SLIC,DTMF信号产生电路原理图
2008-10-13 13:58:29
SLIC的模拟接口是通常的两线电话线,而且线路基本都会出现在室外,同时由于SLIC本身的一些特性,对外界的干扰比较敏感,因此对SLIC芯片进行相应的保护是必不可少的。1、TIP,RING即为电话线
2018-11-09 17:21:03
MSAN-151 MH88615 SLIC的实施细节。 MH88615是用户线接口电路(SLIC),它提供电话和编解码器之间的接口。 MH88615提供的功能包括2-4线转换,恒流线路馈电,板载振铃放大器,断电,信号和控制。提供不同的变体以满足不同的线路阻抗
2020-05-29 17:13:16
Dual-Slew-Rate Cable Driver16 pin QFNGS2989-INE3Multi-Rate Dual-Output Dual-Slew-Rate Cable Driver16 pin
2014-12-06 12:09:56
120VAC input. A dual-output flyback converter with UCC28700 primary-side regulation controller
2018-07-13 08:36:20
anIsolated dual-output of 5 volts and negative 5 volts at 0.25 Amps.
2018-09-06 09:17:06
these galvanometers. Again, the customer will have to keep in mind that this is a dual-output supply so
2022-03-25 11:06:18
/30mA and 5V/30mA dual-output from an ultra-wide 24V to 264V (AC or DC) input. The board is in a
2018-09-30 09:27:48
The MAX1856 offers a low-cost solution for generating a SLIC (ringer and off-hook) power supply
2008-07-25 00:30:59
16 The RT9005A/B is a dual-output Linear regulator for DDR-SDRAM VDDQ supply and termination voltage VTT supply.
2008-07-30 11:50:01
49 General DescriptionThe TC1025 is a dual low-power comparator with atypical supply current
2008-08-07 12:35:34
15 The MAX5098A is a dual-output, high-switching-frequencyDC-DC converter with integrated n-channel
2008-08-13 14:20:43
14 range of 4.75V to 5.5V or 5V to 28V. A mode select input allows for a dual-output supply or connecting two phases together for a single-output
2008-08-18 12:54:13
20 The MAX15022 is a dual-output, pulse-width-modulated(PWM), step-down DC-DC regulator with dual LDO
2008-09-15 01:28:45
25 The LX1752 is a dual output synchronous buck controller using voltage mode PWM architecture.The
2008-10-31 07:42:07
12 The RT9205/A is a dual-output power controllers designedfor high performance graphics cards
2008-12-13 01:44:48
11 General DescriptionThe RT9203/A is a dual-output power controllers designedfor high performance
2008-12-13 01:50:16
15 The MAX1817 is a compact, high-efficiency, dual-output step-up converter for portable devices
2009-01-11 11:00:11
12 The MAX8614A/MAX8614B dual-output step-up DC-DCconverters generate both a positive and negative
2009-01-11 11:18:37
18 The TC4423A/TC4424A/TC4425A devices are a familyof dual-output 3A buffers/MOSFET drivers.
2009-01-19 14:17:26
26 The DS4625 is a dual-output, low-jitter clock oscillator capable of producing frequency output pair
2009-03-31 11:03:02
14
1000Vdc Single & Dual Output 1 Watt Dc-Dc Converter
FEATURES:
●7PIN SIP Package
2009-06-21 11:34:38
19 1.6W Dual Output Flyback Converter using LNK304P:This document is an engineering prototype report
2009-06-28 22:38:40
17 output voltages without the needfor a transformer. Typical applications include metering power supplies,where a 3.3 V supply is r
2009-06-28 22:40:24
13 48W 2 Output Power Supply using TOP246Y:This document is an engineering report describing
2009-07-01 00:20:35
32 20W Dual Output Power Supply using TOP247Y:This document is an engineering prototype report
2009-07-01 00:22:47
20 the input stage to be operated from ±5 V dual supplies or a 5 V single supply while maintaining a CMOS-/TTL-compatible output.Fast 7 ns propag
2009-08-24 15:20:03
24 gains of +2 or greater andhigh output drive capability, such as cable driving. Due to itslow power and single-supply functionality,
2009-08-31 08:43:50
40 The AD5337/AD5338/AD5339 are dual 8-, 10-, and 12-bit buffered voltage output DACs, respectively.
2009-09-16 11:40:33
14 The LP2966 dual ultra low-dropout (LDO) regulator operatesfrom a +2.70V to +7.0V input supply. Each
2009-10-06 09:11:43
11 of the power supply rails. Itfeatures the high output drive with low distortion required forthe demanding application of a single supply x
2009-10-07 09:47:07
11 The LMH6618 (single, with shutdown) and LMH6619 (dual)are 130 MHz rail-to-rail input and output
2009-10-07 10:49:56
16 The LM26LV is a low-voltage, precision, dual-output, lowpowertemperature switch and temperature
2009-10-20 14:49:01
6 This reference design is a 12-V/5-A and 50-V/1-A isolated dual-output auxiliary power supply
2009-11-04 11:28:34
0 The RT9205/A is a dual-output power controllers designedfor high performance graphics cards
2009-11-20 09:50:05
15 This reference design is a 12-V/5-A and 50-V/1-A isolated dual-output auxiliary power supply
2009-12-08 19:03:18
31 This document is an engineering report describing a prototype 2 output universal inputpower supply
2010-01-07 09:22:11
18 The 34710 is a dual-output power regulator IC integratingswitching regulator, linear regulator
2010-01-12 21:26:35
17 The DAC7822 is a dual, CMOS, 12-bit, current output digital-to-analog converter (DAC). This device
2010-06-08 10:48:37
6 a single 2.7V to 5.5V supply.
The applied external reference input voltage VREF determines the full-scale output current. An
2010-06-09 09:36:05
5 The DAC8802 is a dual, 14-bit, current-output digital-to-analogconverter (DAC) designed to operate
2010-06-09 09:40:05
26 a single 2.7V to 5.5V supply.
2010-06-09 10:19:00
16 The DAC8812 is a dual, 16-bit, current-output digital-to-analog converter (DAC) designed to operate
2010-06-09 10:30:54
38 The SN65ELT22 is a dual TTL-to-differential PECL translator. It operates on +5-V supply and ground
2010-08-28 17:16:20
18 The SN65ELT22 is a dual LVTTL to differential LVPECL translator buffer. It operates on +3V supply
2010-08-28 17:39:37
30 The SN75123 is a dual line driver specifically designed to meet the input/output interface
2010-08-28 22:58:53
5 The TL3414A device is a dual operational amplifier that can be operated with single or dual power
2010-09-18 03:51:29
71 The TLV7256 is a CMOS-type general-purpose dual comparator capable of single power-supply operation
2010-09-23 21:34:48
6 The TPS65130/1 is dual-output dc-dc converter generating a positive output voltage up to 15
2010-10-02 19:36:47
90 TPS54283 and TPS54286 are dual output non-synchronous buck converters capable of supporting 2-A
2010-10-02 21:46:04
26 The TPS54383 and TPS54386 are dual output, non-synchronous buck converters capable of supporting
2010-10-03 20:58:39
38 The TPS55383 and TPS55386 are dual output, non-synchronous buck converters capable of supporting
2010-10-03 22:36:18
17 power supply solutions. It provides 5-V and 3.3-V LDOs and requires few external components. The 270-kHz VCLK output can be used to drive a
2010-10-05 22:42:40
70 , processor power, ASIC, FPGA, and digital applications where dual output voltage regulators are required. Easy programmability of the seq
2010-10-21 21:22:26
25 voltages and dual outputs in a compact package and incorporating stability with 10µF low ESR output capacitors.
The TPS767D3xx fam
2010-10-22 22:00:22
14 voltages and dual outputs in a compact package and incorporating stability with 10µF low ESR output capacitors.
The TPS767D3xx fam
2010-10-22 22:14:44
50 The PTB4850x power modules are a dual-output isolated DC/DC converter, designed to provide
2010-11-12 14:37:24
8 The PTB4850x power modules are a dual-output isolated DC/DC converter, designed to provide
2010-11-12 14:44:54
10 The PTB4850x power modules are a dual-output isolated DC/DC converter, designed to provide
2010-11-12 14:46:38
13 The PT6940 Excalibur™ power modules are a series of high-efficiency dual-output regulators
2010-11-16 21:41:00
6 The PT6940 Excalibur™ power modules are a series of high-efficiency dual-output regulators
2010-11-16 21:44:13
2010-11-16 22:44:17
10 The PT6940 Excalibur™ power modules are a series of high-efficiency dual-output regulators
2010-11-16 22:52:13
17 The PT6930 Excalibur™ series of 8-A dual-output ISRs are designed to power DSP ICs. Both
2010-11-18 11:01:22
5 The PT6930 Excalibur™ series of 8-A dual-output ISRs are designed to power DSP ICs. Both
2010-11-18 11:02:39
10 The PT6930 Excalibur™ series of 8-A dual-output ISRs are designed to power DSP ICs. Both
2010-11-18 11:04:11
6
SLIC,DTM
2008-10-13 13:57:28
1397
Dual, Voltage-Output DAC Consumes Miniscule Power
The dual, voltage-output DACs shown
2008-11-24 10:19:58
882
MAX15034 Dual-Output, Synchronous Step-Down Controller Provides Two 25A Outputs or a Single 50A
2009-01-11 11:38:24
844
MAX15023 Dual-Output, Synchronous DC-DC Controller with Wide Operating Range Delivers Up to 25A
2009-01-28 15:00:30
954 Abstract: Theory of operation and description of the DS1077 dual-output all-silicon EconOscillator.
2009-04-22 11:16:53
910
Some subscriber line interface cards (SLICs) require power-supply voltages isolated from the local
2009-05-04 09:32:48
949
Such systems use subscriber-line interface card (SLIC) functions to maintain compatibility with legacy equipment. The voltages required in these system
2009-05-04 09:53:43
2203
SLIC保护方案及电路
2009-11-20 08:46:38
3859
/A is a dual-output power controllers designed for high performance graphics cards and personal comput
2009-11-20 09:30:32
1549
The MAX17116 includes two current-mode 1.4MHz switch mode power-supply (SMPS) regulators
2011-04-10 11:38:32
27 The MAX15021 is a dual-output, pulse-width-modulated(PWM), step-down DC-DC regulator with tracking
2012-10-08 17:09:38
27 Dual Polarity Power Supply电路板设计实例
2016-01-11 17:39:15
0 PCB绘图案例【Circuit Simulation】. Dual Polarity Power Supply
2016-02-16 11:54:45
0 This 8 watt, dual output (+/- 12 volts), off-line power supply is designed around a flyback
2016-06-08 18:28:02
5 120VAC input. A dual-output flyback converter with UCC28700 primary-side regulation controller is used t
2017-12-12 13:45:58
0 120VAC input. A dual-output flyback converter with UCC28700 primary-side regulation controller is used t
2017-12-12 13:52:59
2 MAX1677 dc-dc直流升压变换器,MAX1677 Dual-Output Step-Up and LCD Bias DC-DC Converter
关键字
2018-09-20 20:29:19
790 程控交换机的模拟用户线接口电路,简称用户接口电路,英文SLIC,指的是交换机到用户机之间的接口电路。SLIC的模拟接口是通常的两线电话线,而且线路基本都在室外,同时由于SLICJ本身的特性,其对外
2020-12-02 12:10:47
2429 LTspice AD5679R-LTC3307B Power supply output margining
2021-01-27 22:14:25
1 UG-1932: Evaluating the ADuM4146 Single-/Dual-Supply, High Voltage, Isolated SiC Gate Driver with Miller Clamp
2021-01-27 22:26:25
8 ADuM4146: Single-/Dual-Supply, High Voltage, Isolated SiC Gate Driver with Miller Clamp Data Sheet
2021-01-27 22:28:25
10 ADRF6521: LF to 3 GHz Dual VGA with Output Common-Mode & DC Offset Control Datasheet
2021-01-28 11:30:15
11 LTC3886/LTC3886-1: 60V Dual Output Step-Down Controller with Digital Power System Management Data Sheet
2021-01-28 11:51:16
0 LT3072: Dual, Low Noise, 2.5A Programmable Output, 80mV Low Dropout Linear Regulator Datasheet
2021-01-28 14:18:25
1 AD5751: Industrial I/V Output Driver, Single-Supply, 55 V Maximum Supply, Programmable Ranges Data Sheet
2021-01-28 15:23:30
1 AD9644: 14-Bit, 80 MSPS/155 MSPS, 1.8 V Dual Serial Output Analog-to-Digital Converter (ADC) Data Sheet
2021-01-28 15:40:31
0 LTM4650A-1 Project - Dual Output, High Current Buck μModule Regulator (4.5-16V to 1.5V & 3.3 @ 25A)
2021-02-04 10:31:11
0 LTM4650A Project - Dual Output, High Current Buck μModule Regulator (4.5-16V to 1.5V & 3.3 @ 25A)
2021-02-04 10:33:11
0 LTC3884 Project - High Efficiency, Dual Output Buck Converter with Ultra-Low DCR Current Sensing and PMBus (4.5-14V to Dual 1V @ 30A)
2021-02-04 11:45:15
1 LTC3860 Project - Dual, 2-Phase Step-Down Voltage Mode Supply (6-14V to 1.5V @ 50A)
2021-02-22 12:58:24
1 电子发烧友网为你提供ADI(ADI)MAX77720: Wide Output-Voltage Range, Dual- Polarity PMIC Data Sheet相关产品参数、数据手册,更有
2023-10-12 18:40:53
电子发烧友网为你提供ADI(ADI)MAX16712: Dual-Output, 6A, 2MHz, 2.7V to 16V Step-Down Switching Regulator Data
2023-10-13 18:43:21
电子发烧友网为你提供ADI(ADI)MAX20754: Dual-Output, Configurable Multiphase Power-Supply Controller with PMBus
2023-10-16 18:59:04
电子发烧友网为你提供ADI(ADI)MAX17524EVKITE: Evaluation Kit for the MAX17524 Dual-Output
Voltage 3.3V and 5V
2023-10-17 19:02:54
正在加载...
