink
2011-02-01 11:42:45
1833 ![](https://file1.elecfans.com//web2/M00/A5/D9/wKgZomUMOmmAemRKAAALRH4Nnl0135.gif)
The MAX4372 low-cost, precision, high-side current-sense amplifier is available in a tiny
2011-09-19 11:22:09
42 (TOSHIBA)东芝光耦:SO6封装(包装),Specification of SO6 package
2012-03-16 15:18:48
4379 ![](https://file1.elecfans.com//web2/M00/A6/27/wKgZomUMO_6ALr2_AAAK5pDEF_E617.jpg)
(TOSHIBA)东芝光耦:SO8 封装(包装)Specification of SO8 package
2012-03-16 15:23:21
5634 ![](https://file1.elecfans.com//web2/M00/A6/27/wKgZomUMO_6AEFH4AAALgSkJqkY658.jpg)
电子发烧友网站提供《Source Insight 3.5 编辑器.exe》资料免费下载
2013-12-09 00:36:18
6 Common Source JFET Amplifier电路板设计实例
2016-01-11 17:29:08
0 Source_Insight教程及技巧(大全)——最终整合版
2016-01-18 15:08:19
0 Source_Insight使用教程,好东西,喜欢的朋友可以下载来学习。
2016-01-18 15:08:45
19 a programmable current source output designed to meet the requirements of industrial process control applications.
2017-10-12 16:36:57
24 (DAC) offering a programmable current source and programmable voltage output designed to meet the requirements of industrial process control applications.
2017-10-12 16:40:27
14 (Source_Insight教程及技巧(大全)——最终整合版
2017-10-19 09:18:04
0 Source_Insight3.5+注册码
2017-10-23 08:48:03
23 So, You Wanna Be an Embedded Engineer
2017-10-25 14:14:16
6 JNI Java调用so包相关问题总结,出现了很多问题,按照操作应该不会发生不到so包的错误,其实最后出现的也是说加载不到libpython2.7.x.so.1,我就纳闷了,怎么和python扯上
2017-11-28 13:13:14
3227 细说恒流源,detail of constant current source
关键字:细说恒流源
恒流源是电路中广泛使用的一个组件
2018-09-20 18:52:10
1072 3.9版本支持SO_REUSEPORT,作为Server的TCP Socket一旦绑定到了具体的端口,启动了LISTEN,即使它之前设置过SO_REUSEADDR, 也不会生效。这一点Linux比BSD更加严格
2020-12-11 16:38:13
3541 ![](https://file.elecfans.com/web1/M00/D3/F1/pIYBAF_TMHaAVWHtAAAQviUBbsk664.png)
LTC2672: Five-Channel, Low Dropout, 300 mA, Current Source Output, 16-Bit SoftSpan DAC Data Sheet
2021-01-27 23:00:27
0 ADA4177-2CHIPS: OVP and EMI Protected, Precision, Low Noise and Low Bias Current Op Amp Data Sheet
2021-01-28 12:52:20
4 ADR441ACHIPS: Ultralow Noise, LDO, XFET, Voltage Reference with Current Sink and Source Data Sheet
2021-01-29 11:16:16
8 ADICUP3029 Source Code Example
2021-01-29 13:53:26
0 ADI Precision Studio
2021-01-31 12:27:18
10 LTC2066/LT1389 Demo Circuit - Precision Ultralow Power High Side Current Sense
2021-02-01 14:38:28
1 LT3092: 200mA 2-Terminal Programmable Current Source Data Sheet
2021-02-20 13:07:23
2 AD9164 API - Download Source Code Package
2021-03-10 12:29:33
12 AD916x API - Download Source Code Package
2021-03-10 12:59:35
6 DC1996 CPLD Source Code
2021-03-10 15:25:44
0 DC2071A CPLD Source Code
2021-03-11 09:40:11
0 DC1908A CPLD Source Code
2021-03-11 09:44:11
1 DC2289A CPLD Source Code
2021-03-11 09:48:12
6 LT3066 Demo Circuit - 3.3V Supply with 497mA Precision Current Limit (3.6-45V to 3.3V @ 450mA)
2021-03-11 11:02:19
4 Precision DAC产品选择指南
2021-04-25 16:07:46
8 LT1880:SOT-23,Rail-to-Rail Output,PioAmp Input Current Precision Op Amp数据表
2021-04-26 16:00:02
6 电子发烧友网为你提供TE(ti)CAT-D3301-SO1339相关产品参数、数据手册,更有CAT-D3301-SO1339的引脚图、接线图、封装手册、中文资料、英文资料,CAT-D3301-SO1339真值表,CAT-D3301-SO1339管脚等资料,希望可以帮助到广大的电子工程师们。
2021-07-16 05:00:02
电子发烧友网为你提供TE(ti)CAT-D33047-SO1339相关产品参数、数据手册,更有CAT-D33047-SO1339的引脚图、接线图、封装手册、中文资料、英文资料,CAT-D33047-SO1339真值表,CAT-D33047-SO1339管脚等资料,希望可以帮助到广大的电子工程师们。
2021-07-15 13:00:03
电子发烧友网为你提供TE(ti)CAT-D3304-SO1399相关产品参数、数据手册,更有CAT-D3304-SO1399的引脚图、接线图、封装手册、中文资料、英文资料,CAT-D3304-SO1399真值表,CAT-D3304-SO1399管脚等资料,希望可以帮助到广大的电子工程师们。
2021-07-15 14:00:03
电子发烧友网为你提供TE(ti)CAT-D3303-SO1399相关产品参数、数据手册,更有CAT-D3303-SO1399的引脚图、接线图、封装手册、中文资料、英文资料,CAT-D3303-SO1399真值表,CAT-D3303-SO1399管脚等资料,希望可以帮助到广大的电子工程师们。
2021-07-15 15:00:03
电子发烧友网为你提供TE(ti)CAT-H744-SO1399相关产品参数、数据手册,更有CAT-H744-SO1399的引脚图、接线图、封装手册、中文资料、英文资料,CAT-H744-SO1399真值表,CAT-H744-SO1399管脚等资料,希望可以帮助到广大的电子工程师们。
2021-08-02 16:00:04
电子发烧友网为你提供TE(ti)CAT-D33037-SO1339相关产品参数、数据手册,更有CAT-D33037-SO1339的引脚图、接线图、封装手册、中文资料、英文资料,CAT-D33037-SO1339真值表,CAT-D33037-SO1339管脚等资料,希望可以帮助到广大的电子工程师们。
2021-08-04 13:00:02
2022-01-10 15:17:38
3 热增强 SO8-FL 指南
2022-11-14 21:08:05
1 电子发烧友网为你提供ADI(ADI)ADR3625/ADR3630/ADR3650: Precision, Micropower, High Current Output Voltage
2023-10-12 18:46:26
![](https://www.elecfans.com/uploads/190218/2927106-1Z21P94211255.png)
电子发烧友网为你提供ADI(ADI)MAX44284: 36V, Input Common-Mode, High-Precision, Low-Power Current
2023-10-13 18:35:03
电子发烧友网为你提供ADI(ADI)MAX40080: Precision, Fast Sample-Rate, Digital Current-Sense Amplifier Data Sheet
2023-10-16 18:38:32
电子发烧友网为你提供ADI(ADI)MAX49921: 0 to 70V, High-Precision Current-Sense Amplifier Data Sheet相关产品参数、数据手册
2023-10-16 18:57:04
电子发烧友网为你提供ADI(ADI)MAX9634: nanoPower, 4-Bump UCSP/SOT23, Precision Current-Sense Amplifier Data
2023-10-16 19:17:55
在Linux中,source命令通常用于重新执行刚修改的初始化文件,使之立即生效,而不必注销并重新登录。source命令可以用于读取并执行脚本文件中的命令,通常用于在当前shell环境中重新加载
2023-11-08 14:35:46
588
