Silicon Laboratories 今日宣布针对VoIP网关推出业内最高集成度、最具成本和节能效益的用户线接口电路(SLIC)解决方案。
2011-07-22 09:05:41
2472 voltage isolation 12 V to 12 V converter attwo and a half watts. This provides a low wattage isolated 12
2018-09-20 08:59:03
balanceFully isolated transfer to external 12V supply/battery1-Mb/s stackable isolated differential-UART
2018-11-26 11:51:51
200W PC ATX Power Supply电路图
2009-11-21 10:36:26
描述The PMP5726 is 350W High Speed Full Bridge Phase Shift ZVT – Galvanic Isolated Full Bridge
2018-07-13 00:48:46
SLIC,DTMF信号产生电路原理图
2008-10-13 13:58:29
Rubber End Seal For SLiC™ 2" Closures
2023-03-22 23:08:41
Rubber End Seal For SLiC™ 3" Closures and Terminals
2023-03-22 23:08:42
ADDS SHEATH RETENTION TO 3" SLIC
2023-03-22 23:08:48
ADDS SHEATH RETENTION TO 5" SLIC
2023-03-22 23:08:48
SLIC的模拟接口是通常的两线电话线,而且线路基本都会出现在室外,同时由于SLIC本身的一些特性,对外界的干扰比较敏感,因此对SLIC芯片进行相应的保护是必不可少的。1、TIP,RING即为电话线
2018-11-09 17:21:03
ATX Switching power supply 开关电源电路 [hide] [/hide]
2009-12-20 13:40:38
supply for a multi?sync colormonitor. In order to minimize the screen interference fromthe
2009-03-27 15:56:42
Design Engineers are constantly pushed to reduce thespace and cost of the power supply
2009-05-12 11:01:35
从官网下载的LTpowerCAD解压完整安装setup,软件版本2.7.1,即使是sync/release也是无法解决报错问题,只有system design功能能正常使用外,supply
2024-01-04 08:10:03
MSAN-151 MH88615 SLIC的实施细节。 MH88615是用户线接口电路(SLIC),它提供电话和编解码器之间的接口。 MH88615提供的功能包括2-4线转换,恒流线路馈电,板载振铃放大器,断电,信号和控制。提供不同的变体以满足不同的线路阻抗
2020-05-29 17:13:16
an isolated 57V/40W output from a universal AC input source. This supply is designed for use as a PoE power
2018-07-13 09:46:56
描述The PMP7022 is 1mW (3.1V at 300uA) galvanic isolated DC/DC reference design built to supply a
2018-07-13 05:43:00
`Power Supply and Ground Design for a WiFi Transceiver无线接收器的电源和接地设计虽然是英文资料,但是很精典哦。`
2011-01-28 17:39:28
SWITCH POWER SUPPLY DESIGN
2012-08-16 11:53:46
要减小switching power supply待机损耗,提高待机效率,首先要分析SMPS损耗的构成。根据损耗分析可知,切断启动电阻,降低开关频率,减小开关次数可减小待机损耗
2009-04-20 23:40:59
Optically isolated gate drivers, that supply low level signalvoltages to drive power switches
2009-05-12 11:02:59
Transformerless Power Supply 设计电路图
2008-10-13 12:22:46
power_supply框架包括哪些功能?power_supply框架工作流程是怎样的?如何在power_supply框架下去添加充电IC驱动?
2021-07-28 06:02:56
switching power supply 开关频率选择现在通常在switching power supply(SMPS)设计中用到了“软开关”,和/或,“低功耗/无损缓冲器“。现在,对于一个
2009-04-08 00:43:43
描述This power supply reference design converts an input voltage of 8.5 - 10.5V to an isolated output
2018-09-18 08:41:09
`描述及特性This reference design creates a 5V at 200mA from a 120VAC Input. This supply is to designed
2015-04-14 10:14:06
supply for half-bridge converters. A DCM Flyback with UCC3813-4 controller is used to generate two
2018-12-26 15:35:56
design with the LM5160 regulator provides a simple and compact solution for isolated power supply.主要特色
2018-08-24 10:33:31
using external shunts, reinforced isolation amplifiers, and isolated power supply. The shunt voltage
2018-12-04 14:36:38
描述TIDA-00940 is a 3-W, non-isolated bias power supply with up to 80% efficiency and excellent EMI
2018-12-24 16:00:53
side driver and backplane powered using isolated power stage. High speed digital output modules
2018-09-25 09:05:49
描述The PMP30082 reference design shows two stage power supply. The first stage is a fly-buck
2018-12-24 15:56:53
各位前辈:在选择一款陀螺仪,有如下两个指标:Analog supply voltage 5VDigital supply voltage 3.3V因为根据使用条件,只能提供3.3v的电压,不知道是不是能用所以想请问大家这两个电压分别代表什么意思?多谢!!!!
2017-06-05 17:05:12
端引线连接到了Cell4端,这是按照说明来的。现在的问题是假如连接的是电池,不是模拟的电池,Battery supply还用不用接到板子上,我曾经试图把Battery supply接到板子上,然后,按
2019-06-04 08:00:51
芯片的supply voltage是VDD-VSS还是只是VDD?恳求大佬们回答一下
2019-04-16 08:43:01
描述This reference design creates a non-isolated 5.5V at 250mA from a 230VAC Input.This supply
2018-11-29 15:36:46
描述Isolated power supply is important for analog components like analog to digital converters (ADC
2018-12-04 11:35:09
2015-05-07 15:27:23
DN282减少元件数量并提高SLIC和RF电源的效率
2019-07-15 17:12:20
Whenever high voltage could damage the end equipment there is need for isolation. This isolated CAN
2018-10-22 10:22:43
描述A quasi-resonant non-isolated Flyback supplies 15V @ 400mA from universal input voltage (90Vac
2018-12-03 16:37:27
使用高压电机控制PFC套件时不注意烧了isolated XDS100 电路中ISO7220芯片两个地(GND1和GND2)之间的隔离电容C17我想换一个电容,可否告知C17容值大小。测了一下,这个电容貌似是用做AGND与GND之间的隔离
2018-10-18 14:47:09
The LT®3573 is a monolithic switching regulator specifi -cally designed for the isolated fl
2009-01-13 16:28:51
26 The MAX845 provides an isolated power supply small enough to fit in thin PCMCIA cards
2009-02-07 21:53:06
14 本文主要介绍的是用成品变压器配以控制电路可为SLIC应用提供电源 。
2009-04-29 10:27:59
26 SMART Transmitter Power Supply KFD2-STV5-Ex1-11-channel isolated barrier24 V DC supply (Power Rail
2022-11-08 13:09:35
2W Non-isolated Power Supply using LNK305P:This document is a prototype engineering report
2009-06-28 22:38:01
29 48W 2 Output Power Supply using TOP246Y:This document is an engineering report describing
2009-07-01 00:20:35
32 1.8W non-isolated Power Supply using LNK304:This document is an engineering report describing a 12V
2009-07-01 00:21:07
29 This document is an engineering prototype report describing a non-isolated -12 V, 250mApower supply
2009-07-01 00:22:05
22 20W Dual Output Power Supply using TOP247Y:This document is an engineering prototype report
2009-07-01 00:22:47
20 LM5015 Isolated Two Switch Forward Regulator Quick Start Component Calculator
Note:
2009-09-08 18:57:46
16 , iCoupler® technology to provide an isolated high-side driver with an integrated 275 mW high-side supply. This supply, provided by an internal i
2009-09-24 16:58:45
10
Power Supply Management—Principles, Problems, and Parts:INTRODUCTION
Power supply
2009-09-25 08:18:54
26 Reference Design:Isolated 50 Watt Flyback Converter Using the UCC3809 Primary Side Controller
2009-10-14 09:35:32
19 While the junction-to-case thermalresistance is higher than an equivalent,non-isolated device, what
2009-10-17 09:07:54
9 High Voltage Isolated/Non-Isolated Power Supply Reference Designs:
2009-11-28 16:39:49
5 atx switching power supply:
2009-12-24 11:51:00
54 This document is an engineering report describing a prototype 2 output universal inputpower supply
2010-01-07 09:22:11
18 The AMC1203 is a 1-bit, 10MHz, isolated delta-sigma () modulator with an output buffer separated fro
2010-06-01 11:02:33
34 its typical application in isolated gate drive supply. The cascode connection extends the input volt
2010-07-08 16:28:15
254 its typical application in isolated gate drive supply. The cascode connection extends the input volt
2010-07-17 09:43:56
0 The ISO1050 is a galvanically isolated CAN transceiver that meets or exceeds the specifications
2010-08-25 17:05:53
80
The MAX256 is an integrated primary-side controller and H-bridge driver for isolated
2011-01-02 13:32:34
125
SLIC,DTM
2008-10-13 13:57:28
1397 ![](https://file1.elecfans.com//web2/M00/A4/6A/wKgZomUMNBuAI2GRAAFKOUKoJA0415.jpg)
Power Supply and Accurate Current Monitor for Avalanche Photodiode (APD) Biasing Applications
2009-04-02 08:38:34
1169 yields a single-channel, isolated digital-signal coupler. Optocouplers are the usual choice for coupling digital signals be
2009-04-29 09:25:46
657 ![](https://file1.elecfans.com//web2/M00/A4/D3/wKgZomUMNdqAWUTlAABEL-Ru5tk177.gif)
Such systems use subscriber-line interface card (SLIC) functions to maintain compatibility with legacy equipment. The voltages required in these system
2009-05-04 09:53:43
2203 ![](https://file1.elecfans.com//web2/M00/A4/D7/wKgZomUMNeiAS4muAAAnbruwojg433.gif)
Abstract: Dual output subscriber line-interface cards (SLIC) flyback power supply using feedback
2009-05-04 10:28:16
1005 ![](https://file1.elecfans.com//web2/M00/A4/D7/wKgZomUMNeiABIJUAAAgfc15Vs8436.gif)
Abstract: This application notes describes a compact isolated switch-mode power supply
2009-05-07 10:08:54
1184 ![](https://file1.elecfans.com//web2/M00/A4/DB/wKgZomUMNfuAGxqcAAAZTufoOMA238.gif)
W-CDMA Power Supply Dramatically Improves Transmit Efficiency
Abstract: The MAX1820 switch-mode
2009-07-22 12:53:25
660 50W Isolated Power Supply
Figure 1 shows a 50W "off-the-shelf-designed" power supply
2009-08-13 12:01:07
2865 ![](https://file1.elecfans.com//web2/M00/A5/38/wKgZomUMN3aATCEMAAAomGLna9g842.gif)
Isolated Temperature Sensor
Abstract: This application note presents a novel circuit
2009-09-18 08:37:08
906 ![](https://file1.elecfans.com//web2/M00/A5/44/wKgZomUMN6mAEvbhAABmP23mmko847.gif)
ADP1043A.Digital Controller for Isolated Power Supply Applications
The ADP1043A is a secondary
2009-10-31 11:09:45
954 SLIC保护方案及电路
2009-11-20 08:46:38
3859 ![](https://file1.elecfans.com//web2/M00/A5/5E/wKgZomUMOByAIECqAAA-tLsmZrg481.jpg)
SLIC、DTMF检测和信号音产生电路:由STL3055芯片组成。
2010-01-11 08:50:17
1379 ![](https://file1.elecfans.com//web2/M00/A5/6F/wKgZomUMOGyAXDcEAAFGQoWQnXU356.jpg)
Nuvoton发布高效CODEC/SLIC产品-N681386, N681387增强架构以及音频质量
新唐科技发布高效CODEC/SLIC产品 – N681386, N681387 增强的架构整合了低功耗、优化的温
2010-09-30 11:41:31
1976 An integrated H-bridge driver for isolated power-supply circuits (MAX256) usually drives
2011-01-02 13:30:55
988 ![](https://file1.elecfans.com//web2/M00/A5/D2/wKgZomUMOkaAeYZ3AABSuKtfZ0c763.gif)
BP5843A ISOLATED High-power LED Driver for IIIunination
2011-05-04 10:06:19
29 input, 12V (15V) output, isolated power supply. The Riverside reference design includes a 3W primary-side transformer H-bridge driver for isolate
2012-11-07 15:36:31
26 , 12V (15V) output, isolated power supply. The Lakewood reference design includes a 3W primary-side transformer H-bridge driver for isolated s
2012-11-07 15:38:20
27 Power Supply电路设计,喜欢的朋友可以下载来学习。
2016-01-11 17:54:31
0 Programmable Six Supply Sequencer and Supervisor,有需要的朋友下来看看。
2016-06-02 17:09:58
5 MAX774 用变压器控制电路为SLIC应用提供电源
2016-08-18 18:28:55
0 近年来,超像素算法被应用到计算机视觉的各个领域。超像素捕获图像冗余信息,降低图像后续处理的复杂度。超像素分割作为图像的预处理过程需要满足图像处理的实时性和准确性。在SLIC算法的框架下,所提算法
2017-11-22 16:34:45
3 This reference design provides isolated positive and negative voltage rails for Insulated
2020-11-02 08:00:00
0 程控交换机的模拟用户线接口电路,简称用户接口电路,英文SLIC,指的是交换机到用户机之间的接口电路。SLIC的模拟接口是通常的两线电话线,而且线路基本都在室外,同时由于SLICJ本身的特性,其对外
2020-12-02 12:10:47
2429 UG-1932: Evaluating the ADuM4146 Single-/Dual-Supply, High Voltage, Isolated SiC Gate Driver with Miller Clamp
2021-01-27 22:26:25
8 ADuM4146: Single-/Dual-Supply, High Voltage, Isolated SiC Gate Driver with Miller Clamp Data Sheet
2021-01-27 22:28:25
10 AD5751: Industrial I/V Output Driver, Single-Supply, 55 V Maximum Supply, Programmable Ranges Data Sheet
2021-01-28 15:23:30
1 ADM3050E: 5.7 kV rms, Signal Isolated, Basic CAN FD Transceiver Data Sheet
2021-02-03 11:10:14
6 CN0349: Fully Isolated Conductivity Measurement Data Acquisition System
2021-02-19 10:50:13
1 DC161A LT1373HV | SLIC电源, –20V (60mA)和 –60V (35mA)+
2021-05-31 20:19:15
1 用户线路接口电路 (SLIC) 为“普通旧电话服务”(POTS) 提供直流电源、振铃和监控功能,其中警报电话是先决条件,但通常没有中央振铃器。SLIC还用于终端适配器(TA),互联网协议语音
2023-03-10 11:31:56
594 ![](https://file.elecfans.com/web2/M00/96/F2/poYBAGQKrRqAW17_AABk_Yb3sBw584.png)
对于某些用户线路接口卡(SLIC),线路和振铃器电压应在所有条件下进行调节。图1所示电路满足这一要求。它接受 12V ±10% 输入,并从稳定的 -0V ±400% 输出提供 24mA 至 5mA
2023-06-25 18:08:50
438 ![](https://file1.elecfans.com/web2/M00/8B/65/wKgZomSYElKAfOmSAABieNP66qE437.png)
本应用笔记给出了一个为SLIC产生三个隔离电压的电源。隔离电源采用升压控制器MAX668,带有反激式变压器,输出为-24V和-72V,并用光耦合器隔离反馈信号。线性稳压器MAX8867提供3.3V输出。
2023-06-26 09:24:15
458 ![](https://file1.elecfans.com//web2/M00/8B/68/wKgZomSY6L6ACs-oAABHUHGhunI531.gif)
